foo_spdif - SPDIF support for foobar, SPDIF passthrough support for foobar2000
Grzesio
post Apr 26 2007, 21:50
Hi everyone!
Is anybody interested in SPDIF passthrough for AC3/DTS?
Here it is foo_spdif page
This post has been edited by Grzesio: Apr 26 2007, 21:52
conquerist
post Jan 12 2009, 08:52
First off, thanks Grzesio, this is the first time I've been able to seamlessly use SPDIF with a media library. WMP+AC3Filter always was a pain because WMP keeps the last file open in DirectShow, so SPDIF output is "locked", preventing outputting more than a single song over SPDIF. The only solution was to ouput SPDIF as PCM, aka "kernel streaming" in foobar, which had its own drawbacks.
I'd like to request 2 features for a new version of foo_spdif.
Implementing ApeV2 tags would make foo_spdif alot more usable, because it eliminates the need to use another program or foo_ac3/foo_input_dts to view/edit/see tags. The source of foo_input_dts is available here, which should be a good reference point (of course you'll also have to publish your source code in accordance to the GPL if you re-use the code).
The second feature is purely cosmetic. IMO, it would be "cleaner" to have "DTS" or "AC3" as the %codec% and the detailed info such as " 3/2.1 (5.1) 14bit LE" as %codec_profile%.
infirmus
post Jan 14 2009, 06:46
QUOTE (conquerist @ Jan 12 2009, 17:52) *
Agreed, thanks for the plugin.
I would also like to second those 2 feature suggestions. Especially the APEv2 tagging.
I tried muxing my AC3/DTS files into Matroska Audio (MKA) containers and tag the tracks using the Matroska metadata system but Foobar2000 doesnt seem to support that (although as far as I am aware FLAC in MKA containers can be tagged).
On a separate topic, the plugin doesnt seem to be working correctly with the latest Foobar2000 version. Foobar2000 sometimes crashes when seeking and the seek bar/time elapsed indicator does not increment (i.e. stays at 0:00). Here are two logfiles (Log 1, Log 2).
Another thing I tried with regard to getting SPDIF output was using the DirectShow plugin, but for some reason that doesnt seem to use AC3 Filter. AC3Filter is a DirectShow filter isnt it?
This post has been edited by infirmus: Jan 14 2009, 06:53
- Grzesio   foo_spdif - SPDIF support for foobar   Apr 26 2007, 21:50
- - marlonqpa   cool plugin, but it play my dts files to fast. i t...   Apr 26 2007, 22:54
|- - Grzesio   Yes, well it's probably because your files are...   Apr 26 2007, 23:41
- - Mangix   foobar2000 has a DSP called Resampler which should...   Apr 26 2007, 23:44
|- - willardjuice   I guess this doesn't work for Vista x64? All ...   Apr 27 2007, 00:10
|- - Grzesio   QUOTE (willardjuice @ Apr 27 2007, 00:10)...   Apr 27 2007, 00:20
|- - willardjuice   QUOTE (willardjuice @ Apr 26 2007, 19:10)...   May 21 2007, 00:55
- - cyRq   If you wanna play *.ac3 and *.dts files, you must ...   Apr 27 2007, 10:29
- - Rozzo   Didn't work here. I tried with a clean instal...   Apr 27 2007, 13:33
- - Rozzo   Hi, this kind of plugin is all that I need for ha...   Apr 27 2007, 18:34
|- - Grzesio   QUOTE (Rozzo @ Apr 27 2007, 18:34) Hi, t...   Apr 29 2007, 20:24
- - Grzesio   new release: foo_spdif_v0.2 v0.2: - fixed horribl...   Apr 30 2007, 13:31
- - Erik Garci   Grzesio, Thank you very much for creating this pl...   Apr 30 2007, 16:42
|- - Grzesio   QUOTE (Erik Garci @ Apr 30 2007, 16:42) G...   Apr 30 2007, 19:04
- - Rozzo   Hi, thanks for your work. I don't know if I...   Apr 30 2007, 18:16
|- - Grzesio   QUOTE (Rozzo @ Apr 30 2007, 18:16) When I...   May 6 2007, 12:58
- - Erik Garci   I tried v0.2, and 44.1kHz .AC3 files have no probl...   May 1 2007, 06:03
|- - Grzesio   Ops, that is very very odd what you have discovere...   May 1 2007, 06:56
|- - Erik Garci   QUOTE (Grzesio @ May 1 2007, 00:56) Ops, ...   May 1 2007, 15:02
|- - Erik Garci   QUOTE (Grzesio @ May 1 2007, 00:56) Could...   May 2 2007, 04:57
|- - Grzesio   So it looks like some kind of incompatibility with...   May 2 2007, 12:44
- - Erik Garci   To be more specific, the problem happens when I pl...   May 3 2007, 06:28
- - Erik Garci   I also tested 48kHz DTS files. Same problem. 44....   May 4 2007, 16:08
|- - Grzesio   I hope foo_spdif_v0.3 will help on that.   May 5 2007, 18:01
|- - dDaYb   foobar 0.9.4f + foo_spdif_v0.3 + foo_input_dts 0.1...   May 6 2007, 11:30
|- - Erik Garci   QUOTE (Grzesio @ May 5 2007, 12:01) I hop...   May 6 2007, 16:05
|- - Grzesio   QUOTE (Erik Garci @ May 6 2007, 16:05) By...   May 6 2007, 20:12
- - Dither   Works fine for me but just until it meets with loc...   May 14 2007, 08:28
|- - Grzesio   QUOTE (Dither @ May 14 2007, 08:28) Works...   May 21 2007, 15:53
- - Rozzo   Hi Grzesio, happiness here, plugin started to wor...   May 14 2007, 22:00
- - redmodel   Thanks for the plugin it's something i've ...   May 16 2007, 00:05
- - mmorselli   May I play multi channel WavePack file with this p...   May 16 2007, 21:32
|- - Grzesio   QUOTE (mmorselli @ May 16 2007, 21:32) Ma...   May 21 2007, 16:22
- - aurelio   Hi Grzesio, I get this error: QUOTE Unable to open...   Jun 1 2007, 00:23
|- - SBeaver   QUOTE (aurelio @ May 31 2007, 15:23) Hi G...   Jun 1 2007, 12:36
|- - ociec   QUOTE (aurelio @ May 31 2007, 17:23) My a...   Jun 2 2007, 12:46
|- - Grzesio   QUOTE (ociec @ Jun 2 2007, 12:46) I have...   Jun 3 2007, 22:01
|- - ociec   QUOTE (Grzesio @ Jun 3 2007, 15:01) What ...   Jun 4 2007, 21:21
|- - Grzesio   QUOTE (ociec @ Jun 4 2007, 21:21) QUOTE (...   Jun 5 2007, 15:03
- - Grzesio   latest stablest version: foo_spdif_v1.0   Jun 5 2007, 17:07
|- - yhloh   QUOTE (Grzesio @ Jun 6 2007, 00:07) lates...   Jun 30 2007, 04:33
- - NullString   Thanks for the component! Although, when I sen...   Jun 29 2007, 22:00
|- - Grzesio   QUOTE (NullString @ Jun 29 2007, 22:00) T...   Jul 4 2007, 12:49
|- - NullString   QUOTE (Grzesio @ Jul 4 2007, 07:49) I thi...   Jul 5 2007, 04:53
- - Rozzo   Hi Grezsio, after some time of using the plugin I...   Jul 4 2007, 17:41
|- - Grzesio   QUOTE (Rozzo @ Jul 4 2007, 17:41) after s...   Jul 12 2007, 19:44
- - darkj2k   Cannot connect to d/l page too by IE7 & Firefo...   Jul 9 2007, 15:21
|- - yhloh   QUOTE (darkj2k @ Jul 9 2007, 22:21) Canno...   Jul 14 2007, 05:27
|- - Grzesio   QUOTE (yhloh @ Jul 14 2007, 05:27) QUOTE ...   Jul 16 2007, 10:42
|- - yhloh   I forgot to use proxy server in Poland. 87.239.177...   Jul 17 2007, 00:49
- - mlanglois   Thanks for this GREAT plugin! Unfortunately th...   Jul 10 2007, 14:37
|- - Grzesio   QUOTE (mlanglois @ Jul 10 2007, 14:37) Th...   Jul 12 2007, 20:11
- - gogo   Thanks for this nice plugin. Passing DTS streams v...   Jul 28 2007, 13:30
|- - Grzesio   QUOTE (gogo @ Jul 28 2007, 13:30) Thanks ...   Aug 3 2007, 00:59
|- - isamu   QUOTE (Grzesio @ Aug 2 2007, 23:59) I wil...   Aug 14 2007, 11:49
|- - Grzesio   QUOTE (isamu @ Aug 14 2007, 11:49) I woul...   Aug 14 2007, 20:33
- - Grzesio   Release v1.1 is available. Now you can choose bet...   Aug 22 2007, 12:29
|- - isamu   QUOTE (Grzesio @ Aug 22 2007, 04:29) Rele...   Aug 22 2007, 14:27
|- - Grzesio   QUOTE (isamu @ Aug 22 2007, 14:27) Grzesi...   Aug 22 2007, 18:10
- - Grzesio   Release v1.2 is available.   Aug 23 2007, 15:32
- - yhloh   proxy server for those who live in taiwan 195.116....   Aug 24 2007, 05:10
- - Grzesio   What a rush, v1.3 released   Aug 24 2007, 11:59
- - ontherocks   I tried to use your plugin with Foobar v0.9.4.3 ...   Aug 24 2007, 16:46
|- - Grzesio   QUOTE (ontherocks @ Aug 24 2007, 16:46) I...   Aug 24 2007, 21:44
|- - VinVen   QUOTE (Grzesio @ Aug 24 2007, 15:44) QUOT...   Jul 12 2008, 01:23
|- - VinVen   QUOTE (VinVen @ Jul 11 2008, 19:23) QUOTE...   Jul 12 2008, 13:20
- - ontherocks   Yes I tried that. Uninstalled foobar, the director...   Aug 25 2007, 00:52
- - David Nordin   Is there no way to get RAW or PCM output? For exam...   Nov 2 2007, 16:24
- - chmv   First, many thank for plugin!!! But I...   Dec 6 2007, 10:27
|- - Grzesio   QUOTE (chmv @ Dec 6 2007, 10:27) But I an...   Dec 18 2007, 12:31
- - Grzesio   Sorry for my absence but I am very busy lately Q...   Dec 15 2007, 16:34
|- - tommypeters   QUOTE (Grzesio @ Dec 15 2007, 17:34) Sorr...   Feb 26 2009, 17:25
- - theseBoetz   When I play either a .DTS or an .AC3 file in Fooba...   May 14 2008, 08:44
|- - OpaJo0   QUOTE (theseBoetz @ May 14 2008, 01:44) W...   May 15 2008, 21:40
|- - dts-fan   QUOTE (OpaJo0 @ May 15 2008, 21:40) QUOTE...   Nov 10 2008, 03:17
|- - Sazzily   Hiya, I am rather new to all of this.. but have g...   Nov 21 2008, 16:14
- - theseBoetz   I have an Audigy 2 NX as well, could it be that th...   May 16 2008, 13:04
- - Madsly   Plz, upload v1.3 to rapidshare (or anywhere else)...   Jun 6 2008, 10:24
- - Madsly   http://www.mamboo.ru/media/foobar2000/foo_spdif_1....   Jun 6 2008, 11:24
|- - Blualeono   QUOTE (Madsly @ Jun 6 2008, 04:24) http:/...   Aug 22 2008, 20:06
- - Shayne   Hi I had this working no problem for my ambisonic...   Jun 22 2008, 16:17
- - Shayne   Bump Just wondering if anyone has this working wi...   Jun 29 2008, 23:34
|- - Shayne   QUOTE (Shayne @ Jun 29 2008, 18:34) Bump ...   Jul 5 2008, 17:47
- - Mang1   Hi, Still having troubles with proper speed of pl...   Jul 20 2008, 11:04
- - Slipstreem   The link still works fine for me. Give it another ...   Aug 22 2008, 20:20
- - Tadas   Thanks for this dll, but I still got some issues. ...   Oct 5 2008, 10:11
- - conquerist   First off, thanks Grzesio, this is the first time ...   Jan 12 2009, 08:52
|- - infirmus   QUOTE (conquerist @ Jan 12 2009, 17:52) F...   Jan 14 2009, 06:46
- - roman2   Hi, I'de really like to use foo_spdif to pass...   Jun 20 2009, 15:29
- - Madsly   Grzesio: Can you fix a problem of freezing zooba...   Jul 24 2009, 22:16
- - Kick29   Hi all, Is there any chance to see this plugin po...   Aug 2 2010, 14:34
- - Grzesio   Hi... I had a few minutes so I modified spdif plu...   May 22 2011, 15:48
|- - Sandrine   QUOTE (Grzesio @ May 22 2011, 16:48) I ha...   May 22 2011, 16:27
|- - Polouess   hi. first, thanks for porting this plugin. however...   Jun 28 2011, 09:30
- - mudlord   QUOTE completely disabling the DSP in- and output ...   May 22 2011, 22:51
- - lvqcl   QUOTE do I need any additional MSVC*.dll? Yes, it...   Jun 28 2011, 16:30
|- - Polouess   QUOTE (lvqcl @ Jun 28 2011, 17:30) QUOTE ...   Jul 2 2011, 09:59
- - murrko   aww, http://ga.cba.pl/ is down for several days......   Feb 7 2012, 18:41
- - banan   Hello. I have a cheap plug-and-play USB sound card...   Mar 10 2012, 15:46
- - banan   I just tried foo_spdifer.dll -- and to my surprise...   Mar 10 2012, 16:08
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 31st January 2015 - 18:57
