WMPCDText - CD-Text plug-in for Windows Media Player
Tim De Baets
post Aug 13 2007, 02:56
Author of WMPCDText
I have released WMPCDText, a Windows Media Player plug-in that finally adds support for CD-Text to WMP.
There is an option to automatically read CD-Text from unknown CD's. Alternatively, you can also right-click on a CD-track in the Now Playing-pane while the CD is playing, and click "Read CD-Text". There are some other options too, those can be changed in the plug-in's settings dialog.
Download
Enjoy!
Tim De Baets
September 1, 2007: I have updated WMPCDText with a fix for crashes that might occur in wmpvis.dll when a visualization is enabled in WMP. Please re-download and reinstall WMPCDText if WMP crashes when you advance to the next track, and these crashes started happening after installing WMPCDText.
December 22, 2007: I have released the final version: http://bmproductions.fixnum.org/wmpcdtext
July 9, 2008: WMPCDText 1.1 has been released. This new version fixes the "Error while executing SCSI command: SRB completed with error (4)" message.
July 28, 2009: WMPCDText 1.2 adds full compatibility with Windows Media Player 12 on Windows 7.
July 20, 2012: WMPCDText 1.3 fixes the Read CD-Text menu item not appearing in certain cases, and a possible crash when opening WMP 12.
August 15, 2012: WMPCDText 1.4 fixes an issue that was introduced in version 1.3 and that could lead to a Windows Media Player crash.
This post has been edited by Tim De Baets: Sep 13 2013, 21:43
rallycrawford
post Aug 10 2009, 11:12
Hi, a very usefull little program, thanks. I seem to have a problem with it though. It loads into windows media player, when first installed, as a background plug in and works great BUT when I close media player and reopen it has gone, no where to be found, and I have to install it again each time I use media player.
Tim De Baets
post Aug 10 2009, 15:40
Author of WMPCDText
Are you running a 64-bit version of Windows? These installations contain a 32-bit *and* a 64-bit version of WMP. WMPCDText is only compatible with the 32-bit WMP and it doesn't show up in the 64-bit one. The WMPCDText installer will always launch the 32-bit version when "Run Windows Media Player now" is checked, so that could explain why you only see the plug-in on first launch, if you otherwise always run the 64-bit version. This can be verified with Task Manager: look for wmplayer.exe in the Processes tab, it will have *32 next to it when it's the 32-bit version.
The solution is to make sure that you always run the 32-bit WMP. Usually, this means that you will have to change the target of each shortcut to WMP to the following:
C:\Program Files (x86)\Windows Media Player\wmplayer.exe
Please let me know if that helps.
rallycrawford
post Aug 10 2009, 18:04
QUOTE (Tim De Baets @ Aug 10 2009, 15:40) *
Hi, you are correct. I have changed to 32 bit and all is fine. Seems like the right time to ask if a 64 bit version is coming.
Tim De Baets
post Aug 10 2009, 18:29
Author of WMPCDText
No, I currently don't have any plans for a 64-bit WMPCDText. Is there any specific reason why you prefer running 64-bit WMP over 32-bit?
- Tim De Baets   WMPCDText - CD-Text plug-in for Windows Media Player   Aug 13 2007, 02:56
- - ontariocraig   Hi Tim, Wanted to say thanks for this excellent p...   Oct 15 2007, 16:00
|- - Tim De Baets   QUOTE (ontariocraig @ Oct 15 2007, 17:00)...   Oct 17 2007, 17:09
|- - charliemcdo   Tim, Echoing Craig's comment. Thanks for your...   Oct 19 2007, 18:06
- - MONSIEUR   thank you for this plug-in, it is working on my wi...   Nov 24 2007, 16:50
|- - nottenst   I just tried it on my new Dell XPS 420 Vista machi...   Apr 13 2008, 20:21
- - vijaye7   Hi Tim, Like neil, I am getting the following err...   Apr 15 2008, 16:42
- - Tim De Baets   Neil and Vijay, thanks for reporting this. There s...   Apr 19 2008, 14:13
|- - vijaye7   Thanks for the response, Tim. It happens only for ...   Apr 19 2008, 14:55
- - Tim De Baets   I have done some testing but I haven't been ab...   Apr 21 2008, 18:06
|- - nottenst   QUOTE (Tim De Baets @ Apr 21 2008, 12:06)...   Apr 23 2008, 22:43
- - lennie paz   this program is not working for me on WMP 11 and x...   Apr 23 2008, 13:21
- - Tim De Baets   I have finally been able to fix the "Error wh...   Jul 9 2008, 02:34
- - scherz0   Hello everyone: Unfortunately, this problem still...   Aug 27 2008, 16:19
- - Tim De Baets   scherz0, are you sure that you're using WMPCDT...   Sep 11 2008, 16:57
- - Depo1964   Hi Tim, I just downloaded ver 1.1 (confirmed) and ...   Dec 12 2008, 04:33
- - Mike Gilson   Hi all, new to this forum so apologies if the subj...   Jan 27 2009, 11:07
|- - Tim De Baets   Hi Mike, your problem doesn't seem to be speci...   Jan 27 2009, 20:56
|- - Mike Gilson   QUOTE (Tim De Baets @ Jan 27 2009, 20:56)...   Jan 27 2009, 22:47
|- - Tim De Baets   Sorry for not being clear enough, I was talking ab...   Jan 28 2009, 19:47
- - Nobody777   Love this program! It works beautifully!...   Feb 17 2009, 09:39
|- - Tim De Baets   Do you mean the Windows Media Player toolbar in th...   Feb 20 2009, 14:44
|- - nrmsmith   QUOTE (Tim De Baets @ Feb 20 2009, 05:44)...   May 19 2009, 15:16
|- - Tim De Baets   Thank you for the information, NigelS. I have trie...   May 20 2009, 15:57
|- - nrmsmith   Tim Thanks for responding. Pleased to say it seem...   May 21 2009, 07:56
- - rallycrawford   Hi, a very usefull little program, thanks. I seem ...   Aug 10 2009, 11:12
|- - Tim De Baets   Are you running a 64-bit version of Windows? These...   Aug 10 2009, 15:40
|- - rallycrawford   QUOTE (Tim De Baets @ Aug 10 2009, 15:40)...   Aug 10 2009, 18:04
|- - Tim De Baets   No, I currently don't have any plans for a 64-...   Aug 10 2009, 18:29
|- - rallycrawford   QUOTE (Tim De Baets @ Aug 10 2009, 18:29)...   Aug 10 2009, 20:26
|- - Tim De Baets   The difference in performance is so small that you...   Aug 11 2009, 13:14
- - davidtg   Really appreciate this plug-in! I just always ...   Oct 5 2009, 21:33
- - schefjp   QUOTE (Tim De Baets @ Aug 12 2007, 20:56)...   Jan 8 2010, 13:58
|- - Tim De Baets   No, it's not possible to burn CD-Text with WMP...   Jan 9 2010, 20:38
- - mzelina   Excellent application! Is there a way to progr...   Mar 1 2010, 23:12
|- - Tim De Baets   No, it's not possible to use WMPCDText from an...   Mar 2 2010, 21:01
|- - gerix   thanx for this plug-in. It works well on my machin...   Sep 29 2010, 06:18
- - Houckster   I am using Win 7 Professional and Windows Media Pl...   Dec 23 2010, 03:04
- - Houckster   Apparently I have misinterpreted the purpose of th...   Dec 23 2010, 16:26
|- - Tim De Baets   Indeed, WMPCDText will only add support for readin...   Dec 23 2010, 16:41
- - MacEachaidh   Hi Tim, Many thanks and big smiles for your CD-Tex...   Jan 2 2011, 09:34
- - mkf5128   I just installed WMPCDText on my Win7 Pro machine ...   Jan 12 2011, 00:42
|- - Tim De Baets   It's actually WMP that keeps a cache of all th...   Jan 12 2011, 17:25
- - mkf5128   Thanks for the quick response and solution. I...   Jan 13 2011, 00:00
- - Armed Infant   WOW. This is one of those features that I've ...   Jul 6 2011, 18:16
- - dbminter   I wasn't sure if issues using WMPCDText were p...   Jul 20 2011, 16:59
|- - Tim De Baets   No worries, you posted this in the correct place ...   Jul 20 2011, 21:16
|- - dbminter   QUOTE (Tim De Baets @ Jul 20 2011, 14:16)...   Jul 20 2011, 21:51
|- - Tim De Baets   QUOTE (dbminter @ Jul 20 2011, 22:51) Unf...   Jul 21 2011, 14:08
|- - dbminter   QUOTE (Tim De Baets @ Jul 21 2011, 07:08)...   Jul 21 2011, 16:02
|- - Tim De Baets   If the title has been actually written to the CD a...   Jul 21 2011, 21:30
|- - dbminter   Convert caps option is still enabled right now. I...   Jul 21 2011, 21:41
|- - dbminter   QUOTE (Tim De Baets @ Jul 21 2011, 14:30)...   Jul 21 2011, 21:52
|- - Tim De Baets   Aha, that explains a lot Just to be sure, does W...   Jul 22 2011, 16:43
|- - dbminter   QUOTE (Tim De Baets @ Jul 22 2011, 09:43)...   Jul 22 2011, 16:56
|- - Tim De Baets   I did some more tests on my Windows 7 system, but ...   Jul 23 2011, 15:58
|- - dbminter   QUOTE (Tim De Baets @ Jul 23 2011, 08:58)...   Jul 23 2011, 17:49
|- - dbminter   One thing I have noticed with the plugin installed...   Sep 26 2011, 02:42
|- - Tim De Baets   Are you using the 64-bit version of Windows 7? If ...   Sep 27 2011, 20:31
|- - dbminter   QUOTE (Tim De Baets @ Sep 27 2011, 13:31)...   Sep 27 2011, 20:53
- - preservationist   Minor enhancement I'd like to suggest: Ability...   Oct 17 2011, 05:04
|- - Tim De Baets   WMPCDText should already read Composer from CD-Tex...   Oct 18 2011, 21:12
- - preservationist   Thanks for responding. It was a glitch with Cyberl...   Oct 19 2011, 02:03
- - preservationist   Burning software I'm using allows Comments, pr...   Nov 2 2011, 01:23
- - gabrus   Hi, i have just now installed WMPCDText, but in my...   Jan 12 2012, 15:32
|- - Tim De Baets   Did you install the latest version of WMPCDText (1...   Jan 12 2012, 23:32
- - gabrus   Yes, software is 1.2 version, and i can't see ...   Jan 12 2012, 23:47
|- - Tim De Baets   Please check if WMPCDText is loaded in WMP - it sh...   Jan 13 2012, 13:16
- - gabrus   Yes, i have WMPCDText loaded in Options > Plug-...   Jan 13 2012, 13:57
|- - Tim De Baets   Weird. An Italian WMP shouldn't be a problem e...   Jan 13 2012, 20:58
- - gabrus   Very thanks, i really appreciate your work, and al...   Jan 13 2012, 21:36
- - gabrus   I'm really glad to say that the plugin works n...   Jan 16 2012, 17:08
|- - Tim De Baets   You're welcome gabrus's issue turned out...   Jan 17 2012, 19:45
- - schmoeckwitzer   Just a short question: Does this nice plug-in also...   Mar 27 2012, 08:45
|- - Tim De Baets   Yes, as long as you have Windows Media Player, WMP...   Mar 27 2012, 13:27
- - Tim De Baets   Announcement: WMPCDText 1.3 has been released. Thi...   Jul 20 2012, 20:53
- - gabrus   Very thanks for this update   Jul 20 2012, 23:42
|- - zafer   Hello Tim ! Thanks for the update. I've ju...   Aug 10 2012, 06:59
|- - Tim De Baets   Thanks for reporting this. I can indeed reproduce ...   Aug 10 2012, 15:44
- - zafer   Yes indeed, I just verified it : when plug-in is d...   Aug 11 2012, 16:15
|- - Tim De Baets   Thanks, I'll start working on a fix later this...   Aug 11 2012, 17:14
- - Highcountryrider   Well, a classic case of "If it ain't brok...   Aug 11 2012, 23:45
|- - Tim De Baets   Did you download WMPCDText from the official homep...   Aug 12 2012, 14:50
|- - Highcountryrider   QUOTE (Tim De Baets @ Aug 12 2012, 06:50)...   Aug 12 2012, 17:48
|- - Highcountryrider   OK, I found the culprit! BD IS 2012 has a fire...   Aug 12 2012, 18:14
|- - Tim De Baets   Good to hear that you found the culprit and thanks...   Aug 12 2012, 19:53
- - Tim De Baets   Announcement: WMPCDText 1.4 has been released. Thi...   Aug 15 2012, 16:49
- - zafer   Many thanks Tim !! I've just tested it...   Aug 18 2012, 08:21
- - Kiing12   hi, I've downloaded The latest Update But,Whe...   Aug 30 2012, 23:05
|- - Tim De Baets   When exactly do you get that error message? Is tha...   Aug 31 2012, 10:59
- - Kiing12   I Think Wmc had A Bug Because after i restarted,it...   Aug 31 2012, 16:15
- - cwiseley   Wondering if you have seen this one. I am unable ...   Sep 1 2012, 01:03
|- - Tim De Baets   Are you sure that the plug-in is loaded? The WMPCD...   Sep 1 2012, 21:02
|- - cwiseley   QUOTE (Tim De Baets @ Sep 1 2012, 13:02) ...   Sep 3 2012, 02:09
|- - Tim De Baets   Thanks for sending me a screen shot through PM. I ...   Sep 3 2012, 20:15
- - Kiing12   Ok, So When You Do Another Update, 1 Thing To Do I...   Sep 8 2012, 17:37
|- - Tim De Baets   It sounds like you have encountered a (previously ...   Sep 8 2012, 19:03
|- - Kiing12   http://http://imgur.com/Q4eVv,B0zxv,WOK9b,ln1VP,ig...   Sep 8 2012, 22:12
|- - Tim De Baets   QUOTE (Kiing12 @ Sep 8 2012, 23:12) http:...   Sep 9 2012, 16:13
- - Venyos   Excellent job, but someone still using WMP?   Sep 8 2012, 22:42
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 5th August 2015 - 03:50
