What does ABX really prove?
audioslut512
post Nov 10 2007, 18:59
I recently did some ABX tests of music encoded in FLAC levels 0-8.
To my surprise I could tell the difference more often than not.
Yet I couldn't help but wonder, what does this really prove?
It seems that if an audible difference exists between two tracks, that difference wouldn't necessarily indicate anything as to which track is of higher quality, but rather, that those two tracks are merely different from one another...
Am I missing the point in all of this?
greynol
post Nov 10 2007, 19:50
I concur with the first response you were given, btw. Telling us that you can tell an audible difference between flac compression levels brings your methodology into serious question.
Your eyes cannot hear.
audioslut512
post Nov 10 2007, 20:03
QUOTE (greynol @ Nov 10 2007, 13:50) *
To clarify, I didn't mean to say I could tell the difference between FLAC 0-8 more often than not...
Rather, that of some of the tracks that I tested, which I had previously encoded from the same source (using the same FLAC 1.2.1 codec), difference to my own ear was indicated to me (and only me) by a probability that was statistically significant.
HOWEVER, I did NOT mean to start some sort of argument as to the means by which I performed the tests or for that matter, anything to do with my testing at all (I probably shouldn't have even mentioned those tests to begin with, it was just for context).
I was just trying to frame a much more general question, pertaining to the difference between two tracks sounding different as opposed to one track sounding better than another...
My apologies if I came across otherwise!
saratoga
post Nov 10 2007, 20:08
QUOTE (audioslut512 @ Nov 10 2007, 12:03) *
Wait, so which is it?
audioslut512
post Nov 10 2007, 23:47
QUOTE (Mike Giacomelli @ Nov 10 2007, 14:08) *
The ABX tests which I performed were on tracks which were contained within the set: FLAC levels 0-8.
If I performed an ABX test, the files tested were limited to FLAC 1,2,3,4,5,6,7,8.
That does NOT indicate that I tested ALL levels 0-8.
OF THE TRACKS WHICH I DID TEST, I was able to discern a difference more often than not.
Statistically significant is that which is unlikely to occur by chance.
A statistically significant difference in this case, merely implies that statistical evidence indicates that a discernible difference has a greater probability of existing than it does a probability of not existing.
Whether that difference is due to errors in encoding, playback, or whatever, is entirely irrelevant.
SiriusB
post Nov 12 2007, 08:25
QUOTE (audioslut512 @ Nov 10 2007, 16:47) *
If you repeatedly, 'successfully' (>16 trials each, p<0.05) ABXd flac from flac, or flac from .wav, all using the same track, then your flac encoding/decoding is broken, or your ABX test was crap. Seriously. If you understood what you are claiming, you'd know this must be true.
This post has been edited by SiriusB: Nov 12 2007, 08:26
- audioslut512   What does ABX really prove?   Nov 10 2007, 18:59
- - user   Please show details of your abx tests. Do you have...   Nov 10 2007, 19:05
- - tgoose   An ABX test tells you how likely it is that you ca...   Nov 10 2007, 19:06
- - maksm   No, you're not. If there is a difference, and ...   Nov 10 2007, 19:07
|- - tgoose   QUOTE (maksm @ Nov 10 2007, 18:07) No, yo...   Nov 10 2007, 19:11
- - greynol   There are other tests to rank differences. The po...   Nov 10 2007, 19:15
|- - audioslut512   QUOTE (greynol @ Nov 10 2007, 13:15) Ther...   Nov 10 2007, 19:36
- - Nikaki   Doing ABX on FLAC and actually being successful in...   Nov 10 2007, 19:20
- - greynol   An ABX test cannot prove that there isn't a di...   Nov 10 2007, 19:40
|- - audioslut512   QUOTE (greynol @ Nov 10 2007, 13:40) Actu...   Nov 10 2007, 19:43
- - greynol   I concur with the first response you were given, b...   Nov 10 2007, 19:50
|- - audioslut512   QUOTE (greynol @ Nov 10 2007, 13:50) I co...   Nov 10 2007, 20:03
|- - Mike Giacomelli   QUOTE (audioslut512 @ Nov 10 2007, 12:03)...   Nov 10 2007, 20:08
|- - audioslut512   QUOTE (Mike Giacomelli @ Nov 10 2007, 14...   Nov 10 2007, 23:47
|- - guruboolez   QUOTE (audioslut512 @ Nov 11 2007, 00:47)...   Nov 11 2007, 01:29
|- - SiriusB   QUOTE (audioslut512 @ Nov 10 2007, 16:47)...   Nov 12 2007, 08:25
|- - Vitecs   Not to mention what author is doing with his ABXin...   Nov 12 2007, 09:14
|- - cliveb   QUOTE (Vitecs @ Nov 12 2007, 08:14) Can i...   Nov 12 2007, 09:54
- - greynol   You're not understanding. If you think you...   Nov 10 2007, 20:08
- - Cosmo   QUOTE (audioslut512 @ Nov 10 2007, 12:59)...   Nov 10 2007, 20:31
- - eevan   No offence, but having read all your posts, I...   Nov 11 2007, 00:17
- - AndyH-ha   In the laboratory, and in most audiophile living r...   Nov 11 2007, 00:31
- - greynol   What an incredible waste of time! I propose t...   Nov 11 2007, 00:39
- - odyssey   How can you discuss this? QUOTE (audioslut512 ...   Nov 11 2007, 00:51
- - kwanbis   QUOTE (audioslut512 @ Nov 10 2007, 17:59)...   Nov 11 2007, 01:11
- - audioslut512   just forget it kids.   Nov 11 2007, 02:59
|- - sld   QUOTE (audioslut512 @ Nov 11 2007, 09:59)...   Nov 12 2007, 05:34
|- - audioslut512   QUOTE (sld @ Nov 11 2007, 23:34) QUOTE (a...   Nov 12 2007, 07:09
|- - sld   QUOTE (audioslut512 @ Nov 12 2007, 14:09)...   Nov 12 2007, 10:06
|- - MedO   Well, I just noticed that even I *might* be able t...   Nov 12 2007, 10:33
- - Mike Giacomelli   I still don't really understand what you did. ...   Nov 11 2007, 03:16
|- - audioslut512   QUOTE (Mike Giacomelli @ Nov 10 2007, 21...   Nov 11 2007, 04:56
|- - tgoose   QUOTE (greynol @ Nov 10 2007, 18:40) An A...   Nov 11 2007, 10:18
|- - Alexxander   QUOTE (audioslut512 @ Nov 11 2007, 05:56)...   Nov 11 2007, 11:06
|- - robert   QUOTE (audioslut512 @ Nov 11 2007, 04:56)...   Nov 11 2007, 13:03
||- - audioslut512   QUOTE (robert @ Nov 11 2007, 07:03) QUOTE...   Nov 11 2007, 23:38
|- - Light-Fire   QUOTE (audioslut512 @ Nov 10 2007, 22:56)...   Nov 12 2007, 08:04
- - shadowking   I wouldn't even want to see any lossless abx l...   Nov 11 2007, 05:07
- - William   audioslut512: What is your definition of ABX? Wha...   Nov 11 2007, 06:14
|- - audioslut512   QUOTE (William @ Nov 11 2007, 00:14) audi...   Nov 11 2007, 07:54
- - Bad Monkey   Just run the bit-comparator to check you are in fa...   Nov 11 2007, 10:11
- - kjoonlee   "More often than not" does not equal ...   Nov 11 2007, 12:34
- - greynol   The point is that you cannot make a proper conclus...   Nov 11 2007, 23:43
|- - audioslut512   QUOTE (greynol @ Nov 11 2007, 17:43) The ...   Nov 11 2007, 23:44
- - greynol   You chose not to accept the fact that you couldn...   Nov 12 2007, 00:00
|- - audioslut512   QUOTE (greynol @ Nov 11 2007, 18:00) You ...   Nov 12 2007, 06:57
- - Heresiarch   There is just no point in ABXing lossless files. I...   Nov 12 2007, 00:09
|- - greynol   QUOTE (Heresiarch @ Nov 11 2007, 15:09) T...   Nov 12 2007, 01:13
- - Bad Monkey   He doesn't even know if there are errors. It...   Nov 12 2007, 02:08
- - SamHain86   @MedO- -When you run anythingABX test, I always fo...   Nov 12 2007, 11:43
- - sld   MedO, it also happens on my Core Duo laptop, thoug...   Nov 12 2007, 15:16
RSS Lo-Fi Version Time is now: 25th April 2015 - 11:06
