> Upload forum rules
ARFlac C library/port
Omy
post Feb 25 2008, 22:30
Mostly to do with this thread about ARCue.pl. This is my own port/rewrite to C of the ARFlac.pl script which was in turn based off ARCue.pl. As such then credit must go to the authors of ARCue.pl and ARFlac.pl, although the actual C code is my own work.
Basically, this is a C library (and reference program which uses it) which can be used to check a directory of .flac files against the AccurateRip database. See the thread linked above for discussion of it's limitations.
reardon
post Oct 13 2011, 06:14
QUOTE (Omy @ Feb 25 2008, 14:30) *
I did a bunch of work on this and thought I should share. It now shows EAC and AccurateRip CRCs, and has some updates including:
- AccurateRip v2 CRC
- vary first-track offset (try "-o32" for the most common non-zero offset)
- attempts to find matches for different drive offsets and disc masters. This is not well-implemented. The algorithm is brute-force and slow. It looks at the AR offset CRC (from a ten-sector window) and does a sliding-window search for a match.
- calculate AR/EAC values using only one disc in a multi-disc set.
- attempts to handle the "4608 samples" pad problem of early EAC+FLAC.
- fixes the "confidence number" bugs in early versions of same
It runs on Linux/GNU, not sure what would be involved in making it work on Windows.
Attached File(s)
olivine
post Sep 13 2012, 21:55
[edit] I couldn't compile it properly on linux (as the person posting before me) until I figured out that I had to edit the make file to make it work. Duh.
It looks very promising, although up to now I've only been able to check images that don't need it, because they've been ripped with EAC + AccurateRip. I'd like to verify rips done with rubyripper...
This post has been edited by olivine: Sep 13 2012, 22:13
RSS Lo-Fi Version Time is now: 5th September 2015 - 11:46
