Create playlists out of every album
zoddic
post Feb 4 2008, 16:20
As title says:
Is there a way to create a playlist for every album in my media library? I don't wanna go through 50gb of music manually, will take forever.
*edit*
The main reason for this is to be able to "play" those playlists from the launchy applikation. As it is now, if I pick an album in launchy and press enter, it opens up an explorer window containing all music from that album. I want the whole album to open up in foobar instead. The only way I can imagine this is possible is to use playlists to open from launchy. */edit*
This post has been edited by zoddic: Feb 4 2008, 18:41
uXs
post Feb 5 2008, 14:54
QUOTE (zoddic @ Feb 4 2008, 16:20) *
As title says:
*edit*
http://rapidshare.com/files/89351108/Gener...ylists.zip.html
This is a program I made to generate playlists. It works best if you have your albums and tracks organized strictly the way I have them, which is: "root music folder/genre/artist/year-album/track-title.extension". It may work with other folder structures as well, but I haven't tested it. (Playlists by year require the year-album folder naming though, obviously.)
You'll need an existing folder where it will put your playlists. (Warning: this folder will have its content erased.) If you want playlists by year as well, you'll need another (different) folder for that. (Same warning.) (The playlists by year will be put in the main folder, but it needs this one as a temporary folder.) Finally, if you have manually made playlists that you want to use, you need yet another folder and put the playlists in there. (This one will not be erased. smile.gif)
You can have multiple root music folders, the program will merge them. If it encounters the same album twice, the first one will be used. (This is nice if you have lossless and lossy versions of the same albums. Put the lossless version first and that's the one that will be used. Folder and file names have to be the same but the extension can vary.)
The program generates .m3u8 files.
Final optional step is using the playlists folder as your "My Music" folder in the start menu. Use Tweak UI for that.
No guarantees that it works. I've been using it for like a year (upgrading it now and then) without any problems, but I'm rather anal about folder structures for my music.
No viruses either, but I can hardly expect anyone to trust me. Hell, I wouldn't trust me myself. No source code because it's at home.
This post has been edited by uXs: Feb 5 2008, 14:58
zoddic
post Feb 7 2008, 21:08
QUOTE (uXs @ Feb 5 2008, 14:54) *
As title says:
*edit*
Cool, i'll check it out when I get home, thanks!
*edit* It works! Thanks
This post has been edited by zoddic: Feb 8 2008, 12:06
RSS Lo-Fi Version Time is now: 3rd August 2015 - 14:33
