.Ogg Vorbis aotuv, Question for Aoyumi
Nicos
post Feb 1 2008, 16:48
Mr. Aoyumi
I was wondering if your are near to release a new update version of your
"ogg vorbis version".
Also will you focus on better quality at higher bitrates? (which ones?) and what kind of changes will they be on the next update?
I will appreciate your answer
Thanks in advance
john33
post Apr 4 2008, 21:14
xcLame and OggDropXPd Developer
What command line are you using from foobar and what options are you specifying in oggdropXPd? Sorry to be a pain, but I need to know whether foobar is doing something different. wink.gif
John
Kef
post Apr 5 2008, 04:29
QUOTE (john33 @ Apr 4 2008, 22:14) *
I'm just using default settings and -q0.
oggenc2 and oggdropXPd downloaded from rarewares
This post has been edited by Kef: Apr 5 2008, 07:53
john33
post Apr 5 2008, 09:23
QUOTE (Kef @ Apr 5 2008, 03:29) *
No tagging at all?
John
Kef
post Apr 5 2008, 09:44
QUOTE (john33 @ Apr 5 2008, 10:23) *
No tagging at all?
Ehum... I usually don't use tags but I checked the source (reference libFLAC 1.1.2 20050205) files and yes they are tagged.
QUOTE (Kef @ Apr 5 2008, 10:43) *
No tagging at all?
Maybe it would be a good idea to use wav's to eliminate any tagging problem?
<edit>
I tested with a wav file and it worked perfectly, when I use the flac file it doesn't (using foobar2000 for both). Seems like some tagging problem to me.
</edit>
<edit2>
I removed the tags from the ogg file and still no luck
</edit2>
This post has been edited by Kef: Apr 5 2008, 10:01
john33
post Apr 5 2008, 10:17
QUOTE (Kef @ Apr 5 2008, 08:44) *
<edit>
</edit>
<edit2>
</edit2>
So, if I understand this correctly, the ogg files created from the FLAC files using foobar, with tags copied from the FLAC files, fail in your portable.
The ogg files created from the FLAC files using oggdropXPd are read fine in the portable, but do they contain tags, or not?
The fact that removing the tags from the ogg files doesn't solve the problem may suggest that the tagging routines in foobar are behaving in a way that is not quite standard, or if the oggdropXPd generated files aren't created with tags, then there is something about tagging that the iRiver doesn't like.
Edit: Sorry, thinking about it, the comment about foobar tagging routines is probably complete nonsense since it will presumably just feed the tagging routines in oggenc2!
This post has been edited by john33: Apr 5 2008, 10:32
John
Kef
post Apr 5 2008, 10:37
Correct
They don't contain any tags.
Anyway, I'm glad to find out it probably isn't a bit-stream problem. This is the first time I have encountered this problem and I have done a lot of conversions with both foobar and oggdropXPd. But as a previous poster suggested, it might have something to do with the new 1.2.0 libvorbis. I haven't used 1.2.0 until now (there was no reason to) and since aoTuVb5.5 is using 1.2.0 that might indeed be the problem. Luckily, there are workarounds for me. wink.gif
<edit>
I'll test with libvorbis 1.2.0 later today and let you know if the problem is still there.
</edit>
This post has been edited by Kef: Apr 5 2008, 10:44
- Nicos   .Ogg Vorbis aotuv   Feb 1 2008, 16:48
- - Aoyumi   QUOTE (Nicos @ Feb 2 2008, 00:48) I was w...   Feb 3 2008, 15:28
|- - The Sheep of DEATH   QUOTE (Aoyumi @ Feb 3 2008, 08:28) QUOTE ...   Feb 17 2008, 19:50
|- - Aoyumi   QUOTE (The Sheep of DEATH @ Feb 18 2008, 03...   Feb 19 2008, 15:09
|- - Kef   QUOTE (Aoyumi @ Feb 19 2008, 16:09) QUOTE...   Feb 20 2008, 17:08
- - Bourne   -   Feb 17 2008, 19:57
- - The Sheep of DEATH   Not amusing? If that's true, it's sad to ...   Feb 17 2008, 21:19
- - Bourne   I think he's gotta a point though... lossless ...   Feb 18 2008, 02:55
|- - Josef K.   QUOTE (Bourne @ Feb 18 2008, 02:55) I thi...   Feb 20 2008, 20:29
- - johnsonlam   Disappointing of few hardware support during these...   Feb 18 2008, 04:55
- - simonh   That would be great Aoyumi. That's three peopl...   Feb 19 2008, 15:14
- - Kim_C   I'd like to have a new release too, although i...   Feb 19 2008, 18:37
|- - urak   QUOTE (Kim_C @ Feb 19 2008, 18:37) I...   Feb 20 2008, 14:05
- - Nicos   Kim C has a point. Please do it Aoyumi. There are...   Feb 20 2008, 12:59
|- - esa372   QUOTE (Nicos @ Feb 20 2008, 03:59) Please...   Feb 20 2008, 16:13
- - alter4   I think beta 5.5 is a good thing to keep vorbis an...   Feb 20 2008, 13:08
- - riggits   Vorbis is my codec of choice for music, even for a...   Feb 20 2008, 21:38
- - Lu Tze   For my hard drive I use APE, but for my portable p...   Feb 20 2008, 21:48
- - The Sheep of DEATH   And of course I support a b5.5 release as well, so...   Feb 21 2008, 01:35
- - dB   Same here, +1 many thanks   Feb 21 2008, 03:35
- - Aoyumi   OK. I begin the work that is necessary for releas...   Feb 21 2008, 15:15
|- - jamesbaud   QUOTE (Aoyumi @ Feb 21 2008, 07:15) OK. ...   Feb 21 2008, 17:26
|- - Oliver   QUOTE (Aoyumi @ Feb 21 2008, 10:15) OK. ...   Mar 1 2008, 01:32
|- - m_l   QUOTE (Aoyumi @ Feb 21 2008, 09:15) OK. ...   Mar 2 2008, 01:02
- - Nicos   Good to hear that Aoyumi I'm sure you will m...   Feb 22 2008, 12:33
- - le_canz   QUOTE (The Sheep of DEATH @ Feb 21 2008, 01...   Feb 22 2008, 13:37
- - vinnie97   Just adding another voice of support for this. Th...   Feb 22 2008, 13:42
|- - lex_nasa   Another "yes" vote, and a big "than...   Feb 25 2008, 14:22
- - Arkadas   count me in! Give Ogg a boost again!   Feb 22 2008, 14:16
- - nonreality   I like it for my rockbox nano and it's one of ...   Feb 22 2008, 15:44
- - Spikey   Yeah, i'll just say +1 and thanks for your har...   Feb 24 2008, 02:43
- - edwardar   Another thanks and hoping for another release!   Feb 25 2008, 21:24
- - stigc   one more.   Feb 25 2008, 22:49
- - chapas   I use Vorbis on my portable Samsung player. It...   Feb 26 2008, 04:13
- - Emanuel   +1 I use Vorbis for all portable use. Thanks for ...   Feb 26 2008, 12:44
- - Kujibo   I also use this version to squeeze music on to my ...   Feb 26 2008, 19:46
- - HisInfernalMajesty   Another vote here. Thank you so much for everyth...   Feb 26 2008, 21:15
- - Ojay   But sure. Here is the next PRO vote !   Feb 29 2008, 11:09
- - Bourne   I just found out that the new cheap SONY flash bas...   Mar 1 2008, 03:59
|- - Kef   QUOTE (Bourne @ Mar 1 2008, 04:59) I just...   Mar 1 2008, 07:18
- - Bourne   the noise shows up with "-s %r -Q -q5,000000 ...   Mar 1 2008, 21:01
|- - ilikedirtthe2nd   QUOTE (Bourne @ Mar 1 2008, 21:01) can an...   Mar 1 2008, 21:13
|- - lvqcl   QUOTE (Bourne @ Mar 1 2008, 23:01) can an...   Mar 1 2008, 23:58
- - Nicos   Where do u see noise on Q5 Bourne? im using AoTuV ...   Mar 3 2008, 20:45
- - Bourne   Ayoumi have acknowledged the problem so you don...   Mar 4 2008, 19:17
- - Nicos   Then i hope he can focus more on this problem at t...   Mar 5 2008, 09:40
- - Jerethi   I see Aoyumi has already agreed to release a new v...   Mar 17 2008, 06:23
- - Aoyumi   I released "aoTuV" beta5.5 today....   Mar 31 2008, 14:59
|- - john33   QUOTE (Aoyumi @ Mar 31 2008, 13:59) I rel...   Mar 31 2008, 16:55
|- - kjoonlee   QUOTE (Aoyumi @ Mar 31 2008, 14:59) I rel...   Mar 31 2008, 19:00
|- - Kef   QUOTE (Aoyumi @ Mar 31 2008, 15:59) I rel...   Apr 1 2008, 06:26
|- - cpchan   QUOTE (Aoyumi @ Mar 31 2008, 08:59) I rel...   Apr 2 2008, 02:03
- - jetpower   Thanks Aoyumi!   Mar 31 2008, 15:44
- - urak   Aoyumi, thanks a lot   Mar 31 2008, 18:01
- - Kim_C   Yatta! Especially arigatō for pre-ech...   Mar 31 2008, 18:46
|- - le_canz   Thank you for this release, Aoyumi   Mar 31 2008, 18:49
- - echo   Thank you so much Aoyumi!   Mar 31 2008, 18:50
- - henkersmahlzeit   Great Man!!!   Mar 31 2008, 18:57
- - john33   Compiles now available at Rarewares.   Mar 31 2008, 20:01
|- - henkersmahlzeit   Thnx too, John ... your compile is much faster on ...   Mar 31 2008, 21:30
- - akapuma   Thank you very much, Aoyumi and John. Vorbis is m...   Mar 31 2008, 21:36
- - Arkadas   Thank YYYYYOOOOOUUUUUUUU   Mar 31 2008, 22:14
- - VEG   Thanks Aoyumi! Vorbis rulez!   Mar 31 2008, 23:39
- - halb27   Though I'm not a vorbis user I admire your gre...   Apr 1 2008, 09:38
- - alter4   Thx Aoyumi!!! Pre-echo is real less. W...   Apr 1 2008, 13:33
|- - Kef   QUOTE (alter4 @ Apr 1 2008, 14:33) Thx Ao...   Apr 1 2008, 20:20
- - bukem   That is great news indeed. Just can't wait to ...   Apr 1 2008, 15:46
|- - m_l   Thank You Aoyumi and John I too await LANCER ver...   Apr 2 2008, 04:14
- - DreamTactix291   Thank you very much for the new release. Been usi...   Apr 2 2008, 00:27
- - Spikey   +1- I hope BlackSword is still going to do Lancer ...   Apr 2 2008, 05:21
- - Nicos   Aoyumi you did it finally Thanks for all. I s...   Apr 2 2008, 10:27
|- - lex_nasa   Many many thanks!   Apr 2 2008, 15:14
- - fj4   Thanks for your hard work, Aoyumi, and thanks for ...   Apr 2 2008, 15:53
- - hödyr   Also thanks alot from me, I think without your wor...   Apr 2 2008, 17:34
- - ckjnigel   Sugoi! Otsukaresama deshita! The first thi...   Apr 2 2008, 18:57
- - The Sheep of DEATH   This makes a fine birthday present. I'm glad ...   Apr 3 2008, 01:08
- - vonbach   Are there any noticeable improvements when using q...   Apr 3 2008, 05:25
- - Nicos   Im kind of interested about the first question asw...   Apr 3 2008, 12:07
- - The Sheep of DEATH   Audible improvements at q5? If a5 was transparent...   Apr 3 2008, 22:59
- - Nicos   But what about the pre-echo problems at high bitra...   Apr 4 2008, 08:42
|- - Kef   Does anybody else have problems with this beta 5.5...   Apr 4 2008, 17:46
|- - lvqcl   QUOTE (Kef @ Apr 4 2008, 20:46) Does anyb...   Apr 4 2008, 19:08
||- - Kef   QUOTE (lvqcl @ Apr 4 2008, 20:08) QUOTE (...   Apr 4 2008, 19:21
||- - Kef   QUOTE (Kef @ Apr 4 2008, 20:21) QUOTE (lv...   Apr 4 2008, 20:00
||- - john33   QUOTE (Kef @ Apr 4 2008, 19:00) But that...   Apr 4 2008, 20:13
||- - Kef   QUOTE (john33 @ Apr 4 2008, 21:13) QUOTE ...   Apr 4 2008, 20:28
|- - Aoyumi   QUOTE (Kef @ Apr 5 2008, 01:46) Does anyb...   Apr 5 2008, 11:47
- - john33   What command line are you using from foobar and wh...   Apr 4 2008, 21:14
|- - Kef   QUOTE (john33 @ Apr 4 2008, 22:14) What c...   Apr 5 2008, 04:29
|- - john33   QUOTE (Kef @ Apr 5 2008, 03:29) QUOTE (jo...   Apr 5 2008, 09:23
|- - Kef   QUOTE (john33 @ Apr 5 2008, 10:23) QUOTE ...   Apr 5 2008, 09:44
|- - john33   QUOTE (Kef @ Apr 5 2008, 08:44) ...... M...   Apr 5 2008, 10:17
|- - Kef   QUOTE So, if I understand this correctly, the ogg ...   Apr 5 2008, 10:37
|- - lvqcl   QUOTE (john33 @ Apr 5 2008, 13:17) Edit: ...   Apr 5 2008, 10:53
- - john33   Try a conversion using oggdropXPd and set the opti...   Apr 5 2008, 10:54
|- - Kef   QUOTE (john33 @ Apr 5 2008, 11:54) Try a ...   Apr 5 2008, 11:06
|- - john33   QUOTE (Kef @ Apr 5 2008, 10:06) QUOTE (jo...   Apr 5 2008, 11:35
- - LigH   Are you still interested in material that provokes...   Apr 5 2008, 11:54
|- - Aoyumi   QUOTE (LigH @ Apr 5 2008, 19:54) Are you ...   Apr 5 2008, 23:57
- - Moguta   Thanks for this new release, Aoyumi! The low ...   Apr 6 2008, 01:36
6 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 2nd March 2015 - 03:10
