foo_vis_shpeck, Winamp visualisation plugins wrapper
Yirkha
post Nov 30 2007, 19:56
Group: FB2K Moderator
Shpeck is a component which can load and run Winamp visualisation plugins under foobar2000. Plugins capable of running in an "embedded window" can be put into a Columns UI panel too.
ZIPed distribution contains a README file with short installation guide and changelog.
Please read the rest of this topic before asking, or at least use the fast search function - see the bottom left corner of the page. And use the [​codebox] instead of [code​] for crash dumps to keep them short. Thanks!
Current version is Shpeck 0.3.7 from 2009/09/24.
foo_vis_shpeck.dll (237 KB)
foo_vis_shpeck-0.3.7.zip (121 KB)
mirror
FAQ:
  • Some plugins like MilkDrop 2 or NSFS are not detected.
    Copy the NSCRT.DLL file from Winamp's root directory somewhere, where the Windows DLL loader can find it (e.g. your directory with foobar2000.exe) - not needed since v0.3.0, they can be left in the Plugins directory too.
  • MilkDrop 1 or AVS randomly crashes.
    They are not compatible with DEP, there is no fix available AFAIK. Edit: Fix for MilkDrop 1.04 here.
Original first post:
Hi guys,
I came across a backup of my old foobar 0.8.whatever installation with foo_vis_bacon and Milkdrop yesterday and I thought it would be nice to see some of the carefuly crafted presets again. So I grabbed some other unused stuff from under my desk and hacked together the following thing over night.
While praising the Nullsoft's eternal wisdom about ingenious plug-in design, I gradually realized it actually works somehow (i.e. with more than one particular plug-in and on more than one machine) and it's quite usable too (i.e. not just with a hardcoded path to one plug-in DLL and half-supported API). So I decided to release it for public use.
I'm sure nobody cares about "WHEEE TEH COLORIZZZED PIXELZ!!!11 AND MOOVINK TO MY MUZAXX!! LULZZ!!" any more, but here is the link anyway:
(removed)
Enjoy!
This post has been edited by Yirkha: Jan 7 2010, 13:31
Zarggg
post Oct 28 2010, 05:52
And I was just coming back here to bring up the issue of 7zip version. Kudos. tongue.gif
(LZMA2 is amazing. I've been using it for my site backup archiving ever since 7zip supported it. Compression rates comparable to PPMd and access times comparable to LZMA.)
This post has been edited by Zarggg: Oct 28 2010, 05:53
- Yirkha   foo_vis_shpeck   Nov 30 2007, 19:56
- - romor   Seems like, when Shpeck is embedded in UI and has ...   Aug 25 2010, 21:51
- - byterhythm   QUOTE (byterhythm @ Aug 14 2010, 18:31) F...   Aug 29 2010, 10:24
|- - cjard   QUOTE (byterhythm @ Aug 29 2010, 10:24) -...   Oct 22 2010, 11:18
|- - cjard   QUOTE (cjard @ Oct 22 2010, 11:18) What...   Oct 22 2010, 11:51
- - RavenSoft   Everything was working great, then suddenly today ...   Sep 8 2010, 04:34
- - RavenSoft   guess I can't edit my own post, but I loaded u...   Sep 8 2010, 05:50
- - xenofixus   I am unable to get IPC_SETVOLUME working while usi...   Sep 15 2010, 11:23
- - Yirkha   Yeah, it's broken, thanks for pointing out. U...   Sep 16 2010, 00:06
- - xenofixus   It is indeed enough | thanks   Sep 16 2010, 04:53
- - dbuss1   Here's my dual-monitor setup with it. When I ...   Sep 17 2010, 21:05
- - jw80   I just switched back to foobar from Aimp. First th...   Sep 18 2010, 00:49
- - Yirkha   http://www.hydrogenaudio.org/forums/index....st...   Oct 22 2010, 11:24
- - cjard   note that even though the 556 installer reports yo...   Oct 22 2010, 18:36
- - bukem   Latest version of MilkDrop 2.22 package for foobar...   Oct 23 2010, 12:47
|- - Zarggg   QUOTE (bukem @ Oct 23 2010, 07:47) Note: ...   Oct 26 2010, 22:46
|- - ton   QUOTE (bukem @ Oct 23 2010, 03:47) Latest...   Oct 27 2010, 00:24
|- - TG.scaR   QUOTE (bukem @ Oct 23 2010, 07:47) Latest...   Nov 21 2010, 01:37
- - KarnEvil9   Thanks, bukem!   Oct 23 2010, 14:39
- - Zarggg   Worked fine for me; unpacked using 7zip.   Oct 27 2010, 04:56
- - KarnEvil9   PowerArchiver extracts it just fine too.   Oct 27 2010, 05:10
- - ton   I downloaded the file again and tried it with Powe...   Oct 27 2010, 13:58
|- - KarnEvil9   QUOTE (ton @ Oct 27 2010, 04:58) I downlo...   Oct 27 2010, 16:21
- - wharfrat73   I got that error too using 7 zip. It looks like e...   Oct 27 2010, 15:52
- - Robertina   I see in 7-Zip's compression method column = I...   Oct 27 2010, 20:31
|- - ton   QUOTE (Robertina @ Oct 27 2010, 11:31) I ...   Oct 27 2010, 21:08
- - Zarggg   And I was just coming back here to bring up the is...   Oct 28 2010, 05:52
- - bukem   I should mention about that in my post. Please use...   Oct 28 2010, 10:56
- - ton   Although not so important, I noticed that using th...   Oct 29 2010, 13:02
- - dbuss1   Is there any way to dock shpeck outside of foobar ...   Nov 17 2010, 04:28
- - Yirkha   Generally yes. Depends on the actual plugin being ...   Nov 17 2010, 04:48
|- - audioaficionado   QUOTE (Yirkha @ Nov 16 2010, 20:48) Gener...   Nov 26 2010, 01:53
|- - bukem   QUOTE (audioaficionado @ Nov 26 2010, 01...   Nov 26 2010, 11:52
- - bukem   I've uploaded the file on hotfile   Nov 21 2010, 02:46
|- - TG.scaR   QUOTE (bukem @ Nov 20 2010, 21:46) I...   Nov 21 2010, 03:53
- - tenarms   I love having Winamp functionality inside foobar20...   Nov 23 2010, 03:14
- - gorman   Hi! I'm trying to find a way to disable Wi...   Nov 26 2010, 10:53
- - ionreflex   I just want to report that since foobar2000-1.1.1,...   Nov 26 2010, 19:43
|- - ionreflex   QUOTE (ionreflex @ Nov 26 2010, 13:43) I ...   Feb 8 2011, 19:49
- - Smitty2k1   Best thing I've ever seen, Milkdrop in a tab i...   Nov 30 2010, 04:47
- - $char(9836)   First off, many thanks for this plugin. It's r...   Nov 30 2010, 12:23
- - bukem   MilkDrop 2.23 package for foobar2000 is ready. Ch...   Nov 30 2010, 20:05
|- - Chesteta   QUOTE (bukem @ Nov 30 2010, 14:05) MilkDr...   Apr 9 2011, 21:52
|- - bukem   QUOTE (Chesteta @ Apr 9 2011, 21:52) I am...   Apr 11 2011, 10:29
- - Smitty2k1   Milkdrop always starts with the same visualization...   Dec 5 2010, 01:54
|- - Dodecahedron   QUOTE (Smitty2k1 @ Dec 5 2010, 00:54) Mil...   Feb 15 2011, 01:58
- - dalgard   Today Avast Antivirus vaulted my foo_vis_shpeck.dl...   Jan 6 2011, 16:41
|- - Robertina   QUOTE (dalgard @ Jan 6 2011, 04:41) Today...   Jan 7 2011, 01:47
- - Abbas   I have Updated Avast but arhiv with foo_vis_shpeck...   Jan 8 2011, 02:27
|- - Robertina   QUOTE (Abbas @ Jan 7 2011, 14:27) I have ...   Jan 8 2011, 04:49
- - Hitchhiker427   I've never used Avast, but I'm sure it has...   Jan 8 2011, 12:16
- - Abbas   Now file arhiv with foo_vis_shpeck.dll loaded me i...   Jan 8 2011, 12:37
- - derpotheman   I can't get this component to find milkdrop 2,...   Jan 19 2011, 03:10
- - spuuunit   How do you get this to work? I've put foo_vis_...   Feb 1 2011, 18:43
|- - Cheung   QUOTE (spuuunit @ Feb 1 2011, 11:43) How ...   Feb 8 2011, 04:39
- - tpijag   Not sure exactly the issue, but you do seem confus...   Feb 1 2011, 19:28
- - Xyzzy   Hello I have run Shpeck with no problem, with AVS...   Feb 7 2011, 22:29
- - tribaljet   So, any news about the famous (and hopefully still...   Feb 10 2011, 09:24
- - Dodecahedron   Alright, whenever I run MD 2.23 it seems to be stu...   Feb 16 2011, 00:05
- - Stanzmastertron   I keep getting "the plugin crashed during ren...   Feb 20 2011, 07:46
- - bakis   Did anyone get milkdrop to work with foobar and Sh...   Mar 7 2011, 02:19
- - tribaljet   Milkdrop 2.2 works fine over here, with a slimmed ...   Mar 7 2011, 02:27
- - bakis   Ah sweet. Got it to work after a few tries of diff...   Mar 7 2011, 02:33
- - cmyden   So I got MilkDrop 2.2 up and running, a big thanks...   Apr 9 2011, 22:48
- - DoctorO   to clarify the Milkdrop versioning *fun* seen rece...   Apr 11 2011, 12:23
- - Chesteta   I extracted it at school with winrar and it worked...   Apr 11 2011, 16:22
- - camperdave   I'm having some trouble getting AVS to work. ...   May 7 2011, 23:57
- - tribaljet   QUOTE (camperdave @ May 7 2011, 22:57) I...   May 14 2011, 05:22
|- - emk2203   QUOTE (tribaljet @ May 14 2011, 06:22) Wi...   Jun 10 2011, 16:21
- - manaox2   Thank you for this. It works amazingly well, reall...   Jun 5 2011, 07:26
- - emk2203   Thanks for the link to the plugins folder includin...   Jun 9 2011, 16:00
- - tribaljet   QUOTE (emk2203 @ Jun 10 2011, 15:21) QUOT...   Jun 10 2011, 18:35
|- - emk2203   QUOTE (tribaljet @ Jun 10 2011, 19:35) So...   Jun 11 2011, 19:41
- - tribaljet   Ah, I see. But from what version of Winamp did you...   Jun 11 2011, 20:22
|- - emk2203   QUOTE (tribaljet @ Jun 11 2011, 21:22) Ah...   Jun 12 2011, 13:54
- - tribaljet   QUOTE (emk2203 @ Jun 12 2011, 12:54) QUOT...   Jun 12 2011, 16:59
|- - emk2203   QUOTE (tribaljet @ Jun 12 2011, 17:59) I ...   Jun 12 2011, 18:13
- - tribaljet   QUOTE (emk2203 @ Jun 12 2011, 17:13) If y...   Jun 12 2011, 18:15
|- - emk2203   QUOTE (tribaljet @ Jun 12 2011, 19:15) QU...   Jun 14 2011, 08:38
|- - timmytucker718   QUOTE (emk2203 @ Jun 14 2011, 02:38) QUOT...   Jun 21 2011, 20:04
- - tribaljet   timmytucker718, like the error message says, you s...   Jun 21 2011, 22:07
- - Robertina   timmytucker718, since this error message comes fr...   Jun 21 2011, 22:55
|- - timmytucker718   QUOTE (Robertina @ Jun 21 2011, 16:55) ti...   Jun 22 2011, 06:46
- - bukem   MilkDrop 2.24 package for foobar2000 (based on Win...   Jul 1 2011, 00:56
- - jawohlol   Just wanted to ask, I installed shpeck and want to...   Jul 11 2011, 23:38
|- - WWNSX   QUOTE (jawohlol @ Jul 11 2011, 14:38) Jus...   Aug 31 2011, 00:31
- - kukis   Hi, is there a possibility to autostart visualisat...   Sep 7 2011, 16:23
- - talkinghead42   I'm having a weird problem with shpeck. I used...   Sep 8 2011, 07:15
- - Spoonie_B   Having a problem, hoping for help. Milkdrop2 is n...   Oct 3 2011, 01:46
|- - WWNSX   QUOTE (Spoonie_B @ Oct 2 2011, 17:46) Hav...   Oct 3 2011, 01:55
|- - Spoonie_B   QUOTE (WWNSX @ Oct 3 2011, 02:55) QUOTE (...   Oct 8 2011, 20:32
- - Spoonie_B   bump Could really use some help here if anyone ha...   Oct 31 2011, 03:08
- - A_Man_Eating_Duck   What sort of videocard is in your HP Probook?   Oct 31 2011, 06:05
|- - Spoonie_B   QUOTE (A_Man_Eating_Duck @ Oct 31 2011, 07...   Nov 1 2011, 02:36
- - A_Man_Eating_Duck   Try updating to the latest ATI drivers http://su...   Nov 1 2011, 05:20
- - Spoonie_B   DirectX upgrade did it! Thanks so much for yo...   Nov 5 2011, 19:16
- - trout   It would be great if there were an option to preve...   Nov 17 2011, 01:15
- - soyo   Hi guys! I have a very frustrating problem he...   Dec 3 2011, 01:00
- - tehmadcap   It says Winamp is not required yet when selecting ...   Dec 21 2011, 04:48
- - Shayne   Hi I have been having trouble with milkdrop visua...   Dec 30 2011, 22:57
8 Pages V  « < 5 6 7 8 >
RSS Lo-Fi Version Time is now: 3rd August 2015 - 03:50
