[Not my release] foo_uie_panel_splitter, A Columns UI plugin that works similarly to Panels UI
Spirit_of_the_oc...
post Mar 24 2008, 02:51
I just tried this Plugin and I think it is fantastic. It is a bit like panel ui but a bit more user friendly.It is still in developement and it is in alpha state, but for me it works fine.
As its name says it is a plugin for columns ui.
Screenshot of the dialog:
By using the pseudo transparent mode you can use the normal seekbar and buttons but without the grey (or whatelses colour your style uses) background.
Example:
Maybe Terrestrial is the develloper of this plugin? There are some similarities between Panel ui and this plugin:
For example
- the different drawing types
- the way the panels have coordinates
grounder
post Apr 17 2008, 12:42
2 Spirit_of_the_ocean
Here is example of excellent work
$showpanel (Album Art,1) //show Album Art
$showpanel (Album Art,0) //hide Album Art
Album Art to be on the list Panel Stack Splitter
name must match so that the list
- Spirit_of_the_ocean   [Not my release] foo_uie_panel_splitter   Mar 24 2008, 02:51
- - Kiteroa   How do you get the splitter settings up?   Mar 24 2008, 03:27
|- - Spirit_of_the_ocean   QUOTE (Kiteroa @ Mar 24 2008, 03:27) How ...   Mar 24 2008, 14:30
|- - Kiteroa   QUOTE (Spirit_of_the_ocean @ Mar 25 2008, 02...   Mar 24 2008, 23:19
- - gob   wow, this is good news. im going to watch this com...   Mar 24 2008, 04:01
- - zachastrife   I would like to hear the foobar dev's take on ...   Mar 24 2008, 22:58
|- - Falstaff   QUOTE (zachastrife @ Mar 24 2008, 22:58) ...   Mar 24 2008, 23:47
|- - gob   QUOTE (zachastrife @ Mar 24 2008, 16:58) ...   Mar 25 2008, 07:14
|- - zachastrife   QUOTE (gob @ Mar 25 2008, 07:14) interest...   Mar 25 2008, 09:17
|- - Spirit_of_the_ocean   Please let's get back to topic. QUOTE (zacha...   Mar 25 2008, 11:39
- - Zao   My opinion is: Eew, titleformatting abuse. Why can...   Mar 24 2008, 23:40
|- - Insolent   QUOTE (Zao @ Mar 25 2008, 08:40) My opini...   Mar 25 2008, 13:23
- - grounder   Japanese wiki online translate Panel Stack Splitt...   Mar 30 2008, 12:09
- - carmenm   I am starting to like this component a lot. One b...   Mar 30 2008, 20:22
|- - Spirit_of_the_ocean   You can use %width% and %height% under width and h...   Mar 30 2008, 22:49
- - carmenm   doesnt work for me   Mar 31 2008, 09:06
- - Spirit_of_the_ocean   Dear develloper hopefully you will read this threa...   Apr 16 2008, 09:52
|- - carmenm   QUOTE (Spirit_of_the_ocean @ Apr 16 2008, 10...   Apr 16 2008, 12:32
- - Spirit_of_the_ocean   Hmm in the translation this isn't mentioned an...   Apr 17 2008, 11:40
- - thuan   Well, that is the index of the panel in panel list...   Apr 17 2008, 11:49
- - grounder   2 Spirit_of_the_ocean Here is example of excellent...   Apr 17 2008, 12:42
- - thuan   @grounder: Did you use the wrong function? EDIT: ...   Apr 17 2008, 13:18
- - Kirya   QUOTE (Spirit_of_the_ocean @ Mar 31 2008, 00...   May 19 2008, 09:47
- - Kirya   Can anyone here contact a component author? Maybe ...   May 22 2008, 18:07
- - Kirya   QUOTE call Per Second code every 1 sec + every see...   May 31 2008, 11:31
|- - Spirit_of_the_ocean   I have got a studpid question Does the panel spl...   May 31 2008, 13:16
- - buktore   1. It does work with current version. 2. Look for...   May 31 2008, 14:54
- - Falstaff   i'm just playing with panel splitter i it look...   May 31 2008, 22:08
|- - Spirit_of_the_ocean   I guess panel splitter hasn't a wide spread us...   May 31 2008, 22:26
- - Kirya   Yes, it's very nice, but not so popular and a ...   May 31 2008, 22:20
|- - Falstaff   QUOTE (Kirya @ May 31 2008, 23:20) Yes, i...   Jun 1 2008, 10:41
- - Nickoladze   Doesn't C++ support XML serialization? That co...   Jun 1 2008, 04:58
- - Falstaff   a big lack in panel splitter is the possibility to...   Jun 1 2008, 10:59
|- - fbuser   QUOTE (Falstaff @ Jun 1 2008, 10:59) a bi...   Jun 1 2008, 14:32
- - Kirya   QUOTE btw a support of permanent variable like pva...   Jun 1 2008, 11:17
- - Kirya   also you can combine show/hide panel on one button...   Jun 1 2008, 15:14
- - fbuser   To toggle a panel you can also use this code: COD...   Jun 1 2008, 15:35
|- - Falstaff   great, thanx i'll try this ! QUOTE (Kirya...   Jun 1 2008, 17:01
- - Falstaff   well, i've played with ELPlaylist after added ...   Jun 1 2008, 22:42
- - CepiPerez   This component doesn't support %isplaying% at ...   Jun 2 2008, 13:26
|- - Falstaff   QUOTE (CepiPerez @ Jun 2 2008, 14:26) Thi...   Jun 16 2008, 22:39
- - thuan   The last time I tried it (long long ago) it has %i...   Jun 2 2008, 17:28
- - Kirya   why not try to look at the topic name, %el_isplayi...   Jun 2 2008, 18:40
- - grounder   Feature request: 1. Make page Global script that ...   Jun 10 2008, 15:28
- - Falstaff   i try to port my previous PUI config style in a Co...   Jun 12 2008, 22:21
|- - Spirit_of_the_ocean   QUOTE (Falstaff @ Jun 12 2008, 21:21) - s...   Jun 13 2008, 21:35
|- - Falstaff   QUOTE (Spirit_of_the_ocean @ Jun 13 2008, 22...   Jun 13 2008, 22:02
- - grounder   I, too try port my PUI config configuration is not...   Jun 13 2008, 19:38
- - Fool_on_the_hill   Hello! Can anyone post Brumal-Winter config fo...   Jun 13 2008, 19:41
- - tgpo   I'm trying to add a text button, but am unsure...   Jun 16 2008, 18:58
- - tgpo   Well, it doesn't appear that you put the code ...   Jun 16 2008, 19:56
|- - Falstaff   QUOTE (tgpo @ Jun 16 2008, 20:56) Well, i...   Jun 16 2008, 20:17
|- - v.1   EDITED. Great component by the way! waiting fo...   Sep 21 2008, 18:43
- - tgpo   Huh. I must be doing something incorrectly then, b...   Jun 16 2008, 20:35
|- - Falstaff   QUOTE (tgpo @ Jun 16 2008, 21:35) Huh. I ...   Jun 16 2008, 20:46
- - tgpo   Yep: Splitter Settings:   Jun 16 2008, 20:50
|- - Falstaff   QUOTE (tgpo @ Jun 16 2008, 21:50) Yep: o...   Jun 16 2008, 21:05
- - tgpo   The image code you see there was just me attemptin...   Jun 16 2008, 21:14
|- - Falstaff   QUOTE (tgpo @ Jun 16 2008, 22:14) The ima...   Jun 16 2008, 21:41
- - tgpo   I got it! It seems that the stuff I was adding...   Jun 17 2008, 13:32
|- - Falstaff   QUOTE (tgpo @ Jun 17 2008, 14:32) I got i...   Jun 17 2008, 14:24
- - Falstaff   To the developper of this wonderfull component ...   Jun 20 2008, 11:49
- - tgpo   Where does panel splitter save its settings? I...   Jun 26 2008, 15:50
|- - Spirit_of_the_ocean   I have got strange results when placing a the norm...   Jun 26 2008, 21:30
|- - Falstaff   QUOTE (Spirit_of_the_ocean @ Jun 26 2008, 22...   Jun 26 2008, 21:39
|- - Spirit_of_the_ocean   QUOTE (Falstaff @ Jun 26 2008, 20:39) put...   Jun 26 2008, 21:51
|- - Falstaff   QUOTE (Spirit_of_the_ocean @ Jun 26 2008, 22...   Jun 28 2008, 19:52
|- - Spirit_of_the_ocean   QUOTE (Falstaff @ Jun 28 2008, 18:52) nic...   Jun 29 2008, 22:21
|- - Falstaff   QUOTE (Spirit_of_the_ocean @ Jun 29 2008, 23...   Jun 29 2008, 22:24
- - sune   great plugin I'm having problems, though. I ...   Jul 15 2008, 01:41
|- - johnredcorn   QUOTE (sune @ Jul 14 2008, 19:41) ps. tod...   Jul 17 2008, 11:08
- - sune   Thanks for the help johnredcorn. What I'm doin...   Jul 19 2008, 19:47
|- - johnredcorn   QUOTE (sune @ Jul 19 2008, 12:47) ps. the...   Jul 21 2008, 10:51
- - ryebread   request the support of %isplaying% default foobar ...   Jul 21 2008, 14:02
|- - Falstaff   QUOTE (ryebread @ Jul 21 2008, 15:02) req...   Jul 21 2008, 15:20
- - Keikonium   I have decided I am going to recreate my panels UI...   Jul 21 2008, 22:37
|- - Vitriolic   This is one of those plugins that really could use...   Sep 24 2008, 04:45
- - sune   you don't need to make a tree like that. just ...   Jul 21 2008, 23:57
- - Keikonium   Ah! Now that makes sense . I've got it wor...   Jul 22 2008, 00:28
- - TomBarlow   I got a crash... If anyone can shed some light on ...   Aug 4 2008, 11:52
- - Liberal Zed   If somebody could help me out here, it'd be mu...   Aug 10 2008, 19:09
- - sune   apparently, this component does not support %ispla...   Aug 10 2008, 19:29
- - Liberal Zed   Thanks for the help.   Aug 10 2008, 22:34
- - mundschuss   request: a posibillity to remove the window-borde...   Aug 11 2008, 21:08
|- - Falstaff   QUOTE (mundschuss @ Aug 11 2008, 22:08) r...   Aug 11 2008, 21:51
- - bulhakov   To author: PSS has a huge potential. Do you plan t...   Aug 15 2008, 21:58
- - Falstaff   To author: i miss a function : having the possibi...   Sep 1 2008, 18:37
- - Harun   question: would there be a way to detect which pla...   Sep 3 2008, 02:46
- - Falstaff   When could we expect a new release of Panel Stack ...   Sep 10 2008, 18:09
- - Harun   hey br3tt, I finally made a dynamic playback order...   Sep 11 2008, 02:26
|- - Falstaff   QUOTE (Harun @ Sep 11 2008, 03:26) hey br...   Sep 11 2008, 06:50
- - fbuser   Bug report: For the following layout the cpu load...   Sep 26 2008, 21:15
- - xbullethammer   With PUI you were able to use %_trackinfo_notrack%...   Sep 28 2008, 22:24
- - The Judge   I just tried using this with .ico files and cannot...   Sep 29 2008, 02:12
|- - Vitriolic   QUOTE (The Judge @ Sep 28 2008, 19:12) I ...   Sep 29 2008, 05:22
- - Falstaff   new version Panel Stack Splitter v0.3.5a RELEASED ...   Oct 10 2008, 20:59
- - Falstaff   playback buttons do not work with new version i ...   Oct 10 2008, 21:12
|- - Spirit_of_the_ocean   What happens if you change the relative to an abso...   Oct 10 2008, 21:25
|- - Falstaff   QUOTE (Falstaff @ Oct 10 2008, 22:12) pla...   Oct 10 2008, 21:25
- - Andu   Will you release a hotfix or a new version?   Oct 10 2008, 21:28
9 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 28th April 2015 - 13:34
