foo_vis_shpeck, Winamp visualisation plugins wrapper
Yirkha
post Nov 30 2007, 19:56
Group: FB2K Moderator
Shpeck is a component which can load and run Winamp visualisation plugins under foobar2000. Plugins capable of running in an "embedded window" can be put into a Columns UI panel too.
ZIPed distribution contains a README file with short installation guide and changelog.
Please read the rest of this topic before asking, or at least use the fast search function - see the bottom left corner of the page. And use the [​codebox] instead of [code​] for crash dumps to keep them short. Thanks!
Current version is Shpeck 0.3.7 from 2009/09/24.
foo_vis_shpeck.dll (237 KB)
foo_vis_shpeck-0.3.7.zip (121 KB)
mirror
FAQ:
  • Some plugins like MilkDrop 2 or NSFS are not detected.
    Copy the NSCRT.DLL file from Winamp's root directory somewhere, where the Windows DLL loader can find it (e.g. your directory with foobar2000.exe) - not needed since v0.3.0, they can be left in the Plugins directory too.
  • MilkDrop 1 or AVS randomly crashes.
    They are not compatible with DEP, there is no fix available AFAIK. Edit: Fix for MilkDrop 1.04 here.
Original first post:
Hi guys,
I came across a backup of my old foobar 0.8.whatever installation with foo_vis_bacon and Milkdrop yesterday and I thought it would be nice to see some of the carefuly crafted presets again. So I grabbed some other unused stuff from under my desk and hacked together the following thing over night.
While praising the Nullsoft's eternal wisdom about ingenious plug-in design, I gradually realized it actually works somehow (i.e. with more than one particular plug-in and on more than one machine) and it's quite usable too (i.e. not just with a hardcoded path to one plug-in DLL and half-supported API). So I decided to release it for public use.
I'm sure nobody cares about "WHEEE TEH COLORIZZZED PIXELZ!!!11 AND MOOVINK TO MY MUZAXX!! LULZZ!!" any more, but here is the link anyway:
(removed)
Enjoy!
This post has been edited by Yirkha: Jan 7 2010, 13:31
A_Man_Eating_Duc...
post Dec 14 2007, 11:17
Thanks for this plugin, i have it and milkdrop2 running on a 40inch TV and i just lost 1 hour because i couldn't look away tongue.gif.
- Yirkha   foo_vis_shpeck   Nov 30 2007, 19:56
- - hotzenpl0tz   I, on the other hand think you just made alot of p...   Nov 30 2007, 20:10
|- - Yirkha   It's plain external old style visualisation pl...   Nov 30 2007, 20:29
|- - incunabula   Can't wait to try this out when i get home...   Nov 30 2007, 20:42
- - WWNSX   Well I'm glad someone found this because this ...   Nov 30 2007, 21:26
|- - Yirkha   QUOTE (WWNSX @ Nov 30 2007, 21:26) I trie...   Nov 30 2007, 22:19
|- - WWNSX   thanks for the quick update Yirkha. I don't re...   Nov 30 2007, 22:35
- - Lite   thank you! i have test it and milkdrop vizual ...   Nov 30 2007, 21:48
- - alphaex32   doesn't seem to work with AVS. Im getting ...   Nov 30 2007, 23:21
- - Yotsuya   Request: Can you please modify the control for de...   Nov 30 2007, 23:35
|- - cuotos   Thats so awsome!!! Looks extremely p...   Dec 1 2007, 00:03
|- - WWNSX   QUOTE (cuotos @ Nov 30 2007, 15:03) Thats...   Dec 1 2007, 00:04
|- - Kiteroa   QUOTE (WWNSX @ Dec 1 2007, 12:04) QUOTE (...   Dec 1 2007, 02:56
- - 4nt1   nice component, only thing missing is the ability ...   Dec 1 2007, 02:49
- - Emon   Yes, if you can make this a panel for the new Defa...   Dec 1 2007, 07:55
- - DeepAnger   Thank you so much. I kept an old working 0.8.3 j...   Dec 1 2007, 08:41
- - Tich   I'm getting this error when maximising the vis...   Dec 1 2007, 13:52
- - Yirkha   QUOTE (alphaex32 @ Nov 30 2007, 23:21) do...   Dec 2 2007, 05:36
|- - Spirit_of_the_ocean   QUOTE (Yirkha @ Dec 2 2007, 05:36) @ vis ...   Dec 3 2007, 00:49
|- - Yirkha   QUOTE (Spirit_of_the_ocean @ Dec 3 2007, 00...   Dec 3 2007, 02:45
|- - Slotos   QUOTE (Yirkha @ Dec 3 2007, 03:45) The po...   Dec 3 2007, 15:09
|- - cuotos   QUOTE (Yirkha @ Dec 3 2007, 01:45) The po...   Dec 3 2007, 15:10
|- - Falstaff   QUOTE (Yirkha @ Dec 3 2007, 02:45) QUOTE ...   Jan 20 2008, 11:29
|- - Yirkha   QUOTE (Falstaff @ Jan 20 2008, 11:29) 2nd...   Jan 20 2008, 15:04
|- - Falstaff   OOps, no sorry, i'm going to try this now ...   Jan 20 2008, 18:27
- - Yotsuya   Thanks for the update! AVS in foobar under win...   Dec 2 2007, 10:42
- - alphaex32   Awesome job getting AVS working! Thank you so ...   Dec 3 2007, 02:31
|- - Yirkha   QUOTE (alphaex32 @ Dec 3 2007, 02:31) Awe...   Dec 3 2007, 03:00
- - incunabula   Freaking awesome. AVS and Milkdrop are working pe...   Dec 3 2007, 04:17
- - JadeElephant   This is ******* awesome! Thank you! Finall...   Dec 3 2007, 08:36
- - Andreasvb   Great work! It's bacon on steroids. Just...   Dec 4 2007, 10:47
|- - Yirkha   QUOTE (Andreasvb @ Dec 4 2007, 10:47) Jus...   Dec 4 2007, 16:29
- - Chipicui   Another vote for a ColumnsUI panel version! ...   Dec 4 2007, 13:56
- - Andreasvb   Thank you, works very good!   Dec 4 2007, 17:46
- - JadeElephant   Thanks again for this. Something else I was thinki...   Dec 5 2007, 00:08
- - IDentify   Tnx for this plug!   Dec 5 2007, 19:39
- - WWNSX   Yirkha thanks for the lastest version. I noticed n...   Dec 5 2007, 20:46
- - jahpal   Where can I Find This Winamp Plug In to make This...   Dec 6 2007, 04:16
- - buktore   QUOTE Where can I Find This Winamp Plug In to make...   Dec 6 2007, 05:43
|- - Joelimite   QUOTE (buktore @ Dec 5 2007, 20:43) QUOTE...   Dec 6 2007, 06:06
- - jahpal   I still Can Get It to work i think im missing some...   Dec 6 2007, 08:18
- - JadeElephant   You don't need foo_winamp_spam. All you have t...   Dec 6 2007, 08:59
|- - cristox   please make a panel for coulmnsui.... and consider...   Dec 6 2007, 17:57
|- - Yirkha   Why? Moderation:Removed unnecessary full quote of...   Dec 6 2007, 18:30
|- - cristox   It helps saving bandwidth (not only yours...) Mod...   Dec 6 2007, 18:32
|- - Yirkha   All right, I'll try that next time to see if i...   Dec 6 2007, 18:35
|- - cartman(2vd)   ive found maybe a component collision? i use winam...   Dec 10 2007, 20:17
- - Scidd0w   Yirkha; Thank you very much for the component...   Dec 11 2007, 11:08
- - Liquid_Predator   When I open the configuration window of Milkdrop 2...   Dec 11 2007, 14:25
|- - Liquid_Predator   QUOTE (Liquid_Predator @ Dec 11 2007, 05...   Dec 12 2007, 12:33
- - Spirit_of_the_ocean   I installed Winamp 5.5 copied the directory. The I...   Dec 11 2007, 19:30
|- - Yirkha   QUOTE (Spirit_of_the_ocean @ Dec 11 2007, 19...   Dec 11 2007, 20:08
|- - cartman(2vd)   QUOTE (Spirit_of_the_ocean @ Dec 11 2007, 19...   Dec 11 2007, 20:27
- - Fangs404   I just had to reply to this thread. I just tried ...   Dec 12 2007, 10:40
- - addicted   wow thanks for this! i was waiting for somethi...   Dec 13 2007, 20:03
- - A_Man_Eating_Duck   Thanks for this plugin, i have it and milkdrop2 ru...   Dec 14 2007, 11:17
- - Yirkha   All right, the almighty new version 0.1.0 is final...   Dec 15 2007, 20:11
- - cuotos   That's great news -thanks for your efforts on ...   Dec 16 2007, 01:08
|- - Yirkha   QUOTE (cuotos @ Dec 16 2007, 01:08) In or...   Dec 16 2007, 05:20
|- - cuotos   QUOTE (Yirkha @ Dec 16 2007, 04:20) Are t...   Dec 16 2007, 13:11
- - Yotsuya   AVS in a panel in foobar under wine, thanks!   Dec 16 2007, 03:34
- - Slotos   Works like a charm. Thanks. upd: Ow, not so charm...   Dec 16 2007, 03:51
- - incunabula   Works like a charm here. Thanks for cranking out ...   Dec 16 2007, 05:29
- - kingdom zero   great stuff, working perfect for me   Dec 16 2007, 07:44
- - JadeElephant   This has turned out awesome. Best visualization co...   Dec 16 2007, 08:36
- - buktore   Awesome! Some request : can you somehow re...   Dec 16 2007, 09:44
- - Yirkha   QUOTE (JadeElephant @ Dec 16 2007, 08:36)...   Dec 16 2007, 16:59
|- - JadeElephant   QUOTE (Yirkha @ Dec 16 2007, 10:59) QUOTE...   Dec 16 2007, 20:18
|- - Skates   Great plug-in!!! I cannot thank you e...   Dec 17 2007, 02:05
- - buktore   I have tried nearly every thing i can think of and...   Dec 16 2007, 18:18
|- - Yirkha   QUOTE (buktore @ Dec 16 2007, 18:18) I ha...   Dec 16 2007, 18:47
- - buktore   Oops.. that work. with out the (") of cours...   Dec 16 2007, 19:19
- - GrandInquisitor   This is awesome. Thanks!!   Dec 17 2007, 20:35
- - livedead13   just had to say thanks for this.   Dec 19 2007, 23:44
- - rouge   I just wanted to point out in response to a featur...   Dec 21 2007, 13:59
- - toerbi   Milkdrop2 doenst show up. i Tryd WINAmp veRSIon 5....   Dec 22 2007, 13:47
|- - cartman(2vd)   sry o dont understand completly but if youre tryin...   Dec 22 2007, 17:10
|- - livedead13   QUOTE (cartman(2vd) @ Dec 22 2007, 10...   Dec 22 2007, 22:47
|- - cartman(2vd)   QUOTE (livedead13 @ Dec 22 2007, 22:47) i...   Dec 22 2007, 23:30
|- - livedead13   shpeck wouldn't detect the MilkDrop plugin unl...   Dec 22 2007, 23:51
|- - Yirkha   Sure. Shpeck doesn't "detect" anythi...   Dec 23 2007, 00:23
|- - Kiteroa   I'm trying to put a panel (with some buttons e...   Dec 23 2007, 01:18
|- - Yirkha   QUOTE (Kiteroa @ Dec 23 2007, 01:18) I...   Dec 23 2007, 01:30
|- - Kiteroa   Sure - I'm running panels ui and drawing a lar...   Dec 23 2007, 05:42
- - JadeElephant   OK I'm giving the panel version a go again. An...   Dec 27 2007, 11:26
|- - Yirkha   QUOTE (JadeElephant @ Dec 27 2007, 11:26)...   Dec 27 2007, 23:49
|- - JadeElephant   QUOTE (Yirkha @ Dec 27 2007, 17:49) QUOTE...   Dec 29 2007, 08:10
- - casedawg   Wow, this plug is amazing. Foobar always was a bi...   Dec 28 2007, 16:18
|- - Yirkha   QUOTE (casedawg @ Dec 28 2007, 16:18) On ...   Dec 28 2007, 16:59
|- - casedawg   QUOTE (Yirkha @ Dec 28 2007, 07:59) *clic...   Dec 29 2007, 12:45
- - DeepAnger   Hi, Thank you for this great component. That was ...   Jan 20 2008, 07:22
- - $char(9836)   Can someone please post a working dl link to this ...   Jan 24 2008, 16:14
|- - WWNSX   QUOTE ($char(9836) @ Jan 24 2008...   Jan 24 2008, 18:17
|- - $char(9836)   QUOTE (WWNSX @ Jan 24 2008, 18:17) QUOTE ...   Jan 27 2008, 17:13
- - Keepitsimple   I cant find the plugins. I see the vis_*.dll in th...   Jan 28 2008, 12:16
- - Andreasvb   Copy the nscrt.dll file from the Winamp dir to you...   Jan 28 2008, 12:49
- - Keepitsimple   I now copied the file. I still dont see any visual...   Jan 28 2008, 16:49
- - Andreasvb   Read that the newest version of MD2 doesn't wo...   Jan 28 2008, 17:24
- - Keepitsimple   lol, thx a lot. for other noobs out there. the di...   Jan 28 2008, 18:12
- - Funkstar De Luxe   Just wanted to thank you for this plugin - it...   Feb 1 2008, 00:24
8 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 30th May 2015 - 06:15
