Nero AAC & EAC Why Isn't This Working?
CheechOZ
post Jun 11 2007, 13:29
I've just decided to rip my small CD collection (200 CD's) into AAC files, and I want to use EAC, as that is the only ripper that I ever used (and want to use). I followed the guide in the Nero AAC Recommended Settings post, I think to a "T", but after the ripping process, nothing happens, and the encoding process just fails!! Some notes as to how I set it up might shed some light as to why it doesn't work: I use the file extension as m4a, then I copy and paste the command line that is in the post, of course, changing the path used for the encoder, and my preference for quality value. I use EAC 0.9 b4, as that is the version I use for Uber standard ripping. Can someone please help me to get this to work correctly? Thanks in advance!
tev777
post Feb 3 2012, 15:59
@db1989
I understand that was not the problem in this case, but reading through the thread clearly shows conversation about spaces and quotes. Plus look at the command line just above this. Almost half of it is encoder path info. Cleaning up the easy stuff makes it easier to find problems when they arise.
Eric
- CheechOZ   Nero AAC & EAC Why Isn't This Working?   Jun 11 2007, 13:29
- - HeXeR   If your path to the nero encoder has spaces, you h...   Jun 11 2007, 14:14
- - CheechOZ   I checked to make sure the path was copied perfect...   Jun 11 2007, 15:04
|- - HeXeR   QUOTE (CheechOZ @ Jun 11 2007, 16:04) Thi...   Jun 11 2007, 15:22
|- - CheechOZ   QUOTE (HeXeR @ Jun 11 2007, 10:22) QUOTE ...   Jun 11 2007, 15:51
- - Shocking   I also spent a few hours trying to get Nero AAC wo...   Jun 11 2007, 16:03
|- - telekomsrbija   QUOTE (Shocking @ Jun 11 2007, 16:03) I a...   Jun 10 2010, 23:38
- - CheechOZ   Thanks for helping me out, but I just can't ge...   Jun 11 2007, 16:23
- - HeXeR   Shocking's way of putting the tagger is right....   Jun 11 2007, 16:34
|- - Shocking   QUOTE (HeXeR @ Jun 11 2007, 16:34) Shocki...   Jun 11 2007, 21:39
- - CheechOZ   Thanks again HeXer, but I copied it exactly as you...   Jun 11 2007, 16:58
- - muaddib   Maybe you should use: "C:\Program Files...   Jun 11 2007, 17:04
- - CheechOZ   Can someone else please try and give me the correc...   Jun 11 2007, 17:24
- - Alex B   Personally I would just rip in the single wave fil...   Jun 11 2007, 17:42
- - HeXeR   QUOTE (CheechOZ @ Jun 11 2007, 17:58) And...   Jun 11 2007, 18:17
- - greynol   From http://www.ss64.com/nt/cmd.html CODEThe foll...   Jun 11 2007, 18:36
- - Synthetic Soul   I must admit the above flumoxes me! Easiest...   Jun 11 2007, 19:21
|- - CheechOZ   QUOTE (Synthetic Soul @ Jun 11 2007, 14:2...   Jun 11 2007, 21:24
- - greynol   I just add a pair of sacrificial quotes around the...   Jun 11 2007, 19:24
- - Alex B   The OP (CheechOZ) asked the following by PM. I dec...   Jun 13 2007, 09:35
- - scrolling   QUOTE (Synthetic Soul @ Jun 11 2007, 12:2...   Oct 22 2007, 03:53
- - hlloyge   To add a question to a question: is it possible to...   Jul 19 2010, 22:00
- - greynol   http://www.hydrogenaudio.org/forums/index....st...   Jul 19 2010, 22:09
- - hlloyge   OK, I will play a bit with that, thank you, greyno...   Jul 20 2010, 13:00
- - marco.stanzani   I am getting crazy to use the Nero AAC encoder wit...   Jan 31 2012, 17:09
|- - marco.stanzani   ok i got the solution %s must be replaced by %sour...   Jan 31 2012, 17:30
- - db1989   And the rest. http://wiki.hydrogenaudio.org/index...   Jan 31 2012, 22:35
- - tev777   I really do not understand why you guys do this to...   Jan 31 2012, 23:43
- - db1989   But that is not the problem. The placeholders were...   Feb 1 2012, 20:42
- - soundping   This worked for me. CODE/c C:\"Progr...   Feb 3 2012, 04:10
- - tev777   @db1989 I understand that was not the problem in ...   Feb 3 2012, 15:59
- - Dixieland57   Hi please help me, nothing work for me, I'm go...   May 6 2014, 23:32
RSS Lo-Fi Version Time is now: 24th May 2015 - 18:41
