TAK support for OggdropXPd, is it possible?
gottkaiser
post Apr 12 2007, 21:53
Hello,
I love using OggdropXPd with FLAC. And now the TAK SDK is out.
So I thought maybe it is possible create a TAK Plugin for OggdropXPd or an extra compile?
I'm sure, a lot of user would like to have an easy way to transcode from lossless TAK to the lossy OGG.
Not quite sure if it's possible. Maybe you know?
Thanks in Advance!
TBeck
post Apr 12 2007, 22:32
TAK Developer
QUOTE (gottkaiser @ Apr 12 2007, 21:53) *
Unfortunately i don't know OggdropXPd, but if it's an windows application and only TAK-decoding functionality is needed for your purpose, the TAK library should provide anything needed.
Thomas
gaekwad2
post Apr 13 2007, 10:27
QUOTE (TBeck @ Apr 12 2007, 23:32) *
Yes and (mostly*) yes.
It's a drag-and-drop Vorbis encoder.
*also tag reading, so unicode tags (written with eg. foobar) might be a problem
This post has been edited by gaekwad2: Apr 13 2007, 10:28
rjamorim
post Apr 13 2007, 12:13
Rarewares admin
Well, OggDropXPd is GPL, and the TAK library is not (yet) GPL-compatible.
Then again, Monkey's Audio, LPAC and OptimFrog are supported in OggDrop, and none of these is GPL compatible either.
So, ummmm...
http://www.rarewares.org
TBeck
post Apr 13 2007, 13:17
TAK Developer
QUOTE (gaekwad2 @ Apr 13 2007, 10:27) *
The TAK SDK provides functions for reading APEv2 tags.
IrfCore
post May 7 2011, 09:26
So now four years later, is there any TAK support for OggDrop?
Cantrip
post Apr 9 2012, 06:21
As a previous user of OggDrop, I also was looking for a similar solution since switching to Tak for lossless storage.
I found LameXP 3.18 to directly convert Tak to Aac for Iphone listening with one-click. It does not have a drop pad, but is very easy to use.
You can download LameXP 3.18 hotfix2 here:
http://forum.ru-board.com/topic.cgi?forum=...700&start=8
Sadly LameXP discontinued support for Tak with version 4.0 (which has the cool drop pad mode I was originally looking for) due to lack of Unicode support (whatever that is). LameXP 3.18 is the lastest version with Tak support.
DonP
post Apr 9 2012, 12:38
Group: Members (Donating)
QUOTE (Cantrip @ Apr 9 2012, 01:21) *
Short description is extended alphabet to support many languages.
Cantrip
post Apr 10 2012, 06:20
Thanks for the simple explaination Don.
Features of TAK DirectShow Source Filter:
- Playback TAK audio files in any DirectShow Player (Windows Media Player, MediaPlayerClassic, )
- Now supporting TAK 2.2.0 (multi-channel audio, )
- Support UNICODE filenames and Sample Rates > 44.1 KHz
- Now correctly works in Windows 7 64bit ! (and other 64bit Windows versions)
Perhaps MuldeR can now add TAK support to the latest LameXP. Then TAK would have the simple drop pad convertor, and also an easy GUI for direct Apple AAC conversion (I have been using Nero AAC).
CoRoNe
post Apr 19 2012, 20:12
All of that no problem for the DC-Bass Source Mod as well.
DC-Bass Source Mod: http://reino.degeelebosch.nl
RSS Lo-Fi Version Time is now: 27th January 2015 - 20:15
