determining read offset - CDSpeed dialog disabled
jonpb
post May 13 2007, 23:00
I would like to get the read offset of my LITEON SOHW-832S. The AccurateRip database says it is +12. I only have one CD in the EAC calculation list and, based on that one CD, EAC is saying it is +1006. I downloaded CDSpeed, but the Advanced DAE Quality Test is disabled. I have been searching to find why it is always disabled, does the free version of CDSpeed cripple this feature, or is there something I am doing wrong?
One more question. Once I do get the correct value for the offset and it is positive (+), the way I understand it, since this drive does not have overread into lead-out, I will always be missing the last samples off the last track, correct? It's not that big a deal to lose a couple milliseconds off the last track, what's important is the alignment of all the rest of the tracks. Also, if the correct value turns out to be negative (-), since this drive does have overread into lead-in, in that case, all tracks would be aligned and I would not lose the last samples off the last track, correct?
adamjk
post May 14 2007, 02:47
At first you must create, using NERO CD-DVD Speed, your special test disc and then everything will become very simple.
Detailed manual of CD-DVD Speed you can find here:
http://club.cdfreaks.com/showthread.php?t=192563#post1540652
and don't forget that Nero CD-DVD Speed reports the total of the read offset of the tested drive and the write offset of the recorder which was used to create the test disc.
jonpb
post May 14 2007, 03:50
QUOTE (adamjk @ May 13 2007, 18:47) *
Thanks very much, I guess my search skills aren't so good smile.gif 'cause I did search cdfreaks. Anyways I actually did create a disc using RAW mode as seems to be described in the manual and it didn't work. Unfortunately, that was my last CD-R so I have go out and buy some more to try other configurations. But, in the meantime, what is meant by "write offset of the recorder"? Is "recorder" the software or the hardware? As I understand it, write offset is a property of the hardware and the recording software can either correct this or not. So...
recorder = hardware:
1) the value can only be used in an EAC "combined offset" config
recorder = software
2) cdspeed does the write correction -> the value is the read offset
3) cdspeed does not do the write correction -> the value is the combined offset
Only under scenario (2) can I actually use cdspeed to find the read offset
Correct?
Also, any idea why it doesn't work with a commercial Audio CD, I would assume that the write offset of that "recorder" would be correct, unless scenario (1) is the correct scenario for cdspeed.
This post has been edited by jonpb: May 14 2007, 04:09
RSS Lo-Fi Version Time is now: 22nd May 2015 - 12:38
