[Not My Release] ELPlaylist
Keikonium
post Mar 25 2008, 01:41
Here is the link: http://foo2k.chottu.net/
What it does:
Displays your playlist in a similar fashion to SCPL provided by Panels UI.
QUOTE (grounder @ Mar 30 2008, 19:06) *
You should all check it out happy.gif.
This post has been edited by Keikonium: Apr 6 2008, 06:54
ZyroBlue
post Mar 26 2008, 20:37
QUOTE (TomBarlow @ Mar 26 2008, 19:05) *
Thanks Buktore.
btw, is anyone else noticing the groups occasionally collapse themselves randomly? It's happened to me a couple of times, no idea what's causing it.
Also, should it be possible to put panels in this playlist? I tried adding a seek bar using Power Panels, and it's not come up with [unknown function] or anything, but it's not working...
Accidentally double-clicked on a group? If you haven't changed the setting, this collapses it.
QUOTE (Keikonium @ Mar 26 2008, 18:47) *
QUOTE (ZyroBlue @ Mar 26 2008, 11:44) *
I am not so much into foobar coding..
$puts(img_path,%directoryname%,cover.jpg)//Set Album Image File Path
What will I have to put there in order to correctly recognize my AA named cover.jpg, residing in the same folder than the file?
Change %directoryname% to %path%?
Not quite..This outputs full path, with the filename of the currently played item.
This post has been edited by ZyroBlue: Mar 26 2008, 20:38
- Keikonium   [Not My Release] ELPlaylist   Mar 25 2008, 01:41
- - nightfishing   Not my cup of tea, but very cool! Works out-o...   Mar 25 2008, 02:07
- - Jose Hidalgo   Maybe some screenshots would help ?   Mar 25 2008, 03:39
- - Keikonium   Sure . This is my Columns Playlist done with this ...   Mar 25 2008, 06:00
- - Squeller   Wow, this is pretty interesting   Mar 25 2008, 08:08
- - Hakubo   Looks good, but lacks some basic functionality for...   Mar 25 2008, 09:26
- - Squeller   General question: There are a couple of components...   Mar 25 2008, 10:25
- - thuan   This is not Chinese, it's Japanese. Later this...   Mar 25 2008, 11:12
|- - Spirit_of_the_ocean   I tried this also. My problems so far:Documentatio...   Mar 25 2008, 11:47
|- - Hakubo   QUOTE (thuan @ Mar 25 2008, 13:12) @Hakub...   Mar 25 2008, 12:38
- - buktore   I knew about this component for quite sometime. An...   Mar 25 2008, 12:02
- - Falstaff   look amazing and a fresh new way @Keikonium: tha...   Mar 25 2008, 12:35
- - Falstaff   info: many crashes under panelsUI for me (on ...   Mar 25 2008, 12:51
- - Keikonium   New version is up. Things I've noticed so far ...   Mar 25 2008, 23:29
|- - Falstaff   QUOTE (Keikonium @ Mar 25 2008, 23:29) Ne...   Mar 25 2008, 23:43
- - thuan   Got the time to play around with it, here's my...   Mar 26 2008, 12:03
- - Keikonium   Very nice thuan . New Release 0.2.5.1a. Notes fro...   Mar 26 2008, 14:18
- - buktore   After I have set it up to look like my current SCP...   Mar 26 2008, 14:58
- - Keikonium   Yeah drag and drop would be nice, but it seems to ...   Mar 26 2008, 15:54
|- - ZyroBlue   Am I just too stupid? I copied this plugin over to...   Mar 26 2008, 16:14
|- - Keikonium   QUOTE (ZyroBlue @ Mar 26 2008, 09:14) Am ...   Mar 26 2008, 16:16
- - ZyroBlue   Knew it was something that easy..Thanks!   Mar 26 2008, 16:22
- - TomBarlow   Awesome stuff, thanks for the link. It would be n...   Mar 26 2008, 16:30
- - buktore   Something weird.. Using Vol.up & Vol.down m...   Mar 26 2008, 16:36
|- - Keikonium   QUOTE (buktore @ Mar 26 2008, 09:36) Some...   Mar 26 2008, 16:46
- - ZyroBlue   I am not so much into foobar coding.. $puts(i...   Mar 26 2008, 18:44
|- - Keikonium   QUOTE (ZyroBlue @ Mar 26 2008, 11:44) I a...   Mar 26 2008, 18:47
- - TomBarlow   Thanks Buktore. btw, is anyone else noticing the ...   Mar 26 2008, 19:05
- - ZyroBlue   QUOTE (TomBarlow @ Mar 26 2008, 19:05) Th...   Mar 26 2008, 20:37
- - buktore   QUOTE What will I have to put there in order to co...   Mar 26 2008, 21:35
- - TomBarlow   QUOTE (ZyroBlue @ Mar 26 2008, 19:37) Acc...   Mar 26 2008, 22:02
- - Falstaff   v0.2.5.1a still buggy metahandle leaks message is...   Mar 27 2008, 00:03
- - Squeller   I must admit I agree with the criticism in TAGZ ab...   Mar 27 2008, 21:42
- - Falstaff   new release : v0.2.6a 2008/03/27 " # I can...   Mar 28 2008, 11:27
- - Falstaff   i haven't reproduce the crash yet with new rel...   Mar 28 2008, 12:06
- - buktore   QUOTE Why the panel flash to white when changing t...   Mar 28 2008, 12:17
- - Falstaff   new crash : CODE Illegal operation: Code: C0000...   Mar 28 2008, 12:23
- - buktore   New version is out.. Big thanks for ENTER hotkey....   Mar 28 2008, 17:04
|- - Falstaff   QUOTE (buktore @ Mar 28 2008, 17:04) New ...   Mar 28 2008, 17:27
- - buktore   QUOTE when i change a playlist, playlist display i...   Mar 28 2008, 18:01
- - Falstaff   New bugg found (sorry ...) Cover displayed blur s...   Mar 28 2008, 18:03
- - Falstaff   not a bugg this time (or maybe ...?) if the playl...   Mar 28 2008, 22:09
|- - Kiteroa   Thanks for a great new component - I'm moving ...   Mar 29 2008, 02:51
|- - Yotsuya   QUOTE (Kiteroa @ Mar 28 2008, 21:51) 1) h...   Mar 29 2008, 03:36
- - buktore   New version is out.. Bug about "Activate Now...   Mar 29 2008, 09:51
- - Falstaff   thanx for new release and no matter for the pb of ...   Mar 29 2008, 12:44
- - TomBarlow   I think the per second area is for track display f...   Mar 29 2008, 12:57
|- - Falstaff   QUOTE (TomBarlow @ Mar 29 2008, 12:57) I ...   Mar 29 2008, 14:33
|- - Kiteroa   New version of ELPlaylist (v0.2.7a 2008/03/31)...   Apr 3 2008, 01:57
|- - Kiteroa   QUOTE (Kiteroa @ Apr 3 2008, 13:57) New v...   Apr 3 2008, 10:24
|- - TomBarlow   QUOTE (Kiteroa @ Apr 3 2008, 00:57) New v...   Apr 3 2008, 16:17
- - Falstaff   bugg with the sort option in settings : if checke...   Mar 29 2008, 13:24
- - buktore   I saw in the Readme mentioned that sort option is ...   Mar 29 2008, 14:15
- - ZyroBlue   I think that by this he rather means that per seco...   Mar 29 2008, 14:41
- - Dreamless   I know I'm going to sound stupid for asking th...   Mar 29 2008, 16:34
|- - Falstaff   QUOTE (Dreamless @ Mar 29 2008, 16:34) I ...   Mar 29 2008, 17:44
|- - Dreamless   QUOTE (Falstaff @ Mar 29 2008, 11:44) QUO...   Mar 31 2008, 00:32
- - SmilerSmiles   What I think this component needs is BUTTONS in th...   Mar 29 2008, 20:51
- - grounder   Foo_uie_elplaylist Readme online translate   Mar 31 2008, 00:06
|- - Yotsuya   Keikonium: Would you please consider linking this ...   Apr 6 2008, 04:24
|- - grounder   QUOTE (grounder @ Mar 30 2008, 19:06) Foo...   Apr 6 2008, 11:10
- - Keikonium   If the author still reads this, I have a feature r...   Apr 1 2008, 19:00
|- - Falstaff   QUOTE (Keikonium @ Apr 1 2008, 19:00) If ...   Apr 1 2008, 19:03
|- - carmenm   QUOTE (Falstaff @ Apr 1 2008, 20:03) QUOT...   Apr 2 2008, 08:59
|- - Falstaff   QUOTE (carmenm @ Apr 2 2008, 08:59) QUOTE...   Apr 2 2008, 10:25
- - grounder   Hi! In functions $drawtex $rgb wor...   Apr 2 2008, 12:44
- - Hakubo   I guess it's the new feature. The changelog en...   Apr 3 2008, 18:55
- - Yotsuya   For what it is worth, I recently upgraded my ubunt...   Apr 4 2008, 00:17
- - yen223   I got 1 problem...for some reason when foobar fini...   Apr 4 2008, 08:05
|- - Falstaff   QUOTE (yen223 @ Apr 4 2008, 08:05) I got ...   Apr 4 2008, 11:42
- - Falstaff   new release V0.2.7.1a + Pseudo transparent lost...   Apr 4 2008, 20:50
|- - Kiteroa   If the "Hide header when there is only one gr...   Apr 4 2008, 23:45
|- - Zarkon   QUOTE (Kiteroa @ Apr 4 2008, 15:45) (I do...   Apr 5 2008, 01:03
|- - Kiteroa   QUOTE (Zarkon @ Apr 5 2008, 13:03) QUOTE ...   Apr 5 2008, 01:10
|- - Zarkon   I just realized $ifequal isn't a function...   Apr 5 2008, 01:17
|- - Kiteroa   $ifgreater(%el_group_count%,0,3,0) inthe gro...   Apr 5 2008, 01:35
|- - Zarkon   QUOTE (Kiteroa @ Apr 4 2008, 17:35) (grou...   Apr 5 2008, 01:45
- - Yotsuya   Is there a way to programatically hide the header ...   Apr 5 2008, 01:39
|- - Kiteroa   Thanks but $ifgreater(%el_group_count%,1,3,...   Apr 5 2008, 01:47
|- - Zarkon   I thought it did, but after fiddling around with i...   Apr 5 2008, 02:08
|- - Kiteroa   To the developer: many thanks for what is proving...   Apr 5 2008, 06:15
- - Yotsuya   Thank you I was able to remove the group headers f...   Apr 6 2008, 02:07
|- - Kiteroa   QUOTE (Yotsuya @ Apr 6 2008, 13:07) . --...   Apr 6 2008, 04:08
- - BHitman   First of all: it is a very nice plugin. I'm p...   Apr 6 2008, 20:58
- - buktore   There's an update. + changed: selection state...   Apr 11 2008, 08:23
- - pIv   When all my playlists are empty foobar crashed on ...   Apr 12 2008, 08:55
- - joaotavela   How to get rating stars in ELplaylist? It's po...   Apr 13 2008, 22:03
|- - Falstaff   QUOTE (joaotavela @ Apr 13 2008, 22:03) H...   Apr 13 2008, 23:19
|- - joaotavela   QUOTE (Falstaff @ Apr 13 2008, 16:19) QUO...   Apr 13 2008, 23:58
- - Falstaff   happy for you   Apr 14 2008, 18:33
- - RavenSoft   I just loaded this plugin and its cool but I'm...   Apr 20 2008, 11:30
- - Chipicui   Anyone knows how to re-order tracks with the mouse...   May 5 2008, 17:25
|- - Falstaff   QUOTE (Chipicui @ May 5 2008, 17:25) Anyo...   May 5 2008, 17:45
|- - CepiPerez   QUOTE (Falstaff @ May 5 2008, 13:45) QUOT...   May 10 2008, 14:13
- - Chipicui   Oh!... thanks... Well... looks like going back...   May 5 2008, 19:29
- - mother_gong   I have problem loading my iPod library (foobar2000...   May 10 2008, 18:17
- - Chipicui   QUOTE (CepiPerez @ May 10 2008, 10:13) QU...   May 10 2008, 18:34
- - callisto   QUOTE (mother_gong @ May 10 2008, 19:17) ...   May 11 2008, 01:08
- - buktore   New version is out. You can rearrange your playli...   May 11 2008, 17:37
- - Chipicui   Nice!... thanks! I'll try it right now   May 11 2008, 17:45
10 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 6th July 2015 - 19:35
