Windows XP k mixer vs. whatever is in Vista
audiophilosophy
post Feb 3 2007, 22:02
Group: Members (Donating)
I'm a noob with this technical sort of stuff, but I was wondering if the audio processing stuff included in Vista is better or worse than what we had with XP.
Ok, since I am a noob, this is what I have gathered about XP's audio processing--- the k mixer is bad, and it has a degrading effect on the sound unless you decided to take steps to entirely bypass the k mixer. Correct me if I'm wrong about this.
So I'm wondering, are there any improvements over XP's k mixer with what comes standard with Vista?
CSMR
post Feb 5 2007, 20:38
QUOTE (spockep @ Feb 5 2007, 09:28) *
Thats a nice thought but 99% of consumers aren't aware of DRM. So is it fair to sell things to an unaware public? And to those that are aware, how can you be sure if DRM is not part of what you are purchasing? i.e. Sony rootkit scandal. No offense but it almost sounds like you work for MS.
People who are slightly technically minded will understand what the internet store tells them. They will understand when they are told "you have the right to play this ten times" or whatever. Not difficult. If the store doesn't tell them then I would think it is doing something which would be illegal in most countries.
People who can't even understand this will know from their friends or the media if they notice problems arising from DRM. So these people will get some relevant information from some channels... not the best channels but the channels they would use to make any decision about what to buy.
QUOTE (Dogbert @ Feb 3 2007, 16:46) *
Contrary to popular belief, the kmixer of XP and 2k doesn't change a thing when you move the wave volume slider to the max. DTS encoded wave files can be played through WaveOut/DSound and through the kernel mixer without any loss.
And I should know, I've developed a driver for the C-Media 8738/8768 which just can do that stunt.
No. Windows has a mixer. The mixer has to take what can potentially be several sources and mix them. So no one can be at full volume, even if it is the only thing playing, because then if the system beeps for example you either have the possibiliy of clipping or you have to reduce the volume of what is playing at the same time. Not unreasonably, windows doesn't do this.
The mixing engine of Vista works with 32bit float samples, so there's actually some information lost in the conversion. But there is a so called "exclusive mode" which is available through the WASAPI. It should give you bitperfect output, albeit I haven't seen software which actually support it (yet).
That's right.
Dogbert
post Feb 5 2007, 20:48
QUOTE (CSMR @ Feb 5 2007, 20:38) *
Ahh, so either I am lying, or I am in a delusional state of mind . Yeah, that must be it.
Seriously, try it yourself if you don't believe me. A cmedia card with digital outputs costs ~15 USD.
You have to download the KS plugin from the Optional Components link at Foobar2000.com
Or not. The Realtek drivers use the WaveRT model afaik, so kernel streaming isn't supported at all.
http://code.google.com/p/cmediadrivers
- audiophilosophy   Windows XP k mixer vs. whatever is in Vista   Feb 3 2007, 22:02
- - Martin H   I don't know what changes Vista includes with ...   Feb 3 2007, 22:53
- - crni   Maybe you can explain something to me... I have M-...   Feb 3 2007, 23:25
- - Tripwire   Vista uses a floating point pipeline in their audi...   Feb 3 2007, 23:36
- - AndyH-ha   QUOTE so obviously kmixer changes digital stream i...   Feb 4 2007, 01:27
|- - Dogbert   QUOTE (AndyH-ha @ Feb 4 2007, 01:27)...   Feb 4 2007, 01:46
|- - audiophilosophy   QUOTE (Dogbert @ Feb 3 2007, 18:46) QUOTE...   Feb 4 2007, 01:50
|- - crni   QUOTE (Dogbert @ Feb 3 2007, 16:46) Contr...   Feb 4 2007, 10:07
|- - Dogbert   QUOTE (crni @ Feb 4 2007, 10:07) ONLY way...   Feb 4 2007, 11:07
|- - Martin H   For anyone interessted in this bit-mangling issue ...   Feb 4 2007, 11:52
|- - audiophilosophy   QUOTE But like I said, it is impossible (or I have...   Feb 4 2007, 17:07
|- - Dogbert   QUOTE (audiophilosophy @ Feb 4 2007, 17:0...   Feb 4 2007, 17:28
- - HotshotGG   QUOTE So are you saying that the audio quality tha...   Feb 4 2007, 05:44
|- - audiophilosophy   QUOTE (HotshotGG @ Feb 3 2007, 22:44) QUO...   Feb 4 2007, 16:43
|- - Jebus   QUOTE (HotshotGG @ Feb 3 2007, 21:44) The...   Feb 4 2007, 19:23
|- - Dogbert   QUOTE (Jebus @ Feb 4 2007, 19:23) Vista l...   Feb 4 2007, 19:48
- - sld   Foobar2000 with KS works in Vista. I was using an...   Feb 4 2007, 07:09
- - mugen   How do I get KS working in Vista? With a Realtek ...   Feb 4 2007, 09:08
|- - sld   QUOTE (mugen @ Feb 4 2007, 16:08) How do ...   Feb 5 2007, 19:36
- - Dogbert   The kernel mixer of the 64 bit version of Windows ...   Feb 4 2007, 18:29
- - Borisz   I can use Kernel Streaming in Vista, using a Sound...   Feb 4 2007, 18:52
- - TREX6662k6   Actually you are able to disable driver signing by...   Feb 4 2007, 19:52
|- - Dogbert   QUOTE (TREX6662k6 @ Feb 4 2007, 19:52) Ac...   Feb 4 2007, 19:56
- - TREX6662k6   I agree with A) but B) there is a command you can ...   Feb 4 2007, 20:04
- - HotshotGG   QUOTE Well, sidetracking successful. What the hell...   Feb 4 2007, 20:22
- - Firon   Jebus: HD DVD works just fine on XP. So does Blu-R...   Feb 4 2007, 20:27
|- - Jebus   QUOTE (Firon @ Feb 4 2007, 12:27) Jebus: ...   Feb 4 2007, 20:40
|- - rjamorim   QUOTE (Jebus @ Feb 4 2007, 16:40) And no,...   Feb 5 2007, 01:39
|- - chelgrian   QUOTE (rjamorim @ Feb 5 2007, 01:39) I se...   Feb 5 2007, 21:02
|- - rjamorim   QUOTE (chelgrian @ Feb 5 2007, 17:02) QUO...   Feb 6 2007, 01:39
- - bidz   The DRM system in Vista is only active if you play...   Feb 4 2007, 20:40
|- - Dogbert   QUOTE (bidz @ Feb 4 2007, 20:40) The DRM ...   Feb 4 2007, 20:47
||- - bidz   QUOTE (Dogbert @ Feb 4 2007, 11:47) In Wi...   Feb 4 2007, 20:56
||- - Dogbert   QUOTE (bidz @ Feb 4 2007, 20:56) That...   Feb 4 2007, 21:48
||- - jeffster   QUOTE (bidz @ Feb 5 2007, 07:56) The DRM ...   Feb 5 2007, 15:43
|- - spockep   QUOTE (bidz @ Feb 4 2007, 15:40) The DRM ...   Feb 5 2007, 18:28
- - CSMR   QUOTE (spockep @ Feb 5 2007, 09:28) Thats...   Feb 5 2007, 20:38
|- - Dogbert   QUOTE (CSMR @ Feb 5 2007, 20:38) No. Wind...   Feb 5 2007, 20:48
- - JunkieXL   QUOTE (jeffster @ Feb 5 2007, 07:43) Kind...   Feb 5 2007, 21:05
- - Martin H   Hi Dogbert Are you saying that the person who wr...   Feb 5 2007, 22:48
- - CSMR   QUOTE (Dogbert @ Feb 5 2007, 11:48) Ahh, ...   Feb 5 2007, 22:52
|- - Dogbert   QUOTE (CSMR @ Feb 5 2007, 22:52) So what ...   Feb 5 2007, 23:08
- - CSMR   Yes and when they are mixed together, is the volum...   Feb 5 2007, 23:21
|- - Dogbert   QUOTE (CSMR @ Feb 5 2007, 23:21) Yes and ...   Feb 5 2007, 23:50
- - tgoose   Is it really illegal to watch DVDs using OSS? I wa...   Feb 7 2007, 00:25
RSS Lo-Fi Version Time is now: 27th January 2015 - 15:24
