> Upload forum rules
ARFlac C library/port
Omy
post Feb 25 2008, 22:30
Mostly to do with this thread about ARCue.pl. This is my own port/rewrite to C of the ARFlac.pl script which was in turn based off ARCue.pl. As such then credit must go to the authors of ARCue.pl and ARFlac.pl, although the actual C code is my own work.
Basically, this is a C library (and reference program which uses it) which can be used to check a directory of .flac files against the AccurateRip database. See the thread linked above for discussion of it's limitations.
reardon
post Oct 13 2011, 06:14
QUOTE (Omy @ Feb 25 2008, 14:30) *
I did a bunch of work on this and thought I should share. It now shows EAC and AccurateRip CRCs, and has some updates including:
- AccurateRip v2 CRC
- vary first-track offset (try "-o32" for the most common non-zero offset)
- attempts to find matches for different drive offsets and disc masters. This is not well-implemented. The algorithm is brute-force and slow. It looks at the AR offset CRC (from a ten-sector window) and does a sliding-window search for a match.
- calculate AR/EAC values using only one disc in a multi-disc set.
- attempts to handle the "4608 samples" pad problem of early EAC+FLAC.
- fixes the "confidence number" bugs in early versions of same
It runs on Linux/GNU, not sure what would be involved in making it work on Windows.
Attached File(s)
bort27
post May 15 2013, 05:41
QUOTE (reardon @ Oct 13 2011, 00:14) *
Thank you so much for doing this! I've been using this to verify all of my old CD rips. Works like a charm.
I added one little feature that allows you to specify an AccurateRip disc ID instead of having the program generate it (e.g. "flac_arcrc -a 0019e74c-01142329-b40d1e0f ."). It's really useful for enhanced CDs that have data tracks (EAC or CueTools will give you the AccurateRip ID).
Attached File(s)
RSS Lo-Fi Version Time is now: 28th May 2015 - 06:29
