86 Pages V  « < 71 72 73 74 75 > »
Columns UI appearance, Post a screenshot of your config!
emte
post Mar 11 2012, 20:12
Post #1801
I was thinking of making these images display in different colours but I don't know how to make them dependent of genres. Wanted to make the same classification as on the page of the pleasurize foundation.
aeidein
post Mar 11 2012, 23:34
Post #1802
Do you have to manually scan each album with the DR component?
C3POwen
post Mar 12 2012, 11:06
Post #1803
QUOTE (emte @ Mar 11 2012, 19:12) *
I guess you could do this if you had different versions of the DR images, sorted out into different folders, and then used a combination of $if functions, but it might over-complicate things. You could always use the colour scheme from the Unofficial DR Database, as you'd only need one set of DR images.
QUOTE (aeidein @ Mar 11 2012, 22:34) *
You do, and you need to ensure that it is set up to write the values as tags in the selected files.
You can set this in File > Preferences > Advanced > Tools > Dynamic Range Meter > Write DR meta data tags
emte
post Mar 12 2012, 16:50
Post #1804
QUOTE (C3POwen @ Mar 12 2012, 11:06) *
Yeah, I have these images grouped into three categories and it is divided on the website, but I can't implement the division into foobar. In other words, I can't make one set apply only to specified genres and, and likewise with the others. Tried $if functions but nothing comes out of this. smile.gif If I don't find a way to make it, I may stick to the unofficial scale.
This post has been edited by emte: Mar 12 2012, 16:51
C3POwen
post Mar 12 2012, 19:56
Post #1805
QUOTE (emte @ Mar 12 2012, 15:50) *
You may be able to get it working using something like this:
$if($and(%album dynamic range%,$or($stricmp(%genre%,classical),$stricmp(%genre%,soundtrack))),$imageabs(x,y,w,h,skins\dynamicrange\HIGH\DR%album dynamic range%.png),)
$if($and(%album dynamic range%,($or($stricmp(%genre%,alternative),$stricmp(%genre%,pop),$stricmp(%genre%,rock))),$imageabs(x,y,w,h,skins\dynamicrange\LOW\DR%album dynamic range%.png),)
You should then be able to use the $or function to specify more genres. If anyone has a more elegant solution, then please feel free to suggest.
Abraxas
post Mar 13 2012, 09:52
Post #1806
chiwou
post Mar 13 2012, 10:20
Post #1807
nice and where is the download?
Abraxas
post Mar 13 2012, 10:30
Post #1808
Well, as it is my first try I have there real mess in code. Some absolute paths. I don't even know how to properly put it all together for download.
sollniss
post Mar 13 2012, 11:49
Post #1809
DUI kind of style which focuses on usability rather than fanciness.
The very act of observing, influences what happens.
Neonphytismo
post Mar 13 2012, 21:20
Post #1810
QUOTE (Abraxas @ Mar 13 2012, 18:30) *
You can just pack your whole folder, the experienced users will figure all the necessaries out.
I like yours.
mad messy misanthropist morbid mused
MDMA
post Mar 14 2012, 19:13
Post #1811
QUOTE (Abraxas @ Mar 13 2012, 10:30) *
I suggest you use a portable copy of foobar, then its just a case of zipping up your foobar2000 directory if you want to share it with someone, they can then run it 'straight out the box'
btw might I say its a slick config, another request for you to share it! smile.gif
This post has been edited by MDMA: Mar 14 2012, 19:14
Abraxas
post Mar 15 2012, 08:52
Post #1812
Thank you for tips. I'll release it as soon as I finish all small tweaks. Also there will be at least 4 color themes available (green, blue, fire, glamour). I hope to finish it later today.
tdisbd
post Mar 15 2012, 19:33
Post #1813
Falstaff
post Mar 15 2012, 21:45
Post #1814
http://br3tt.online.fr/
Falstaff
post Mar 17 2012, 16:25
Post #1815
trying my WSH CoverFlow script in my Slate config:
BiTeLSE
post Mar 17 2012, 17:07
Post #1816
Fancy! Composition with your skin is impressive. I'm curious how it will work compare to other cover flows plugins. I don't use any because loads are too high for me. Or should I say: to my PC smile.gif
EDIT:
Heh, just saw beta version on dA. Time to test.
This post has been edited by BiTeLSE: Mar 17 2012, 17:09
prateek88
post Mar 18 2012, 14:58
Post #1817
[quote name='Falstaff' date='Mar 17 2012, 16:25' post='789767']
wow....looking forward for the release.... smile.gif, scrollbar in addition would be a nice idea unsure.gif
Falstaff
post Mar 18 2012, 17:47
Post #1818
horizontal scrollbar already added, just turned off of this preview. More screenshots here + get the script (beta) : http://fav.me/d4t4lh7
SenzaCoil
post Mar 19 2012, 18:45
Post #1819
QUOTE (sollniss @ Mar 13 2012, 11:49) *
Is it possible to get your config for having thiis ?
MacStew
post Mar 21 2012, 02:47
Post #1820
QUOTE (Falstaff @ Mar 17 2012, 17:25) *
Will download this with pleasure
robollama
post Mar 21 2012, 22:29
Post #1821
A skin I made has no borders around the filters on my computer, but whenever anyone installs it they get these white borders:
What do I need to do so that when people install it they don't have the borders?
tdisbd
post Mar 22 2012, 05:39
Post #1822
BunnyHoover
post Mar 22 2012, 12:36
Post #1823
QUOTE (tdisbd @ Mar 22 2012, 05:39) *
THIS WILL BE VERY GOOD !
Superunknown
post Mar 27 2012, 09:37
Post #1824
QUOTE (Abraxas @ Mar 15 2012, 08:52) *
Looking forward to downloading your config too
Corey
post Mar 29 2012, 20:55
Post #1825
Guys, how can I learn to solve this problem, don't know what to do, to sort this ones in correct order : ) noob here alert!!
RSS Lo-Fi Version Time is now: 28th January 2015 - 20:58
