Lame 3.90.2 vs 3.92, Audible differences with APS?
Lev
post Jan 16 2003, 16:03
oops, I always thought I had been using 3.90.2, but upon actually opening my eyes and checking, it seems I am using 3.92. I have swapped to 3.90.2, although I cannot tell one little difference whatsoever.
Is there any difference, audibly?
http://www.megalev.co.uk
RIV@NVX
post Jan 16 2003, 16:10
3.92 is newer, 3.90.2 is older... I don't know about difference.
dev0
post Jan 16 2003, 16:26
There should be no audible difference, but maybe a small one in bitrate, since 3.92 uses different compilerflags.
dev0
NeoRenegade
post Jan 16 2003, 17:02
Apparently the developpers have screwed something up; 3.92 and later I believe use the wrong noiseshaping with APS.
I personally would recommend 3.90.2 for the VBR presets, and 3.93.1 for the ABR & CBR presets.
Gabriel
post Jan 16 2003, 17:07
LAME developer
Lev
post Jan 16 2003, 17:22
What does the '???' mean?
Wrong noise shaping or not?
I know that the newer compiles of Lame have 'disadvantaged' APS... ph34r.gif
Daffy
post Jan 16 2003, 17:23
QUOTE (NeoRenegade @ Jan 16 2003 - 11:02 AM)
You state 3.92 and later is screwed up (without backing that up, btw), and then recommend 3.93.1. Isn't 3.93.1 later than 3.92?
Clarify your claims please.
EDIT: My mistake. I now see you recommend 3.93.1 for ABR and CBR. However, I disagree with your claim that 3.92 APS is screwed up.
This post has been edited by Daffy: Jan 16 2003, 17:26
Gabriel
post Jan 16 2003, 17:37
LAME developer
Noise shaping is the same between 3.90.2, 3.91, 3.92, 3.93.1.
LordofStars
post Jan 16 2003, 18:19
'tis only 3.93 that comes unreccomended.
r3mix zealot.
dev0
post Jan 16 2003, 18:24
We've been through this so many times...
The differences between 3.90.2 and 3.92 are:
- changed compiler options, that might cause a slight modification in bitrate;
- support for CBR/ABR alt-presets for bitrates <80kbps
3.90.2 is still the HA approved, most tested and fastest version, so if you don't need any of the 'features' of 3.92 or 3.93.1 use it!
dev0
RSS Lo-Fi Version Time is now: 7th July 2015 - 17:19
