Double-blind test of SACD and DVD-A vs. Redbook 16/44 in JAES Septembe, (hint: no surprises!) (bumped from 2007 in post #35)
Axon
post Sep 10 2007, 04:11
Group: Members (Donating)
"Audibility of a CD-Standard A/D/A Loop Inserted into High-Resolution Audio Playback". E. Brad Meyer and David R. Moran. JAES 55(9) September 2007. It's worth noting that members of the BAS wrote the paper and performed in the tests. You'll need an AES membership to access the article, so no link.
Abstract:
Claims both published and anecdotal are regularly made for audibly superior sound quality for two-channel audio encoded with longer word lengths and/or at higher sampling rates than the 16-bit/44.1-kHz CD standard. The authors report on a series of double-blind tests comparing the analog output of high-resolution players playing high-resolution recordings with the same signal passed through a 16-bit/44.1-kHz "bottleneck." The tests were conducted for over a year using different systems and a variety of subjects. The systems included expensive professional monitors and one high-end system with electrostatic loudspeakers and expensive components and cables. The subjects included professional recording engineers, students in a university recording program, and dedicated audiophiles. The test results show that the CD-quality A/D/A loop was undetectable at normal-to-loud listening levels, by any of the subjects, on any of the playback systems. The noise of the CD-quality loop was audible only at very elevated levels.
This post has been edited by Axon: Sep 10 2007, 04:13
Axon
post Sep 13 2007, 20:23
So I've been monitoring Audio Asylum's thread on this (yeah, I know, bad idea). They do offer a few good criticisms.
  • JA asserted that the high res player they used, a Pioneer 563A, does not have any better of a dynamic range with high res recordings compared to CDs. Pioneer sez it's 108db, but hey, maybe it is lower in reality. It's asserted that this could obscure details in the high res listening, while still being low enough that the added quantization stage at 16/44 increases the noise level enough for audibility when listening to silence at loud levels.
  • Like I said, virtually no details are provided on the exact equipment used. The BAS website mentions the 563A in passing in an old article describing the test.
  • The statistical analysis is rather shoddy. The test results are not broken down by listener, or listening location, or by almost anything else. Type A and B error is not defined. The null hypothesis is not defined.
  • Musical selections are not listed.
  • Listeners are not described in terms of experience in any detail.
krabapple
post Sep 14 2007, 22:56
QUOTE (Axon @ Sep 13 2007, 15:23) *
Too bad. I guess we'll have to wait for Atkinson & Co to perform the slam-dunk scientific demonstration that hi-rez really audibly matters rolleyes.gif
david moran
post Sep 19 2007, 22:15
>> * JA asserted that the high res player they used, a Pioneer 563A, does not have any better of a dynamic range with high res recordings compared to CDs. Pioneer sez it's 108db, but hey, maybe it is lower in reality. It's asserted that this could obscure details in the high res listening, while still being low enough that the added quantization stage at 16/44 increases the noise level enough for audibility when listening to silence at loud levels.
These are not good criticisms. Just pro-forma nitpicking, so it appears something is wrong with the experiment. (There has to be, right?) There is nothing wrong with it. We used more than one hi-rez player. The noise floor of the venue was incredibly low. The loud levels were very loud. The source material --- lots of it, the widest range we could find, samplers, special demo cuts --- was extremely quiet in its noise floors.
>> * Like I said, virtually no details are provided on the exact equipment used. The BAS website mentions the 563A in passing in an old article describing the test.
It does not matter what we used, since we degraded a hi-rez system and no one heard any difference, ever, regardless. We could have used an even better-quality 16/44 loop. But perhaps a genuinely compelling reason will arise and we will list the gear. The experiment was expanded to several other venues, including serious tweak systems, recording studios, and the like. No difference in the ability of the listeners to hear the "degradation."
>> * The statistical analysis is rather shoddy. The test results are not broken down by listener, or listening location, or by almost anything else. Type A and B error is not defined. The null hypothesis is not defined.
What could this mean? Of course we spoke to statisticians, who were unanimous in saying it was a straightforward test of detectability, yes or no. Either some listeners heard a difference or not. No one did. No one came close. Any listener, any venue, any material. We did go over the results sorting by hearing bandwidth, sex, age, and experience. You will have to read the paper to be convinced, or not. If you really cannot afford to buy it, email me at drmoran@aol.com.
>> * Musical selections are not listed.
Made no difference. This kind of thing is just to try to poke holes in an ironclad coin-flip result. We got a very wide range of material, types, instruments, vocals, genres, etc. Special stuff made for hi-rez demos, etc. etc.
>> * Listeners are not described in terms of experience in any detail.
Not so --- just not enough detail for some who simply cannot believe the results.
David Moran
krabapple
post Sep 19 2007, 23:52
QUOTE (david moran @ Sep 19 2007, 17:15) *
The genuinely compelling reason for a detailed methods section in any scientific paper, is so the work can at least theoretically be reproduced. And as you've seen, the subjectivist camp/Audio Asylum inmates will be all over you if you don't document everything scrupulously.
It suggest you did not publish the Type I and Type II error statistics associated with your tests. Most scientific papers that involve statistics at least include a Type I error (p value).
I'd be happy to buy it, but it appears to be not yet available for purchase. I'd love to get a copy.
Believe it or now, most of us here are very much on your 'side'. Hydrogenaudio even has advocacy of blind tests built into it Terms of Use.
It's just regrettable if a paper on this perennial hot topic failed to provide extensive method detail, because every omission will be used against it. And thus a topic that should have been laid to rest years ago, will remain 'hot'.
Perhaps you could set up a 'supplementary materials and methods' webpage to provide those details?
This is common in journals where printed space is at a premium (e.g., Science, Nature).
This post has been edited by krabapple: Sep 19 2007, 23:54
david moran
post Sep 20 2007, 22:40
Okay. Thank you all for your thoughtful responses, and I apologize for misinterpreting or impugning anyone here. (Or indeed anywhere.)
Rightly or wrongly, the chief reason we did not provide details was to preclude, or try to preclude, being nitted to death over the details. Which surely would have happened. The hi-rez players sucked, your amp and preamp suck, your speakers suck, so of course you could not hear anything. Etc. etc. Quite apart from the other venues and the number of listeners and trials.
So, as I say, rightly or wrongly. Y'all will observe that none of the AESJ editors or reviewers felt the lack of specifics was of any import whatsoever. No one mentioned a thing, not even once. We were asked for some more breakout of the results, which we provided.
Nonetheless, since we are receiving almost exactly the same flak as if we had given all the specifics, I am sure at some point, soon, we will post it all somewhere, perhaps on the BAS website.
Thanks for your modulated reading and responding.
David Moran
Kees de Visser
post Sep 22 2007, 08:52
QUOTE (david moran @ Sep 20 2007, 23:40) *
IMHO it's a pity that the AES doesn't provide any standards or even guidelines regarding subjective listening tests. The AES technical committee on Perception and Subjective Evaluation of Audio Signals (PSEAS) doesn't seem to be of much help in this respect. Anecdotal evidence is still widely accepted in the pro audio community. A possible reason could be that most engineers don't know how to set up and conduct a proper listening test. An often used excuse is that it involves a huge budget and lots of time and therefore can only be done by large companies and institutions.
AFAIK Perceptual Coding is the only area where subjective evaluation is used methodically. This forum is a good example of that.
I do hope that the AES (or another organisation of equal importance) will provide standards or guidelines and make an effort in promoting them.
Kees de Visser
This post has been edited by Kees de Visser: Sep 22 2007, 08:57
- Axon   Double-blind test of SACD and DVD-A vs. Redbook 16/44 in JAES Septembe   Sep 10 2007, 04:11
- - PoisonDan   Interesting, thanks!   Sep 10 2007, 07:08
- - hushypushy   Very interesting...people are still going to claim...   Sep 10 2007, 07:14
- - Kees de Visser   Thanks for the info. Any details about the A/D/A l...   Sep 10 2007, 12:16
- - LANjackal   Thanks for this   Sep 10 2007, 13:18
- - Bad Monkey   The test results show that the CD-quality A/D/A lo...   Sep 10 2007, 13:48
|- - hushypushy   QUOTE (Bad Monkey @ Sep 10 2007, 05:48) T...   Sep 10 2007, 17:15
- - kdo   Can smb remind me please if there was any AES arti...   Sep 10 2007, 13:58
- - Madman1153   The title as well as the Abstract of this article ...   Sep 10 2007, 17:57
- - Bad Monkey   @ hushypushy: You've rush-read my post and hav...   Sep 10 2007, 17:59
- - Canar   Did they noise shape the 16-bit audio? Noise shapi...   Sep 10 2007, 18:47
- - AndyH-ha   The several comments about lack of inferences on s...   Sep 10 2007, 19:34
- - Axon   Sorry, I haven't had a whole lot of time to su...   Sep 10 2007, 20:37
|- - Kees de Visser   OK, I finally got the paper (written by the Boston...   Sep 11 2007, 06:33
|- - dmckean   QUOTE (Axon @ Sep 10 2007, 12:37) The pap...   Sep 12 2007, 00:59
|- - krabapple   QUOTE (Axon @ Sep 10 2007, 15:37) The pap...   Sep 13 2007, 17:27
|- - Axon   QUOTE (krabapple @ Sep 13 2007, 11:27) So...   Sep 13 2007, 20:02
- - AndyH-ha   They tested the quantization level of 16/44 by ABX...   Sep 11 2007, 00:03
- - greynol   Sounds like more than just quantization noise was ...   Sep 11 2007, 06:53
- - 2Bdecided   It implies the best and most convenient content av...   Sep 11 2007, 12:26
|- - user   I think, the result of this paper and tests are cl...   Sep 11 2007, 13:53
- - Axon   So I've been monitoring Audio Asylum's thr...   Sep 13 2007, 20:23
|- - krabapple   QUOTE (Axon @ Sep 13 2007, 15:23) So I...   Sep 14 2007, 22:56
|- - david moran   >> * JA asserted that the high res playe...   Sep 19 2007, 22:15
|- - krabapple   QUOTE (david moran @ Sep 19 2007, 17:15) ...   Sep 19 2007, 23:52
||- - david moran   Okay. Thank you all for your thoughtful responses,...   Sep 20 2007, 22:40
|||- - krabapple   QUOTE (david moran @ Sep 20 2007, 17:40) ...   Sep 22 2007, 06:48
|||- - Kees de Visser   QUOTE (david moran @ Sep 20 2007, 23:40) ...   Sep 22 2007, 08:52
|||- - spockep   QUOTE (david moran @ Sep 20 2007, 17:40) ...   Sep 22 2007, 13:37
||- - bernlin2000   QUOTE (krabapple @ Sep 19 2007, 16:52) Be...   Dec 20 2012, 10:50
|- - Axon   Thank you for replying (and hopefully you'll s...   Sep 20 2007, 00:42
- - dekkersj   I contacted the authors and they replied that they...   Sep 20 2007, 20:58
- - dekkersj   Thanks David, Good to talk to you this way I ...   Sep 20 2007, 22:49
- - Axon   What they said. Thanks for responding. Clearly i...   Sep 23 2007, 04:01
|- - 2Bdecided   QUOTE (Axon @ Sep 23 2007, 04:01) For eve...   Sep 24 2007, 11:39
- - usernaim   I'm not an advocate of hi-rez, but I wanted to...   May 28 2012, 18:43
|- - Arnold B. Krueger   QUOTE (usernaim @ May 28 2012, 13:43) I...   May 29 2012, 15:37
|- - 2Bdecided   QUOTE (Arnold B. Krueger @ May 29 2012, 15...   May 29 2012, 17:47
|- - Arnold B. Krueger   QUOTE (2Bdecided @ May 29 2012, 12:47) QU...   May 29 2012, 21:10
- - 2Bdecided   Arny, I'm on your side. The point is they clai...   May 31 2012, 10:17
|- - Arnold B. Krueger   QUOTE (2Bdecided @ May 31 2012, 05:17) Ar...   May 31 2012, 12:45
- - SoNic67   I am a fan of SACD recordings. Not necesarelly bec...   Jun 1 2012, 00:08
|- - 2Bdecided   QUOTE (SoNic67 @ Jun 1 2012, 00:08) Anywa...   Jun 1 2012, 11:40
|- - Arnold B. Krueger   QUOTE (2Bdecided @ Jun 1 2012, 06:40) QUO...   Jun 1 2012, 12:01
|- - SoNic67   QUOTE (2Bdecided @ Jun 1 2012, 06:40) You...   Jun 2 2012, 00:56
|- - Arnold B. Krueger   QUOTE (Sonic67)Everyone tells me that I can't ...   Jun 3 2012, 00:27
- - Wombat   QUOTE (2Bdecided @ May 29 2012, 18:47) Fa...   Jun 3 2012, 00:11
- - bernlin2000   QUOTE (Axon @ Sep 9 2007, 21:11) "Au...   Dec 20 2012, 10:44
- - DonP   One argument I would consider is that if any compo...   Dec 20 2012, 14:26
|- - sawdin   If the BAS testing was so flawed, why haven't ...   Jan 6 2013, 19:58
|- - Arnold B. Krueger   QUOTE (sawdin @ Jan 6 2013, 13:58) If the...   Jan 7 2013, 15:51
|- - drmoran@aol.com   QUOTE (Arnold B. Krueger @ Jan 7 2013, 09...   Jan 20 2013, 01:25
- - mzil   Dr. Moran, I think this test you used is brilliant...   Jan 20 2013, 06:01
|- - Arnold B. Krueger   QUOTE (mzil @ Jan 20 2013, 00:01) Dr. Mor...   Jan 22 2013, 19:02
|- - mzil   QUOTE (Arnold B. Krueger @ Jan 22 2013, 14...   Jan 22 2013, 22:50
- - eretsua   The difference in sound between vinyl and CDs, I t...   Jan 23 2013, 03:22
|- - Engelsstaub   QUOTE (eretsua @ Jan 22 2013, 20:22) The ...   Jan 23 2013, 04:28
||- - julf   QUOTE (Engelsstaub @ Jan 23 2013, 04:28) ...   Jan 23 2013, 08:33
||- - markanini   QUOTE (julf @ Jan 23 2013, 08:33) QUOTE (...   Jan 23 2013, 09:14
||- - julf   QUOTE (markanini @ Jan 23 2013, 09:14) Do...   Jan 23 2013, 10:54
||- - eretsua   Sigh, regardless of how well or how poorly anyone ...   Jan 23 2013, 11:27
||- - julf   QUOTE (eretsua @ Jan 23 2013, 11:27) Sigh...   Jan 23 2013, 12:10
|- - Arnold B. Krueger   QUOTE (eretsua @ Jan 22 2013, 21:22) The ...   Jan 24 2013, 19:45
- - markanini   That's like calling a prostitute a nun for hav...   Jan 24 2013, 06:40
- - 2Bdecided   No, I think he means use the vinyl as the source, ...   Jan 25 2013, 11:14
|- - Arnold B. Krueger   QUOTE (2Bdecided @ Jan 25 2013, 05:14) No...   Jan 25 2013, 13:17
|- - db1989   QUOTE (Arnold B. Krueger @ Jan 25 2013, 12...   Jan 25 2013, 13:50
||- - dhromed   QUOTE (db1989 @ Jan 25 2013, 13:50) Iím s...   Jan 25 2013, 14:02
|- - 2Bdecided   QUOTE (Arnold B. Krueger @ Jan 25 2013, 12...   Jan 25 2013, 14:01
- - db1989   Oh lawd! Why didnít I ever suspect before? Co...   Jan 25 2013, 14:12
- - greynol   eretsua is suggesting that a CD using the same mas...   Jan 25 2013, 17:47
- - eretsua   Greynol is correct. What I meant is that indeed th...   Jan 26 2013, 00:14
|- - krabapple   QUOTE (eretsua @ Jan 25 2013, 19:14) So t...   Jan 26 2013, 17:48
|- - Arnold B. Krueger   QUOTE (eretsua @ Jan 25 2013, 18:14) So t...   Jan 28 2013, 19:24
|- - greynol   QUOTE (Arnold B. Krueger @ Jan 28 2013, 10...   Jan 28 2013, 20:03
- - greynol   We have a saying around here: you can make your CD...   Jan 26 2013, 00:42
- - 2Bdecided   I'm totally lost. Anyway, while I'm happ...   Jan 28 2013, 14:04
|- - Nessuno   QUOTE (2Bdecided @ Jan 28 2013, 14:04) I...   Jan 28 2013, 15:25
|- - greynol   QUOTE (2Bdecided @ Jan 28 2013, 05:04) I...   Jan 28 2013, 19:54
|- - krabapple   QUOTE (2Bdecided @ Jan 28 2013, 09:04) I...   Jan 29 2013, 05:12
- - 2Bdecided   I was lost with who suggested we blind tested what...   Jan 29 2013, 10:45
- - greynol   Due to the two off-topic posts in the last 24 hour...   Jun 15 2013, 01:22
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 2nd April 2015 - 06:22
