foo_vis_shpeck, Winamp visualisation plugins wrapper
Yirkha
post Nov 30 2007, 19:56
Group: FB2K Moderator
Shpeck is a component which can load and run Winamp visualisation plugins under foobar2000. Plugins capable of running in an "embedded window" can be put into a Columns UI panel too.
ZIPed distribution contains a README file with short installation guide and changelog.
Please read the rest of this topic before asking, or at least use the fast search function - see the bottom left corner of the page. And use the [​codebox] instead of [code​] for crash dumps to keep them short. Thanks!
Current version is Shpeck 0.3.7 from 2009/09/24.
foo_vis_shpeck.dll (237 KB)
foo_vis_shpeck-0.3.7.zip (121 KB)
mirror
FAQ:
  • Some plugins like MilkDrop 2 or NSFS are not detected.
    Copy the NSCRT.DLL file from Winamp's root directory somewhere, where the Windows DLL loader can find it (e.g. your directory with foobar2000.exe) - not needed since v0.3.0, they can be left in the Plugins directory too.
  • MilkDrop 1 or AVS randomly crashes.
    They are not compatible with DEP, there is no fix available AFAIK. Edit: Fix for MilkDrop 1.04 here.
Original first post:
Hi guys,
I came across a backup of my old foobar 0.8.whatever installation with foo_vis_bacon and Milkdrop yesterday and I thought it would be nice to see some of the carefuly crafted presets again. So I grabbed some other unused stuff from under my desk and hacked together the following thing over night.
While praising the Nullsoft's eternal wisdom about ingenious plug-in design, I gradually realized it actually works somehow (i.e. with more than one particular plug-in and on more than one machine) and it's quite usable too (i.e. not just with a hardcoded path to one plug-in DLL and half-supported API). So I decided to release it for public use.
I'm sure nobody cares about "WHEEE TEH COLORIZZZED PIXELZ!!!11 AND MOOVINK TO MY MUZAXX!! LULZZ!!" any more, but here is the link anyway:
(removed)
Enjoy!
This post has been edited by Yirkha: Jan 7 2010, 13:31
bukem
post Oct 28 2010, 10:56
I should mention about that in my post. Please use latest beta version of 7-zip to unpack the archive (9.17 at the moment) or any other compatible archiving utility. Apologies for the inconvenience.
@Zarggg:
Meant no disrespect or finger pointing when added the comment about RapidShare.
This post has been edited by bukem: Oct 28 2010, 11:00
- Yirkha   foo_vis_shpeck   Nov 30 2007, 19:56
- - romor   Seems like, when Shpeck is embedded in UI and has ...   Aug 25 2010, 21:51
- - byterhythm   QUOTE (byterhythm @ Aug 14 2010, 18:31) F...   Aug 29 2010, 10:24
|- - cjard   QUOTE (byterhythm @ Aug 29 2010, 10:24) -...   Oct 22 2010, 11:18
|- - cjard   QUOTE (cjard @ Oct 22 2010, 11:18) What...   Oct 22 2010, 11:51
- - RavenSoft   Everything was working great, then suddenly today ...   Sep 8 2010, 04:34
- - RavenSoft   guess I can't edit my own post, but I loaded u...   Sep 8 2010, 05:50
- - xenofixus   I am unable to get IPC_SETVOLUME working while usi...   Sep 15 2010, 11:23
- - Yirkha   Yeah, it's broken, thanks for pointing out. U...   Sep 16 2010, 00:06
- - xenofixus   It is indeed enough | thanks   Sep 16 2010, 04:53
- - dbuss1   Here's my dual-monitor setup with it. When I ...   Sep 17 2010, 21:05
- - jw80   I just switched back to foobar from Aimp. First th...   Sep 18 2010, 00:49
- - Yirkha   http://www.hydrogenaudio.org/forums/index....st...   Oct 22 2010, 11:24
- - cjard   note that even though the 556 installer reports yo...   Oct 22 2010, 18:36
- - bukem   Latest version of MilkDrop 2.22 package for foobar...   Oct 23 2010, 12:47
|- - Zarggg   QUOTE (bukem @ Oct 23 2010, 07:47) Note: ...   Oct 26 2010, 22:46
|- - ton   QUOTE (bukem @ Oct 23 2010, 03:47) Latest...   Oct 27 2010, 00:24
|- - TG.scaR   QUOTE (bukem @ Oct 23 2010, 07:47) Latest...   Nov 21 2010, 01:37
- - KarnEvil9   Thanks, bukem!   Oct 23 2010, 14:39
- - Zarggg   Worked fine for me; unpacked using 7zip.   Oct 27 2010, 04:56
- - KarnEvil9   PowerArchiver extracts it just fine too.   Oct 27 2010, 05:10
- - ton   I downloaded the file again and tried it with Powe...   Oct 27 2010, 13:58
|- - KarnEvil9   QUOTE (ton @ Oct 27 2010, 04:58) I downlo...   Oct 27 2010, 16:21
- - wharfrat73   I got that error too using 7 zip. It looks like e...   Oct 27 2010, 15:52
- - Robertina   I see in 7-Zip's compression method column = I...   Oct 27 2010, 20:31
|- - ton   QUOTE (Robertina @ Oct 27 2010, 11:31) I ...   Oct 27 2010, 21:08
- - Zarggg   And I was just coming back here to bring up the is...   Oct 28 2010, 05:52
- - bukem   I should mention about that in my post. Please use...   Oct 28 2010, 10:56
- - ton   Although not so important, I noticed that using th...   Oct 29 2010, 13:02
- - dbuss1   Is there any way to dock shpeck outside of foobar ...   Nov 17 2010, 04:28
- - Yirkha   Generally yes. Depends on the actual plugin being ...   Nov 17 2010, 04:48
|- - audioaficionado   QUOTE (Yirkha @ Nov 16 2010, 20:48) Gener...   Nov 26 2010, 01:53
|- - bukem   QUOTE (audioaficionado @ Nov 26 2010, 01...   Nov 26 2010, 11:52
- - bukem   I've uploaded the file on hotfile   Nov 21 2010, 02:46
|- - TG.scaR   QUOTE (bukem @ Nov 20 2010, 21:46) I...   Nov 21 2010, 03:53
- - tenarms   I love having Winamp functionality inside foobar20...   Nov 23 2010, 03:14
- - gorman   Hi! I'm trying to find a way to disable Wi...   Nov 26 2010, 10:53
- - ionreflex   I just want to report that since foobar2000-1.1.1,...   Nov 26 2010, 19:43
|- - ionreflex   QUOTE (ionreflex @ Nov 26 2010, 13:43) I ...   Feb 8 2011, 19:49
- - Smitty2k1   Best thing I've ever seen, Milkdrop in a tab i...   Nov 30 2010, 04:47
- - $char(9836)   First off, many thanks for this plugin. It's r...   Nov 30 2010, 12:23
- - bukem   MilkDrop 2.23 package for foobar2000 is ready. Ch...   Nov 30 2010, 20:05
|- - Chesteta   QUOTE (bukem @ Nov 30 2010, 14:05) MilkDr...   Apr 9 2011, 21:52
|- - bukem   QUOTE (Chesteta @ Apr 9 2011, 21:52) I am...   Apr 11 2011, 10:29
- - Smitty2k1   Milkdrop always starts with the same visualization...   Dec 5 2010, 01:54
|- - Dodecahedron   QUOTE (Smitty2k1 @ Dec 5 2010, 00:54) Mil...   Feb 15 2011, 01:58
- - dalgard   Today Avast Antivirus vaulted my foo_vis_shpeck.dl...   Jan 6 2011, 16:41
|- - Robertina   QUOTE (dalgard @ Jan 6 2011, 04:41) Today...   Jan 7 2011, 01:47
- - Abbas   I have Updated Avast but arhiv with foo_vis_shpeck...   Jan 8 2011, 02:27
|- - Robertina   QUOTE (Abbas @ Jan 7 2011, 14:27) I have ...   Jan 8 2011, 04:49
- - Hitchhiker427   I've never used Avast, but I'm sure it has...   Jan 8 2011, 12:16
- - Abbas   Now file arhiv with foo_vis_shpeck.dll loaded me i...   Jan 8 2011, 12:37
- - derpotheman   I can't get this component to find milkdrop 2,...   Jan 19 2011, 03:10
- - spuuunit   How do you get this to work? I've put foo_vis_...   Feb 1 2011, 18:43
|- - Cheung   QUOTE (spuuunit @ Feb 1 2011, 11:43) How ...   Feb 8 2011, 04:39
- - tpijag   Not sure exactly the issue, but you do seem confus...   Feb 1 2011, 19:28
- - Xyzzy   Hello I have run Shpeck with no problem, with AVS...   Feb 7 2011, 22:29
- - tribaljet   So, any news about the famous (and hopefully still...   Feb 10 2011, 09:24
- - Dodecahedron   Alright, whenever I run MD 2.23 it seems to be stu...   Feb 16 2011, 00:05
- - Stanzmastertron   I keep getting "the plugin crashed during ren...   Feb 20 2011, 07:46
- - bakis   Did anyone get milkdrop to work with foobar and Sh...   Mar 7 2011, 02:19
- - tribaljet   Milkdrop 2.2 works fine over here, with a slimmed ...   Mar 7 2011, 02:27
- - bakis   Ah sweet. Got it to work after a few tries of diff...   Mar 7 2011, 02:33
- - cmyden   So I got MilkDrop 2.2 up and running, a big thanks...   Apr 9 2011, 22:48
- - DoctorO   to clarify the Milkdrop versioning *fun* seen rece...   Apr 11 2011, 12:23
- - Chesteta   I extracted it at school with winrar and it worked...   Apr 11 2011, 16:22
- - camperdave   I'm having some trouble getting AVS to work. ...   May 7 2011, 23:57
- - tribaljet   QUOTE (camperdave @ May 7 2011, 22:57) I...   May 14 2011, 05:22
|- - emk2203   QUOTE (tribaljet @ May 14 2011, 06:22) Wi...   Jun 10 2011, 16:21
- - manaox2   Thank you for this. It works amazingly well, reall...   Jun 5 2011, 07:26
- - emk2203   Thanks for the link to the plugins folder includin...   Jun 9 2011, 16:00
- - tribaljet   QUOTE (emk2203 @ Jun 10 2011, 15:21) QUOT...   Jun 10 2011, 18:35
|- - emk2203   QUOTE (tribaljet @ Jun 10 2011, 19:35) So...   Jun 11 2011, 19:41
- - tribaljet   Ah, I see. But from what version of Winamp did you...   Jun 11 2011, 20:22
|- - emk2203   QUOTE (tribaljet @ Jun 11 2011, 21:22) Ah...   Jun 12 2011, 13:54
- - tribaljet   QUOTE (emk2203 @ Jun 12 2011, 12:54) QUOT...   Jun 12 2011, 16:59
|- - emk2203   QUOTE (tribaljet @ Jun 12 2011, 17:59) I ...   Jun 12 2011, 18:13
- - tribaljet   QUOTE (emk2203 @ Jun 12 2011, 17:13) If y...   Jun 12 2011, 18:15
|- - emk2203   QUOTE (tribaljet @ Jun 12 2011, 19:15) QU...   Jun 14 2011, 08:38
|- - timmytucker718   QUOTE (emk2203 @ Jun 14 2011, 02:38) QUOT...   Jun 21 2011, 20:04
- - tribaljet   timmytucker718, like the error message says, you s...   Jun 21 2011, 22:07
- - Robertina   timmytucker718, since this error message comes fr...   Jun 21 2011, 22:55
|- - timmytucker718   QUOTE (Robertina @ Jun 21 2011, 16:55) ti...   Jun 22 2011, 06:46
- - bukem   MilkDrop 2.24 package for foobar2000 (based on Win...   Jul 1 2011, 00:56
- - jawohlol   Just wanted to ask, I installed shpeck and want to...   Jul 11 2011, 23:38
|- - WWNSX   QUOTE (jawohlol @ Jul 11 2011, 14:38) Jus...   Aug 31 2011, 00:31
- - kukis   Hi, is there a possibility to autostart visualisat...   Sep 7 2011, 16:23
- - talkinghead42   I'm having a weird problem with shpeck. I used...   Sep 8 2011, 07:15
- - Spoonie_B   Having a problem, hoping for help. Milkdrop2 is n...   Oct 3 2011, 01:46
|- - WWNSX   QUOTE (Spoonie_B @ Oct 2 2011, 17:46) Hav...   Oct 3 2011, 01:55
|- - Spoonie_B   QUOTE (WWNSX @ Oct 3 2011, 02:55) QUOTE (...   Oct 8 2011, 20:32
- - Spoonie_B   bump Could really use some help here if anyone ha...   Oct 31 2011, 03:08
- - A_Man_Eating_Duck   What sort of videocard is in your HP Probook?   Oct 31 2011, 06:05
|- - Spoonie_B   QUOTE (A_Man_Eating_Duck @ Oct 31 2011, 07...   Nov 1 2011, 02:36
- - A_Man_Eating_Duck   Try updating to the latest ATI drivers http://su...   Nov 1 2011, 05:20
- - Spoonie_B   DirectX upgrade did it! Thanks so much for yo...   Nov 5 2011, 19:16
- - trout   It would be great if there were an option to preve...   Nov 17 2011, 01:15
- - soyo   Hi guys! I have a very frustrating problem he...   Dec 3 2011, 01:00
- - tehmadcap   It says Winamp is not required yet when selecting ...   Dec 21 2011, 04:48
- - Shayne   Hi I have been having trouble with milkdrop visua...   Dec 30 2011, 22:57
8 Pages V  « < 5 6 7 8 >
RSS Lo-Fi Version Time is now: 1st August 2015 - 22:30
