Nero AAC & EAC Why Isn't This Working?
CheechOZ
post Jun 11 2007, 13:29
I've just decided to rip my small CD collection (200 CD's) into AAC files, and I want to use EAC, as that is the only ripper that I ever used (and want to use). I followed the guide in the Nero AAC Recommended Settings post, I think to a "T", but after the ripping process, nothing happens, and the encoding process just fails!! Some notes as to how I set it up might shed some light as to why it doesn't work: I use the file extension as m4a, then I copy and paste the command line that is in the post, of course, changing the path used for the encoder, and my preference for quality value. I use EAC 0.9 b4, as that is the version I use for Uber standard ripping. Can someone please help me to get this to work correctly? Thanks in advance!
CheechOZ
post Jun 11 2007, 16:23
Thanks for helping me out, but I just can't get this to work, and it's probably the simplest thing too!!! I used the exact same string as you are using, and still nothing! blink.gif
- CheechOZ   Nero AAC & EAC Why Isn't This Working?   Jun 11 2007, 13:29
- - HeXeR   If your path to the nero encoder has spaces, you h...   Jun 11 2007, 14:14
- - CheechOZ   I checked to make sure the path was copied perfect...   Jun 11 2007, 15:04
|- - HeXeR   QUOTE (CheechOZ @ Jun 11 2007, 16:04) Thi...   Jun 11 2007, 15:22
|- - CheechOZ   QUOTE (HeXeR @ Jun 11 2007, 10:22) QUOTE ...   Jun 11 2007, 15:51
- - Shocking   I also spent a few hours trying to get Nero AAC wo...   Jun 11 2007, 16:03
|- - telekomsrbija   QUOTE (Shocking @ Jun 11 2007, 16:03) I a...   Jun 10 2010, 23:38
- - CheechOZ   Thanks for helping me out, but I just can't ge...   Jun 11 2007, 16:23
- - HeXeR   Shocking's way of putting the tagger is right....   Jun 11 2007, 16:34
|- - Shocking   QUOTE (HeXeR @ Jun 11 2007, 16:34) Shocki...   Jun 11 2007, 21:39
- - CheechOZ   Thanks again HeXer, but I copied it exactly as you...   Jun 11 2007, 16:58
- - muaddib   Maybe you should use: "C:\Program Files...   Jun 11 2007, 17:04
- - CheechOZ   Can someone else please try and give me the correc...   Jun 11 2007, 17:24
- - Alex B   Personally I would just rip in the single wave fil...   Jun 11 2007, 17:42
- - HeXeR   QUOTE (CheechOZ @ Jun 11 2007, 17:58) And...   Jun 11 2007, 18:17
- - greynol   From http://www.ss64.com/nt/cmd.html CODEThe foll...   Jun 11 2007, 18:36
- - Synthetic Soul   I must admit the above flumoxes me! Easiest...   Jun 11 2007, 19:21
|- - CheechOZ   QUOTE (Synthetic Soul @ Jun 11 2007, 14:2...   Jun 11 2007, 21:24
- - greynol   I just add a pair of sacrificial quotes around the...   Jun 11 2007, 19:24
- - Alex B   The OP (CheechOZ) asked the following by PM. I dec...   Jun 13 2007, 09:35
- - scrolling   QUOTE (Synthetic Soul @ Jun 11 2007, 12:2...   Oct 22 2007, 03:53
- - hlloyge   To add a question to a question: is it possible to...   Jul 19 2010, 22:00
- - greynol   http://www.hydrogenaudio.org/forums/index....st...   Jul 19 2010, 22:09
- - hlloyge   OK, I will play a bit with that, thank you, greyno...   Jul 20 2010, 13:00
- - marco.stanzani   I am getting crazy to use the Nero AAC encoder wit...   Jan 31 2012, 17:09
|- - marco.stanzani   ok i got the solution %s must be replaced by %sour...   Jan 31 2012, 17:30
- - db1989   And the rest. http://wiki.hydrogenaudio.org/index...   Jan 31 2012, 22:35
- - tev777   I really do not understand why you guys do this to...   Jan 31 2012, 23:43
- - db1989   But that is not the problem. The placeholders were...   Feb 1 2012, 20:42
- - soundping   This worked for me. CODE/c C:\"Progr...   Feb 3 2012, 04:10
- - tev777   @db1989 I understand that was not the problem in ...   Feb 3 2012, 15:59
- - Dixieland57   Hi please help me, nothing work for me, I'm go...   May 6 2014, 23:32
RSS Lo-Fi Version Time is now: 27th January 2015 - 17:10
