foo_playlist_tree_mod, Modified version of foo_playlist_tree
fbuser
post Jul 12 2008, 23:13
Here is a modified version of foo_playlist_tree which is compatible with fb2k 0.9.5.3 or later. Because cwbowron asked me to change the name of the component it is now called foo_playlist_tree_mod.
Download with scheme support: Attached File  foo_playlist_tree_mod_scheme.7z ( 665.12K ) Number of downloads: 9448
Download without scheme support: Attached File  foo_playlist_tree_mod_no_scheme.7z ( 136.06K ) Number of downloads: 2478
Because it uses the new search filter API introduced with fb2k 0.9.5.3, this version or later is required.
Changelog for version 3.0.6.3:
  • fixed a crash while shutting down foobar2000 without displaying the playlist tree first
This post has been edited by fbuser: Jan 9 2010, 16:02
Joelimite
post May 23 2009, 21:50
I have a quick question about formatting in foo_playlist_tree. I have multi-disc albums organized into separate folders (for example, The Beatles\The White Album\CD1). In addition, I tag each of the tracks of each disc by disc number. However, when I select the album in foo-playlist_tree, it doesn't treat the discs as separate. Instead, it lists the files like this:
01. First track on CD1
01. First track on CD2
02. Second track on CD1
02. Second track on CD2
and so on...
How can I create a conditional if/then statement that will list each disc of multi-disc albums separately? Thanks for any help offered. I'm terrible at scripting...
This post has been edited by Joelimite: May 23 2009, 21:51
- fbuser   foo_playlist_tree_mod   Jul 12 2008, 23:13
- - aliendesaster   Oh my god, great! Although I got used to fast...   Jul 12 2008, 23:57
- - smkk   ColumnsUI onry i guess since it doesnt seem work w...   Jul 13 2008, 01:52
|- - odyssey   QUOTE (smkk @ Jul 13 2008, 02:52) Columns...   Jul 13 2008, 15:23
- - topdownjimmy   Thank you! Playlist Tree is essential for my ...   Jul 13 2008, 19:45
- - Canar   Glad to see this component is back. I don't us...   Jul 13 2008, 21:54
- - shakey_snake   ...Nor do I, but I'm glad to see this componen...   Jul 13 2008, 22:34
- - bubbleguuum   I may use CUI again just for this...   Jul 14 2008, 00:03
- - aliendesaster   @fbuser Do you maintain this component from now on...   Jul 17 2008, 22:32
- - fbuser   I ported this component mainly for my own needs, b...   Jul 17 2008, 23:12
- - scars   Hi, nice Job, now i dont get an error while start...   Jul 27 2008, 10:02
- - Zetto   The one thing i missed most after switching to ...   Jul 28 2008, 07:29
- - HAL_   I'm using playlist tree in order to generate a...   Jul 28 2008, 18:33
- - fbuser   Look here. So you can use CODE@quote<@format...   Jul 28 2008, 23:01
- - Robbi   Hallo, Is it possible to have a query like this c...   Jul 30 2008, 18:29
- - hydrotemplar   the link isn't working for me... it's givi...   Aug 4 2008, 08:10
- - fbuser   It's fixed. Thanks for the report.   Aug 4 2008, 09:20
- - Don Reba   QUOTE (fbuser @ Jul 12 2008, 15:13) Here ...   Aug 4 2008, 18:48
- - Arithmomaniac   Sounds great! 1) Could you revive the download...   Aug 28 2008, 21:09
- - fbuser   1) The link is correct, but the server is down at ...   Aug 28 2008, 22:56
- - q-stankovic   QUOTE (fbuser @ Aug 28 2008, 23:56) For t...   Aug 29 2008, 16:32
|- - Spirit_of_the_ocean   I can't download this component? Can someone h...   Sep 2 2008, 16:02
- - fbuser   Sorry, the downtime of the server is longer than e...   Sep 2 2008, 22:06
- - Onkel Andy   Hi guys! At first sight this plugin looked a l...   Sep 4 2008, 01:38
- - fbuser   The criteria has to be provided by the scheme quer...   Sep 4 2008, 21:13
|- - Onkel Andy   QUOTE (fbuser @ Sep 4 2008, 14:13) The cr...   Sep 6 2008, 00:12
- - fbuser   When you apply the following snippet do your filte...   Sep 6 2008, 16:44
- - fbuser   The server where I host the component is back now....   Sep 19 2008, 23:46
- - xbullethammer   Two questions: - Will you fix the annoying bug th...   Oct 22 2008, 18:26
|- - fbuser   QUOTE (xbullethammer @ Oct 22 2008, 18:26...   Oct 26 2008, 19:21
- - xbullethammer   QUOTE This is new to me. I don't have such pro...   Oct 26 2008, 22:07
- - fbuser   I tried it in a fresh installation with four playl...   Oct 26 2008, 23:05
- - wizel   How can others could created dynamic filters witho...   Nov 17 2008, 18:09
|- - ledge   QUOTE (wizel @ Nov 18 2008, 05:09) How ca...   Nov 17 2008, 23:10
|- - wizel   QUOTE (ledge @ Nov 17 2008, 23:10) QUOTE ...   Nov 18 2008, 21:13
|- - wizel   QUOTE (wizel @ Nov 18 2008, 21:13) QUOTE ...   Nov 19 2008, 18:54
- - fireslug   I'd like to use foo_playlist_tree_mod (PTM) to...   Dec 27 2008, 19:55
- - SardonicWrath   Hi Thanks for the port! But why are the play...   Jan 13 2009, 15:22
|- - fbuser   QUOTE (SardonicWrath @ Jan 13 2009, 15:22...   Jan 13 2009, 16:05
- - SardonicWrath   don't works for me. if i use %artist%|%album...   Jan 13 2009, 16:36
- - fbuser   You need to do it this way: CODE%artist%|%album% ...   Jan 13 2009, 19:48
- - fbuser   %_foldercount% has to be used, if you want to show...   Jan 17 2009, 20:28
- - hoolyboy   please forgive my newbie ignorance but where might...   Jan 20 2009, 01:13
- - bubi jackson   Especially a title formatting reference would be n...   Jan 20 2009, 02:28
|- - SardonicWrath   QUOTE (bubi jackson @ Jan 20 2009, 02:28)...   Jan 20 2009, 02:41
- - bubi jackson   argh, I have overlooked the Tutorial Link with the...   Jan 20 2009, 03:01
- - bubi jackson   Hi. I made a query with the average rating ( sum ...   Jan 22 2009, 00:21
- - bubi jackson   Nobody any idea?   Jan 24 2009, 00:46
|- - Dan Popescu   $padcut(__CALCULATED_VALUE__,6) - it pads wit...   Jan 24 2009, 08:23
- - bubi jackson   Thanks Dan Popescu but it doesn't work. I mad...   Jan 24 2009, 12:03
- - bubi jackson   I have another question. I'm not able to sort...   Jan 31 2009, 17:15
|- - fbuser   QUOTE (bubi jackson @ Jan 31 2009, 17:15)...   Feb 1 2009, 15:31
- - thecircusfreak   Excuse me, ok, this is a powerful plugin, but is t...   Feb 1 2009, 13:04
- - bubi jackson   Ah, ok. Thank you fbuser   Feb 1 2009, 15:51
- - lwiczek   Where can I download this component? Link in first...   Feb 3 2009, 12:55
- - SardonicWrath   is there something one can do about slow startup t...   Feb 16 2009, 13:36
|- - fbuser   QUOTE (SardonicWrath @ Feb 16 2009, 13:36...   Feb 16 2009, 22:56
- - aliendesaster   I guess wine compatibility isn't too heigh pos...   Mar 1 2009, 15:36
- - fbuser   The crash is caused by the embedded scheme interpr...   Mar 2 2009, 12:53
- - m00zikD00d   I have a few quick questions.... 1.) Does anyone ...   Mar 17 2009, 19:16
|- - fbuser   QUOTE (m00zikD00d @ Mar 17 2009, 19:16) 1...   Mar 17 2009, 22:00
|- - m00zikD00d   Thank you much   Mar 17 2009, 22:45
- - Jleagle   I have just installed this plugin but i cant seem ...   Mar 25 2009, 18:11
- - fbuser   foo_playlist_tree_mod is not an UI element, it is ...   Mar 25 2009, 19:34
- - Jleagle   That explains, thanks, got it working now.   Mar 25 2009, 19:42
- - TomBarlow   This is a great component, the only thing I'm ...   Apr 12 2009, 22:43
- - Joelimite   I have a quick question about formatting in foo_pl...   May 23 2009, 21:50
- - TomBarlow   You need to insert %discnumber% into your sort str...   May 23 2009, 21:57
- - Joelimite   The latter option worked perfect! Thanks, Tom.   May 23 2009, 22:18
- - 2E7AH   Link to documentation http://www.bazquux.com/wiki/...   Jun 1 2009, 09:53
- - T.P Wang   @2E7AH: http://www.bazquux.com/w/index.php?title=F...   Jun 1 2009, 10:36
- - 2E7AH   Thanks   Jun 1 2009, 10:48
- - petibras   hello For now my list look this way + Genre . ...   Jul 1 2009, 06:33
- - petibras   hello, got a question I got the tree in panel sta...   Jul 5 2009, 18:35
- - fbuser   This has nothing to do with foo_playlist_tree_mod....   Jul 5 2009, 19:54
- - petibras   Putted my PSS in wich is the playlist tree named ...   Jul 6 2009, 02:58
- - vol   How to make a query to display top artists, albums...   Jul 25 2009, 10:03
- - 2E7AH   http://www.bazquux.com/wiki/Example_Queries#Most_P...   Jul 25 2009, 10:07
|- - vol   QUOTE (2E7AH @ Jul 25 2009, 11:07) http:/...   Jul 25 2009, 10:36
- - m00zikD00d   Where is the configuration data stored for playlis...   Jul 25 2009, 21:21
- - fbuser   The query definitions and results are stored in th...   Jul 25 2009, 22:30
- - 22U2   Is it possible to get separated genres view? I ha...   Sep 13 2009, 07:53
- - fbuser   Try using %<genre>% as your first level   Sep 13 2009, 10:38
- - 22U2   its just what im looking for. thx!   Sep 13 2009, 11:03
- - watercolor   There is a question about Playlist Tree Mod. My P...   Sep 24 2009, 14:47
|- - fbuser   QUOTE (watercolor @ Sep 24 2009, 14:47) I...   Sep 24 2009, 18:00
|- - watercolor   QUOTE (fbuser @ Sep 25 2009, 02:00) QUOTE...   Sep 24 2009, 22:06
|- - fbuser   QUOTE (watercolor @ Sep 24 2009, 22:06) I...   Sep 24 2009, 23:18
|- - watercolor   QUOTE (fbuser @ Sep 25 2009, 07:18) QUOTE...   Sep 25 2009, 01:56
- - fbuser   None of the things you mentioned should lead to an...   Sep 25 2009, 08:28
|- - watercolor   QUOTE (fbuser @ Sep 25 2009, 16:28) None ...   Sep 25 2009, 09:38
|- - watercolor   It is continuation. When the meta data of a doubt...   Sep 25 2009, 21:22
- - qwertz   I've fiddled around a bit with foo_playlist_tr...   Sep 28 2009, 20:25
- - pappaapa   Thank you for this great component! I didn...   Dec 12 2009, 11:41
- - fbuser   New version, see first post.   Jan 9 2010, 16:04
- - Keesface   I'm trying to group my playlists by name, I wa...   Jan 13 2010, 01:23
- - KindOfAutomatic   Is there any way to display 16x16 png icons? Or ma...   Jan 22 2010, 20:14
- - tstevens   Dunno if anyone is monitoring this thread anymore ...   Feb 10 2010, 22:59
|- - tstevens   ok - I'm a ding dong. I happened upon a small ...   Feb 11 2010, 04:46
- - tstevens   Ok, so now this is working there is one bit I...   Feb 11 2010, 18:54
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 31st January 2015 - 20:18
