foo_playcount_mod, foo_playcount with silent tag updating
Crusoli
post Feb 17 2007, 04:12
Hey guys,
This release is based on the unofficial playcount component:
http://www.hydrogenaudio.org/forums/index....showtopic=42625
I've always been annoyed by the popup window in foo_playcount so I modded it to supress the popups (thanks to terrestrial for sharing his code).
Unfortunately the windows still popup on some files (I can't figure out why, maybe somebody with more coding experience can take a look at the source, it's included) but it works for most.
I changed the name of the plugin because there are quite a few versions around and they are often messed up.
CURRENT VERSION:
1.0.2 (updated March 4th 2007)
CHANGES SINCE LAST VERSION:
-added option to exclude files from being processed based on file format and on whether its part of the media library or not
-added option to choose between classical playcount tags (PLAY_COUNTER, FIRST_PLAYED, LAST_PLAYED) and the official playback statistics component version (PLAY_COUNT, FIRST_PLAYED_TIMESTAMP, LAST_PLAYED_TIMESTAMP)
note: if you change the tag type the old tags will be converted into the new format on next playback. If both tag types are present in a file the current tag style will be used and the old one will be deleted.
-removed the "remove old tags" option (guess all files should be cleaned by now if necessary)
DOWNLOAD:
http://foobar.crusoli.de/foo_playcount_mod.zip
This post has been edited by Crusoli: Mar 4 2007, 23:57
Crusoli
post Feb 27 2007, 05:26
QUOTE (pIv @ Feb 17 2007, 08:09) *
Also my sugesstion is convert official tags (last_played_timestamp, first_played_timestamp, play_count) if it present to last_played, first_played and play_counter.
Hm, where exactly do I find the plugin using those tag standards?
- Crusoli   foo_playcount_mod   Feb 17 2007, 04:12
- - Kiteroa   Thanks. Unfortunately I get the following error m...   Feb 17 2007, 06:55
- - Mangix   use 0.9. my guess is that you're using 0.8   Feb 17 2007, 07:25
- - pIv   I confirm Kiteroa post. Version of Foobar is 0.9.4...   Feb 17 2007, 08:09
|- - Kiteroa   My version of Foobar is 0.9.4.2.   Feb 17 2007, 08:10
- - orchid   I'm getting the same error. As for the officia...   Feb 17 2007, 11:12
- - Andreasvb   I'm getting this error: CODEFailed to load DLL...   Feb 17 2007, 14:21
- - Frank Bicking   QUOTE (Crusoli @ Feb 17 2007, 04:12) This...   Feb 17 2007, 14:57
- - Crusoli   QUOTE (Frank Bicking @ Feb 17 2007, 14:57...   Feb 17 2007, 15:50
|- - Andreasvb   QUOTE (Crusoli @ Feb 17 2007, 15:50) @and...   Feb 17 2007, 16:10
|- - Frank Bicking   QUOTE (Crusoli @ Feb 17 2007, 15:50) Ther...   Feb 17 2007, 16:11
- - Crusoli   Deutsch is jetzt nicht das Problem. ;-) Unfortuna...   Feb 17 2007, 16:50
- - Crusoli   Everyone who encountered problems with the first r...   Feb 17 2007, 17:26
- - Andreasvb   The plugin loads now, thanks. But the "updat...   Feb 17 2007, 17:51
- - tomthomson   plugin works for me after the update, thanks updat...   Feb 17 2007, 19:32
- - Crusoli   Since the feedback on the test version was good so...   Feb 18 2007, 00:51
|- - Kiteroa   The plugin loads now, thanks. But the "updat...   Feb 18 2007, 01:01
- - DustMagnet   Nice. I had given up on the playcount plugins, bu...   Feb 18 2007, 03:24
- - ExtensionArt   I'm so happy play count is working finally (ha...   Feb 19 2007, 17:01
- - Crusoli   Not that I know of. Put it on the to-do list...   Feb 19 2007, 17:44
- - Strictly4me   Works perfect on my foo (0.9.4), without popups...   Feb 19 2007, 18:00
- - stampgevaar   works good in my case   Feb 19 2007, 18:24
- - fabiospark   Does this plugin write in the files or somewhere e...   Feb 19 2007, 18:50
- - Crusoli   It writes all infos directly to the file tags.   Feb 19 2007, 19:06
- - LeBakalite   This plugin seems great ! For what version of ...   Feb 19 2007, 19:10
- - DustMagnet   Darn, now I'm getting what seems to be random ...   Feb 19 2007, 20:35
- - VeaaC   Works for me   Feb 22 2007, 15:40
- - Keikonium   I've been using it for about an hour (18 songs...   Feb 22 2007, 16:20
- - lwiczek   Still getting popup sometimes. + for the idea - t...   Feb 25 2007, 11:59
- - elenhil   I'm getting a lot of failed tag update alerts ...   Feb 26 2007, 11:41
- - Crusoli   QUOTE (elenhil @ Feb 26 2007, 11:41) I...   Feb 27 2007, 04:33
|- - elenhil   QUOTE (Crusoli @ Feb 27 2007, 06:33) QUOT...   Feb 28 2007, 13:04
- - Crusoli   QUOTE (pIv @ Feb 17 2007, 08:09) Also my ...   Feb 27 2007, 05:26
- - pIv   http://www.foobar2000.org/components/foo_playcount...   Feb 27 2007, 06:14
- - Bh4i   Just wanted to tell that this is the ONLY playcoun...   Mar 4 2007, 13:45
- - lwiczek   When playing from cd i'm getting: "Could ...   Mar 4 2007, 17:19
- - Crusoli   QUOTE (elenhil @ Feb 28 2007, 13:04) ...   Mar 4 2007, 23:36
- - Crusoli   New version 1.0.2 released. Check the first post f...   Mar 4 2007, 23:56
- - TheTravis   Thanks! This plugin fixed my problem. When usi...   Mar 5 2007, 00:15
- - pIv   New version very nive! I have only one sugges...   Mar 5 2007, 07:59
- - pIv   For prevent popups "Could not write info (Sha...   Mar 6 2007, 14:23
|- - elenhil   QUOTE (pIv @ Mar 6 2007, 16:23) For preve...   Mar 7 2007, 09:29
- - Bh4i   I dont think ull be pleased to hear it, but v1.0.2...   Mar 6 2007, 17:47
- - Crusoli   *aaaaaaaaargh*   Mar 6 2007, 18:04
- - eb3604   still won't load for me. Using latest foobar,...   Mar 6 2007, 21:48
- - dark_avenger   Hi I got a problem with this mod ... like the ...   Mar 14 2007, 11:29
- - freanir   QUOTE (elenhil @ Mar 7 2007, 09:29) QUOTE...   Mar 14 2007, 15:29
- - rouge   Would be nice if you could do this for rating quic...   Mar 16 2007, 20:16
- - FofR   Is it possible to use this so that ONLY First Play...   Mar 18 2007, 02:17
- - Crusoli   QUOTE (dark_avenger @ Mar 14 2007, 11:29)...   Mar 18 2007, 03:26
|- - rouge   QUOTE (Crusoli @ Mar 17 2007, 20:26) QUOT...   Mar 19 2007, 05:31
- - FofR   Couple more questions, can I use this whilst using...   Mar 20 2007, 23:03
- - barry123   I really like this one but how do I change the way...   Mar 21 2007, 15:18
|- - ladiko   QUOTE (barry123 @ Mar 21 2007, 16:18) I d...   Mar 22 2007, 11:51
- - Crusoli   QUOTE (rouge @ Mar 19 2007, 05:31) I have...   Mar 24 2007, 17:17
- - henk102   Hi I found this code, i'm nearly happy about i...   Mar 25 2007, 16:43
- - shakey_snake   No matter how high I adjust my buffer, this plugin...   Mar 27 2007, 04:09
|- - slinger1182   QUOTE (shakey_snake @ Mar 26 2007, 21:09)...   Mar 27 2007, 08:34
- - Crusoli   How high is the bitrate? And does it also happen o...   Apr 22 2007, 00:47
- - Acropolis   used the source code to incorporate into one of my...   May 22 2007, 16:47
- - Andreasvb   Can you release foo_playcount_mod with your change...   May 22 2007, 17:30
|- - Acropolis   sorry, I was wrong, removing the Sleeps will get r...   May 22 2007, 17:52
- - Andreasvb   Those damn popups, hard to hide. Thanks for tryi...   May 22 2007, 18:06
|- - Acropolis   Conclusion: you CANNOT get rid of it Reason: CODE...   May 22 2007, 18:25
- - Andreasvb   *crosses fingers*   May 22 2007, 18:52
|- - Acropolis   ok, finally solved. it's not perfect, but the ...   May 23 2007, 05:00
- - Andreasvb   Seems to work wonderful. Thanks a lot, Acropolis...   May 23 2007, 08:24
|- - Acropolis   I don't use audioscrobbler, so I don't kno...   May 23 2007, 11:14
- - Andreasvb   The popups for playcounter is gone, very good. Ma...   May 23 2007, 11:22
|- - Acropolis   QUOTE (Andreasvb @ May 23 2007, 20:22) Ma...   May 23 2007, 11:33
- - snively   Thanks for the mod. Is there a way to merge the da...   May 30 2007, 04:25
- - masterrossi   is the data written in the database or is it writt...   Jun 28 2007, 13:06
- - Legendary   How to let play count work ? I down dll file and p...   Jun 28 2007, 14:39
- - Pingwinho   Strange... It does not work for my mp3 files. Only...   Jul 28 2007, 12:21
- - thuan   Check whether mp3 is in the list of exclude files ...   Jul 28 2007, 13:53
- - xan K   this plugin works like a charm! I've never...   Aug 17 2007, 05:05
|- - kanak   QUOTE (xan K @ Aug 17 2007, 00:05) this p...   Aug 17 2007, 05:35
- - xan K   thanks for the reply, but there's a problem: w...   Aug 17 2007, 07:18
- - thuan   Because foobar doesn't support custom tag fiel...   Aug 17 2007, 09:48
- - xan K   ok, thanks then.   Aug 17 2007, 15:13
- - pIv   I find bug in this plugin. Official playcount sto...   Sep 14 2007, 09:44
- - ladiko   cant confirm this. for me (berlin, gmt+1, or now ...   Sep 16 2007, 20:38
- - n0obie4life   Never mind~   Nov 17 2007, 08:50
- - $char(9836)   This is a great plugin except that it seems to ope...   Dec 21 2007, 11:38
|- - BuZ   QUOTE ($char(9836) @ Dec 21 2007...   Jan 3 2008, 18:48
- - kanak   You could try the other unofficial play count plug...   Dec 21 2007, 14:54
- - helloterence   Sorry for bumping this, but this is the thread the...   Apr 4 2009, 16:01
- - tpijag   What part of not supporting panels skins do you no...   Apr 4 2009, 16:11
- - unknownserv   Is it possible for this to write to the files cont...   Sep 19 2009, 14:02
- - Symmetric   I've been hit a couple times recently with the...   Nov 27 2010, 22:33
- - MC Escher   Are you sure the statistics are lost? Perhaps beca...   Nov 28 2010, 01:46
RSS Lo-Fi Version Time is now: 28th March 2015 - 13:43
