foo_input_tak, TAK decoder
foosion
post Apr 11 2007, 22:12
Group: FB2K Moderator (Donating)
TAK decoder plugin for foobar2000 0.9.4 and newer.
Supports playback and tagging. No special support for recovery of damaged TAK files. Version 0.2 uses functions from the foobar2000 SDK to access APEv2 tags instead of the functions provided by the TAK SDK.
The component can be downloaded from my components page.
yerma
post Apr 21 2007, 17:33
As I said, I will happily test it on monday, as I have no multicore machine within reach until then.
- foosion   foo_input_tak   Apr 11 2007, 22:12
- - Matyas   can I be the first to say thank you? I guess so. T...   Apr 11 2007, 22:52
- - spived   Thank you, it works!   Apr 11 2007, 23:04
- - Brydenn33   You are my hero! Thank you   Apr 12 2007, 01:04
- - kanak   QUOTE (foosion @ Apr 12 2007, 03:12) TAK ...   Apr 12 2007, 01:36
- - TBeck   QUOTE (foosion @ Apr 11 2007, 22:12) TAK ...   Apr 12 2007, 04:30
- - gib   *pumps fist* Thank you foosion. I've been lo...   Apr 12 2007, 09:32
- - Skorzeny1   Probably my first post here: THANK YOU!!...   Apr 12 2007, 10:08
- - ssjkakaroto   Nice one foosion, thanks! B)   Apr 12 2007, 12:08
- - Skorzeny1   Something strange is happening ;.tak-plugin works ...   Apr 12 2007, 14:47
- - Synthetic Soul   I don't really understand about the reinstall ...   Apr 12 2007, 15:12
|- - Skorzeny1   QUOTE (Synthetic Soul @ Apr 12 2007, 16:1...   Apr 12 2007, 15:40
- - kanak   @Skorzeney Stupid question but, are you using foo...   Apr 12 2007, 15:15
- - $char(9836)   When I transcode to tak in foobar converter the ta...   Apr 12 2007, 18:13
- - Synthetic Soul   Are you sure it's not the WAVE to TAK conversi...   Apr 12 2007, 18:20
- - ssjkakaroto   It's probably because TAK needs a completely d...   Apr 12 2007, 18:20
- - $char(9836)   Oh, I thought the wav conversation was included in...   Apr 12 2007, 18:27
- - kanak   Foobar crashes when tagging large number of files ...   Apr 13 2007, 03:04
- - foosion   foo_input_tak 0.2.1 Recompiled against final TAK ...   Apr 13 2007, 08:52
- - HisInfernalMajesty   Anyway to add the ability to allow embedded cueshe...   Apr 14 2007, 05:02
- - randal1013   thanks!   Apr 14 2007, 05:47
- - kanak   This is the only crash i have had after upgrading ...   Apr 15 2007, 03:45
|- - TrNSZ   kanak, have you tried updating to tak_deco_lib 1.0...   Apr 16 2007, 06:27
|- - kanak   QUOTE (TrNSZ @ Apr 16 2007, 11:27) kanak,...   Apr 16 2007, 06:31
|- - gaekwad2   QUOTE (TrNSZ @ Apr 16 2007, 07:27) A few ...   Apr 16 2007, 10:38
- - GeSomeone   There is a beta now of 0.9.4.3 from the change li...   Apr 16 2007, 11:21
- - foosion   QUOTE (TrNSZ @ Apr 16 2007, 07:27) A few ...   Apr 16 2007, 11:37
|- - TBeck   QUOTE (foosion @ Apr 16 2007, 11:37) QUOT...   Apr 16 2007, 22:22
- - FixXx   hi foosion, integrating some more encoder-informa...   Apr 16 2007, 14:27
|- - foosion   QUOTE (FixXx @ Apr 16 2007, 15:27) integr...   Apr 16 2007, 16:47
- - foosion   foo_input_tak 0.3 Bundled tak_deco_lib.dll 1.0.2....   Apr 17 2007, 00:08
|- - kanak   QUOTE (foosion @ Apr 17 2007, 05:08) foo_...   Apr 17 2007, 00:42
|- - FixXx   QUOTE (foosion @ Apr 16 2007, 17:08) foo_...   Apr 17 2007, 10:07
- - Scidd0w   QUOTE (foosion @ Apr 16 2007, 15:08) foo_...   Apr 17 2007, 08:28
- - A_Man_Eating_Duck   TAK v3 and Foobar v9.4.3b crashed when i was repla...   Apr 17 2007, 10:56
- - foosion   To anyone experiencing crashes: Can you reproduce ...   Apr 18 2007, 18:54
|- - kanak   QUOTE (foosion @ Apr 18 2007, 23:54) To a...   Apr 19 2007, 02:23
|- - Squeller   QUOTE (kanak @ Apr 18 2007, 17:23) Let...   Apr 19 2007, 06:29
|- - kanak   QUOTE (Squeller @ Apr 19 2007, 11:29) QUO...   Apr 19 2007, 06:49
- - TBeck   I have thought about possible sources for the erro...   Apr 18 2007, 19:44
- - foosion   foo_input_tak 0.3.1 TAK decoder is closed and reo...   Apr 19 2007, 10:44
|- - kanak   QUOTE (foosion @ Apr 19 2007, 15:44) foo_...   Apr 19 2007, 15:24
- - urlwolf   Ok, I think I found a problem, but I'm not sur...   Apr 20 2007, 01:53
- - foosion   QUOTE (kanak @ Apr 19 2007, 16:24) Is it ...   Apr 20 2007, 16:38
|- - yerma   QUOTE (foosion @ Apr 20 2007, 17:38) That...   Apr 20 2007, 17:09
- - yerma   OK, I'm back. The crashes mentioned above hap...   Apr 20 2007, 18:39
|- - TBeck   QUOTE (yerma @ Apr 20 2007, 18:39) For a ...   Apr 21 2007, 14:18
|- - TBeck   QUOTE (TBeck @ Apr 21 2007, 14:18) I foun...   Apr 21 2007, 17:08
- - yerma   As I said, I will happily test it on monday, as I ...   Apr 21 2007, 17:33
|- - TBeck   QUOTE (yerma @ Apr 21 2007, 17:33) As I s...   Apr 21 2007, 19:19
- - Squeller   With your new decoding library, the (dynamic) bitr...   Apr 21 2007, 22:09
|- - TBeck   TAK Decoding library 1.0.4 is out: TAK Decoding l...   Apr 21 2007, 23:22
|- - Squeller   QUOTE (TBeck @ Apr 21 2007, 14:22) That...   Apr 23 2007, 13:23
|- - Spirit_of_the_ocean   Could someone create a TAK Icon that fits to the ...   Apr 23 2007, 16:51
- - Gnerma   I've got a possible bug for you foosion. After...   Apr 22 2007, 03:20
|- - foosion   QUOTE (Gnerma @ Apr 22 2007, 04:20) I...   Apr 24 2007, 20:17
|- - Gnerma   QUOTE (foosion @ Apr 24 2007, 12:17) Embe...   Apr 24 2007, 20:23
- - kanak   QUOTE (TBeck @ Apr 21 2007, 17:22) QUOTE ...   Apr 22 2007, 04:39
- - yerma   As promised, I tested the new decoding library. 53...   Apr 23 2007, 10:45
- - urlwolf   foobar 9.4.3 hungs when I try to play a tak file. ...   Apr 23 2007, 19:35
- - TBeck   QUOTE (kanak @ Apr 22 2007, 04:39) QUOTE ...   Apr 23 2007, 21:32
- - manoa   is there a Tak Decode plugin for foobar version 0....   Apr 24 2007, 03:07
|- - kanak   QUOTE (manoa @ Apr 23 2007, 21:07) is the...   Apr 24 2007, 03:34
- - manoa   "this component appears to have been built wi...   Apr 24 2007, 07:00
|- - kanak   QUOTE (manoa @ Apr 24 2007, 01:00) ...   Apr 24 2007, 07:06
- - A_Man_Eating_Duck   QUOTE (manoa @ Apr 24 2007, 18:00) ...   Apr 24 2007, 10:46
- - yerma   I guess I found another bug, this time in foo_inpu...   May 7 2007, 13:36
|- - TBeck   QUOTE (yerma @ May 7 2007, 13:36) ... The...   May 7 2007, 22:03
|- - yerma   QUOTE (TBeck @ May 7 2007, 23:03) Can you...   May 8 2007, 09:07
|- - TBeck   QUOTE (yerma @ May 8 2007, 09:07) QUOTE (...   May 8 2007, 21:13
- - yerma   I did some experiments and the error is replicable...   May 9 2007, 11:44
|- - foosion   QUOTE (yerma @ May 9 2007, 12:44) I did s...   May 10 2007, 12:34
- - GeSomeone   An error I noticed, but can not reproduce at the m...   May 10 2007, 19:10
- - aeroman   Excellent, no problems to report with Rip, Tag and...   May 12 2007, 19:06
- - foosion   foo_input_tak 0.3.2 Fixed bug with reopening TAK ...   May 13 2007, 19:10
|- - TBeck   Great! Thanks for your effort! Thom...   May 14 2007, 22:04
|- - GeSomeone   QUOTE (foosion @ May 13 2007, 19:10) foo_...   May 15 2007, 17:03
- - yerma   my problem with silent tracks: FIXED! Thanks...   May 14 2007, 09:30
- - Acropolis   foosion, can you make the embedded cuesheet still ...   May 19 2007, 18:07
- - foosion   Use the "Utils/Edit Cuesheet" command.   May 19 2007, 18:40
|- - Acropolis   QUOTE (foosion @ May 20 2007, 03:40) Use ...   May 20 2007, 13:42
- - eevan   I've found the problem with the Secret Rabbit ...   May 19 2007, 20:05
- - IrfCore   I noticed a small issue in foobar with TAK Decoder...   Jun 21 2007, 12:04
- - musicmusic   BTW foosion, slight OT but I was using application...   Oct 4 2007, 15:59
|- - foosion   QUOTE (musicmusic @ Oct 4 2007, 16:59) BT...   Oct 4 2007, 17:37
- - musicmusic   QUOTE (foosion @ Oct 4 2007, 17:37) I mov...   Oct 4 2007, 17:48
- - foosion   I've tested takc.exe with the application veri...   Oct 4 2007, 18:18
- - TBeck   QUOTE (musicmusic @ Oct 4 2007, 15:59) BT...   Oct 4 2007, 19:03
- - musicmusic   QUOTE (TBeck @ Oct 4 2007, 19:03) Thank y...   Oct 4 2007, 22:45
- - Squeller   Hi foosion, AFAIR you wanted to do some decoding p...   Nov 5 2007, 09:35
- - foosion   No, my only idea was to always decode one frame at...   Nov 5 2007, 12:01
- - foosion   foo_input_tak 0.3.4 Recompiled with latest TAK SD...   Nov 9 2007, 01:01
|- - Spirit_of_the_ocean   Thanks a lot   Nov 9 2007, 01:22
- - Audio_Adepta   Im not sure if this is a problem specifically with...   Jan 16 2008, 16:48
- - eevan   It retains only standard fields. This is a user co...   Jan 16 2008, 16:58
- - alvaro84   Hm, I just tried to search for this thing in this ...   Mar 5 2008, 15:04
|- - foosion   QUOTE (alvaro84 @ Mar 5 2008, 15:04) So, ...   Mar 5 2008, 16:56
- - alvaro84   Thanks for the answers - the performance isn't...   Mar 5 2008, 18:16
- - foosion   foo_input_tak 0.4 Adds the ability to read embedd...   Mar 9 2008, 17:32
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 1st August 2015 - 11:56
