lossyWAV 1.0.0 released., Added noise WAV bit reduction method.
Nick.C
post May 12 2008, 20:53
lossyWAV Developer
lossyWAV 1.0.0b released:
lossyWAV 1.0.0b, Copyright © 2007,2008 Nick Currie. Copyleft.
This program is free software: you can redistribute it and/or modify it under
the terms of the GNU General Public License as published by the Free Software
Foundation, either version 3 of the License, or (at your option) any later
version.
This program is distributed in the hope that it will be useful,but WITHOUT ANY
WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.  See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License along with
this program.  If not, see <http://www.gnu.org/licenses/>.
Usage   : lossyWAV <input wav file> <options>
Example : lossyWAV musicfile.wav
Quality Options:
-q, --quality <n>   quality preset (10=highest quality, 0=lowest bitrate;
                    -q 5 is generally accepted to be transparent)
                    default=-q 5.
Standard Options:
-c, --check         check if WAV file has already been processed; default=off.
                    errorlevel=16 if already processed, 0 if not.
-C, --correction    write correction file for processed WAV file; default=off.
-f, --force         forcibly over-write output file if it exists; default=off.
-h, --help          display help.
-L, --longhelp      display extended help.
-M, --merge         merge existing lossy.wav and lwcdf.wav files.
-N, --noclips       set allowable number of clips / channel / codec block to 0;
                    default=3,3,3,3,2,1,0,0,0,0,0 (-q 0 to -q 10)
-o, --outdir <dir>  destination directory for the output file(s).
-v, --version       display the lossyWAV version number.
Special thanks:
David Robinson for the method itself and motivation to implement it.
Don Cross for the Complex-FFT algorithm used.
Horst Albrecht for valuable tuning input and feedback.
Explanation, history and lossless codec settings in the wiki article
[edit] 1.0.0b necessitated by unknown WAV chunk handling error and 24-bit --correction / --merge parameter error.
Link to GNU GPLv3+ source code for lossyWAV 1.0.0b [/edit]
N.B.: lossyWAV 1.1.0b released here.
This post has been edited by Nick.C: Mar 20 2009, 23:18
Attached File(s)
krmathis
post May 16 2008, 21:03
Can you please link me to the source code?
Its released under the GPL license, but I am unable to find it for download.
This post has been edited by krmathis: May 16 2008, 21:04
- Nick.C   lossyWAV 1.0.0 released.   May 12 2008, 20:53
- - collector   QUOTE (Nick.C @ May 12 2008, 11:53) lossy...   May 12 2008, 21:19
|- - Nick.C   QUOTE (collector @ May 12 2008, 21:19) QU...   May 12 2008, 21:23
|- - Dologan   RE: lossyWAV 1.0.0 released.   May 12 2008, 21:25
- - PabUK   22 minutes late. Bitterly disappointed. Kidding ...   May 12 2008, 21:20
- - sauvage78   Just Thanks Edit: plz validated news & fro...   May 12 2008, 21:32
|- - Nick.C   QUOTE (sauvage78 @ May 12 2008, 21:32) Ju...   May 12 2008, 21:51
|- - TBeck   QUOTE (Nick.C @ May 12 2008, 21:51) Unfor...   May 13 2008, 02:17
|- - Nick.C   QUOTE (TBeck @ May 13 2008, 02:17) QUOTE ...   May 13 2008, 07:45
- - Mitch 1 2   Nice work. Taking this experimental concept and fo...   May 13 2008, 02:59
- - skamp   All in all, this release came pretty fast, and it...   May 13 2008, 08:07
|- - Nick.C   QUOTE (skamp @ May 13 2008, 08:07) All in...   May 13 2008, 08:18
- - 2Bdecided   Well done Nick, and thank you. Thank you too to a...   May 13 2008, 10:08
|- - Nick.C   QUOTE (2Bdecided @ May 13 2008, 10:08) We...   May 13 2008, 10:25
- - Balnes   QUOTE (Nick.C @ May 12 2008, 20:53) lossy...   May 13 2008, 15:21
|- - Nick.C   QUOTE (Balnes @ May 13 2008, 15:21) Hello...   May 13 2008, 16:01
|- - collector   QUOTE (Nick.C @ May 13 2008, 07:01) The W...   May 13 2008, 23:49
||- - Nick.C   QUOTE (collector @ May 13 2008, 23:49) Pl...   May 14 2008, 06:28
||- - collector   QUOTE (Nick.C @ May 13 2008, 21:28) QUOTE...   May 14 2008, 10:04
||- - Nick.C   QUOTE (collector @ May 14 2008, 10:04) QU...   May 14 2008, 10:19
|- - tev777   QUOTE (Nick.C @ May 13 2008, 11:01) ... s...   May 22 2008, 00:32
|- - Nick.C   QUOTE (tev777 @ May 22 2008, 00:32) QUOTE...   May 22 2008, 07:39
- - shadowking   Very good work. Much appreciated.   May 13 2008, 15:42
- - halb27   Hallo Nick, I've just come home from the exte...   May 13 2008, 22:03
|- - Nick.C   QUOTE (halb27 @ May 13 2008, 22:03) Hallo...   May 13 2008, 22:08
- - jesseg   Or if someone dithered to 16bit and saved as 24bit...   May 14 2008, 11:02
- - ckjnigel   Most importantly, I add my congrats. The techn...   May 14 2008, 18:51
- - carpman   A little late, but congratulations Nick.C, halb27 ...   May 14 2008, 19:38
- - beto   I have not followed the development of lossyWAV cl...   May 15 2008, 20:55
|- - Nick.C   QUOTE (beto @ May 15 2008, 20:55) I have ...   May 15 2008, 21:04
||- - beto   QUOTE (Nick.C @ May 15 2008, 17:04) ... ...   May 15 2008, 21:57
|||- - carpman   QUOTE (beto @ May 15 2008, 21:57) You can...   May 15 2008, 22:03
|||- - Nick.C   QUOTE (carpman @ May 15 2008, 22:03) QUOT...   May 15 2008, 22:08
||- - jesseg   QUOTE (Nick.C @ May 15 2008, 15:04) It sh...   May 21 2008, 05:49
|- - halb27   QUOTE (beto @ May 15 2008, 21:55) ... How...   May 16 2008, 08:23
- - krmathis   Can you please link me to the source code? Its rel...   May 16 2008, 21:03
|- - Nick.C   QUOTE (krmathis @ May 16 2008, 21:03) Can...   May 16 2008, 21:15
|- - krmathis   QUOTE (Nick.C @ May 16 2008, 22:15) Downl...   May 17 2008, 09:24
|- - spies   QUOTE (krmathis @ May 17 2008, 01:24) Dow...   May 17 2008, 17:59
|- - Nick.C   QUOTE (spies @ May 17 2008, 17:59) QUOTE ...   May 17 2008, 18:37
- - hödyr   I have not followed the development and just disco...   May 17 2008, 01:56
- - french dok   This seem to be really interesting but one questio...   May 19 2008, 08:13
|- - halb27   QUOTE (french dok @ May 19 2008, 09:13) T...   May 19 2008, 08:39
|- - Nick.C   QUOTE (french dok @ May 19 2008, 08:13) T...   May 19 2008, 10:08
- - french dok   I see. Point c) from halb27 is indeed a good remar...   May 19 2008, 16:17
- - Jalan   is there a more in-depth "how to" for fo...   May 26 2008, 07:10
|- - Nick.C   QUOTE (Jalan @ May 26 2008, 07:10) is the...   May 26 2008, 07:38
- - carpman   Nick I think there's a problem with the recom...   May 26 2008, 18:41
- - Jalan   QUOTE (Nick.C @ May 26 2008, 02:38) Have ...   May 26 2008, 19:16
|- - carpman   QUOTE (Jalan @ May 26 2008, 19:16) tried ...   May 26 2008, 19:28
- - memomai   I'd like to integrate lossyWAV into foobar2000...   May 31 2008, 19:13
- - halb27   QUOTE (memomai @ May 31 2008, 20:13) I...   May 31 2008, 23:04
RSS Lo-Fi Version Time is now: 1st March 2015 - 21:13
