foo_sstp_lyrics, play SAKURA script lyrics to SSP
Yiting
post Oct 6 2007, 22:55
This component can play a SAKURA script lyrics to the SSP client.
A demo on youtube.
Homepage & Manual: http://yiting2002.myweb.hinet.net/rainmeter/sstp_lyrics.html
Download: foo_sstp_lyrics-0.2.2.zip (52.7 KB)
If you don't know what is SSP, please see Wikipedia.
This post has been edited by Yiting: Jul 7 2008, 10:24
Yiting
post Oct 10 2007, 15:00
============ Release Note ===========
● @SakuraScriptGhost is only available for Direct SSTP mode.
● If you active multiple ghost at the same time, it can find the correct one.
● If your lyric is written for specific ghost (e.g. flele), this is very useful to avoid impacting other ghost!
Changes in v0.2.2:
*ADD @SakuraScriptGhost for specific ghost name (e.g. @SakuraScriptGhost=flele).
This post has been edited by Yiting: Jun 28 2008, 20:42
traveling
post Nov 1 2007, 03:02
Thanks for telling this.
Yiting
post Nov 11 2007, 20:36
Here is very important updated in this release version.
If you have used previous version, please updates this version.
Thanks everyone for using it, thanks for support of CUC's members.
Stark Wong
post Jan 10 2008, 00:45
Is it possible to add lrc lyrics support to the plugin? As it is common to have this type of lyric file, it would be great if the plugin can support it.
This post has been edited by Stark Wong: Jan 10 2008, 00:52
Yiting
post Mar 9 2008, 09:51
Update for support .lrc style lyrics (multiple timetag), and some code optimize.
In this case, it would use Primary property to build lyric script for general surface.
Gusnana1412
post Mar 10 2008, 10:56
Hi Yiting,
Do you mind helping, on how to use the lyrics to show up in SSP?
(It only show the "Next song is ...")
Thanks in advance
Yiting
post Mar 10 2008, 11:58
QUOTE (Gusnana1412 @ Mar 10 2008, 17:56) *
If you have show "Next song is ...", i think that's easy to do.
1. check you lyrics filename is the same with song's filename or song's title, and put them in the same directory.
2. file extension is .txt or .lrc or .ssl
3. If it's .txt or .ssl, must contains a @SakuraScript=1 statement in file.
Gusnana1412
post Mar 11 2008, 11:25
Thank You Yiting, I didnt know @SakuraScript=1 statement must be put on the file.
Currently it works with samename.txt, but I found some problem (It wasn't work with @SakuraScript=1 statement). If you save the txt file with "Unicode" type it wont work.
I have another question, the lyric only show one per line and will removed previous line as soon as the next line show up. My question will be, is it possible to make it stack/scrollable?
Yiting
post Mar 12 2008, 06:28
QUOTE (Gusnana1412 @ Mar 11 2008, 18:25) *
It's defined by SAKURA script, you must have this statment.
Yes, please use UTF-8 or ANSI. A regular SAKURA script even not allow UTF-8.
It is, but you should learn how to write a SAKURA script. The script could help you to finish this effect.
Gusnana1412
post Mar 12 2008, 21:23
Thank You for the reply and I'm sorry if I failed to find SAKURA script command list.
Yiting
post Mar 25 2008, 18:58
Important update for changing communication method with Direct SSTP.
Seems the recent version of SSP have some problem with socket. After a long time frequently communication, it may not receive any data large than a MTU, then a script will be break unless you restart SSP.
That's why I want to release this version, for avoiding this situation. Nevertheless, Direct SSTP is exactly better than regular protocol on local communication.
D.Sync
post May 10 2008, 07:08
How to use this plugin anyways? I already got the lyric file with the same name as the mp3 but nothing appear?
Yiting
post Jun 28 2008, 16:50
QUOTE (D.Sync @ May 10 2008, 14:08) *
I think you just need a SSP to show the characters like above.
This component only send lyrics to it.
You can find some introduction on Wikipedia.
matav
post Dec 28 2010, 23:44
Post #15
*bump*
wow! blink.gif what a bump!
anyways... just out of curiosity, does anyone know where i can download ghosts that talk in freaking english?
try my portable foobar theme -- eXdb v4d
http://bit.ly/matavfb
NanaMiku
post Mar 24 2011, 07:21
Post #16
i want to know is it possible to use the lyric file on the music that splitted using cue file?
RSS Lo-Fi Version Time is now: 4th March 2015 - 05:02
