LAME mp3 encode wav by right clicking file?
dnewhous
post Oct 14 2007, 08:23
Is there any software that will encode a wav filet to an mp3 by right clicking on the file in Windows Explorer? Preferably using the LAME encoder.
nannaloori
post Jan 3 2013, 10:42
QUOTE (j7n @ Oct 14 2007, 19:19) *
Add your LAME command line to the Windows registry.
(1) Find: HKEY_CLASSES_ROOT\.wav and locate the (Default) value. Let's assume it is $SomeKey$.
(2) Now go to: HKEY_CLASSES_ROOT\$SomeKey$\shell\
Create a new subkey called whatever you like (here "LAME-test"). Select the new subkey and under (Default) enter the text that will appear in your right-click menu ("• My LAME Command"). Now create a key called "command" one level deeper.
(3) There under another (Default) value enter the actual LAME command.
For example, lame.exe -V 2 -h "%L"
Tried this, didn't get it to work - nothing appeared in the context menu. (Did manage to succeed with the advice on creating a context menu for encoding of whole folder here
Using windows 7. My $SomeKey$ was WMP11.AssocFile.WAV. Located that, went to the shell subkey, created "encode v0 mp3", inside which created "command", and changed the default value to "C:\Program Files (x86)\lame\lame.exe" -V0 "%L" - to no avail.
What to do?
This post has been edited by nannaloori: Jan 3 2013, 10:44
JJZolx
post Jan 3 2013, 12:42
QUOTE (nannaloori @ Jan 3 2013, 03:42) *
A very easy way to do this without having to directly edit the registry is with Nirsoft's File Types Manager. Find the .wav entry, then right-click in the lower window and create a new action.
- dnewhous   LAME mp3 encode wav by right clicking file?   Oct 14 2007, 08:23
- - softska   http://www.dbpoweramp.com/dmc.htm   Oct 14 2007, 11:48
- - trev   any FREE program that will do it?   Oct 14 2007, 14:55
|- - softska   QUOTE (trev @ Oct 14 2007, 08:55) any FRE...   Oct 15 2007, 06:10
- - smok3   http://www.google.com/search?q=add%20thing...ht-cl...   Oct 14 2007, 16:00
|- - j7n   Add your LAME command line to the Windows registry...   Oct 14 2007, 18:19
- - trev   thanks for the registry hack advice. i'm not ...   Oct 15 2007, 02:27
|- - j7n   QUOTE i tried it, didn't seem to work. if you ...   Oct 15 2007, 09:16
- - greynol   I'm still looking for some kind of generic hoo...   Oct 15 2007, 09:07
- - Zoom   When I want to set up an encoder I don't like ...   Oct 15 2007, 18:02
|- - j7n   What about encoders that expect input files not as...   Oct 15 2007, 18:33
|- - Zoom   QUOTE (j7n @ Oct 15 2007, 13:33) What abo...   Oct 17 2007, 21:29
|- - j7n   Previously, I found that it is handy to set the Se...   Oct 17 2007, 21:48
|- - greynol   QUOTE (j7n @ Oct 17 2007, 13:48) Do you n...   Oct 17 2007, 23:24
- - greynol   You just create a batch file for the encoder, it...   Oct 15 2007, 18:46
|- - j7n   You're saying that it would not spawn an encod...   Oct 15 2007, 20:48
|- - greynol   QUOTE (j7n @ Oct 15 2007, 12:48) You...   Oct 15 2007, 21:29
- - hybridfan   QUOTE (dnewhous @ Oct 14 2007, 08:23) Is ...   Oct 18 2007, 21:21
- - nannaloori   QUOTE (j7n @ Oct 14 2007, 19:19) Add your...   Jan 3 2013, 10:42
- - JJZolx   QUOTE (nannaloori @ Jan 3 2013, 03:42) Tr...   Jan 3 2013, 12:42
RSS Lo-Fi Version Time is now: 2nd March 2015 - 21:03
