Topic: .Ogg Vorbis aotuv (Read 486930 times) previous topic - next topic
.Ogg Vorbis aotuv
 count me in!
Give Ogg a boost again!
.Ogg Vorbis aotuv
I like it for my rockbox nano and it's one of the best lossy formats for my Squeezebox. I very much would be interested in a new release.  Thank you for the last.
.Ogg Vorbis aotuv
Yeah, i'll just say +1 and thanks for your hard work. Any improvement is of course a welcome improvement, this codec is excellent for quality and filesize.
- Spike
.Ogg Vorbis aotuv
Another "yes" vote, and a big "thank you" to Aoyumi for making the codec so good already.
.Ogg Vorbis aotuv
Another thanks and hoping for another release!
.Ogg Vorbis aotuv
Reply #30
one more.
.Ogg Vorbis aotuv
I use Vorbis on my portable Samsung player. It's the best lossy codec, and Aoyumi made it better. Aoyumi is number one! Thanks for your work!
.Ogg Vorbis aotuv
+1
I use Vorbis for all portable use. Thanks for all the effort put into this great project. I can only hope for Ogg Vorbis to survive.
.Ogg Vorbis aotuv
Reply #33
I also use this version to squeeze music on to my portable player at about 64 kbps. I mostly use this for transcribing/learning songs so the quality doesn't have to be perfect. Very much appreciate your efforts at the low bit rates here!
.Ogg Vorbis aotuv
Reply #35
But sure. Here is the next PRO vote !
.Ogg Vorbis aotuv
Reply #37
I just found out that the new cheap SONY flash based mp3 players they all play OGG now... So I'm considering! Not sure as why the aouTuV b5 is the recommended encoder since it introduces noise in the high frequencies...
.Ogg Vorbis aotuv
Reply #38
AFAIK It only introduces noise if you increase the low-pass settings far over the default value.
.Ogg Vorbis aotuv
Reply #39
the noise shows up with "-s %r -Q -q5,000000 - -o %d" which is pretty standard in FB2K, no low-pass setting... You just can't see the noise if you encode with q3 and below because the lowpass will be automatically lower.
can anyone tell me if libvorbis 1.2.0 has aotuv4.5/R1 incorporated into the code?
.Ogg Vorbis aotuv
Reply #40
I'm not sure, but if I remember correctly autuv beta 2 was the last to be merged into libvorbis. 1.2.0 brings additional fixes, but no aotuv tunings.
.Ogg Vorbis aotuv
Reply #41
http://svn.xiph.org/trunk/vorbis/CHANGES:
libvorbis 1.1.0 (2004-09-22) -- "Xiph.Org libVorbis I 20040629"
* merges tuning improvements from Aoyumi's aoTuV with fixups
readme.txt from oggenc_aoTuV_b5.zip:
"Since beta2 was adopted as official 1.1, beta3 uses 1.1 as a base"
That's all.
.Ogg Vorbis aotuv
Reply #42
OK.  I begin the work that is necessary for release of beta5.5.
Thank you for many statements.?
Thank You for everything you've done, it's appreciated.
.Ogg Vorbis aotuv
Reply #43
Where do u see noise on Q5 Bourne? im using AoTuV b5 encoder at Q5 and i tested it with the original wav many times and i havent noticed noise at that quality.
.Ogg Vorbis aotuv
Reply #44
Ayoumi have acknowledged the problem so you don't need to be looking for it
(and I'm too lazy to explain now...)
.Ogg Vorbis aotuv
Reply #45
Then i hope he can focus more on this problem at the specific bitrates that causes it on his new beta 5.5 release.
.Ogg Vorbis aotuv
Reply #46
I see Aoyumi has already agreed to release a new version, but for what it's worth, I'm in favor as well.  Ogg vorbis is my singular favorite codec, so I'm always in favor of anything that strengthens it!
I just discovered Opus. Holy mackerel!
.Ogg Vorbis aotuv
Reply #47
I released "aoTuV" beta5.5 today.
aoTuV page
.Ogg Vorbis aotuv
Reply #48
Thanks Aoyumi!
.Ogg Vorbis aotuv
Reply #49
I released "aoTuV" beta5.5?today.
aoTuV page
A full set of compiles will be available at Rarewares a little later. You will notice that oggenc2.85 and oggdropXPd1.9.0 in aoTuVb5.5 flavours have grown quite considerably in size. This is due to the inclusion of the new 0.1.3 release of libsamplerate as the built in resampler. According to Erik, the medium and best options are now of notably higher quality.
