FLAC Frontend doesn't work, WinXP x64 or something else?
IrfCore
post Aug 9 2007, 06:30
I have recently moved from XP 32bit to XP 64bit cuz 4GB RAM isn't supported in 32bit XP.
I'm not sure if it's because I'm on XP x64 or if it's something else.
FLAC Frontend won't decompress to wav or convert wav to FLAC.
Does anyone know how to get it working again?
This post has been edited by IrfCore: Aug 9 2007, 06:30
IrfCore
post Oct 21 2007, 06:33
chelrob, I only run as admin.
I have switched to Window 2003 Server.
On Windows 2003 it works.
GEoMaNTiK
post Oct 29 2007, 12:01
QUOTE (IrfCore @ Oct 21 2007, 15:33) *
I also have been getting this error, so I played with some settings and found that by removing the tick on this option under ReplayGain (Treat input files as one album), all is working perfectly!!!
eddie the eagle
post Dec 30 2011, 05:14
QUOTE (GEoMaNTiK @ Oct 29 2007, 22:01) *
Thanks Geo & Kyle.
Exactly the same issue on Win7 32-bit (win2dos not recognised.)
Exactly the same solution. (Just wish I understood why)
eddie
This post has been edited by eddie the eagle: Dec 30 2011, 05:17
- IrfCore   FLAC Frontend doesn't work   Aug 9 2007, 06:30
- - greynol   What are the names of the files you're trying ...   Aug 9 2007, 06:40
- - IrfCore   Don't matter, this happens for all wav and fla...   Aug 9 2007, 06:43
- - greynol   Just humor me.   Aug 9 2007, 06:46
- - IrfCore   How can it matter if it happens to all files! ...   Aug 9 2007, 06:48
- - greynol   And the path?   Aug 9 2007, 06:49
- - IrfCore   Well it always worked before on these paths E:...   Aug 9 2007, 06:52
- - greynol   I asked because FLAC frontend, which is very much ...   Aug 9 2007, 06:56
- - IrfCore   I've tried deleting go.bat, same thing Even ...   Aug 9 2007, 07:00
- - greynol   Of course. Instead of deleting it, open it up wit...   Aug 9 2007, 07:03
- - IrfCore   ye and creates a new one if you delete the first ...   Aug 9 2007, 07:05
- - greynol   from the command line, navigate to C:\ProgCo...   Aug 9 2007, 07:12
- - IrfCore   running the bat works but not in FLAC frontend   Aug 9 2007, 07:20
- - greynol   Maybe it has something to do with the vb6 runtime ...   Aug 9 2007, 07:25
- - IrfCore   You done enough, thanx   Aug 9 2007, 07:26
- - chelrob   Did you try running flac frontend as Administrator...   Sep 3 2007, 05:51
- - hollasch   I'm having the same problem with FLAC Front En...   Sep 13 2007, 03:23
- - IrfCore   chelrob, I only run as admin. I have switched to ...   Oct 21 2007, 06:33
|- - GEoMaNTiK   QUOTE (IrfCore @ Oct 21 2007, 15:33) chel...   Oct 29 2007, 12:01
|- - sabbey   Sorry for the bump, wrong thread...   Dec 19 2008, 01:59
|- - eddie the eagle   QUOTE (GEoMaNTiK @ Oct 29 2007, 22:01) QU...   Dec 30 2011, 05:14
- - desktop22   Im trying to use flac front end to convert wav to ...   Jan 25 2009, 07:57
- - tevez32   You need to add the FLAC installation directory to...   Feb 26 2012, 03:17
- - deramanap   I was having this issue with my flac frontend not ...   Mar 11 2013, 04:44
RSS Lo-Fi Version Time is now: 30th August 2015 - 09:38
