10 Pages V  « < 4 5 6 7 8 > »
foo_input_tak, TAK decoder
Case
post Apr 13 2009, 08:14
Post #126
Group: Developer (Donating)
That file works just fine after you replace tak_deco_lib.dll in foobar2000 folder with updated version.
tedgo
post May 28 2009, 09:59
Post #127
I created some TAK files with md5 checksum today, but foobar2000 0.9.6.7 properties doesn't recognise md5 info.
I verified the files with TAK.exe and the checksum is present.
Is it a known issue of foo_input_tak or tak_deco_lib?
I have TAK 1.1.1.0 and the tak_deco_lib.dll shipped with it, and the latest foo_input_tak.dll.
Used this parameter: -e -p4m -md5 -ihs - %d
This post has been edited by tedgo: May 28 2009, 10:00
foosion
post Jun 15 2009, 22:10
Post #128
Group: FB2K Moderator (Donating)
foo_input_tak 0.4.3
The component now supports damage reporting for the file integrity verifier. It now also comes with tak_deco_lib.dll 1.1.1. Enjoy!
kanak
post Jun 17 2009, 17:34
Post #129
Hi foosion,
I was wondering if you could add support for displaying the MD5 hash of the audio data in the properties dialog, as supported by tak 1.1.1 onwards.
foosion
post Jun 18 2009, 00:07
Post #130
I don't see how to extract this information using the TAK SDK.
TBeck
post Jun 18 2009, 08:21
Post #131
TAK Developer
QUOTE (foosion @ Jun 15 2009, 22:10) *
foo_input_tak 0.4.3
QUOTE (kanak @ Jun 17 2009, 17:34) *
QUOTE (foosion @ Jun 18 2009, 00:07) *
That's right...
Probably i will add metadata read functions to the next SDK (V1.1.3) release.
Thomas
This post has been edited by TBeck: Jun 18 2009, 08:21
Kamigari
post Sep 25 2009, 03:51
Post #132
Hi, the zip archive of the plugin being hosted on the foobar site is corrupted (and there were a few more like that... can't remember which ones were corrupted atm), so could you re-upload the plugin? Thanks
kode54
post Sep 25 2009, 09:37
Post #133
Group: Admin
QUOTE (Kamigari @ Sep 24 2009, 19:51) *
I just tested the archive linked here as well as foosion's components site here, and both verify fine with WinRAR.
Kamigari
post Sep 27 2009, 14:41
Post #134
Hmm, you're right. I guess its just a bug in Alzip instead.
Mr.Duck
post Dec 8 2009, 20:28
Post #135
QUOTE (kode54 @ Sep 25 2009, 08:37) *
zip file is corrupt. Cannot unpack with windows XP or with servant salamander. Only the "tak_deco_lib.dll" file fails to unpack. I got the latest version from Thomas Beck homepage instead.
Mr.Duck
post Dec 8 2009, 20:34
Post #136
crap, now I get a... "Unrecoverable playback error: Class not registered" error message sad.gif
This post has been edited by Mr.Duck: Dec 8 2009, 20:34
Mr.Duck
post Dec 8 2009, 21:30
Post #137
QUOTE (Mr.Duck @ Dec 8 2009, 19:34) *
Don't know what happened there. I just did a fresh foobar installation with v0.9.6.9 and used 7zip to get unpack the corrupt zip archive. Now it works smile.gif
mudlord
post Dec 8 2009, 23:08
Post #138
QUOTE (Mr.Duck @ Dec 8 2009, 13:28) *
Not corrupt. Works here fine. Must be a issue with how the file is packed and the compression method used.
_mē_
post Dec 19 2009, 13:05
Post #139
yerma
post Dec 19 2009, 14:04
Post #140
QUOTE (_mē_ @ Dec 19 2009, 13:05) *
TAK playback works. I'm no programmer, but it seems that the TAK API of the deco-lib didn't change, so there's no need for an updated input plugin.
foosion
post Dec 19 2009, 14:30
Post #141
Even if the API has been modified or extended, I haven't seen a new TAK SDK yet. Thomas said he wants to release an updated SDK together with TAK 2.0 final.
TBeck
post Dec 19 2009, 21:35
Post #142
TAK Developer
QUOTE (foosion @ Dec 19 2009, 14:30) *
I haven't modified the API with this release. The new library should be 100% compatible. But it's still a beta...
Iskatar
post Feb 11 2010, 07:56
Post #143
Now this is odd. I did a fresh install of the newest version of foobar and slapped in the latest TAK Decoder and I'm getting a "Unable to open item for playback (Unsupported file format)" error. Anyone know what the problem is?
GeSomeone
post Feb 11 2010, 14:10
Post #144
You should place the TAK decoder library in de foobar2000 program directory.
In theory, there is no difference between theory and practice.
Iskatar
post Feb 11 2010, 21:34
Post #145
QUOTE (GeSomeone @ Feb 11 2010, 14:10) *
I installed it correctly, it loads... but it just doesn't work.
Iskatar
post Feb 12 2010, 22:09
Post #146
QUOTE (Iskatar @ Feb 11 2010, 21:34) *
Alright, I uninstalled it and restarted my computer, then reinstalled it. It works now. Great.
tgckpg
post Jan 10 2011, 18:55
Post #147
I got error when installing...
Failed to load DLL: foo_input_tak.dll
I'm using v1.1.1.
This post has been edited by tgckpg: Jan 10 2011, 18:56
PrimulaRosea
post Jan 11 2011, 03:06
Post #148
put tak_deco_lib.dll in foobar2000 root folder
Case
post Jan 11 2011, 18:48
Post #149
The new easier and preferred way to install components is documented here.
johnsonlam
post Jan 20 2011, 19:47
Post #150
To Foosion,
QUOTE (GeSomeone @ Jan 13 2011, 17:11) *
QUOTE (johnsonlam @ Jan 13 2011, 05:32) *
QUOTE (TBeck @ Jan 10 2011, 19:50) *
1) Support for HDCD bit recognition
I don't think this is the business of a lossless codec...
My reason is simple, because the HDCD decoding through Foobar2000 not working, whenever not working should be fixed, of course it's the lowest priority, and I'm not programmer, can't help even if I want to.
TBeck is right, every lossless codec just keeps the HDCD control bits and that's it. I think what you really mean has to do with the foobar2000 TAK decoder plugin, it should be made postprocessor aware (as should still be done with the ALAC and Monkey decoders). Maybe you should file your request with foosion, who was so kind to provide the foobar input plugin for TAK.
Thank you for directing me to foosion, I really need your explain to know the problem.
And thanks Thomas for the hard work.
Can you please improve the plugin and let Foobar2000 to detect HDCD encode with TAK?
Sorry but I know nothing about programming, but I can help to test.
Hong Kong - International Joke Center (after 1997-06-30)
RSS Lo-Fi Version Time is now: 3rd August 2015 - 10:42
