FLAC Frontend doesn't work, WinXP x64 or something else?
IrfCore
post Aug 9 2007, 06:30
I have recently moved from XP 32bit to XP 64bit cuz 4GB RAM isn't supported in 32bit XP.
I'm not sure if it's because I'm on XP x64 or if it's something else.
FLAC Frontend won't decompress to wav or convert wav to FLAC.
Does anyone know how to get it working again?
This post has been edited by IrfCore: Aug 9 2007, 06:30
greynol
post Aug 9 2007, 06:40
What are the names of the files you're trying to encode/decode (including the full path)?
Your eyes cannot hear.
IrfCore
post Aug 9 2007, 06:43
Don't matter, this happens for all wav and flac files...
This post has been edited by IrfCore: Aug 9 2007, 06:44
greynol
post Aug 9 2007, 06:46
Just humor me.
IrfCore
post Aug 9 2007, 06:48
How can it matter if it happens to all files!
well the first I tried with was CDImage.wav
greynol
post Aug 9 2007, 06:49
And the path?
IrfCore
post Aug 9 2007, 06:52
Well it always worked before on these paths
E:\E LL temp
D:\D LL temp
I doesn't even work if I choose "same as input directory"
This post has been edited by IrfCore: Aug 9 2007, 06:53
greynol
post Aug 9 2007, 06:56
I asked because FLAC frontend, which is very much unlike foobar2000, generates a batch file and then executes it. If there is unicode in the path or filename the script will choke.
It doesn't delete the batch after trying to execute it. Check it out, maybe there's something obvious in there.
IrfCore
post Aug 9 2007, 07:00
Even tried the RAREWARES version...
This post has been edited by IrfCore: Aug 9 2007, 07:02
greynol
post Aug 9 2007, 07:03
Of course. Instead of deleting it, open it up with a text editor.
...sorry if I was misleading earlier. FLAC frontend doesn't delete the batch after it's done with it whether the result was successful or not. It simply overwrites go.bat the next time you use the program.
This post has been edited by greynol: Aug 9 2007, 07:05
IrfCore
post Aug 9 2007, 07:05
in the bat file go.bat
@echo off
C:
cd "C:\ProgCore(x86)\FLAC"
win2dos go.bat
flac -6 "E:\E LL temp\1 1CDImage.wav"
echo -------------------------------------------------------------------------------
This post has been edited by IrfCore: Aug 9 2007, 07:08
greynol
post Aug 9 2007, 07:12
from the command line, navigate to
and then run go.bat.
you should be able to see what the problem is without the window closing.
IrfCore
post Aug 9 2007, 07:20
greynol
post Aug 9 2007, 07:25
Maybe it has something to do with the vb6 runtime files or mscomctl.ocx in XP64. I don't think I can provide much help beyond this point, sorry. sad.gif
IrfCore
post Aug 9 2007, 07:26
Post #15
chelrob
post Sep 3 2007, 05:51
Post #16
Did you try running flac frontend as Administrator?
hollasch
post Sep 13 2007, 03:23
Post #17
I'm having the same problem with FLAC Front End 1.7.1 in Vista. I run as administrator, and the command line flashes very briefly. I am able to decipher that it is saying:
'win2dos' is not recognized as a valid internal or external command.
Suggestions?
Kyle
IrfCore
post Oct 21 2007, 06:33
Post #18
chelrob, I only run as admin.
I have switched to Window 2003 Server.
On Windows 2003 it works.
GEoMaNTiK
post Oct 29 2007, 12:01
Post #19
QUOTE (IrfCore @ Oct 21 2007, 15:33) *
I also have been getting this error, so I played with some settings and found that by removing the tick on this option under ReplayGain (Treat input files as one album), all is working perfectly!!!
sabbey
post Dec 19 2008, 01:59
Post #20
Sorry for the bump, wrong thread...
This post has been edited by sabbey: Dec 19 2008, 12:28
desktop22
post Jan 25 2009, 07:57
Post #21
Im trying to use flac front end to convert wav to flac but when i tried to convert it says cannot find file don't know why?
eddie the eagle
post Dec 30 2011, 05:14
Post #22
QUOTE (GEoMaNTiK @ Oct 29 2007, 22:01) *
Thanks Geo & Kyle.
Exactly the same issue on Win7 32-bit (win2dos not recognised.)
Exactly the same solution. (Just wish I understood why)
eddie
This post has been edited by eddie the eagle: Dec 30 2011, 05:17
tevez32
post Feb 26 2012, 03:17
Post #23
You need to add the FLAC installation directory to your program search path. From Windows Explorer:
right click on Computer, then select Properties
on the left column, click on Advanced system settings
within the Advanced tab, click on the Environment Variables button
In the System variables section, scroll down and find Path and click on Edit
Append the following at the end of the Variable value input box
;C:\Program Files (x86)\FLAC\
You will need to restart the FLAC front-end application.
Good luck
deramanap
post Mar 11 2013, 04:44
Post #24
I was having this issue with my flac frontend not working & found this forum. I just did the fix to the path & everything works great now.
Thanks for the HELP!!!!!!!!!! Dan
RSS Lo-Fi Version Time is now: 25th April 2015 - 14:52
