23 Pages V  « < 16 17 18 19 20 > »
.Ogg Vorbis aotuv, Question for Aoyumi
[JAZ]
post Feb 23 2011, 00:18
Post #426
You needed four minutes for 8 positive ABX in a "Very easily noticeable" test? :?
What's wrong, you methodology to test, or your description?
sauvage78
post Feb 23 2011, 00:35
Post #427
Sorry, don't get your problem. I knew which artefact I was searching & I always found it, so for me it was easy.
As I said the bug is not included in the ABXing. Obviously you didn't read correctly.
Edit: In case it wasn't clear I will re-word it: I ABXed the 5 first seconds only (which is not transparent) & the bug itself is at second 10-13 so not ABXed (but it doesn't need ABXing anyway as it is huge)
This post has been edited by sauvage78: Feb 23 2011, 00:44
CDImage+CUE
Secure [Low/C2/AR(2)]
Flac -4
Destroid
post Feb 23 2011, 00:42
Post #428
Yeah, I heard it, sounds like water jug artifact that should not be there.
Odd, at -q0 it doesn't f*** up at all that I can hear.
edit: forgot to mention was using Rarewares generic compile, if it matters.
edit2: artifact bug reported starts happening at -q2 and above
This post has been edited by Destroid: Feb 23 2011, 00:55
clobon
post Feb 23 2011, 07:49
Post #429
Hi there,
first things first: a very big Thank you to Aoyumi and John33 for all the good work!!!
Is there a chance that this bug concerning short_block_test_2 will be audible in "normal" music?
Regards, Clobon
Aoyumi
post Feb 23 2011, 11:56
Post #430
QUOTE (lvqcl @ Feb 23 2011, 03:16) *
Bug report: incorrect encode of short_block_test_2.flac
(you can download it here - http://web.archive.org/web/20030618115117/...s/test_samples/ )
added: here it is [attachment=6375:short_block_test_2.wv]
Thank you for a report.
I investigated it and found one mistake.
I will release the revision soon.
Aoyumi
lvqcl
post Feb 23 2011, 12:32
Post #431
QUOTE (Aoyumi @ Feb 23 2011, 13:56) *
Aoyumi
I'm glad that it helped. And thanks for the new aoTuV.
alter4
post Feb 23 2011, 13:14
Post #432
@Aoyumi
At first Aoyumi, thank you very match for your work again !!!!!
On topic: I have idea, It is not new and maybe a little bit premature but I propose to release final beta6 branch (e.g. beta 6.4 ... you know) as Aotuv Release2 (R2) with the purpose to reflect stability and fine changes from Release 1
rt87
post Feb 23 2011, 15:42
Post #433
aoTuV Beta6.01 [beta6 >> beta6.01] (2011/02/23)
# In the specific pattern, the bug that caused overflow was fixed.
Sorry for my English.
alter4
post Feb 23 2011, 15:51
Post #434
QUOTE (john33 @ Feb 22 2011, 20:13) *
QUOTE (rt87 @ Feb 22 2011, 16:12) *
Aoyumi
Post #435
Hi all,
I released a revision.
Please replace the previous version with the new version.
Aoyumi
john33
post Feb 23 2011, 16:52
Post #436
xcLame and OggDropXPd Developer
QUOTE (alter4 @ Feb 23 2011, 14:51) *
John
john33
post Feb 23 2011, 17:44
Post #437
John
Andavari
post Feb 23 2011, 18:25
Post #438
Is it Oggenc 2.85 using aoTuVb 6.01 or Oggenc 2.87 using aoTuVb 6.01? Just wondering because of the version listed on the Rarewares.org page before I 7-Zip them up and archive them locally.
Link: http://www.rarewares.org/ogg-oggenc.php#oggenc-aotuv
Complexity of incoherent design.
alter4
post Feb 23 2011, 18:49
Post #439
C:\>oggenc2.exe -h
OggEnc v2.87 (aoTuV Beta 6.01)
© 2000-2005 Michael Smith <msmith@xiph.org>
& portions by John Edwards <john.edwards33@ntlworld.com>
Usage: oggenc2 [options] input.wav [...]
john33
post Feb 23 2011, 19:26
Post #440
QUOTE (Andavari @ Feb 23 2011, 17:25) *
Edit: Done. smile.gif
This post has been edited by john33: Feb 23 2011, 19:29
John
IgorC
post Feb 24 2011, 04:56
Post #441
Thank you, Aoyumi.
Really great work.
http://listening-test.coresv.net/results.htm
Nowings69
post Feb 24 2011, 06:02
Post #442
Congratulations and thank you very much
I used many trial issues since August of the last year without knowing this one.
the_cat
post Feb 24 2011, 19:40
Post #443
what is the recommended preset for the current version
thank you all
capma
post Feb 24 2011, 20:00
Post #444
I'm having trouble with john33's oggenc2 and encoding of 6 ch WAV file: bitrate is too low (average 151 kbps @ Q10), sounds awfully. Previous version (based on b5.7) encodes file properly.
alter4
post Feb 24 2011, 22:35
Post #445
Can confirm the bug with venc.exe too. Vanilla vorbis 1.3.2 is ok.
Looks like bug in aotuv but not in John compilation.
This post has been edited by alter4: Feb 24 2011, 22:45
Nowings69
post Feb 25 2011, 10:14
Post #446
@john33
Could you change your oggenc2's writing library in OGG COMMENT?
oggenc2(yours)
AO; aoTuV [20110223] (based on Xiph.Org's libVorbis)
venc
I wanna diplay your oggenc2 for aotuv
like this
This post has been edited by Nowings69: Feb 25 2011, 10:18
sauvage78
post Feb 25 2011, 10:28
Post #447
It's called "vendor string", both looks identical in your post, so what's your problem? john33 ain't gonna display oggenc2 version in vorbis's vendor string if that's what you're asking for. (I'm not sure I get what you want ...)
This post has been edited by sauvage78: Feb 25 2011, 10:33
CDImage+CUE
Flac -4
Nowings69
post Feb 25 2011, 10:36
Post #448
QUOTE (sauvage78 @ Feb 25 2011, 18:28) *
it's called "vendor string", both looks identical in your post.
OH
Sorry,I didnt care here is not for Foobar.
But I hope he understand what im saying
alter4
post Feb 25 2011, 11:09
Post #449
Very interesting things, at my laptop all is ok (with venc and oggenc2) with converting 6ch-wav to 6ch-ogg, but the 6ch samples are different. Maybe the problem is file specific.
I will additionally check the problem at home today night and attach a problematic sample if so.
john33
post Feb 25 2011, 12:17
Post #450
QUOTE (Nowings69 @ Feb 25 2011, 09:14) *
@john33
oggenc2(yours)
venc
like this
Are you saying that you want the 'AO: ' removed from the front of the Vendor String? If so, I'm not sure that I should considering Aoyumi created the modified libraries and that is his chosen Vendor String. To change it might suggest that I am using a different version of the libraries.
John
RSS Lo-Fi Version Time is now: 1st February 2015 - 17:57
