Anyone who wants to write foo_accuraterip_db?, Plugin for checking any tracks
Fandango
post Aug 1 2007, 03:32
why is there no plugin that checks any selected tracks as an album using AR checksums for comparing the results with the AR database?
That would be handy, since foobar2000 would do all the conversion.
EDIT: Thanks for moving the thread and giving it a better title. blush.gif
Some things to consider...
  • There shall be no any limitation regarding the source of the tracks used. So lossy files get decoded to PCM, just like losslessly encoded files. It doesn't hurt if the plugin is held dumb enough to not be bothered whether the source was lossy or lossless. In fact this might even be useful to verify that a false entry based on a non-CD-source has made it into the AR database, in case someone has a hunch that a specific "release" has made it into the database.
    Of course, checks on the decoded output must apply, namely that it is 16bit, 44.1kHz PCM. And maybe it's also wise to not allow internet radio streams as input for this plugin, in case it's possible to check this. Or else the user who accidentally chose such a playlist entry might wait forever for the plugin to finish.
  • Don't object: "but why any tracks? you mean you want to select some lossy files and see if they make up an album that is present in the AR database?" -- No, I don't want to do that, maybe once or twice just for the fun of it. But although it doesn't make sense to check random tracks as one album, there's also no reason why this shall not be possible.
    To make myself clearer: I think the grouping of tracks for an AR check should be implemented more or less exactly like the grouping for replaygain was done... i.e. "treat selected tracks as one album", "treat selected tracks as album(s) (using tags)".
  • There should be a log output, that can be copied and pasted or even automatically written to a file using tagz script for creating that file's name. Not just a window that says "Album was verified as being accurately ripped."/"Album couldn't be verified as being accurately ripped."
    The log output should resemble the output of the AR.dll for the time being... and maybe later, even better it could be written using user-defineable templates.
Any more ideas? Objections?
This post has been edited by Fandango: Aug 1 2007, 04:04
jdcarr
post Aug 24 2007, 19:53
QUOTE (Fandango @ Jul 31 2007, 21:32) *
I'd sure like it too...but there's one inherent problem with it...let me know if I'm wrong, but:
Every single drive when it rips offsets the rip differently...just barely. Therefore, in order to accurately compare a rip against the accuraterip database it requires knowing the exact offset of the drive that ripped it, which makes it a little difficult, since every drive has a different offset.
That's why there's plugins for ripping programs (EAC and dbPowerAmp) and nothing else. Do I make sense?
- Fandango   Anyone who wants to write foo_accuraterip_db?   Aug 1 2007, 03:32
- - kanak   I'd surely use it. Now if only someone would d...   Aug 1 2007, 04:12
- - jdcarr   QUOTE (Fandango @ Jul 31 2007, 21:32) Hi,...   Aug 24 2007, 19:53
|- - Spirit_of_the_ocean   Thats why you are asked in some programs to make e...   Aug 24 2007, 20:32
|- - NormanPCN   QUOTE (jdcarr @ Aug 24 2007, 11:53) I...   Aug 24 2007, 22:39
- - odyssey   It would be great for such plugin, but I don't...   Aug 24 2007, 21:58
- - Jose Hidalgo   Hi everyone, Please count me in : such component ...   Jan 11 2008, 19:17
- - Fandango   A wrong offset correction is always an issue when ...   Jan 11 2008, 19:24
|- - odyssey   QUOTE (Fandango @ Jan 11 2008, 19:24) Wha...   Jan 11 2008, 20:16
- - Jose Hidalgo   +1 : Fandango, I can assure that I have ripped ALL...   Jan 11 2008, 22:07
- - Fandango   That's what I think most people will have. Eit...   Jan 12 2008, 00:09
- - Jose Hidalgo   Well, all this stuff looks promising. Now all we...   Jan 12 2008, 02:38
|- - Fandango   QUOTE (Jose Hidalgo @ Jan 12 2008, 02:38)...   Jan 12 2008, 16:09
- - ssjkakaroto   It would already be really useful if AR was integr...   Jan 27 2008, 16:05
|- - Fandango   QUOTE (ssjkakaroto @ Jan 27 2008, 16:05) ...   Feb 3 2008, 21:38
- - 2tec   QUOTE (Fandango @ Jul 31 2007, 19:32) why...   Apr 13 2008, 15:14
- - gausome   QUOTE (2tec @ Apr 13 2008, 08:14) QUOTE (...   Apr 21 2008, 20:25
- - Borisz   I would be perfectly content with just a scanner, ...   Apr 25 2008, 12:34
- - unfortunateson   hope to see this come to fruition someday.   Jun 11 2008, 18:59
- - Parsi   I just wanted to open up a new thread about this. ...   Jul 18 2008, 18:06
|- - odyssey   QUOTE (Parsi @ Jul 18 2008, 19:06) Howeve...   Jul 18 2008, 19:44
- - XPEHOPE3   Such an utility exists. It looks like this: It...   Jul 28 2008, 06:56
|- - odyssey   QUOTE (XPEHOPE3 @ Jul 28 2008, 07:56) Suc...   Jul 28 2008, 08:33
- - XPEHOPE3   QUOTE But does it write the results in tags or eve...   Jul 28 2008, 09:16
|- - odyssey   QUOTE (XPEHOPE3 @ Jul 28 2008, 10:16) QUO...   Jul 28 2008, 12:19
- - twostar   Fooaccrip works for me. I tested with a cd ripped ...   Jul 28 2008, 12:09
- - XPEHOPE3   I will tell the author about my post here and hope...   Jul 28 2008, 13:17
- - Parsi   odyssey, According to my tests arcue supports preg...   Jul 29 2008, 11:59
|- - odyssey   QUOTE (Parsi @ Jul 29 2008, 12:59) odysse...   Jul 29 2008, 14:17
- - odyssey   Just tried it out today. It seem to work very well...   Aug 4 2008, 20:19
- - foorious   I definitely second that.   Aug 5 2008, 14:59
- - Borisz   I imagine a foobar integrated accuraterip verifier...   Sep 14 2008, 11:23
- - foorious   Any upcoming news on FooAccRip ? Our friend odysse...   Sep 22 2008, 14:52
- - Gregory S. Chudov   QUOTE (foorious @ Sep 22 2008, 16:52) I...   Oct 2 2008, 12:20
RSS Lo-Fi Version Time is now: 24th May 2015 - 09:13
