ARCue.pl - Check whole CD rips with AccurateRip
Christopher Key
post Mar 21 2007, 09:39
Hello All,
I've throw together a pure perl script that calculates the track checksums for a cue/wav file pair and then checks them against the AccurateRip database. It's available from:
http://www.srcf.ucam.org/~cjk32/ARCue/ARCue.pl
Simply save it somewhere sensible, and from a command prompt, run:
ARCue.pl file1.cue file2.cue ...
A few points to bear in mind:
1) This is written in pure perl, so is quite slow, maybe 30s per track. If any perl gurus have any tips of speeding it up, they'd be much appreciated.
2) The range of cue files supported is probably very limited. It works with those generated by EAC. If it doesn't work with yours, please let me know.
3) The script relies on 32bit integer arithmetic, so I'm not sure how it'll behave on 64bit systems, any feedback will be gratefully recieved.
4) For reasons I can't fathom, approx 1 in 30 tracks checksums are incorrectly calculated. If a track is reported as inaccurately ripped, try running again before reripping. If anyone can shed any light on what might be going on, I'd be very grateful. So far, I can discern no noticable pattern as to when it happens.
Finally, as noted in the script, please read,
http://www.accuraterip.com/3rdparty-access.htm
before use.
Chris Key
wraithdu
post Mar 27 2007, 04:28
For the programming uninitiated, how do you go about installing Perl to use this script?
Oh, and if someone has a good way to integrate this into the REACT2 config for FLAC images, that would be great too.
This post has been edited by wraithdu: Mar 27 2007, 04:29
- Christopher Key   ARCue.pl - Check whole CD rips with AccurateRip   Mar 21 2007, 09:39
- - gib   I have not tried it, but it sounds very cool. I s...   Mar 21 2007, 11:09
|- - bhoar   I agree, very cool. Something I am likely to take...   Mar 23 2007, 13:50
- - ssjkakaroto   Sounds very good Christopher. Now AccurateRip can ...   Mar 23 2007, 15:40
- - brainsoft   This is exactly what I've been looking for, an...   Mar 26 2007, 22:12
- - brainsoft   Do you know if there are any particular settings t...   Mar 27 2007, 02:57
|- - Christopher Key   QUOTE (brainsoft @ Mar 27 2007, 01:57) Do...   Mar 27 2007, 18:39
|- - brainsoft   QUOTE (Christopher Key @ Mar 27 2007, 13...   Mar 28 2007, 00:13
- - gib   I finally got around to installing Perl and gave t...   Mar 27 2007, 04:20
- - wraithdu   For the programming uninitiated, how do you go abo...   Mar 27 2007, 04:28
|- - gib   QUOTE (wraithdu @ Mar 26 2007, 17:28) For...   Mar 27 2007, 04:55
|- - g30rge   QUOTE (gib @ Mar 27 2007, 04:55) QUOTE (w...   Jul 15 2007, 14:51
|- - David256   QUOTE (g30rge @ Jul 15 2007, 08:51) For t...   Jul 15 2007, 21:57
- - caligae   First of all big thanks. I've started using Ac...   Mar 27 2007, 12:12
|- - Christopher Key   [quote name='caligae' post='481280' date='Mar 27 2...   Mar 27 2007, 21:22
|- - caligae   QUOTE (Christopher Key @ Mar 27 2007, 22...   Mar 28 2007, 08:27
||- - Christopher Key   QUOTE (caligae @ Mar 28 2007, 07:27) QUOT...   Mar 30 2007, 08:40
||- - caligae   QUOTE (Christopher Key @ Mar 30 2007, 09...   Mar 30 2007, 13:03
||- - Christopher Key   QUOTE (caligae @ Mar 30 2007, 12:03) Have...   Mar 31 2007, 16:31
|- - Jose Hidalgo   QUOTE (Christopher Key @ Mar 27 2007, 21...   Feb 18 2008, 18:03
|- - Omy   QUOTE (Jose Hidalgo @ Feb 18 2008, 17:03)...   Feb 18 2008, 20:10
|- - Jose Hidalgo   Well, back to my previous post then : QUOTE (Omy...   Feb 19 2008, 19:04
|- - mr-b   QUOTE (Jose Hidalgo @ Feb 19 2008, 18:04)...   Feb 25 2008, 16:06
- - greynol   Besides the lengths of all the tracks, the start p...   Mar 27 2007, 18:48
- - caligae   I was able to verify a multiple files rip. First c...   Mar 27 2007, 19:21
- - greynol   Check my previous post. A data track will influen...   Mar 27 2007, 19:25
- - caligae   QUOTE (Christopher Key @ Mar 21 2007, 10...   Mar 27 2007, 20:44
- - madxcream   Great program. I found a cd that doesn't have ...   Mar 31 2007, 02:04
|- - Christopher Key   QUOTE (madxcream @ Mar 31 2007, 01:04) di...   Mar 31 2007, 16:20
- - madxcream   I have another problem with a cd I just tried. Wit...   Mar 31 2007, 14:28
|- - Christopher Key   QUOTE (madxcream @ Mar 31 2007, 13:28) I ...   Mar 31 2007, 15:44
|- - Christopher Key   QUOTE (Christopher Key @ Mar 31 2007, 14...   Mar 31 2007, 16:46
|- - madxcream   QUOTE (Christopher Key @ Mar 31 2007, 10...   Mar 31 2007, 17:35
|- - Christopher Key   QUOTE (madxcream @ Mar 31 2007, 16:35) CO...   Mar 31 2007, 20:19
|- - madxcream   QUOTE (Christopher Key @ Mar 31 2007, 14...   Mar 31 2007, 21:31
|- - Christopher Key   Hi Kevin, Right, EAC is getting the file, dBAR-0...   Apr 1 2007, 12:38
- - madxcream   The other problem I had with ARCue having the wron...   Mar 31 2007, 17:45
- - madxcream   Hey Chris, here is the info you wanted: Cueshee...   Apr 1 2007, 17:21
|- - Christopher Key   QUOTE (madxcream @ Apr 1 2007, 16:21) COD...   Apr 1 2007, 20:26
- - madxcream   Confirmed to work, thanks Chris!   Apr 1 2007, 21:20
- - madxcream   found another problem one: EAC disc ID: [Disc ID:...   Apr 1 2007, 21:36
|- - Christopher Key   QUOTE (madxcream @ Apr 1 2007, 20:36) fou...   Apr 1 2007, 22:17
|- - madxcream   QUOTE (Christopher Key @ Apr 1 2007, 16:1...   Apr 1 2007, 22:57
- - madxcream   Chris, are you still working on getting ARCue to w...   Apr 12 2007, 19:10
|- - Christopher Key   QUOTE (madxcream @ Apr 12 2007, 19:10) Ch...   Apr 15 2007, 21:35
|- - madxcream   QUOTE (Christopher Key @ Apr 15 2007, 15...   Apr 15 2007, 23:19
- - brainsoft   Has any more work been done on producing a faster/...   May 2 2007, 01:25
|- - brainsoft   QUOTE (brainsoft @ May 1 2007, 20:25) Has...   May 2 2007, 23:13
- - wraithdu   I'd like to integrate this into my REACT2 conf...   May 3 2007, 02:45
|- - madxcream   QUOTE (wraithdu @ May 2 2007, 20:45) I...   May 3 2007, 20:14
- - wraithdu   Getting arcue to scan the ripped WAV image is no p...   May 4 2007, 04:13
|- - madxcream   QUOTE (wraithdu @ May 3 2007, 22:13) If s...   May 4 2007, 19:48
|- - brainsoft   QUOTE (madxcream @ May 4 2007, 14:48) QUO...   May 7 2007, 04:29
- - Antonski   QUOTE (brainsoft @ May 3 2007, 01:13) If ...   May 4 2007, 10:40
- - wraithdu   This is EXACTLY what I've been looking for. T...   May 7 2007, 04:46
- - brainsoft   If anyone's interested here are my files. I h...   May 7 2007, 04:51
- - wraithdu   megaupload works for me, or rapidshare I suppose. ...   May 9 2007, 05:31
- - wraithdu   I made a few additions to your scripts to write th...   May 11 2007, 05:02
|- - brainsoft   QUOTE (wraithdu @ May 11 2007, 00:02) add...   May 16 2007, 23:31
- - wraithdu   My latest additions to my REACT2 code: REACT.ini ...   May 18 2007, 01:14
|- - brainsoft   Nice work. For anyone interested arcue.pl has bee...   May 22 2007, 10:44
|- - madxcream   QUOTE (brainsoft @ May 22 2007, 04:44) Ni...   May 22 2007, 19:47
|- - brainsoft   QUOTE (madxcream @ May 22 2007, 14:47) QU...   May 22 2007, 22:35
|- - Christopher Key   QUOTE (brainsoft @ May 22 2007, 22:35) QU...   May 23 2007, 00:08
- - madxcream   I have a question. Does EAC using accruaterip down...   May 23 2007, 19:39
|- - Christopher Key   QUOTE (madxcream @ May 23 2007, 19:39) I ...   May 24 2007, 10:33
- - brainsoft   I think we need a logfile switch arcue.pl source....   May 28 2007, 03:40
- - wraithdu   A logfile option would be great. I wasn't tot...   May 29 2007, 21:09
|- - jnc   So, what is the AccurateRip algo anyways? Best I c...   Jun 4 2007, 01:53
- - valnar   To everyone who contributed to the ARCue.pl script...   Jun 13 2007, 02:48
- - valnar   wraithdu, I'm having one problem with a disc ...   Jun 18 2007, 11:29
|- - wraithdu   QUOTE (valnar @ Jun 18 2007, 05:29) wrait...   Jun 20 2007, 18:00
|- - wraithdu   QUOTE (wraithdu @ Jun 20 2007, 12:00) QUO...   Jun 21 2007, 00:59
- - Fandango   Hello guys, I have a request and I'm hoping yo...   Jul 4 2007, 19:12
|- - David256   QUOTE (Fandango @ Jul 4 2007, 13:12) Can ...   Jul 10 2007, 07:18
|- - Fandango   QUOTE (David256 @ Jul 10 2007, 08:18) I h...   Jul 15 2007, 00:38
|- - David256   QUOTE (Fandango @ Jul 14 2007, 18:38) Btw...   Jul 15 2007, 21:28
|- - No Fun   QUOTE (David256 @ Jul 16 2007, 00:28) QUO...   Dec 27 2007, 16:30
|- - Omy   QUOTE (David256 @ Jul 15 2007, 20:28) QUO...   Feb 11 2008, 22:09
- - wraithdu   Does your patched version fix the errorlevel retur...   Jul 14 2007, 02:26
|- - David256   QUOTE (wraithdu @ Jul 13 2007, 20:26) Doe...   Jul 15 2007, 21:18
- - micmac   Hello all, I tried the updated script from David2...   Jul 15 2007, 01:31
- - Fandango   ARCue.pl only supports single WAV rips. You'll...   Jul 15 2007, 02:16
|- - micmac   QUOTE (Fandango @ Jul 14 2007, 19:16) ARC...   Jul 15 2007, 13:31
- - Synthetic Soul   I'm confused. I though the release of 0.99 pr...   Jul 15 2007, 22:06
- - spoon   >What does this script provide that the new EAC...   Jul 15 2007, 22:17
- - Fandango   Yes, imagine you have ripped hundreds of CDs witho...   Jul 15 2007, 23:09
- - Synthetic Soul   Thanks guys. It's funny, installing the new ...   Jul 16 2007, 07:39
- - Fandango   I think it's a very cool thing that EAC now co...   Jul 16 2007, 15:56
- - greynol   ...except that there are some bugs that need to ge...   Jul 16 2007, 17:17
- - Fandango   I saw your post in the EAC release thread, nasty b...   Jul 16 2007, 19:54
- - spoon   >Hopefully no one is ripping discs with gaps pr...   Jul 16 2007, 20:39
- - Sleepy   In case anyone is still trying to sort out the pro...   Jul 18 2007, 07:45
- - odyssey   Could it be made possible to check if an album nee...   Jul 30 2007, 23:41
- - Jose Hidalgo   I'd be interested in testing that script anywa...   Feb 19 2008, 10:26
- - Fandango   Jose, get an Win32 executable version here: http:/...   Feb 19 2008, 16:43
- - Jose Hidalgo   Woo-hoo ! Rock'n'roll ! Thanks...   Feb 19 2008, 18:01
- - Fandango   Nope, it will only accept whole image rips in WAV ...   Feb 19 2008, 18:13
- - Fandango   I'd love to be able to check individual files,...   Feb 25 2008, 17:49
- - Omy   QUOTE (Fandango @ Feb 25 2008, 16:49) I...   Feb 25 2008, 18:05
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 4th August 2015 - 12:00
