foo_uie_powerpanels, Transparent seek & volume panels
borgusiek
post Aug 5 2007, 15:10
PowerPanels for Foobar2000 v0.9+
PowerPanels consists of a two panels designed for Panels UI: seek panel & volume panel.
These are transparent panels which you can put in other panels
over your custom drawn progress and/or volume bar
and change playback position and volume by simply clicking on them
instead of using default seek and volume toolbars.
I have prepared brief description how to use it so I won't be duplicating it here.
More info and download at: http://borgusiek.neostrada.pl/foobar
Lucky Luciano
post Mar 28 2008, 20:28
I was having the same problem. I'll probably add to the right of it a button similar in design with the progress bar and with which I could set the volume to 100%. Problem is I can't find a function for setting the volume at a certain value. I guess calling "Volume Up" once or twice would do it.
Smirra
post Mar 28 2008, 21:49
Can anyone check if they have the same problem with the hotkeys(not working) as me?
I use the latest foobar version in XP sp2.
antar3s
post Mar 29 2008, 00:58
@z-x
maybe making the panel bigger will help. think about it this way: if the panel is 50pixels you can probably only address 50 different volume settings...
@Smirra
also using XP SP2 and it works fine here.
sometimes i get hotkey problems, but not reproducable and that was already before i used powerpanels. and clicking in the scpl makes the hotkeys work again.
Smirra
post Mar 29 2008, 12:46
QUOTE (antar3s @ Mar 29 2008, 00:58) *
@Smirra
Something tells me that it's other plugins that are "fighting back" and making them usable again... I might be wrong. Bcuz when i encountered the problem i had pretty much just the progress bar. And when i tried to replicate it as clean codewise as possible i was only using just that plugin.
It can also be that u don't use the 0.9.5.1 version as u haven't given any detail about what version you use of foobar!
antar3s
post Mar 29 2008, 14:22
i am using foobar version 0.9.5.1
if at all it might depend on the panels ui version that you are using. i'm running 0.14.9, and i have been using 0.13.8 and 0.14.12 without noticing this problem.
maybe only certain shortcuts are affected? i only tested if opening the preference page works...
- borgusiek   foo_uie_powerpanels   Aug 5 2007, 15:10
- - jclim00   Very cool!   Aug 5 2007, 15:36
|- - Kiteroa   Thanks - works well; does a great job!   Aug 5 2007, 15:43
- - FofR   Works like a charm, very nice   Aug 5 2007, 17:43
- - carmenm   This plugin is really good but i have one problem ...   Aug 5 2007, 18:25
|- - cristox   This makes it perfect now!   Aug 5 2007, 18:47
- - YounhaLOV   really thank you Borqusiek^^ great component   Aug 6 2007, 01:55
- - Nickoladze   Very cool   Aug 6 2007, 15:56
- - store88   @borgusiek Can you make the plugins work without p...   Aug 7 2007, 13:30
|- - carmenm   QUOTE (store88 @ Aug 7 2007, 14:30) @borg...   Aug 7 2007, 13:39
- - The Judge   Haven't given this a try yet but this was the ...   Aug 7 2007, 16:01
- - BLaZor   can you use images too just like using js in wsh p...   Aug 7 2007, 16:07
|- - carmenm   QUOTE (BLaZor @ Aug 7 2007, 17:07) can yo...   Aug 7 2007, 16:20
|- - BLaZor   QUOTE (carmenm @ Aug 7 2007, 16:20) QUOTE...   Aug 7 2007, 16:27
|- - The Judge   QUOTE (BLaZor @ Aug 7 2007, 15:27) QUOTE ...   Aug 7 2007, 16:57
- - Taish   Thanks works great   Aug 7 2007, 16:47
- - BLaZor   Nice, although instead of streching an image, coul...   Aug 7 2007, 17:19
- - borgusiek   Glad you like the panels, for me that was the miss...   Aug 8 2007, 21:09
- - BelleAndZEK   been waiting for this for so long. I didn't tr...   Aug 8 2007, 23:26
- - cristox   It does not work well with Panels UI 0.14.12 beta....   Aug 9 2007, 21:39
|- - Faveris   It is the plugin i was waiting Thanks! But I ...   Aug 12 2007, 18:47
- - radecke   thanks for this great plugin. now i finally have a...   Aug 12 2007, 21:49
- - Keikonium   Would I beable to get some code for a seekbar plea...   Aug 21 2007, 22:30
- - Keikonium   Anyone willing to help? If I can get some working ...   Aug 24 2007, 06:29
|- - Spirit_of_the_ocean   QUOTE (Keikonium @ Aug 24 2007, 05:29) An...   Aug 24 2007, 10:34
|- - Keikonium   QUOTE (Spirit_of_the_ocean @ Aug 24 2007, 03...   Aug 24 2007, 18:12
||- - Spirit_of_the_ocean   No problem. There was a user I can't remember ...   Aug 24 2007, 19:26
|- - konakona   nvm, got it all sorted out. thanks!   Nov 23 2007, 20:08
- - carmenm   I have some redraw problem with this plugin. While...   Aug 24 2007, 13:42
- - DarkBlackCorner   niiice, I was always clicking on the progress bar ...   Aug 24 2007, 14:11
- - Keikonium   I just do this to edit my panels nice and fast:   Aug 24 2007, 19:37
|- - Spirit_of_the_ocean   Thanks Didn't know that. Yes foobar is ver...   Aug 24 2007, 19:46
- - tool++   I just have to say that this plugin is AWESOME   Aug 28 2007, 11:48
- - spaceships   Is there anyway to have multiple instances of powe...   Aug 31 2007, 14:29
- - lhnz   The link is down?!   Sep 9 2007, 09:58
|- - Kirya   QUOTE (lhnz @ Sep 9 2007, 11:58) The link...   Sep 9 2007, 12:39
- - gregory   i have a problem similar to carmenm's, when i...   Sep 9 2007, 18:14
- - montyview   Just a quick thanks for this component: works real...   Sep 14 2007, 17:06
- - Kirya   little request: is it possible to change onmouseov...   Sep 22 2007, 00:21
- - KnightMare   nice, thanks   Sep 22 2007, 12:26
- - skyhopper88   I'm trying to impliment this with FofR's c...   Dec 5 2007, 18:14
- - dRsrb   Great Plugin! One request: Seeking with held...   Dec 7 2007, 22:34
- - blaxima   I use a seekbar in my playlist so it moves to the ...   Dec 19 2007, 04:45
- - Lucky Luciano   EDIT: nevermind!   Jan 15 2008, 07:00
- - Smirra   Power Panels disables my hotkeys... T.T. I localiz...   Mar 26 2008, 20:37
|- - antar3s   is it only a focus problem, ie do the hotkeys work...   Mar 26 2008, 23:22
|- - Smirra   QUOTE (antar3s @ Mar 26 2008, 23:22) is i...   Mar 27 2008, 00:21
|- - antar3s   QUOTE (Smirra @ Mar 27 2008, 00:21) But i...   Mar 27 2008, 01:14
|- - Smirra   QUOTE (antar3s @ Mar 27 2008, 01:14) QUOT...   Mar 27 2008, 14:04
- - z-x   I can't set the volume to 100% with volume bar...   Mar 28 2008, 18:35
- - Lucky Luciano   I was having the same problem. I'll probably a...   Mar 28 2008, 20:28
|- - Smirra   Can anyone check if they have the same problem wit...   Mar 28 2008, 21:49
|- - antar3s   @z-x maybe making the panel bigger will help. thin...   Mar 29 2008, 00:58
|- - Smirra   QUOTE (antar3s @ Mar 29 2008, 00:58) @Smi...   Mar 29 2008, 12:46
|- - antar3s   i am using foobar version 0.9.5.1 if at all it mig...   Mar 29 2008, 14:22
|- - Smirra   QUOTE (antar3s @ Mar 29 2008, 15:22) i am...   Mar 30 2008, 11:52
- - Walterrrr   Does anyone use the seek panel vertically? It seem...   Apr 21 2008, 22:11
- - punkluck1   New guy here. I'm working on touching up my c...   Apr 23 2008, 17:50
- - Walterrrr   Hello, from http://borgusiek.neostrada.pl/foobar/...   Apr 23 2008, 22:28
|- - punkluck1   QUOTE (Walterrrr @ Apr 23 2008, 15:28) He...   Apr 24 2008, 00:21
|- - Walterrrr   QUOTE (Walterrrr @ Apr 23 2008, 14:28) If...   May 19 2008, 10:41
- - Walterrrr   according to your code CODE$if(%isplaying...   Apr 24 2008, 06:34
|- - punkluck1   QUOTE (Walterrrr @ Apr 23 2008, 23:34) ac...   Apr 24 2008, 22:10
- - Walterrrr   full requoting isn't quite necessary when repl...   Apr 24 2008, 22:15
- - punkluck1   Ha, just trying to be thorough. When I click on...   Apr 24 2008, 22:21
- - randmdood   can't see what your doing wrong^^^^ only thin...   May 4 2008, 13:25
- - punkluck1   Man, I've moved everything around and nothing ...   May 4 2008, 18:44
- - randmdood   sorry it didn't help.. if i think of something...   May 7 2008, 12:16
- - callisto   QUOTE (punkluck1 @ May 4 2008, 19:44) Man...   May 7 2008, 14:37
- - Lucky Luciano   Here's simple example of a progress bar. Maybe...   May 7 2008, 16:55
- - punkluck1   Hmmm, after reading these last few replies, I thin...   May 7 2008, 19:24
- - callisto   Um, thats the problem! Powerpanels do not work...   May 7 2008, 20:22
- - punkluck1   Man, what a doof! I apologize to all. Unfort...   May 7 2008, 20:34
- - Kirya   any chance for update with the "metadb_displa...   Jul 14 2008, 19:23
- - IcyStorm   Does anyone have a mirror or alternate download li...   Sep 6 2008, 18:00
|- - v.1   QUOTE (IcyStorm @ Sep 6 2008, 18:00) Does...   Sep 10 2008, 20:03
- - KnightMare   http://drop.io/download/48c87372/14f66d1c6...power...   Sep 11 2008, 02:25
|- - Fuzzehskittlez   QUOTE (KnightMare @ Sep 10 2008, 19:25) h...   Sep 13 2008, 19:36
|- - KnightMare   QUOTE (Fuzzehskittlez @ Sep 13 2008, 14:3...   Sep 21 2008, 12:00
- - Wheel of Fortune   QUOTE (Fuzzehskittlez @ Sep 13 2008, 20:3...   Sep 14 2008, 09:24
- - bulhakov   foo_uie_powerpanels_v0.1.zip   Sep 14 2008, 10:20
|- - Jan B   QUOTE (bulhakov @ Sep 14 2008, 03:20) foo...   Nov 26 2008, 16:19
|- - aland   I found this page from an article which mentions t...   Nov 23 2014, 21:27
- - Wheel of Fortune   QUOTE (bulhakov @ Sep 14 2008, 11:20) foo...   Sep 14 2008, 10:24
RSS Lo-Fi Version Time is now: 29th July 2015 - 12:04
