Default UI Gallery, Screenshots only. Use the discussion thread for questions/comments.
foosion
post Oct 20 2007, 15:26
Group: FB2K Moderator (Donating)
For questions and other comments, please use the separate discussion thread.
Please use thumbnails or links for pictures larger than roughly 800x600 and 80KB.
Screenshots with faked elements (windows carefully positioned over the UI) will be removed to avoid confusion among users.
I've recently grown fond to the above layout with the 0.9.5 Default UI including the Facets component from Frank Bicking. Note: That is not the regular playlist dropdown, so don't even ask how to get icons in there. tongue.gif
Frank: Added guidelines at the top.
This post has been edited by Frank Bicking: Jul 22 2008, 20:46
shakey_snake
post Apr 20 2008, 04:34
So, here's the layout I'm using now:
To duplicate this, you need the following:
  1. Foobar 0.9.5.2 or later.
  2. The Theme File: Download (thanks HA)
  3. foo_facets
  4. foo_cwb_hooks
  5. Either foo_playback_custom or foo_playcount_mod to get the Last Played column and Status bar to display correctly.
  6. The code I use for the window title, (which for whatever reason isn't exported with the theme)
    %title%[ FROM %album%][ '('%track%[/%totaltracks%]')'][' BY '%track artist%]$repeat($char(32),999)
  7. The Black Mesa v2 visual style for XP.
(Just as a reminder, all discussion belongs in the discussion thread.)
This post has been edited by shakey_snake: Apr 20 2008, 04:57
elevatorladylevitateme
- foosion   Default UI Gallery   Oct 20 2007, 15:26
- - kanak   The foobar beta is fantastic. The following config...   Oct 20 2007, 23:11
- - shakey_snake   Well, we've had the new Interface for about a ...   Oct 28 2007, 22:41
|- - Rozzo   This is mine Rozzo   Nov 1 2007, 14:01
|- - badaboom   When I first stumbled upon foobar2000 a couple wee...   Dec 19 2007, 01:30
- - eejadx   Edit: Download theme file here.   Oct 29 2007, 03:08
- - elbo   http://img98.imageshack.us/img98/4442/foobarjt1.pn...   Oct 29 2007, 03:31
- - Laemtao   Aiming for minimalism. Could always be more minim...   Oct 29 2007, 04:37
- - NEMO7538   RE: Default UI Gallery   Oct 29 2007, 08:06
- - stampgevaar   This is mine, the facets component really brings n...   Oct 29 2007, 09:00
- - miscellanea   Main Layout : Simple Playlist + Tabs Colors : Foru...   Oct 29 2007, 10:05
- - SunRa   Here is my config Another view And here is the...   Oct 29 2007, 14:54
- - SmilerSmiles   Here is my new layout. On the left is my desktop I...   Oct 29 2007, 15:53
- - Gow   Here is my take on foobar2000's new default UI...   Oct 29 2007, 18:14
- - /mnt   A week after using foobar 0.9.5 beta with my title...   Oct 29 2007, 23:46
- - Cyaneyes   goodbye columns.. you were great while you lasted....   Oct 30 2007, 16:33
- - twostar   finally an easy way to customize the layout. here...   Oct 30 2007, 22:26
|- - sinfony   Here's what I've got, modeled off one I sa...   Oct 31 2007, 05:20
- - TedFromAccounting   Here's my setup for my widescreen   Nov 1 2007, 03:20
- - fooruncle   my new simple and clean yet highly flexible norton...   Nov 1 2007, 12:48
- - shakey_snake   Tweaked mine a bit: I use this as a no cover im...   Nov 1 2007, 18:09
- - anonnamiss   Here it is. Plain, but easy to use...works for me...   Nov 2 2007, 01:31
- - exLONS   Mine fb, simple, may be a little strange.   Nov 2 2007, 16:47
- - Sharen   QUOTE (shakey_snake @ Nov 2 2007, 01:09) ...   Nov 2 2007, 20:07
- - mourner   Here's mine: http://agafonkin.com/files/images...   Nov 2 2007, 23:59
- - Yotsuya   RE: Default UI Gallery   Nov 4 2007, 06:25
- - Emon   This new beta is really quite nice. This is what I...   Nov 5 2007, 05:56
- - Emon   Refined a bit after I decided that I didn't ne...   Nov 5 2007, 07:24
- - antiKk   Here's my final after much tweaking.   Nov 10 2007, 04:48
- - beto   This is mine, pretty much a ripoff from some ideas...   Nov 16 2007, 22:54
- - Blur   Bare-bones, Low-on-Resources, Thin, Compact theme....   Nov 25 2007, 00:38
- - fl102   nothing special. but i like it   Nov 25 2007, 13:03
- - Blur   Uses Font: Frutiger Linotype. Dimensions: Width=4...   Nov 26 2007, 02:47
|- - Garfield4   Here's Mine - With a few Dockable Panels on Di...   Nov 26 2007, 12:39
- - kaki123   Mine, really simple, that's why I like it :   Dec 7 2007, 20:57
- - Yirkha   The basic controls are on the keyboard.   Dec 17 2007, 18:45
- - Byron86   Moderation: Your image (850 KB) was ten times larg...   Dec 22 2007, 14:30
- - /mnt   Made some small changes on my foobar 0.9.5 setup a...   Dec 23 2007, 20:20
- - raintheory   pretty standard-ish, but just the way i want it.   Dec 27 2007, 04:50
- - Raven.am0k   Finally I also got to Foobar2ks new Default UI. It...   Dec 28 2007, 03:11
- - JohanDeBock   Moderation: Please do not inline images larger tha...   Jan 3 2008, 21:34
- - JohanDeBock   New one:   Jan 5 2008, 00:13
- - miscellanea   Changed to 0.9.5 final and added Facets.   Jan 5 2008, 12:32
- - DeepAnger   Larger Pictures (1680 x 1050 + ClearType): View 1,...   Jan 5 2008, 14:24
- - Paine-   Album art is in static position across all tabs   Jan 16 2008, 03:12
- - AlleyMan   Finally started using facets and a fullscreen DUI.   Jan 16 2008, 05:57
|- - heycheckit   heres mine: http://img213.imageshack.us/my.php?ima...   Mar 29 2008, 00:00
- - Hengest   'Widescreen' view   Feb 2 2008, 13:10
- - lextune   My first foo with custom buttons. Added thumbn...   Feb 11 2008, 17:00
- - McMusic   Here is my precious The cool thing is, that ...   Feb 15 2008, 22:39
- - hybridfan   RE: Default UI Gallery   Feb 16 2008, 15:34
- - NullString   The upload post with the theme: http://www.hydroge...   Feb 16 2008, 16:48
- - JoyO   RE: Default UI Gallery   Feb 16 2008, 18:17
- - TuNk77   I updated mine a bit:   Feb 16 2008, 18:57
- - spaceships   Moderation: Please do not inline images larger tha...   Feb 16 2008, 21:28
- - _stranger_   simple and useful:   Feb 19 2008, 02:10
- - ktr   so, love the DUI since the fb0.9, gj!   Feb 21 2008, 11:05
- - snively   RE: Default UI Gallery   Feb 22 2008, 20:26
- - shakey_snake   So, here's the layout I'm using now: To ...   Apr 20 2008, 04:34
- - suaff   mini   Apr 22 2008, 20:20
- - voltron   RE: Default UI Gallery   Apr 26 2008, 17:07
- - eonn   RE: Default UI Gallery   Apr 26 2008, 19:51
- - Koma   still foobar2000 v.0.9.4.5   Apr 30 2008, 03:08
- - Harun   iTunes-esque config with two tabs that switch betw...   May 14 2008, 08:19
- - Shinryuu   I ended up with this, it is really simple and fun ...   May 14 2008, 22:53
- - saivert   (click for fullsize) I have removed all offending...   May 19 2008, 02:50
- - cowgod   i've been playing around with the new (to me) ...   May 25 2008, 17:47
- - KrimzonP   Here is my foobar done to my satisfaction (only fo...   May 30 2008, 23:48
- - Mar2zz   Here is mine, I especially like having facets in m...   May 31 2008, 13:28
- - labou   heres mine Moderation: Please do not inline im...   Jun 3 2008, 03:27
- - JohanDeBock   My Setup, I always use half of my screen. ...   Jun 8 2008, 12:18
- - marcelush   my way   Jun 15 2008, 10:15
- - renderMan   Took some experimenting...   Jun 17 2008, 08:47
- - BokanoiD   mine... pretty standard stuff   Jun 17 2008, 14:45
- - Gamof   RE: Default UI Gallery   Jun 18 2008, 15:12
- - blackwater   Just created my first layout with the new defaultu...   Jun 26 2008, 00:10
- - Neszton   Hi everyone! Here's my DUI image from my ...   Jul 6 2008, 21:09
- - TedFromAccounting   Most current incarnation of my layout   Jul 8 2008, 01:44
- - Neszton   Updated http://i223.photobucket.com/albums/dd264...   Jul 8 2008, 07:28
- - Tiffa   Here's mine:   Jul 11 2008, 18:02
- - Olaf   RE: Default UI Gallery   Jul 11 2008, 18:39
- - grimes   RE: Default UI Gallery   Jul 12 2008, 04:17
- - ciaastek   Is there any way to remove all those menu buttons?...   Jul 15 2008, 08:04
- - acidus   RE: Default UI Gallery   Jul 16 2008, 13:17
- - labou   went 4 something different with this one   Jul 25 2008, 22:56
- - Harun   I used dockable panels to get rid of the border be...   Jul 26 2008, 20:11
- - start78   foobar2000 v0.9.5.4 + "Facets" by Frank_...   Jul 31 2008, 14:39
- - flakpt   Heres mine, Facets + Text Display: Lyrics: E...   Jul 31 2008, 14:52
- - skelly831   It'll be called... 25 hour fitness... for one ...   Aug 5 2008, 01:11
- - navap   No fancy effects or eye candy, but very functional...   Aug 8 2008, 02:22
- - Jamen Shook   I have only been using Foobar for several weeks or...   Aug 8 2008, 02:53
- - Dublo7   Here's my current theme. It's nice, simple...   Aug 17 2008, 18:32
- - holz0r   Very simple config but it works perfect for me.   Aug 17 2008, 20:59
- - addict   RE: Default UI Gallery   Sep 5 2008, 23:41
- - (Sly)   "The sound has no skin." ...   Sep 6 2008, 19:57
5 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 25th April 2015 - 15:34
