17 Pages V   1 2 3 > »
Closed TopicStart new topic
foobar2000 0.9.5 beta 9
jarsonic
post Oct 20 2007, 14:49
foobar20000 0.9.5 beta 9 has been released.
Download foobar2000 0.9.5 beta 9
Changelog
Known issues / issues fixed in beta 9
Feature proposals
Highlights
New Default User Interface
The new Default User Interface allows complex layout using building blocks that are called UI Elements. The Default User Interface puts a focus on instant usability and easy configuration; it deliberately does not offer total visual customization and reduces the use of title formatting. The Quick Appearance Setup window lets users choose from a set of predefined layouts, color schemes, and playlist configurations. The layout editing mode and scratchboxes allow in-place configuration of the layout with Copy & Paste functionality. The current configuration can be exported as a theme for archiving or transfer to another foobar2000 installation.
The following UI Elements are included by default:
  • Containers: horizontal and vertical Splitter, Tabs, Playlist Tabs, Toolbar Header
  • Media Library Viewers: Album List
  • Playlist Renderers: Playlist View
  • Selection Properties: Album Art Viewer, Selection Properties
  • Utility: Console, Equalizer, Playlist Manager
Containers
Containers provide the ability to structure the main window layout. Splitters arrange two elements horizontally or vertically. Tabs allow switching between multiple elements. The Playlist Tabs element displays a tab for each playlist and hosts a single element which is normally a playlist view. The Toolbar Header element allows to position a toolbar area above or below another element.
The Quick Appearance Setup window can be opened from the main menu (View > Layout > Quick Setup) or from the Default User Interface preferences page (Quick Setup button in the Theme Management section).
Spectrum (UI Element)
The Spectrum element displays a spectrogram visualisation. By default it uses global theme colors, but it can also be configured to use custom colors.
Toolbar Header (UI Element)
The Toolbar Header element is a container that hosts a single element and displays a toolbar area with one or more toolbars above or below it.
File Operations (Component)
The File Operations component is used to rename, copy and move files according to specified schemes. Those schemes can be saved as presets and are accessible from the context menu. This component replaces the corresponding features of the deprecated Masstagger component.
Improved File Properties Dialog
The improved Properties Dialog now integrates tagging-features which previously were part of the Masstagger.
For a full overview of what's new, see the release notes page.
Upgrade from previous versions
These upgrade notes extend the general upgrade notes from the FAQ.
You can install foobar2000 0.9.5 on top of an existing foobar2000 0.9.x installation.
Component compatibility
foobar2000 0.9.5 is compatible with most components made for older 0.9.x versions of foobar2000 with the following exceptions:
  • It is not recommended to mix official component DLLs from 0.9.5 with those from earlier versions due to inter-component dependencies in the new version.
  • foo_pqview (Playback Queue Viewer): The new version will not load foo_common as it contains a prototype for global appearance configuration that is unused but could confuse users. Users of foo_pqview should upgrade to a 0.9.5 compatible version.
  • foo_utils (Utilities): The Copy & Paste functions from foo_utils have been integrated into the core. Users of foo_utils should either upgrade to a 0.9.5 compatible version or remove the component if they do not require the component's additional functions.
Updated versions of foo_pqview and foo_utils are available from here.
Configuration, media library, and playlists
The media library and existing playlists are unaffected by upgrading to 0.9.5. The configuration should be unaffected except for Default User Interface settings and certain keyboard shortcuts.
Default User Interface and Title Formatting
The title formatting strings previously located on the Display > Title Formatting can now be found on the Advanced preferences page in the Display / Legacy title formatting settings branch. These strings are no longer used by the new Default User Interface.
Keyboard shortcuts
In order to minimize potential interference with typing in the new Default User Interface, existing single-letter shortcuts without Alt or Control modifier keys are removed on the first run after installing 0.9.5. Manually re-adding these shortcuts, while possible, is not recommended due to the issues stated above.
This post has been edited by Peter: Dec 23 2007, 15:41
Synthetic Soul
post Oct 20 2007, 14:56
Requires XP or newer.
Looks like I need to wait until this evening to check on my laptop. smile.gif
Sounds interesting though.
I'm on a horse.
AlleyMan
post Oct 20 2007, 15:04
Wow, this is an amazing release
Shinsou
post Oct 20 2007, 15:28
unbelievable
shakey_snake
post Oct 20 2007, 15:29
Group: FB2K Moderator
Wow, this is awesome.
As much as I've loved PanelsUI, I'd gladly switch to an interface that focuses on usability and reliability.
This is just what foobar needs. Thanks for listening to your user base for this one. smile.gif
This post has been edited by shakey_snake: Oct 20 2007, 15:34
elevatorladylevitateme
randal1013
New Album List component
*Updates automatically with Media Library content changes (“Refresh” command no longer needed)
thank you!
yandexx
post Oct 20 2007, 15:38
Oh my gosh! What a surprise for a big fan of foobar2000! Thank you!
stimulating the audio nerve directly
guruboolez
post Oct 20 2007, 15:41
Group: Members (Donating)
This new standard interface enriched with built-in presets is really a great improvement! Now I get foobar2000 looks pleasant without any effort (I didn't followed any UI improvement since two years and I didn't have the time to understand this whole scripting & components system).
In my opinion this is the most important release since years... maybe the most important one ever.
DotNoir
post Oct 20 2007, 15:48
This version is one of those Pringles moments; Once you pop, you can't stop. The usability is great (not that I had any problems with previous versions either) and all the new features in default UI are great.
Thanks Peter
Two things are infinite: the universe and human stupidity; and I'm not sure about the universe
buktore
post Oct 20 2007, 15:56
Ha ha ha biggrin.gif I just have a thought "Foobar developer must secretly doing something big for sure. base on the hint here and there." and BOOM this come out.
This post has been edited by buktore: Oct 20 2007, 15:57
Lyx
post Oct 20 2007, 15:58
It didnt made it into the releasenotes, but its worth mentioning, how easy it is now to create autoplaylists via Albumlist.
mil3s
post Oct 20 2007, 16:01
QUOTE (shakey_snake @ Oct 20 2007, 08:29) *
Sure, it's a very small improvement. But they have a loooooooooong way to go if they wanna match up to panels or columns ui. The new ui looks far from elegant.
Fandango
post Oct 20 2007, 16:06
This is nice surprise to see a new beta, and wow! what a great beta it is!
I was never a big fan of columns/panels UI, but the disadvantages of those two are gone in 0.9.5. It works all so great together and now it's really easy to set up.
The scratchbox is great, too! I also like the Facets plugin.
Well done!
Lyx
post Oct 20 2007, 16:09
"They" have no interest in doing that. Maybe you didn't read the UI intro properly smile.gif
guruboolez
post Oct 20 2007, 16:14
Post #15
FLAC library updated on 0.95b1.
Just for fun: one decoding speed benchmark based on one single CDImage.
0.9.4.5: Speed (x realtime): 197.780
Settings:
Buffer entire file into memory: no
High priority: yes
Passes: 4
File: N:\au_LONG\Mozart - [Manze, Egarr] Violin Sonatas, 1781\CDImage.flac
Run 1:
Length: 1:11:42.160
Opening time: 0:00.025
Decoding time: 0:21.943
Speed (x realtime): 196.063
Run 2:
Length: 1:11:42.160
Opening time: 0:00.046
Decoding time: 0:22.019
Speed (x realtime): 195.381
Run 3:
Length: 1:11:42.160
Opening time: 0:00.012
Decoding time: 0:21.498
Speed (x realtime): 200.121
Run 4:
Length: 1:11:42.160
Opening time: 0:00.117
Decoding time: 0:21.549
Speed (x realtime): 199.646
Total:
Opening time: 0:00.012 min, 0:00.117 max, 0:00.050 average
Decoding time: 0:21.498 min, 0:22.019 max, 0:21.752 average
Speed (x realtime): 195.381 min, 200.121 max, 197.780 average
Total:
Length: 4:46:48.640
Opening time: 0:00.200
Decoding time: 1:27.009
0.9.5 beta 1: Speed (x realtime): 354.446
Settings:
High priority: yes
Passes: 4
Run 1:
Length: 1:11:42.160
Opening time: 0:00.002
Decoding time: 0:12.049
Speed (x realtime): 357.065
Run 2:
Length: 1:11:42.160
Opening time: 0:00.029
Decoding time: 0:12.228
Speed (x realtime): 351.833
Run 3:
Length: 1:11:42.160
Opening time: 0:00.033
Decoding time: 0:12.319
Speed (x realtime): 349.229
Run 4:
Length: 1:11:42.160
Decoding time: 0:11.955
Speed (x realtime): 359.857
Total:
Opening time: 0:00.002 min, 0:00.033 max, 0:00.022 average
Decoding time: 0:11.955 min, 0:12.319 max, 0:12.138 average
Speed (x realtime): 349.229 min, 359.857 max, 354.446 average
Total:
Length: 4:46:48.640
Opening time: 0:00.089
Decoding time: 0:48.551
0.9.5 with flac 1.2.1 decoding library is now... 79,21% faster!!! While it has no importance on playback it significantly speeds up transcoding (from flac source). [EDIT: only one core is used with both fb2k version]
I also noticed that the number of encoding thread can be set (useful when transcoding from source located on optical media).
_
configuration:
Core2Duo E6300
1GB Ram
cheap motherboard
FLAC file: 304 MB at 593 kbps
This post has been edited by guruboolez: Oct 20 2007, 16:33
Andreasvb
post Oct 20 2007, 16:16
Post #16
Thanks everyone who made this, it's truly brilliant!
Excellent work guys.
Windows 8.1u3 Pro x64 Media Center // foobar2000 1.3.8
Fandango
post Oct 20 2007, 16:19
Post #17
QUOTE (Lyx @ Oct 20 2007, 17:09) *
I think it's good enough for most users (including myself). I prefer easier to use user interfaces over comples ones, but I think here they actually found a good compromise between usability and the amount features.
The Facets plugin is a good showcase of what's possible now and how a more elegant UI element should be created.
BTW, you can still use the old panels/columns UI interface but I doubt its development will be continued, will it?
QUOTE (guruboolez @ Oct 20 2007, 17:14) *
This post has been edited by Fandango: Oct 20 2007, 16:22
Lyx
post Oct 20 2007, 16:23
Post #18
QUOTE (Fandango @ Oct 20 2007, 17:19) *
An informal post will maybe made soon, which will among other things echo what you wrote above :)
TuNk77
post Oct 20 2007, 16:27
Post #19
I just tried the new beta, but it crashes when i use columns UI and the fancy new spectrum visual.
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="foobar2000.exe" FILTER="GRABMI_FILTER_PRIVACY">
<MATCHING_FILE NAME="foobar2000.exe" SIZE="1056768" CHECKSUM="0x9B7E79B7" BIN_FILE_VERSION="0.9.5.0" BIN_PRODUCT_VERSION="0.9.5.0" PRODUCT_VERSION="0, 9,
5, 0" FILE_DESCRIPTION="foobar2000 Application" PRODUCT_NAME=" foobar2000 Application" FILE_VERSION="0, 9, 5, 0" ORIGINAL_FILENAME="foobar2000.exe"
INTERNAL_NAME="foobar2000" LEGAL_COPYRIGHT="Copyright © 2001-2007 Peter Pawlowski" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4"
VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFF03F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.9.5.0" UPTO_BIN_PRODUCT_VERSION="0.9.5.0"
LINK_DATE="10/19/2007 10:47:23" UPTO_LINK_DATE="10/19/2007 10:47:23" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="libcurl.dll" SIZE="95292" CHECKSUM="0x5E5957DE" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="01/02/2004
19:07:03" UPTO_LINK_DATE="01/02/2004 19:07:03" />
<MATCHING_FILE NAME="libmmd.dll" SIZE="2814044" CHECKSUM="0x38345C3E" BIN_FILE_VERSION="9.1.9.2" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="9.1"
FILE_DESCRIPTION="Math Library for Intel® Compilers (thread-safe)" COMPANY_NAME="Intel Corporation" PRODUCT_NAME="Intel® C Compiler, Intel® C++
Compiler, Intel® Fortran Compiler" FILE_VERSION="9.1.9.2" ORIGINAL_FILENAME="libmmd.dll" INTERNAL_NAME="libmmd.dll" LEGAL_COPYRIGHT="Copyright ©
1985-2005 Intel Corporation" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x0" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0"
LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="9.1.9.2" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="02/16/2007 14:29:27" UPTO_LINK_DATE="02/16/2007 14:29:27"
<MATCHING_FILE NAME="libpng13.dll" SIZE="203264" CHECKSUM="0x394974A9" BIN_FILE_VERSION="1.2.8.1799" BIN_PRODUCT_VERSION="1.2.8.1799"
PRODUCT_VERSION="1.2.8.1799" FILE_DESCRIPTION="LibPng: PNG image compression library" COMPANY_NAME="LibPng" PRODUCT_NAME="LibPng" FILE_VERSION="1.2.8.1799"
ORIGINAL_FILENAME="libpng13.dll" INTERNAL_NAME="libpng13" LEGAL_COPYRIGHT="© 2004 Glenn Randers-Pehrson" VERFILEDATEHI="0x0" VERFILEDATELO="0x0"
VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3E738" LINKER_VERSION="0x10002" UPTO_BIN_FILE_VERSION="1.2.8.1799"
UPTO_BIN_PRODUCT_VERSION="1.2.8.1799" LINK_DATE="12/04/2004 00:09:31" UPTO_LINK_DATE="12/04/2004 00:09:31" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="shared.dll" SIZE="159744" CHECKSUM="0x2A451A6A" MODULE_TYPE="WIN32" PE_CHECKSUM="0x28C8E" LINKER_VERSION="0x0" LINK_DATE="10/18/2007
12:02:27" UPTO_LINK_DATE="10/18/2007 12:02:27" />
<MATCHING_FILE NAME="uninstall.exe" SIZE="354515" CHECKSUM="0x3FFA175F" BIN_FILE_VERSION="0.9.5.0" BIN_PRODUCT_VERSION="0.9.5.0"
FILE_DESCRIPTION="foobar2000" COMPANY_NAME="foobar2000.org" PRODUCT_NAME="foobar2000" FILE_VERSION="0.9.5 beta 1" ORIGINAL_FILENAME="foobar2000_0.9.5 beta
1.exe" LEGAL_COPYRIGHT="© Peter Pawlowski. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1"
MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.9.5.0" UPTO_BIN_PRODUCT_VERSION="0.9.5.0" LINK_DATE="09/29/2007 12:50:33"
UPTO_LINK_DATE="09/29/2007 12:50:33" VER_LANGUAGE="Language Neutral [0x0]" />
<MATCHING_FILE NAME="zlib1.dll" SIZE="59904" CHECKSUM="0x7697A3DC" BIN_FILE_VERSION="1.2.3.0" BIN_PRODUCT_VERSION="1.2.3.0" PRODUCT_VERSION="1.2.3"
FILE_DESCRIPTION="zlib data compression library" PRODUCT_NAME="zlib" FILE_VERSION="1.2.3" ORIGINAL_FILENAME="zlib1.dll" INTERNAL_NAME="zlib1.dll"
LEGAL_COPYRIGHT="© 1995-2004 Jean-loup Gailly & Mark Adler" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x10004" VERFILETYPE="0x2"
MODULE_TYPE="WIN32" PE_CHECKSUM="0xF587" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.2.3.0" UPTO_BIN_PRODUCT_VERSION="1.2.3.0" LINK_DATE="07/20/2005
09:48:10" UPTO_LINK_DATE="07/20/2005 09:48:10" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="components\foo_albumlist.dll" SIZE="329728" CHECKSUM="0x56C9E9D" MODULE_TYPE="WIN32" PE_CHECKSUM="0x54D3A" LINKER_VERSION="0x0"
LINK_DATE="10/19/2007 10:45:57" UPTO_LINK_DATE="10/19/2007 10:45:57" />
<MATCHING_FILE NAME="components\foo_albumlist_autoupdate.dll" SIZE="86016" CHECKSUM="0x70E82167" MODULE_TYPE="WIN32" PE_CHECKSUM="0x23820"
LINKER_VERSION="0x0" LINK_DATE="08/24/2006 22:08:42" UPTO_LINK_DATE="08/24/2006 22:08:42" />
<MATCHING_FILE NAME="components\foo_audioscrobbler.dll" SIZE="201216" CHECKSUM="0xF2256308" BIN_FILE_VERSION="1.3.6.0" BIN_PRODUCT_VERSION="1.3.6.0"
PRODUCT_VERSION="1, 3, 6, 0" FILE_DESCRIPTION="foo_audioscrobbler" PRODUCT_NAME=" foo_audioscrobbler" FILE_VERSION="1, 3, 6, 0"
ORIGINAL_FILENAME="foo_audioscrobbler.dll" INTERNAL_NAME="foo_audioscrobbler" LEGAL_COPYRIGHT="Copyright © 2004 Russ Garrett, © 2006-2007 Florian
Heidenreich" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x35FD1" LINKER_VERSION="0x0"
UPTO_BIN_FILE_VERSION="1.3.6.0" UPTO_BIN_PRODUCT_VERSION="1.3.6.0" LINK_DATE="05/13/2007 12:23:40" UPTO_LINK_DATE="05/13/2007 12:23:40" VER_LANGUAGE="English
(United Kingdom) [0x809]" />
<MATCHING_FILE NAME="components\foo_cdda.dll" SIZE="189440" CHECKSUM="0xF3AB60D3" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3A9E1" LINKER_VERSION="0x0"
LINK_DATE="10/19/2007 10:45:49" UPTO_LINK_DATE="10/19/2007 10:45:49" />
<MATCHING_FILE NAME="components\foo_common.dll" SIZE="225280" CHECKSUM="0x6F17E47C" BIN_FILE_VERSION="0.2.0.0" BIN_PRODUCT_VERSION="0.2.0.0"
PRODUCT_VERSION="0, 2, 0, 0" FILE_DESCRIPTION="foobar2000 Common Services component" PRODUCT_NAME="foobar2000 Common Services" FILE_VERSION="0, 2, 0, 0"
ORIGINAL_FILENAME="foo_common.dll" INTERNAL_NAME="foo_common" LEGAL_COPYRIGHT="Copyright © 2005 Holger Stenger" VERFILEDATEHI="0x0" VERFILEDATELO="0x0"
VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3896E" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.2.0.0"
UPTO_BIN_PRODUCT_VERSION="0.2.0.0" LINK_DATE="03/11/2006 18:23:55" UPTO_LINK_DATE="03/11/2006 18:23:55" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="components\foo_converter.dll" SIZE="409600" CHECKSUM="0xD60EB172" MODULE_TYPE="WIN32" PE_CHECKSUM="0x703F7" LINKER_VERSION="0x0"
LINK_DATE="08/20/2007 15:02:03" UPTO_LINK_DATE="08/20/2007 15:02:03" />
<MATCHING_FILE NAME="components\foo_dsp_skip_silence.dll" SIZE="40960" CHECKSUM="0xA0C62553" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12567"
LINKER_VERSION="0x0" LINK_DATE="10/02/2006 09:38:50" UPTO_LINK_DATE="10/02/2006 09:38:50" />
<MATCHING_FILE NAME="components\foo_dsp_std.dll" SIZE="274944" CHECKSUM="0x4699D659" MODULE_TYPE="WIN32" PE_CHECKSUM="0x47D61" LINKER_VERSION="0x0"
LINK_DATE="10/19/2007 10:45:58" UPTO_LINK_DATE="10/19/2007 10:45:58" />
<MATCHING_FILE NAME="components\foo_dsp_vlevel.dll" SIZE="139264" CHECKSUM="0xB9C7B124" MODULE_TYPE="WIN32" PE_CHECKSUM="0x27C52" LINKER_VERSION="0x0"
LINK_DATE="03/24/2006 15:55:08" UPTO_LINK_DATE="03/24/2006 15:55:08" />
<MATCHING_FILE NAME="components\foo_fileops.dll" SIZE="269824" CHECKSUM="0x27294BA0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x49B8A" LINKER_VERSION="0x0"
LINK_DATE="10/19/2007 10:46:10" UPTO_LINK_DATE="10/19/2007 10:46:10" />
<MATCHING_FILE NAME="components\foo_freedb2.dll" SIZE="245760" CHECKSUM="0x3016211" MODULE_TYPE="WIN32" PE_CHECKSUM="0x442F5" LINKER_VERSION="0x0"
LINK_DATE="08/16/2007 15:27:44" UPTO_LINK_DATE="08/16/2007 15:27:44" />
<MATCHING_FILE NAME="components\foo_infobox.dll" SIZE="253952" CHECKSUM="0x552B5108" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4588F" LINKER_VERSION="0x0"
LINK_DATE="10/09/2006 13:17:11" UPTO_LINK_DATE="10/09/2006 13:17:11" />
<MATCHING_FILE NAME="components\foo_input_std.dll" SIZE="1173504" CHECKSUM="0x3A493319" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12B790" LINKER_VERSION="0x0"
LINK_DATE="10/19/2007 10:45:45" UPTO_LINK_DATE="10/19/2007 10:45:45" />
<MATCHING_FILE NAME="components\foo_msnalt.dll" SIZE="94208" CHECKSUM="0x84A5FB9D" MODULE_TYPE="WIN32" PE_CHECKSUM="0x17AB8" LINKER_VERSION="0x0"
LINK_DATE="04/10/2006 13:39:29" UPTO_LINK_DATE="04/10/2006 13:39:29" />
<MATCHING_FILE NAME="components\foo_random.dll" SIZE="249856" CHECKSUM="0x41188E58" MODULE_TYPE="WIN32" PE_CHECKSUM="0x46633" LINKER_VERSION="0x0"
LINK_DATE="03/13/2006 10:35:03" UPTO_LINK_DATE="03/13/2006 10:35:03" />
<MATCHING_FILE NAME="components\foo_removeplayed.dll" SIZE="90112" CHECKSUM="0xEA0B980C" MODULE_TYPE="WIN32" PE_CHECKSUM="0x222D9" LINKER_VERSION="0x0"
LINK_DATE="09/02/2007 11:15:31" UPTO_LINK_DATE="09/02/2007 11:15:31" />
<MATCHING_FILE NAME="components\foo_rgscan.dll" SIZE="265728" CHECKSUM="0x1E469956" MODULE_TYPE="WIN32" PE_CHECKSUM="0x49F02" LINKER_VERSION="0x0"
LINK_DATE="10/19/2007 10:44:48" UPTO_LINK_DATE="10/19/2007 10:44:48" />
<MATCHING_FILE NAME="components\foo_uie_albumart.dll" SIZE="241664" CHECKSUM="0x274A87D" MODULE_TYPE="WIN32" PE_CHECKSUM="0x481CE" LINKER_VERSION="0x0"
LINK_DATE="01/16/2007 01:04:42" UPTO_LINK_DATE="01/16/2007 01:04:42" />
<MATCHING_FILE NAME="components\foo_uie_albumlist.dll" SIZE="261632" CHECKSUM="0x418C272F" MODULE_TYPE="WIN32" PE_CHECKSUM="0x44377" LINKER_VERSION="0x0"
LINK_DATE="06/11/2007 13:13:53" UPTO_LINK_DATE="06/11/2007 13:13:53" />
<MATCHING_FILE NAME="components\foo_uie_console.dll" SIZE="87040" CHECKSUM="0x3F531B12" MODULE_TYPE="WIN32" PE_CHECKSUM="0x169FD" LINKER_VERSION="0x0"
LINK_DATE="11/22/2006 12:59:04" UPTO_LINK_DATE="11/22/2006 12:59:04" />
<MATCHING_FILE NAME="components\foo_uie_peakmeter.dll" SIZE="200704" CHECKSUM="0x90957F0E" BIN_FILE_VERSION="0.0.4.1" BIN_PRODUCT_VERSION="0.0.4.1"
PRODUCT_VERSION="0, 0, 4, 1" FILE_DESCRIPTION="foo_uie_peakmeter is a foobar2000 plugin " COMPANY_NAME=" " PRODUCT_NAME="foo_uie_peakmeter" FILE_VERSION="0,
0, 4, 1" ORIGINAL_FILENAME="foo_uie_peakmeter.dll" INTERNAL_NAME="foo_uie_peakmeter" LEGAL_COPYRIGHT="Copyright © 2007 Matthias Brodrecht"
VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x38F8C" LINKER_VERSION="0x0"
UPTO_BIN_FILE_VERSION="0.0.4.1" UPTO_BIN_PRODUCT_VERSION="0.0.4.1" LINK_DATE="10/15/2007 18:24:49" UPTO_LINK_DATE="10/15/2007 18:24:49" VER_LANGUAGE="German
(Germany) [0x407]" />
<MATCHING_FILE NAME="components\foo_uie_vis_channel_spectrum.dll" SIZE="155648" CHECKSUM="0xC4DF7C04" MODULE_TYPE="WIN32" PE_CHECKSUM="0x297E9"
LINKER_VERSION="0x0" LINK_DATE="08/29/2007 13:55:45" UPTO_LINK_DATE="08/29/2007 13:55:45" />
<MATCHING_FILE NAME="components\foo_ui_columns.dll" SIZE="594944" CHECKSUM="0xDF3C348C" MODULE_TYPE="WIN32" PE_CHECKSUM="0x9B7E7" LINKER_VERSION="0x0"
LINK_DATE="11/22/2006 12:05:23" UPTO_LINK_DATE="11/22/2006 12:05:23" />
<MATCHING_FILE NAME="components\foo_ui_panels.dll" SIZE="942080" CHECKSUM="0x25BA9F54" MODULE_TYPE="WIN32" PE_CHECKSUM="0xE8C74" LINKER_VERSION="0x0"
LINK_DATE="06/12/2007 17:28:21" UPTO_LINK_DATE="06/12/2007 17:28:21" />
<MATCHING_FILE NAME="components\foo_ui_std.dll" SIZE="715776" CHECKSUM="0x7F920A40" MODULE_TYPE="WIN32" PE_CHECKSUM="0xBE0BC" LINKER_VERSION="0x0"
LINK_DATE="10/19/2007 10:45:11" UPTO_LINK_DATE="10/19/2007 10:45:11" />
<MATCHING_FILE NAME="components\foo_unpack.dll" SIZE="165888" CHECKSUM="0x9847132B" MODULE_TYPE="WIN32" PE_CHECKSUM="0x31AE1" LINKER_VERSION="0x0"
LINK_DATE="04/20/2007 19:35:15" UPTO_LINK_DATE="04/20/2007 19:35:15" />
<MATCHING_FILE NAME="components\foo_utils.dll" SIZE="225280" CHECKSUM="0x7F1B89AD" BIN_FILE_VERSION="0.5.0.0" BIN_PRODUCT_VERSION="0.5.0.0"
PRODUCT_VERSION="0, 5, 0, 0" FILE_DESCRIPTION="Utilities for foobar2000" COMPANY_NAME=" " PRODUCT_NAME="foo_utils" FILE_VERSION="0, 5, 0, 0"
ORIGINAL_FILENAME="foo_utils.dll" INTERNAL_NAME="foo_utils" LEGAL_COPYRIGHT="Copyright © 2005 Holger Stenger" VERFILEDATEHI="0x0" VERFILEDATELO="0x0"
VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3CA24" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.5.0.0"
UPTO_BIN_PRODUCT_VERSION="0.5.0.0" LINK_DATE="05/09/2006 11:01:32" UPTO_LINK_DATE="05/09/2006 11:01:32" VER_LANGUAGE="Language Neutral [0x0]" />
<MATCHING_FILE NAME="components\foo_verifier.dll" SIZE="175104" CHECKSUM="0x70597674" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2EE36" LINKER_VERSION="0x0"
LINK_DATE="08/29/2006 20:09:17" UPTO_LINK_DATE="08/29/2006 20:09:17" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="kernel32.dll" SIZE="930304" CHECKSUM="0xCBCCF8A9" BIN_FILE_VERSION="5.1.2600.1106" BIN_PRODUCT_VERSION="5.1.2600.1106"
PRODUCT_VERSION="5.1.2600.1106" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows®
Operating System" FILE_VERSION="5.1.2600.1106 (xpsp1.020828-1920)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft
Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xE7ED3"
LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.1106" UPTO_BIN_PRODUCT_VERSION="5.1.2600.1106" LINK_DATE="08/29/2002 10:40:40"
UPTO_LINK_DATE="08/29/2002 10:40:40" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
</DATABASE>
alphaex32
post Oct 20 2007, 16:38
Post #20
I feel like I'm missing something here, because none of the old UI elements are showing up in the "replace element" list for me. I only see the default ones, and Id like to use the browser, bookmarks, lyrics, etc. Also, nothing is showing up in the new albumart panel, and I cant figure out how to get to any kind of settings dialogue for it. I also don't see anything about the "scratchbox " or "facets plugin."
edit: Ok, I found the facets plugin, which is awesome btw. I still really miss the old UI components but I love this new layout system. No chance of backward compatibility?
This post has been edited by alphaex32: Oct 20 2007, 16:43
Ran Sagy
post Oct 20 2007, 16:43
Post #21
"Better than sliced bread!". Thanks to the foobar2000 team for the wonderful work so far.
q-stankovic
post Oct 20 2007, 16:47
Post #22
I am sitting right now in an inet-cafe and has downloaded new beta and the brand new facet plugin - i know how i will spend the rest of my day. I expected many new things but not this: it seems to be amazing!
Thanks for your hard work!
One question just: is it a big work for developer of some panels (bookmarks, history, lyricshow, queuemanager...) to transfer their plugins?
This post has been edited by q-stankovic: Oct 20 2007, 16:50
Frank Bicking
post Oct 20 2007, 16:49
Post #23
QUOTE (alphaex32 @ Oct 20 2007, 17:38) *
Those components you have listed are panels for Columns UI, which is an entirely different user interface.
Panels were never part of the default UI.
From the footnote in the release notes:
UI Elements are conceptually similar to the panels introduced by Columns UI, but are incompatible with them so they were given a new name.
aurelio
post Oct 20 2007, 16:56
Post #24
Whoa! The return of the Spectrum!! Many thanks!
Squeller
post Oct 20 2007, 17:01
Post #25
Wow, a new beginning. I'll need some time for that...
BTW, the fb2k default icon has some ugly white pixels at the corner here, wxp, 16 bit colors.
Is there a way to reset the default UI settings only? Would be helpful especially at the beginning...
EDIT: OK I found the quick setup window. Great work.
The layout import/export/cut/copy/scratchbox: Very fine!
This post has been edited by Squeller: Oct 20 2007, 17:09
RSS Lo-Fi Version Time is now: 25th May 2015 - 08:56
