WMPCDText - CD-Text plug-in for Windows Media Player
Tim De Baets
post Aug 13 2007, 02:56
Author of WMPCDText
I have released WMPCDText, a Windows Media Player plug-in that finally adds support for CD-Text to WMP.
There is an option to automatically read CD-Text from unknown CD's. Alternatively, you can also right-click on a CD-track in the Now Playing-pane while the CD is playing, and click "Read CD-Text". There are some other options too, those can be changed in the plug-in's settings dialog.
Download
Enjoy!
Tim De Baets
September 1, 2007: I have updated WMPCDText with a fix for crashes that might occur in wmpvis.dll when a visualization is enabled in WMP. Please re-download and reinstall WMPCDText if WMP crashes when you advance to the next track, and these crashes started happening after installing WMPCDText.
December 22, 2007: I have released the final version: http://bmproductions.fixnum.org/wmpcdtext
July 9, 2008: WMPCDText 1.1 has been released. This new version fixes the "Error while executing SCSI command: SRB completed with error (4)" message.
July 28, 2009: WMPCDText 1.2 adds full compatibility with Windows Media Player 12 on Windows 7.
July 20, 2012: WMPCDText 1.3 fixes the Read CD-Text menu item not appearing in certain cases, and a possible crash when opening WMP 12.
August 15, 2012: WMPCDText 1.4 fixes an issue that was introduced in version 1.3 and that could lead to a Windows Media Player crash.
This post has been edited by Tim De Baets: Sep 13 2013, 21:43
dbminter
post Jul 20 2011, 16:59
I wasn't sure if issues using WMPCDText were put by just replying to this post or not. So, if this belongs somewhere else, sorry. smile.gif
I've tried this plugin on 2 different computers and have gotten the same results. When the plugin tries to automatically get CD Text for Track names, it returns garbage data for the Track name. However, if I use the right click context menu to Read CD Text manually, the Track names then are read in with their proper CD Text.
The other thing I've come across is even when I uncheck the option to convert from uppercase to lowercase, some conversion still occurs. For instance, in my CD Text test CD, I have the text CD Text Test Disc as part of some of the CD Text. When the plugin reads the CD Text in, it returns Cd Text Test Disc instead of CD Text Test Disc.
Tim De Baets
post Jul 20 2011, 21:16
Author of WMPCDText
First, which version of WMP and Windows are you using? Are you using the latest version of WMPCDText, 1.2?
Regarding the first issue, would it be possible to post a screen shot of the garbage track names? You can attach the screen shot to your reply. Also, do you get the same issue if you let CDex read the CD-Text?
About your second issue, does the option stay unchecked in WMPCDText's settings? Even with the option checked, WMPCDText will only convert if the original text is in all caps. I suggest that you check if the CD-Text isn't in all caps after all, by also using CDex.
dbminter
post Jul 20 2011, 21:51
QUOTE (Tim De Baets @ Jul 20 2011, 14:16) *
WMP 12.0.7601.175141 and the latest version of WMPCDText, 1.2.
Unfortunately, I now cannot get the issue to repeat. I had had the problem where if I used Read CD Text, I'd get garbage, then the right text, then garbage text, alternately. It was reproducable. Now, I can't reproduce it. It was a long string of apparently random text sometimes mixed in with part of the CD Text. I can't post screenshot, but, I can post the file name from a rip that was being returned as I did copy and paste those into a post on a different forum.
01 H`6 a(VpN4{ V]O,4 צzc )ʞ(^{1TIv& .mp3
It should be
01 CD Text Test Title Track 1- In The Navy.mp3
When I'd use the Read CD Text context menu option, I'd get
Cd Text Test Title Track 1- In The Navy.mp3.
It SHOULD be 01 CD Text Test Title Track 1- In The Navy.mp3 with both C and D capitalized in CD.
Let me see. I've never heard of this app before. I get the correct CD Text in CDex, even with the correct capitalization of CD.
I see, I misunderstood the nature of the function. It only works on ALL caps text, not a mixture. Actually, it does say that in the settings, doesn't it? blush.gif
I just checked it DOES say that! Sorry.
Tim De Baets
post Jul 21 2011, 14:08
Author of WMPCDText
QUOTE (dbminter @ Jul 20 2011, 22:51) *
I'll do some more tests on my Windows 7 system, but I've never seen this issue on my own systems so I probably won't be able to reproduce it myself either. And without a way to reproduce, I'm afraid that it will be near impossible to debug this.
So am I right to assume that this is cleared up now? Note that WMPCDText will automatically read the CD-Text only once, after that the CD-Text is cached in WMP's database. However, you can still force it to read CD-Text again by using the Read CD-Text context menu option.
- Tim De Baets   WMPCDText - CD-Text plug-in for Windows Media Player   Aug 13 2007, 02:56
- - ontariocraig   Hi Tim, Wanted to say thanks for this excellent p...   Oct 15 2007, 16:00
|- - Tim De Baets   QUOTE (ontariocraig @ Oct 15 2007, 17:00)...   Oct 17 2007, 17:09
|- - charliemcdo   Tim, Echoing Craig's comment. Thanks for your...   Oct 19 2007, 18:06
- - MONSIEUR   thank you for this plug-in, it is working on my wi...   Nov 24 2007, 16:50
|- - nottenst   I just tried it on my new Dell XPS 420 Vista machi...   Apr 13 2008, 20:21
- - vijaye7   Hi Tim, Like neil, I am getting the following err...   Apr 15 2008, 16:42
- - Tim De Baets   Neil and Vijay, thanks for reporting this. There s...   Apr 19 2008, 14:13
|- - vijaye7   Thanks for the response, Tim. It happens only for ...   Apr 19 2008, 14:55
- - Tim De Baets   I have done some testing but I haven't been ab...   Apr 21 2008, 18:06
|- - nottenst   QUOTE (Tim De Baets @ Apr 21 2008, 12:06)...   Apr 23 2008, 22:43
- - lennie paz   this program is not working for me on WMP 11 and x...   Apr 23 2008, 13:21
- - Tim De Baets   I have finally been able to fix the "Error wh...   Jul 9 2008, 02:34
- - scherz0   Hello everyone: Unfortunately, this problem still...   Aug 27 2008, 16:19
- - Tim De Baets   scherz0, are you sure that you're using WMPCDT...   Sep 11 2008, 16:57
- - Depo1964   Hi Tim, I just downloaded ver 1.1 (confirmed) and ...   Dec 12 2008, 04:33
- - Mike Gilson   Hi all, new to this forum so apologies if the subj...   Jan 27 2009, 11:07
|- - Tim De Baets   Hi Mike, your problem doesn't seem to be speci...   Jan 27 2009, 20:56
|- - Mike Gilson   QUOTE (Tim De Baets @ Jan 27 2009, 20:56)...   Jan 27 2009, 22:47
|- - Tim De Baets   Sorry for not being clear enough, I was talking ab...   Jan 28 2009, 19:47
- - Nobody777   Love this program! It works beautifully!...   Feb 17 2009, 09:39
|- - Tim De Baets   Do you mean the Windows Media Player toolbar in th...   Feb 20 2009, 14:44
|- - nrmsmith   QUOTE (Tim De Baets @ Feb 20 2009, 05:44)...   May 19 2009, 15:16
|- - Tim De Baets   Thank you for the information, NigelS. I have trie...   May 20 2009, 15:57
|- - nrmsmith   Tim Thanks for responding. Pleased to say it seem...   May 21 2009, 07:56
- - rallycrawford   Hi, a very usefull little program, thanks. I seem ...   Aug 10 2009, 11:12
|- - Tim De Baets   Are you running a 64-bit version of Windows? These...   Aug 10 2009, 15:40
|- - rallycrawford   QUOTE (Tim De Baets @ Aug 10 2009, 15:40)...   Aug 10 2009, 18:04
|- - Tim De Baets   No, I currently don't have any plans for a 64-...   Aug 10 2009, 18:29
|- - rallycrawford   QUOTE (Tim De Baets @ Aug 10 2009, 18:29)...   Aug 10 2009, 20:26
|- - Tim De Baets   The difference in performance is so small that you...   Aug 11 2009, 13:14
- - davidtg   Really appreciate this plug-in! I just always ...   Oct 5 2009, 21:33
- - schefjp   QUOTE (Tim De Baets @ Aug 12 2007, 20:56)...   Jan 8 2010, 13:58
|- - Tim De Baets   No, it's not possible to burn CD-Text with WMP...   Jan 9 2010, 20:38
- - mzelina   Excellent application! Is there a way to progr...   Mar 1 2010, 23:12
|- - Tim De Baets   No, it's not possible to use WMPCDText from an...   Mar 2 2010, 21:01
|- - gerix   thanx for this plug-in. It works well on my machin...   Sep 29 2010, 06:18
- - Houckster   I am using Win 7 Professional and Windows Media Pl...   Dec 23 2010, 03:04
- - Houckster   Apparently I have misinterpreted the purpose of th...   Dec 23 2010, 16:26
|- - Tim De Baets   Indeed, WMPCDText will only add support for readin...   Dec 23 2010, 16:41
- - MacEachaidh   Hi Tim, Many thanks and big smiles for your CD-Tex...   Jan 2 2011, 09:34
- - mkf5128   I just installed WMPCDText on my Win7 Pro machine ...   Jan 12 2011, 00:42
|- - Tim De Baets   It's actually WMP that keeps a cache of all th...   Jan 12 2011, 17:25
- - mkf5128   Thanks for the quick response and solution. I...   Jan 13 2011, 00:00
- - Armed Infant   WOW. This is one of those features that I've ...   Jul 6 2011, 18:16
- - dbminter   I wasn't sure if issues using WMPCDText were p...   Jul 20 2011, 16:59
|- - Tim De Baets   No worries, you posted this in the correct place ...   Jul 20 2011, 21:16
|- - dbminter   QUOTE (Tim De Baets @ Jul 20 2011, 14:16)...   Jul 20 2011, 21:51
|- - Tim De Baets   QUOTE (dbminter @ Jul 20 2011, 22:51) Unf...   Jul 21 2011, 14:08
|- - dbminter   QUOTE (Tim De Baets @ Jul 21 2011, 07:08)...   Jul 21 2011, 16:02
|- - Tim De Baets   If the title has been actually written to the CD a...   Jul 21 2011, 21:30
|- - dbminter   Convert caps option is still enabled right now. I...   Jul 21 2011, 21:41
|- - dbminter   QUOTE (Tim De Baets @ Jul 21 2011, 14:30)...   Jul 21 2011, 21:52
|- - Tim De Baets   Aha, that explains a lot Just to be sure, does W...   Jul 22 2011, 16:43
|- - dbminter   QUOTE (Tim De Baets @ Jul 22 2011, 09:43)...   Jul 22 2011, 16:56
|- - Tim De Baets   I did some more tests on my Windows 7 system, but ...   Jul 23 2011, 15:58
|- - dbminter   QUOTE (Tim De Baets @ Jul 23 2011, 08:58)...   Jul 23 2011, 17:49
|- - dbminter   One thing I have noticed with the plugin installed...   Sep 26 2011, 02:42
|- - Tim De Baets   Are you using the 64-bit version of Windows 7? If ...   Sep 27 2011, 20:31
|- - dbminter   QUOTE (Tim De Baets @ Sep 27 2011, 13:31)...   Sep 27 2011, 20:53
- - preservationist   Minor enhancement I'd like to suggest: Ability...   Oct 17 2011, 05:04
|- - Tim De Baets   WMPCDText should already read Composer from CD-Tex...   Oct 18 2011, 21:12
- - preservationist   Thanks for responding. It was a glitch with Cyberl...   Oct 19 2011, 02:03
- - preservationist   Burning software I'm using allows Comments, pr...   Nov 2 2011, 01:23
- - gabrus   Hi, i have just now installed WMPCDText, but in my...   Jan 12 2012, 15:32
|- - Tim De Baets   Did you install the latest version of WMPCDText (1...   Jan 12 2012, 23:32
- - gabrus   Yes, software is 1.2 version, and i can't see ...   Jan 12 2012, 23:47
|- - Tim De Baets   Please check if WMPCDText is loaded in WMP - it sh...   Jan 13 2012, 13:16
- - gabrus   Yes, i have WMPCDText loaded in Options > Plug-...   Jan 13 2012, 13:57
|- - Tim De Baets   Weird. An Italian WMP shouldn't be a problem e...   Jan 13 2012, 20:58
- - gabrus   Very thanks, i really appreciate your work, and al...   Jan 13 2012, 21:36
- - gabrus   I'm really glad to say that the plugin works n...   Jan 16 2012, 17:08
|- - Tim De Baets   You're welcome gabrus's issue turned out...   Jan 17 2012, 19:45
- - schmoeckwitzer   Just a short question: Does this nice plug-in also...   Mar 27 2012, 08:45
|- - Tim De Baets   Yes, as long as you have Windows Media Player, WMP...   Mar 27 2012, 13:27
- - Tim De Baets   Announcement: WMPCDText 1.3 has been released. Thi...   Jul 20 2012, 20:53
- - gabrus   Very thanks for this update   Jul 20 2012, 23:42
|- - zafer   Hello Tim ! Thanks for the update. I've ju...   Aug 10 2012, 06:59
|- - Tim De Baets   Thanks for reporting this. I can indeed reproduce ...   Aug 10 2012, 15:44
- - zafer   Yes indeed, I just verified it : when plug-in is d...   Aug 11 2012, 16:15
|- - Tim De Baets   Thanks, I'll start working on a fix later this...   Aug 11 2012, 17:14
- - Highcountryrider   Well, a classic case of "If it ain't brok...   Aug 11 2012, 23:45
|- - Tim De Baets   Did you download WMPCDText from the official homep...   Aug 12 2012, 14:50
|- - Highcountryrider   QUOTE (Tim De Baets @ Aug 12 2012, 06:50)...   Aug 12 2012, 17:48
|- - Highcountryrider   OK, I found the culprit! BD IS 2012 has a fire...   Aug 12 2012, 18:14
|- - Tim De Baets   Good to hear that you found the culprit and thanks...   Aug 12 2012, 19:53
- - Tim De Baets   Announcement: WMPCDText 1.4 has been released. Thi...   Aug 15 2012, 16:49
- - zafer   Many thanks Tim !! I've just tested it...   Aug 18 2012, 08:21
- - Kiing12   hi, I've downloaded The latest Update But,Whe...   Aug 30 2012, 23:05
|- - Tim De Baets   When exactly do you get that error message? Is tha...   Aug 31 2012, 10:59
- - Kiing12   I Think Wmc had A Bug Because after i restarted,it...   Aug 31 2012, 16:15
- - cwiseley   Wondering if you have seen this one. I am unable ...   Sep 1 2012, 01:03
|- - Tim De Baets   Are you sure that the plug-in is loaded? The WMPCD...   Sep 1 2012, 21:02
|- - cwiseley   QUOTE (Tim De Baets @ Sep 1 2012, 13:02) ...   Sep 3 2012, 02:09
|- - Tim De Baets   Thanks for sending me a screen shot through PM. I ...   Sep 3 2012, 20:15
- - Kiing12   Ok, So When You Do Another Update, 1 Thing To Do I...   Sep 8 2012, 17:37
|- - Tim De Baets   It sounds like you have encountered a (previously ...   Sep 8 2012, 19:03
|- - Kiing12   http://http://imgur.com/Q4eVv,B0zxv,WOK9b,ln1VP,ig...   Sep 8 2012, 22:12
|- - Tim De Baets   QUOTE (Kiing12 @ Sep 8 2012, 23:12) http:...   Sep 9 2012, 16:13
- - Venyos   Excellent job, but someone still using WMP?   Sep 8 2012, 22:42
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 3rd June 2015 - 20:56
