in_mad v2 Winamp MAD MP3 input plugin
MoSPDude
post Jan 12 2008, 12:44
Hi, this is a long awaited (although not fully finished) conversion and improvement of my previous updated in_mad plug-in.
The notable new features/fixes (that I can remember from notes) include,
* Re-written/ported to C++ to 'enable' better WA5 compatibility
* Fully Unicode GUI
* Icecast mp3 streaming fixed
* WA5 Global Configuration supported
* Improved basic and advanced editing
* Slightly improved ID3v2.3 support
* 32 bit output uses full internal 28 bit representation
* Advanced-style Basic formatting for WA2
* Non-Unicode backward compatible for WA2 (not fully tested)
* Multi-lingual dialogs (once someone translates!)
* Re-designed APE tag support including Unicode
The playback and EQ backend is mostly the same except ported through to C++ and into a class structure.
However some things are incomplete,
* New Binary editor disabled
* EQU2 tag editing and writing disabled
The latest DLL can be downloaded from http://www.zen23652.zen.co.uk/in_mad_2b.zip.
Source code is now separate from http://www.zen23652.zen.co.uk/in_mad_2b_src.zip
This post has been edited by MoSPDude: Jan 12 2008, 12:44
MoSPDude
post Mar 4 2008, 09:19
Hi Emre,
I've dropped back to FPM_INTEL (as in my previous in_mad) mainly to see if this helps with peoples problems. As far as I know VS2005 does support 64bit signed int properly however. I kept OPT_ACCURACY on in both cases. I personally didn't notice a difference in speed, though I'd need to test it further. In mad.h, it strongly recommends against FPM_DEFAULT.
If anyone has noticed any major differences as such (eg. improved the stuttering) please feedback.
Edit: As this is the first time I've tried FPM_INTEL in Visual Studio, it appears to not take account of OPT_ACCURACY as it did using GCC. I'll have a look into it.
This post has been edited by MoSPDude: Mar 4 2008, 09:23
Emre
post Mar 5 2008, 04:03
QUOTE (MoSPDude @ Mar 4 2008, 10:19) *
Hi Emre,
Hi MoSPDude,
I did some tests with ffdshow's libmad component. i get source code via svn (rev 1882) and i did some modifications in libmad project files. i compiled ff_libmad.dll with vc2005 express and vc2008 express.
for speed test i used foobar2000 with haali's foo_input_ds plugin.
directshow filter chain: source mp3 in matroska container -> haali splitter -> ffdshow audio decoder (libmad)
test results with foobar2000's decoding speed test plugin (cpu core2duo e6550~2.8ghz):
FPM_INTEL VC8 : 115,674x
FPM_INTEL VC9 : 116.268x
FPM_64BIT VC8 : 76.676x
FPM_64BIT VC9 : 77.104x
clsid's build (rev 1882) FPM_INTEL ICL10 (SSE) : 124.217x
xxl's build (rev 1878) FPM_INTEL VC7 : 113.877x
i can't sure about this test accuracy but it seems FPM_64BIT ~%34 slower than FPM_INTEL.
cheers...
- MoSPDude   in_mad v2 Winamp MAD MP3 input plugin   Jan 12 2008, 12:44
- - j7n   This version is great, most importantly special ch...   Jan 12 2008, 22:47
- - MoSPDude   As a note, I've only tested this on Windows XP...   Jan 13 2008, 00:00
|- - Maggi   QUOTE (MoSPDude @ Jan 13 2008, 01:00) If ...   Jan 14 2008, 16:21
|- - MoSPDude   OK, that one bug already! I'm uploading...   Jan 14 2008, 18:08
||- - Maggi   QUOTE (MoSPDude @ Jan 14 2008, 19:08) OK,...   Jan 15 2008, 10:41
|- - j7n   I tried to run Winamp 5.35 under Win98. UTF charac...   Jan 14 2008, 18:10
- - Kjn_Wds   Great work, as usual : ) !   Jan 14 2008, 16:02
- - MoSPDude   True, I was hoping Windows 98 wouldn't have a ...   Jan 14 2008, 18:21
- - MoSPDude   I just checked to see if Unicows was linked with t...   Jan 15 2008, 00:46
- - BtEO   Winamp 5.51 on Windows XP. The new version of thi...   Jan 16 2008, 05:07
- - MoSPDude   I've uploaded a fix for the tag reading proble...   Jan 16 2008, 08:55
- - Domin   Would there be a way to fix it so when streaming m...   Jan 16 2008, 22:13
- - MoSPDude   Hi Domin, in what way does it crash when the strea...   Jan 17 2008, 00:46
|- - Domin   QUOTE (MoSPDude @ Jan 17 2008, 00:46) Hi ...   Feb 17 2008, 14:55
- - kerimcem   turkish character I,İ,Ş,Ğ ID3V2 no...   Jan 18 2008, 13:12
- - MoSPDude   I've uploaded another update, this adds suppor...   Jan 22 2008, 20:08
|- - j7n   The latest in_mad now fails to load under Win98. I...   Jan 22 2008, 21:29
|- - robert   QUOTE (j7n @ Jan 22 2008, 21:29) The late...   Jan 22 2008, 22:08
- - MoSPDude   Under my virtual machine on WA 5.35 it works well....   Jan 22 2008, 21:51
|- - [JAZ]   QUOTE (MoSPDude @ Jan 22 2008, 22:51) EDI...   Jan 22 2008, 22:06
- - zipr   Where can I find out exactly what this plugin is s...   Jan 25 2008, 16:54
- - MoSPDude   This plug-in is an alternative mp3 decoder plug-in...   Jan 25 2008, 18:11
|- - benski   QUOTE Where can I find out exactly what this plugi...   Jan 25 2008, 18:40
|- - lvqcl   QUOTE (benski @ Jan 25 2008, 20:40) The a...   Jan 27 2008, 14:50
- - MoSPDude   Its nice for the latest Winamp versions to have th...   Jan 26 2008, 11:40
|- - j7n   QUOTE (MoSPDude @ Jan 26 2008, 12:40) @j7...   Jan 29 2008, 20:51
- - nemoW   Thanks for Unicode file/pathname support![hr] ...   Jan 27 2008, 21:30
- - nonreality   I set it up in Mediamonkey and it seems to work fi...   Jan 30 2008, 04:02
- - Sylph   Hey, MoSPDude, thank you so much for the plugin...   Feb 1 2008, 18:13
- - MoSPDude   Hey, I've uploaded an update to fix the Replay...   Feb 1 2008, 19:13
|- - Sylph   QUOTE (MoSPDude @ Feb 1 2008, 19:13) Hey,...   Feb 1 2008, 19:20
- - MoSPDude   The first link on the main page contains the lates...   Feb 1 2008, 19:40
|- - Sylph   QUOTE (MoSPDude @ Feb 1 2008, 19:40) The ...   Feb 1 2008, 20:07
- - _Raziel-BG   It acts kinda strange here. On some MP3s it shows ...   Feb 3 2008, 05:54
- - Orochi7777   MoSPDude I love what you have done with this plugi...   Feb 7 2008, 05:58
- - -sanb-   Orochi7777 QUOTE I noticed that In_mad stores its ...   Feb 7 2008, 18:22
- - BSOD2600   Has anyone else noticed 'stuttering' with ...   Feb 9 2008, 23:47
- - Trainwreck56   QUOTE (BSOD2600 @ Feb 10 2008, 09:47) Has...   Feb 10 2008, 02:13
- - CromagDK   Hey there im wonderering a bit, when i play a st...   Feb 11 2008, 13:55
- - MoSPDude   I'm hoping to get chance to have a play this c...   Feb 12 2008, 11:22
|- - Trainwreck56   QUOTE (MoSPDude @ Feb 12 2008, 21:22) @BS...   Feb 12 2008, 13:50
|- - BSOD2600   QUOTE (MoSPDude @ Feb 12 2008, 03:22) @BS...   Feb 12 2008, 23:33
|- - _Raziel-BG   QUOTE (MoSPDude @ Feb 12 2008, 11:22) @_R...   Mar 13 2008, 00:11
- - -sanb-   MoSPDude I'm using AIMP player for listening m...   Feb 12 2008, 15:39
- - Orochi7777   QUOTE I'll look into a portable configuation, ...   Feb 12 2008, 19:27
- - Cybermutant   Like a previous poster, I'm also using a large...   Feb 15 2008, 19:29
- - MoSPDude   Hi, the 0.15.1 (beta) is correct - its an old name...   Feb 15 2008, 23:55
- - gameplaya15143   I figured out that the unicode support option has ...   Feb 16 2008, 19:06
- - MoSPDude   Hi folks, I've put up another update - this v...   Mar 3 2008, 20:57
- - Orochi7777   MoSPDude you are my HERO. Thank you very much f...   Mar 3 2008, 21:07
- - Emre   @MoSPDude did you drop FPM_64BIT compile switch f...   Mar 3 2008, 23:52
- - -sanb-   MoSPDude BIG THANKS!!! MY MAN!...   Mar 4 2008, 00:08
- - MoSPDude   Hi Emre, I've dropped back to FPM_INTEL (as in...   Mar 4 2008, 09:19
|- - Emre   QUOTE (MoSPDude @ Mar 4 2008, 10:19) Hi E...   Mar 5 2008, 04:03
|- - j7n   Hi, MoSPDude. The last version (with ini-file) in...   Mar 5 2008, 13:14
|- - Emre   QUOTE (j7n @ Mar 5 2008, 14:14) ...interr...   Mar 6 2008, 19:19
|- - j7n   I can confirm that disabling EQ solves the problem...   Mar 6 2008, 21:22
- - BSOD2600   1) I'm still getting occasional short pauses i...   Mar 9 2008, 07:18
- - -sanb-   BSOD2600 Try to delete this section QUOTE HKEY_USE...   Mar 9 2008, 08:05
|- - BSOD2600   QUOTE (-sanb- @ Mar 9 2008, 00...   Mar 9 2008, 10:24
|- - k.eight.a   QUOTE (BSOD2600 @ Mar 9 2008, 10:24) QUOT...   Mar 9 2008, 16:58
- - MoSPDude   Hi guys, Sorry for the confusion of it all, I rea...   Mar 10 2008, 00:20
|- - BSOD2600   QUOTE (MoSPDude @ Mar 9 2008, 16:20) The ...   Mar 10 2008, 02:38
- - John Clement   Are there any plans to add the unsynced Lyrics tag...   Mar 25 2008, 19:53
- - Yashu   I am somewhat new here, but I was wondering, I hav...   Mar 31 2008, 00:41
- - Sylph   When can we expect an update?   Apr 23 2008, 14:16
- - Slipstreem   I'm currently running version 0.15.1b publishe...   Apr 26 2008, 03:15
- - BSOD2600   QUOTE (Slipstreem @ Apr 25 2008, 19:15) I...   Apr 26 2008, 19:11
- - SkripT2   Thanks a lot @MoSPDude for this new version. I hav...   May 6 2008, 23:18
- - BSOD2600   This yet another dead mp3 project?   Jul 21 2008, 09:09
- - Sylph   I wonder, too...   Jul 21 2008, 10:20
- - MoSPDude   Hi guys, I think it's safe to say that for th...   Jul 24 2008, 20:22
- - lvqcl   MoSPDude, in_mad adds tags in ISO 8859 encoding. N...   Jul 24 2008, 22:48
- - Mits2008   I have been lurking in this forum for years, and I...   Sep 15 2008, 15:42
|- - Sylph   QUOTE (Mits2008 @ Sep 15 2008, 16:42) Thi...   Oct 1 2008, 14:44
|- - shakey_snake   QUOTE (Mits2008 @ Sep 15 2008, 10:42) My ...   Oct 1 2008, 16:04
|- - Karolinger   QUOTE (Mits2008 @ Sep 15 2008, 10:42) Tha...   Oct 4 2008, 01:25
- - deinlandel   Version from Winamp site has serious issues with R...   Oct 3 2008, 07:18
RSS Lo-Fi Version Time is now: 31st March 2015 - 10:23
