Default UI .fth thread, for when you get those requests
NullString
post Feb 16 2008, 22:04
This post has been edited by shakey_snake: Jun 3 2009, 19:45
sizetwo
post Jul 9 2008, 14:06
laugh.gif Love your config. I use it (slightly modified) a lot ... Thanks!
synclpz
post Aug 20 2008, 12:20
which plugins should i have to run this?
NullString
post Aug 20 2008, 15:54
just foobar 0.9.5+ and facets.
synclpz
post Aug 21 2008, 19:30
Thanx, got a bit stupid about it %)
shakey_snake
post Jun 3 2009, 19:49
Group: FB2K Moderator
Color scheme made to match purple nebula like backgrounds, like this one.
Import "main layout" for spectrogram colors.
(pic)
Attached File  nebula_matching_colors.zip ( 2.59K ) Number of downloads: 643
This post has been edited by shakey_snake: Jun 3 2009, 20:01
elevatorladylevitateme
phool
post Jun 8 2009, 13:29
In response to the request to upload my configuration I posted here
The "Livesets" tab probably won't work out so well as I've used custom tags in conjunction with Facets there.
Attached File(s)
jasondavidcarr
post Mar 23 2010, 15:17
I thought I'd share my foobar2000 theme and setup because there's not a whole lot of basic default user interface themes that are pretty and functional (let alone easy to set up). This theme promises to be all three (but the first is obviously subjective). First off, some screenshots:
Installation
1. Start with a fresh installation of foobar2000 1.0.1 (or a later version).
2. Download the attached "Jason's Clean Theme 1.0.zip" file and extract it directly into your foobar2000 installation directory (overwrite all necessary files/folders).
3. Start up foobar2000, and everything will be set, but you'll have no music in your library. Go to the File menu and select Preferences.
4. In the Preferences window, select "Media Library" on the left, and then click the "Add..." button in the top right.
5. Choose the folder where all of your music resides.
6. Press OK out of the Preferences dialog, wait a few seconds for foobar2000 to parse your music, and then you're all set!
Usage Tips
Double-click on an album in the playlist to bring up the songs for that album. In the songs, double-click the name of the album to go back to the album covers.
Double-click on the status bar at the bottom to jump to the currently playing song in the playlist.
To set the rating for a song, right-click on the song and select Playback Statistics > Rating > 1-5. Or use Ctrl-1 through Ctrl-5 as a keyboard shortcut (Ctrl-~ clears the rating).
The colors are completely customizable via the Display > Standard User Interface > Colors and Fonts preferences dialog.
By default, ratings and playback statistics are stored only in foobar2000's database. To automatically store them in the song file tags as well, check the "Automatically synchronize file tags with statistics" option under Advanced > Tools > Playback Statistics in the preferences dialog. The interface mentions that this is "disrecommended" (which isn't a word, by the way), but this feature works perfectly fine for me.
Components
You'll need to pick up the components from here and put them in your components subfolder:
  1. Facets (foo_facets.dll) - http://foobar2000.audiohq.de/foo_facets/
    - Used for the top genre, artist, and album filtering.
  2. Playback Statistics (foo_playcount.dll) - http://www.foobar2000.org/components/view/foo_playcount
    -Used to keep track of song ratings and statistics.
  3. EsPlaylist (foo_uie_esplaylist.dll) - http://foo2k.chottu.net/
    -Used for the bottom album art-enabled playlist.
Let me know your thoughts or if you run into any issues.
Jason
[Merger #1]
I should note that the theme will work just fine under XP, except for the rating stars. This is due to the fact that the default XP user interface font doesn't include the necessary star characters. See this thread for a workaround:
http://www.hydrogenaudio.org/forums/lofive...php/t71224.html
You'll want to right-click on the Rating column header, select "Edit Column", and put the code from the above thread into the Format box.
If you're running Windows Vista or Windows 7, it should work just fine out of the box.
[Merger #2]
My post was moved here from a separate thread and the attachment was deleted because I bundled the necessary components (which apparently doesn't fly). I've attached a new zip file without the components included.
This post has been edited by shakey_snake: Mar 23 2010, 15:22
Reason for edit: Merged.
Attached File(s)
Attached File  Jason_s_Clean_Theme_1.0.zip ( 5.75K ) Number of downloads: 1916
atca_de
post May 19 2013, 10:49
QUOTE (jasondavidcarr @ Mar 23 2010, 15:17) *
Jason
Hello Jason,
thank you for sharing your layout. :-)
Unfortunately I donīt get get the Album-Arts page to look like yours..
I only see the Album title, Artist-Name, year and genre right-side the Album-Cover.. So I donīt geht more than three Albums in a row.
What do I have to change?
Regards,
Markus
marc2003
post May 19 2013, 12:41
EsPlaylist is probably configured to show the contents of the active playlist. right click>browse>browse library to show everything.
RSS Lo-Fi Version Time is now: 31st March 2015 - 19:12
