Running Foobar in Linux, Alien Cats crossbreeding with Penguins
Yotsuya
post May 17 2007, 13:38
I have had several people ask me about making foobar work under linux. There are several threads mentioning it is possible however it is hard to find much detail about it. I have foobar running rather stable on my linux box and have created this thread in an attempt to provide a central place for questions and answers for running foobar under linux. Peter has indicated he will not develop a linux version of foobar so I thought it would be proper to keep these sorts of questions out of the main threads. I intend to update this post and polish these instructions as discussion reveals more information. I have pieced this together from various other sources and applied them to my own configuration. If you have a better approach to running foobar under linux please share with the rest of us.
* Wujek_Bogdan has provided instructions in Polish, you can find them here.
Installation
I. Wine
- You will need a working linux box with wine. Under Ubuntu you can use the command:
sudo apt-get install wine
- If you intend to use multilingual support, I suggest winelocale.
- This tutorial assumes you have a wine drive z: mapped to your filesystem root "/" directory. This is the default setup with most wine installs.
- Be sure to configure wine as a Windows XP or newer machine, foobar does not support older OSs such as Win95 or Win2k. Also be sure to install windows fonts so everything looks pretty. To do this with winetricks:
sh winetricks winxp allfonts
- To correct audio stuttering problems during CPU spikes, set wine audio acceleration to "Emulation" instead of "Full". From the Wine Application DB entry for foobar2000:
The beta version of foobar2000 uses Directsound by default, which can cause some problems when playing music. In order to get the program to play music properly, you must set the Hardware Acceleration to emulate Directsound. Go to a terimal and type in "winecfg". A window will open with options for you to modify. Click on the Audio tab, and then look for "Hardware Acceleration". It is currently on "Full". Click on it, and you will have a list of options. Click on "Emulation", and then click on "Apply". foobar2000 should now be able to play music. Note that this will make foobar2000 version 0.8.3 give out an error when you try to play an audio file. Just change it back to "Full" in winecfg when you're done using foobar2000 version 0.9 beta.
II. Foobar2000
* If you have an existing copy of foobar, copy your old foobar2000 folder to ~/.foobar2000 and skip this section.
- Download the foobar installer from the main foobar homepage.
- Run the foobar installer with wine:
wine foobar2000_0.9.6.3.exe
- Use the "Portable installation" Type to avoid mucking about with user profiles.
- Install to the location z:\home\YOURNAME\.foobar2000\ which translates through wine as ~/.foobar2000
  • DO NOT install "Audio CD support", wine does not currently support direct access to optical drives.
III. Shell Script
- Let's build a shell script to execute foobar like a normal Linux program
gksudo gedit /usr/bin/foobar2000
#!/bin/sh
cd ~/.foobar2000/
if [ "$1" != "" ]; then
filename=`echo z:$1 | sed 's/\\//\\\\/g'`
wine foobar2000.exe "$filename" &
else
wine foobar2000.exe &
fi
* If you are using winelocale, replace "wine" with "wineloc -l ja_JP" or something similar for your region.
- Close gedit and save the file.
- Make the file executable with the following command:
sudo chmod +x /usr/bin/foobar2000
IV. Application Package
- Pick an icon for foobar, I rather like this one by Byan. Save it as /usr/share/icons/foobar2000.png
- Let's build a .desktop application package so we can launch foobar from the gnome main menu
gksudo gedit /usr/share/applications/foobar2000.desktop
[Desktop Entry]
Type=Application
Name=foobar2000
GenericName=Plays Music
Version=1.0
Encoding=UTF-8
Terminal=false
Exec=/usr/bin/foobar2000
Comment=Plays Music
Categories=GNOME;GTK;AudioVideo;Audio;Player;
Components
Not all components work well with wine, here is a list of some components with special requirements:Keyboard Shortcuts:
By default, wine should allow foobar to map multimedia keys if they are not already mapped by something else however these bindings will not be global (you cannot change songs when using a different program). To globally control foobar with your multimedia keys you may want to read through this post over on the ubuntu forums. To summarize:
- Press Alt+F2 to open a Run Configuration window.
- Enter "gconf-editor" in the box and either press <Enter> or click [Run]
- This should open the Gnome Configuration Editor.
- In the left pane navigate to /apps/metacity/keybinding_commands and define the following keys:
command_1 - wine ~/.foobar2000/foobar2000.exe /playpause
command_2 - wine ~/.foobar2000/foobar2000.exe /stop
command_3 - wine ~/.foobar2000/foobar2000.exe /next
command_4 - wine ~/.foobar2000/foobar2000.exe /prev
- In the left pane navigate to /apps/metacity/global_keybindings and define the following keys:
run_command_1 - XF86AudioPause
run_command_2 - XF86AudioStop
run_command_3 - XF86AudioNext
run_command_4 - XF86AudioPrev
Announcing Now Playing Information:
Many people like to announce what they are currently playing in foobar to other programs such as IRC or an Instant Meesenger. Most of the popular solutions do not translate well outside of wine. However I discovered foo_np_simple which basically dumps titleformatted text into an external plain text file that can then be processed by your external program (cat ~/.foobar2000/now_playing.txt). I have considered trying to mirror a nowplaying info file from another player such as quodlibet and then create an xchat perl script to parse the information nicely but I think that goes beyond the scope of this topic.
Other Comments:
- Wine tray icons are a bit buggy with both gnome and kde, To Avoid problems you may want to prevent foobar from minimizing to it in your Columns/Panels config.
- These instructions are written for a gnome environment. For KDE users replace "gksudo" with "kdesu" and "gedit" with "kate".
This post has been edited by Yotsuya: Mar 20 2009, 01:22
http://www.ubuntu.com
MC Escher
post Jun 20 2007, 09:08
Good news everyone!
The latest version of Wine (0.9.39) seems to have fixed the stuttering for me (I still have to test it some more). The changelog for the release does mention some fixes to audio handling, so maybe the patch mentioned here finally got in?
See here for instructions on getting a repository working for the latest version for Debian and Debian-based distros, so you'll always get the latest version.
nbv4
post Jun 23 2007, 04:08
QUOTE (MC Escher @ Jun 20 2007, 00:08) *
Good news everyone!
the stuttering is less, but it's still there for me. Using 0.9.39
huge improvement though...
Also, I've been having the problem where, if I try to minimize the window, the window just freezes up. The borders remain, but the rest goes transparent, and then the whole thing becomes unresponsive. uTorrent acted the same way. Last year when I tried linux, I remember all wine apps doing the same thing. Is there a fix for this?
edit:
QUOTE (bubbleguuum @ May 19 2007, 10:30) *
Mandatory screenshot:
How do you have your sources set up in album art panel? All my covers are found at "/home/nbv4/covers/%artist% - %album%.jpg", but that string doesn't work.
This post has been edited by nbv4: Jun 23 2007, 06:59
Spirit_of_the_oc...
post Jun 23 2007, 10:07
Is this Foobar 0.8 or 0.9 ?
I want to have Album art panel for 0.8 if it exists?
Can someone help me?
@Wine 0.39 that is quite good. I think sooner or later these problems will be fixed. The question is when.
bubbleguuum
post Jun 24 2007, 13:23
QUOTE (Spirit_of_the_ocean @ Jun 23 2007, 11:07) *
It's the latest 0.9
no idea
Suer, the ameliorations in 0.39 comes from the Google Summer of code work being done on sound in wine.
This post has been edited by bubbleguuum: Jun 24 2007, 13:24
Spirit_of_the_oc...
post Jun 25 2007, 14:41
Under 0.9.39 and Foobar 0.9 I found some strange behaviours of the sound sad.gif
bubbleguuum
post Jun 25 2007, 15:10
QUOTE (Spirit_of_the_ocean @ Jun 25 2007, 15:41) *
Like what ? If it is sound distortion, on my sound card I had to use the resampler @ 48000Hz for the sound not to be garbled / strange.
Just tried 0.39 and using JACK as the audio driver I can move window like mad and have 0 skips! yay!
- Yotsuya   Running Foobar in Linux   May 17 2007, 13:38
- - pepoluan   Nice should be in the wiki   May 18 2007, 06:14
- - Spirit_of_the_ocean   It seems you can read my thoughts Thanks for thi...   May 18 2007, 13:45
- - aliendesaster   I'll try it when I'm home. How is performa...   May 18 2007, 16:57
- - hotzenpl0tz   Do newer Wine versions fix the problem, that playb...   May 18 2007, 17:43
|- - bubbleguuum   QUOTE (hotzenpl0tz @ May 18 2007, 18:43) ...   May 18 2007, 21:25
|- - bubbleguuum   More good news: Starting with wine 0.9.36 (possib...   May 19 2007, 19:30
- - Rasi   nice... although i love MPD+Client, i really miss ...   May 19 2007, 18:00
- - MC Escher   What kind of hardware acceleration do you use in W...   May 19 2007, 22:19
|- - bubbleguuum   QUOTE (MC Escher @ May 19 2007, 23:19) Wh...   May 19 2007, 23:11
- - Yotsuya   I am running wine 0.9.37 and also experience sound...   May 20 2007, 13:19
- - MC Escher   QUOTE (bubbleguuum @ May 19 2007, 14:11) ...   May 20 2007, 17:32
- - arT2   hi there, great tut at the moment the only thing...   May 27 2007, 11:11
|- - bubbleguuum   QUOTE (arT2 @ May 27 2007, 12:11) hi ther...   May 27 2007, 12:41
- - arT2   cool, thank you for this nice piece of information...   May 27 2007, 13:57
- - Wujek_Bogdan   Foobar works nice (even with ColumnsUI), but soun...   May 28 2007, 23:39
- - btag   Very nice guide. Now I can finally run foobar as a...   May 30 2007, 02:49
|- - bubbleguuum   QUOTE (btag @ May 30 2007, 03:49) Very ni...   May 31 2007, 21:11
- - Wujek_Bogdan   THX. I'll check it. i also tried running fooba...   May 30 2007, 14:17
- - pinknyunyu   Hi Old to foobar2000 but new to linux (ubuntu)--j...   May 31 2007, 15:09
|- - bubbleguuum   QUOTE (pinknyunyu @ May 31 2007, 16:09) H...   May 31 2007, 18:45
- - pinknyunyu   Also, are there any linux players that display alb...   May 31 2007, 16:30
- - Yotsuya   pinknyunyu: Both AmaroK and Quodlibet will display...   May 31 2007, 17:09
- - pinknyunyu   Thanks! I'll check them out. And thanks ...   May 31 2007, 17:30
- - Wujek_Bogdan   i was also searching this option. i found only tha...   Jun 1 2007, 13:34
|- - Spirit_of_the_ocean   Maybe he talks about O.8 there is in preferences a...   Jun 2 2007, 14:32
- - Wujek_Bogdan   if you want to run application with custom priorit...   Jun 2 2007, 18:09
- - Spirit_of_the_ocean   I use 0.83 for playing it works really good. I thi...   Jun 3 2007, 20:52
- - Wujek_Bogdan   take a look HERE it seems, that it is possible to ...   Jun 4 2007, 08:19
|- - Spirit_of_the_ocean   QUOTE - playing audio works (but stutters if the s...   Jun 4 2007, 18:14
- - Y.Z.   It is possible to run foobar2k without sound chopp...   Jun 10 2007, 13:17
|- - bubbleguuum   QUOTE (Y.Z. @ Jun 10 2007, 14:17) It is p...   Jun 10 2007, 13:19
|- - Spirit_of_the_ocean   QUOTE (bubbleguuum @ Jun 10 2007, 12:19) ...   Jun 10 2007, 14:10
|- - Y.Z.   QUOTE (Spirit_of_the_ocean @ Jun 10 2007, 15...   Jun 10 2007, 15:36
|- - Spirit_of_the_ocean   Thanks a lot I am using feisty fawn so I have to ...   Jun 10 2007, 18:10
- - Rasi   cd /your/wine/root/folder patch -p1 < Implement...   Jun 10 2007, 19:54
|- - Y.Z.   QUOTE (Rasi @ Jun 10 2007, 20:54) cd /you...   Jun 10 2007, 20:42
||- - Spirit_of_the_ocean   Can I use this with feisty fawn?   Jun 11 2007, 18:32
||- - Y.Z.   QUOTE (Spirit_of_the_ocean @ Jun 11 2007, 19...   Jun 12 2007, 11:20
|- - Spirit_of_the_ocean   ups problem solved.... I did everything as descri...   Jun 16 2007, 20:40
- - vbbjq   With wine 0.9.38 h -p1 < Implement_SetThreadPri...   Jun 14 2007, 04:54
- - Wujek_Bogdan   why do you want to use ASIO? it doesn't make A...   Jun 14 2007, 13:38
- - vbbjq   asio can realtime output..............if you using...   Jun 14 2007, 13:44
- - Wujek_Bogdan   yes, but ASIO is essential for recording (MIDI for...   Jun 14 2007, 17:48
- - MC Escher   Good news everyone! The latest version of Wine...   Jun 20 2007, 09:08
|- - nbv4   QUOTE (MC Escher @ Jun 20 2007, 00:08) Go...   Jun 23 2007, 04:08
|- - Spirit_of_the_ocean   Is this Foobar 0.8 or 0.9 ? I want to have Album a...   Jun 23 2007, 10:07
|- - bubbleguuum   QUOTE (Spirit_of_the_ocean @ Jun 23 2007, 11...   Jun 24 2007, 13:23
|- - Spirit_of_the_ocean   Under 0.9.39 and Foobar 0.9 I found some strange b...   Jun 25 2007, 14:41
|- - bubbleguuum   QUOTE (Spirit_of_the_ocean @ Jun 25 2007, 15...   Jun 25 2007, 15:10
|- - Spirit_of_the_ocean   Resample @48000HZ? What exactly does this mean? W...   Jun 26 2007, 22:02
|- - nbv4   QUOTE (bubbleguuum @ Jun 25 2007, 06:10) ...   Jun 26 2007, 23:37
|- - bubbleguuum   QUOTE (nbv4 @ Jun 27 2007, 00:37) is ther...   Jun 27 2007, 16:04
|- - nbv4   QUOTE (bubbleguuum @ Jun 27 2007, 07:04) ...   Jun 27 2007, 21:09
|- - Spirit_of_the_ocean   I installed jack started jack. Then I started foob...   Jun 28 2007, 00:29
- - bubbleguuum   QUOTE (nbv4 @ Jun 23 2007, 05:08) How do ...   Jun 23 2007, 08:39
- - Spirit_of_the_ocean   A new version of wine has appeared today Changelo...   Jun 29 2007, 23:57
- - Betse   I'm just trying out Ubuntu and i would like to...   Jul 3 2007, 13:35
|- - Spirit_of_the_ocean   QUOTE (Betse @ Jul 3 2007, 12:35) wine -l...   Jul 3 2007, 21:40
- - tgoose   Just a thought, but if/when JACK gets completely p...   Jul 4 2007, 13:20
|- - bubbleguuum   QUOTE (tgoose @ Jul 4 2007, 14:20) Just a...   Jul 4 2007, 19:28
|- - Spirit_of_the_ocean   For me wine 0.9.40 and Jack work perfectly   Jul 4 2007, 21:26
- - MC Escher   Does anyone else notice a big regression with the ...   Jul 16 2007, 13:48
|- - Spirit_of_the_ocean   I get messages that jack isn't found. This is ...   Jul 16 2007, 23:36
- - Bojan   foobar2000 works very well for me with the ALSA dr...   Jul 16 2007, 23:52
- - MC Escher   QUOTE (Spirit_of_the_ocean @ Jul 16 2007, 14...   Jul 17 2007, 00:00
- - hybridfan   Very interesting, shame I got rid of Kubuntu, woul...   Jul 17 2007, 11:11
- - Yotsuya   Well I finally resolved a problem with my account ...   Jul 18 2007, 04:54
|- - Spirit_of_the_ocean   QUOTE (Yotsuya @ Jul 18 2007, 03:54) I am...   Jul 18 2007, 23:23
|- - nbv4   QUOTE (Spirit_of_the_ocean @ Jul 18 2007, 15...   Jul 19 2007, 02:56
|- - bubbleguuum   QUOTE (nbv4 @ Jul 19 2007, 03:56) I'm...   Jul 19 2007, 09:20
|- - nbv4   QUOTE (bubbleguuum @ Jul 19 2007, 01:20) ...   Jul 19 2007, 20:19
- - MC Escher   Same here. Ubuntu .deb from the budgetdedicated re...   Jul 19 2007, 23:20
- - plukin   My feisty install of wine works well with foobar, ...   Jul 19 2007, 23:34
|- - nbv4   QUOTE (plukin @ Jul 19 2007, 15:34) My fe...   Jul 20 2007, 05:37
|- - bubbleguuum   QUOTE (nbv4 @ Jul 20 2007, 06:37) we...   Jul 20 2007, 08:44
|- - Spirit_of_the_ocean   If you upgrade to 9.41 there is just the message t...   Jul 20 2007, 10:24
|- - nbv4   QUOTE (bubbleguuum @ Jul 20 2007, 00:44) ...   Jul 21 2007, 18:59
- - Yotsuya   When switching to the audio tab, the only errors w...   Jul 21 2007, 05:56
- - Spirit_of_the_ocean   wine v0.9.41 doesn't seem to support jack but ...   Jul 21 2007, 19:37
- - skamp   The audio still goes into a short loop whenever I ...   Jul 29 2007, 12:39
|- - nbv4   QUOTE (skamp @ Jul 29 2007, 04:39) The au...   Aug 2 2007, 00:44
|- - skamp   nbv4: that's not the point. Different applicat...   Aug 2 2007, 11:57
- - Thanasis159   I will try it... Hope it works!   Jul 29 2007, 21:27
- - fivre   I'm not sure about stutter (music stutters whe...   Aug 3 2007, 07:58
- - Yotsuya   fivre: I once encountered some background whitenoi...   Aug 4 2007, 00:28
|- - fivre   QUOTE (Yotsuya @ Aug 3 2007, 18:28) fivre...   Aug 9 2007, 03:42
|- - skamp   QUOTE (Yotsuya @ Aug 4 2007, 01:28) And f...   Aug 11 2007, 11:31
|- - stampgevaar   QUOTE (Yotsuya @ Aug 4 2007, 01:28) And f...   Aug 22 2007, 20:55
- - Yotsuya   skamp: It can use mpeg321, gstreamer, or mplayer (...   Aug 11 2007, 14:18
|- - skamp   QUOTE (Yotsuya @ Aug 11 2007, 15:18) It c...   Aug 11 2007, 15:23
- - Spirit_of_the_ocean   I think I have made a mistake when updating to a v...   Aug 21 2007, 11:24
- - dkg   gentoo-amd64, wine v0.9.38, foobar v.0.9.4.4, and ...   Aug 27 2007, 09:00
- - j8ee   Is dragging menu toolbars working for anyone here?...   Aug 27 2007, 21:06
|- - nbv4   QUOTE (j8ee @ Aug 27 2007, 13:06) Is drag...   Aug 31 2007, 04:05
- - skamp   Try loading a web page in Firefox while listening ...   Aug 27 2007, 21:25
|- - Kavika   QUOTE (skamp @ Aug 27 2007, 12:25) Try lo...   Sep 5 2007, 03:54
|- - skamp   QUOTE (Kavika @ Sep 5 2007, 04:54) Edit: ...   Sep 13 2007, 10:09
- - sveterv   There is one thing which can resolve all your prob...   Sep 14 2007, 09:49
- - FredPT   Hi there! This news about the CFS are great, b...   Sep 17 2007, 22:23
5 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 26th May 2015 - 07:59
