4 Pages V  « < 2 3 4
foo_playcount_mod, foo_playcount with silent tag updating
xan K
post Aug 17 2007, 05:05
Post #76
this plugin works like a charm! I've never seen a popup and all my songs get tagged. Only question is if it can write tags in ID3v2.3? The format it uses is ID3v2.4 and windows explorer and some other programs can't read it properly.
thanks.
kanak
post Aug 17 2007, 05:35
Post #77
QUOTE (xan K @ Aug 17 2007, 00:05) *
thanks.
It writes to ID3V2.4 because that's what foobar is using for mp3s. To change this, go to preferences -> advanced. Under tagging enable "use compatibility mode".
xan K
post Aug 17 2007, 07:18
Post #78
thanks for the reply, but there's a problem: when I select "use compatibility mode" play counts aren't written to the tag at all.
thuan
post Aug 17 2007, 09:48
Post #79
Because foobar doesn't support custom tag fields in compatibility mode (including but not limited to play_counter, first_played and last_played fields).
xan K
post Aug 17 2007, 15:13
Post #80
ok, thanks then.
pIv
post Sep 14 2007, 09:44
Post #81
I find bug in this plugin.
Official playcount store in tags last_played(first_played)_timestamp time for GMT and calculate last_played and first_played by adding time zone shift to GMT time.
My time zone is Moscow.
On PC with play_count_mod I play new song and have any time playstamps in tags (for official plugin).
On another PS with official playcount I load this song and I see first(last)_played greater real time on 4 hours - Moscow time zone shift.
That is - plugin store time stamp of current time (zone), but no GMT time.
This post has been edited by pIv: Sep 14 2007, 09:46
ladiko
post Sep 16 2007, 20:38
Post #82
cant confirm this.
for me (berlin, gmt+1, or now gmt+2 cause of the summertime) both write gmt+1 resp. gmt+2 time and not gmt.
n0obie4life
post Nov 17 2007, 08:50
Post #83
Never mind~
This post has been edited by n0obie4life: Dec 16 2007, 06:27
$char(9836)
post Dec 21 2007, 11:38
Post #84
This is a great plugin except that it seems to open & close the files 4 times, this makes my foobar freeze for about a second and it's extremely annoying, + foo_playcount 1.9.2 doesn't seem to work when I try to switch back unsure.gif
This is the log from my console:
Autoplaylists initialized in: 0:00.016778
"5 Stars" : 0:00.010447
"All Music" : 0:00.006292
Startup time : 0:03.891912
Elapsed time: 1
Audioscrobbler: Handshake successful.
Reopening played file after update: "F:\Musik\All Musik\Stephen Lynch\A Little Bit Special\05. Stephen Lynch - Special.mp3"
Audioscrobbler: Submitting 2 cached tracks...
Audioscrobbler: Submission succeeded.
I just like listening to music
kanak
post Dec 21 2007, 14:54
Post #85
You could try the other unofficial play count plugin in the meantime (foo_playback_custom).
BuZ
post Jan 3 2008, 18:48
Post #86
QUOTE ($char(9836) @ Dec 21 2007, 12:38) *
Elapsed time: 1
same problem :/ and sometimes i get such popups: "Could not write info (Sharing violation) to:"
i think these two problems are somehow connected.. or am i wrong? unsure.gif
helloterence
post Apr 4 2009, 16:01
Post #87
Sorry for bumping this, but this is the thread the designer of the skins Foobear linked to for this plugin which I have yet to figure out why it doesn't work as it should (new to Foobar2000).
As you can see, this is how the Last Played and Tracked Played should be correctly presented:
For me, I get nothing but a question mark under the specified labels:
I followed the instructions thoroughly and through many re-installations and nothing's changed. Figured I must be doing something wrong lol. I am using Foobar2000 v.0.9.5.2.
As for installing this component, I extracted both the .dll and .cpp file in the component folder. Is that not correct? Otherwise, could I get some assistance? Thanks.
tpijag
post Apr 4 2009, 16:11
Post #88
What part of not supporting panels skins do you not understand?
Yes your issue is of a different sort...but sometimes these these can get complex and no telling just where the issue is?
There is no support for your configuration here.
terry
Based on my experience here....if you insist on posting images of unsupported configurations and asking questions....your thread will be locked or your individual messages will end up in the recycle bin.
EDIT: helloterence,
You are new to foobar.
It is a great program, but can be a little trying at first. Why not start with something a little less demanding to configure. In addition to the problems you will /are having as this is an unsupported configuration, you are not using the current version of Foobar. Why spend effort running full speed on a dead end
road?
There are plenty of alternatives. This is a new one that is quite similar in look. And there are others.
http://www.hydrogenaudio.org/forums/index....showtopic=70731
This post has been edited by tpijag: Apr 4 2009, 16:32
unknownserv
post Sep 19 2009, 14:02
Post #89
Is it possible for this to write to the files contained within a cue sheet?
Symmetric
post Nov 27 2010, 22:33
Post #90
I've been hit a couple times recently with the following issue: if foobar doesn't close properly, I loose all playback statistics. This happened most recently when the power to my PC was cut. I've tried to reproduce this by killing the foobar task, but in that case the statistics seem to be saved correctly.
Help/suggestions would be much appreciated.
MC Escher
post Nov 28 2010, 01:46
Post #91
Are you sure the statistics are lost? Perhaps because of the crash the ui didn't reload the changes. Try to reload the tag info (Tagging -> Reload info from files). Another possibility is foobar crashing the moment the files are written, but that's rare.
4 Pages V  « < 2 3 4
RSS Lo-Fi Version Time is now: 1st February 2015 - 02:26
