Seamless crossfade everytime, on manual or automatic title change
nufchavq
post Jul 10 2007, 20:09
Hello
I saw that it was a recurrent problem to make foobar do acceptable crossfading between tracks. Indeed, there are two major extensions (Continuator and Gapless Crossfader) that would allow foobar to do it but in all default configurations it was hard to obtain a really seamless crossover between tracks, especially when manually changing tracks. It was a main reason to my to stay with 0.8.x foobar with it DirectSound 2.5 that allowed me to do that crossfading by setting the good cache value. But DirectSound 2.5 is no more supported in foobar 0.9.x nor in Vista.. So after a dozen of unsuccessful tries, I think I found a right extension/settings combination. Just see below:
First install VC8 sp1 runtime libraries in order to get the extension to work
http://acropolis.lokalen.org/wp-content/pl...nload.php?id=15
Then install Gapless Crossfader http://acropolis.lokalen.org/wp-content/pl...wnload.php?id=1
(official site: http://acropolis.lokalen.org/2006/10/fooba...000-components)
If you have Continuator, disable it
Activate Gapless Crossfader into DSP Page
Enable what's shown
Configure the extension in the DSP Page
Set the buffer lenght
Set the fading control
And it should crossfade! Hope it would help someone.. smile.gif)
kanak
post Jul 10 2007, 20:54
Thanks. I did as you said-- and it seems to be working very well.
Edit: I listened to a couple of albums with the setting, and it works as mentioned.
This post has been edited by kanak: Jul 10 2007, 22:27
Maranatha
post Jul 10 2007, 23:36
Thanks for sharing that, works VERY well!
This post has been edited by Maranatha: Jul 10 2007, 23:48
nufchavq
post Jul 11 2007, 00:13
Drug
post Jul 14 2007, 22:49
I'm disappointed that this plugin causes my foobar to crash when a song is changed or stopped.
Maranatha
post Jul 14 2007, 22:58
QUOTE (Drug @ Jul 14 2007, 16:49) *
As well you should be. You need to double check and make sure you have all the lib.dll files in your main installation directory. That's more than likely your problem..
Drug
post Jul 15 2007, 03:01
i installed that vc redistributable thingie and placed this libmmd.dll in the foobar directory. This placing prevented the message box at the start of foobar which called on a failure of something in the crossfader plugin.
foobar starts well with the plugin, i can configure the settings and all...but when i skip a song or stop it, foobar just closes.
gob
post Jul 15 2007, 05:04
i like crossfading, but i wish it was smarter, so it only crossfadesif shuffle mode is activated.
Squeller
post Jul 15 2007, 09:53
QUOTE (gob @ Jul 14 2007, 20:04) *
Yep, good idea, just like foo_rg_trn. Maybe ask acropolis? I already do use it this way, but because I control via girder...
Acropolis
post Jul 15 2007, 10:19
Group: Banned
$if($strcmp($substr(%cwb_playback_order%,1,7),Shuffle),
$gapless_crossfader(enable,true),
$gapless_crossfader(enable,false)
22PhuhAW
post Jul 24 2007, 19:50
Thank you Nufchavq! Extactly what I was searching for!
gob
post Jul 25 2007, 04:46
QUOTE (Squeller @ Jul 15 2007, 04:53) *
damn, thanks for posting this. ive been looking for something like this since the day i found out about replaygain beer.gif
QUOTE (Acropolis @ Jul 15 2007, 05:19) *
$if($strcmp(%cwb_playback_order%,'Shuffle (tracks)'),
Hey Acropolis, thats exactly what i was looking for, but where should i put this? i can put it into panels UI's track or user globals and it enables/disables hte crossfader as expected. however anywhere i use %cwb_playback_order% it is replaced with 'true'%cwb_playback_order%.
This post has been edited by gob: Jul 25 2007, 04:47
Squeller
post Jul 25 2007, 08:08
I reckon you can put it into SCPL or track display panel...
QUOTE (Acropolis @ Jul 15 2007, 10:19) *
Ah yes, I forgot about the tagz support smile.gif BTW $strstr makes life easier. Is case sensitive.
$if($strstr(%cwb_playback_order%,Shuffle),
This post has been edited by Squeller: Jul 25 2007, 08:14
nitroguy
post Aug 3 2007, 06:36
I am not sure if this is what you mean by "manually changing tracks", but here's what I'm looking for (can you tell me if this will accomplish what I need?)
Halfway through a song, if I switch to a different song, will it crossfade? It does this on my Rio Karma, and love it. Is there a plug in that will?
nitro
Squeller
post Aug 3 2007, 07:04
Post #15
QUOTE (nitroguy @ Aug 3 2007, 07:36) *
"Crossfade on manual track change" + PM.
This post has been edited by Squeller: Aug 3 2007, 07:16
freakngoat
post Aug 14 2009, 06:17
Post #16
So I know this is an old thread, but I'm trying to get the gapless crossfader plugin working under Windows 7 (foobar2000 v.0.9.6.8).
First of all, the VC8 sp1 runtime libraries link doesn't work anymore.
The plugin itself seems to install fine, and foobar loads with no problems or error messages. I've tried to configure it based on the screen shots shown but my problem is that when I manually switch songs, there is a small gap before the crossfade into the new song. Otherwise it seems to work fine. I just need to get rid of that small gap.
Any ideas?
Blualeono
post Aug 21 2009, 14:47
Post #17
QUOTE (freakngoat @ Aug 13 2009, 23:17) *
Any ideas?
same problem...
globetrotting
post Jan 11 2010, 08:54
Post #18
Any ideas?
Same here - I only have a short gap as soon as I click on "next song".
After that gap the old song continues playing & fades out, the next song fades in nicely, without producing another gap.
But the gap which occurs right when clicking on "next song" is a bit annoying - nobody else has it or knows a solution?
Components:
foobar 09.6.9
gapless Crossfader 0341 (SSE)
skip Silence
relook
post Apr 20 2011, 21:10
Post #19
QUOTE (freakngoat @ Aug 14 2009, 06:17) *
Any ideas?
same for me, annoying gap - still looking something perfect like sqrsoft crossfade for winamp.
or solve the gap-issue.
Help please
thankyou
rizzowitcs
post Apr 23 2011, 23:17
Post #20
Same here.
Any solution for this yet?
This post has been edited by db1989: Apr 26 2012, 01:06
Reason for edit: deleting pointless full quote of above post
zaede
post Apr 24 2011, 02:33
Post #21
Same here,
would be really great if there is a solution.
Reason for edit: as above
foobar2000 best player ever
At0m5k
post Apr 26 2012, 00:27
Post #22
I know this is occurring due to a limitation in the way foobar handles DSP plugins, but it'd be awesome if we could manually change and seek through tracks smoothly.
Well, looks like it's already planned to be included in the next version according to this thread:
http://www.hydrogenaudio.org/forums/index....showtopic=92627
This post has been edited by At0m5k: Apr 26 2012, 00:34
db1989
post Apr 26 2012, 00:56
Post #23
Said next version was 1.1.11, so the feature for which you bumped this year-old thread already exists; moreover, it is entirely separate from the DSP pipeline.
RSS Lo-Fi Version Time is now: 1st February 2015 - 16:57
