TAK 1.0 - Final release of the new lossless codec, offers superior performance
TBeck
post Jan 26 2007, 11:00
TAK Developer
It's been a long time...
About
TAK is a lossless audio compressor, similar to FLAC, WavPack and Monkey's Audio. On average, lossless compression reduces the file size to about 50 percent of the original size; however the compression can vary between approximately 30 and 70 percent, depending on the file. Decompression restores a bit identical copy of the original audio data (that's why we call it lossless).
My goal was to develop a compressor which combines good compression with optimal decoding speeds. On average, the current implementation should match the compression efficiency of Monkey's Audio High, while achieving decompression speeds similar to FLAC.
Features
- Good compression. The strongest mode (Extra) is on par with Monkey's Audio High and OptimFrog Normal. TAK's fastest mode (Turbo) easily outperforms FLAC's strongest mode. This classification is based upon the evaluation of hundreds of files of different genres; it may not be the case for every file that you compress.
- Fast compression speed. Currently I know of no other compressor which compresses faster than TAK's Turbo and Fast modes, while providing similar compression ratios.
- Very fast decompression speed. The decoding speeds achieved are similar to, and often surpassing, those achieved by FLAC.
- Support for any common audio format (not fully implemented).
- Streaming support. An info frame, which contains all the information required to decompress a file, is inserted into the compressed audio data every 2 seconds.
- Error tolerance. A single bit error will never affect more than 250 ms of the audio data, as the compressed data is being stored in independent frames no more than that duration. The decoder is able to decompress even badly damaged files, by removing corrupt frames or replacing them with silence.
- Error detection. Each single frame is protected by a 24-bit checksum (CRC).
- Fast and sample accurate seeking. The file header contains a seektable with seekpoints (at 1 second intervals). In the absence of the seektable seeking can still be achieved by using the sync codes of the frame headers and the (optional) relative offset values contained in each info frame, which are pointing to the previous and next info frame.
- Meta data. A flexible and extensible structure in which to embed non audio data.
Changes
Improved:
- Synthetic Soul was so kind to correct my bad english in the ReadMe.
Fixed:
- Decoding with the command line version: if you specified wildcards for the file selection and the source directory contained only 1 TAK file, the decoder always threw the message 'File already exists'. Even worse: using the overwrite option in this situation led to deletion of the compressed source file!
- Usually the decoder ignores any data appended to the file end of the compressed file (for instance APEv2 tags). But it failed, if the file size was an integer multiple of the frame size (in samples).
Both bugs affected only the decoder, therefore there is no need to re-encode TAK files created with beta 2. Files created with earlier versions than beta 2 should be replaced.
Thank you
Thank you to all the members who have supported the development of TAK!
Firstly, you have provided encouragement to build yet another lossless audio compressor. Otherwise I would have dropped the whole project!
You helped to evaluate and optimize TAK. There have been 13 releases over a period of 8 months before the alpha version, and all of them have been evaluated by you!
Special thanks to the following members (in alphabetical order):
Destroid
Josef Pohm
Synthetic Soul
Download
The final can be downloaded from rarewares.org (Thanks to rjamorim!):
TAK 1.0 (Final)
Future
Some important features are missing in this release. Please find below my current to-do list:
- Plugins for other applications, such as Winamp or foobar2000 (a Winamp plugin is already close to completion).
- An SDK for other developers.
- Internal tagging.
- Unicode support.
- Piping support.
- MD5 audio checksums for verification and identification.
- A german version.
- Embedded cue sheets.
- Embedded cover art.
- Multi channel audio.
- Even more speed and better compression.
This post has been edited by TBeck: Jan 30 2007, 05:18
vhl
post Jan 30 2007, 19:01
Is it possible to make version with multicore support? Almost all new processors is multicore, why developers do not use this advantages?
jcoalson
post Jan 30 2007, 19:55
FLAC Developer
QUOTE (vhl @ Jan 30 2007, 13:01) *
it's complicated, difficult to get right, and non-portable. better to spawn multiple processes for individual files and let the OS handle it.
- TBeck   TAK 1.0 - Final release of the new lossless codec   Jan 26 2007, 11:00
- - gib   I just wanted to say congratulations. It's be...   Jan 26 2007, 11:19
- - askoff   What is TAK? What are the advantages over rivals?   Jan 26 2007, 12:26
|- - Sunhillow   QUOTE (askoff @ Jan 26 2007, 12:26) What ...   Jan 26 2007, 13:05
- - PoisonDan   askoff, you're kidding, right? Did you really...   Jan 26 2007, 13:02
- - Synthetic Soul   I can't believe that it's been almost ten ...   Jan 26 2007, 13:14
|- - TBeck   QUOTE (Synthetic Soul @ Jan 26 2007, 13:1...   Jan 26 2007, 14:48
- - askoff   I'm sorry if I hurt someones feelings for aski...   Jan 26 2007, 15:01
|- - TBeck   QUOTE (askoff @ Jan 26 2007, 15:01) I...   Jan 26 2007, 15:08
- - skamp   Uh, what about unix users?   Jan 26 2007, 15:32
- - Synthetic Soul   QUOTE (askoff @ Jan 26 2007, 14:01) And i...   Jan 26 2007, 16:12
|- - kwanbis   QUOTE (Synthetic Soul @ Jan 26 2007, 15:1...   Jan 26 2007, 16:19
|- - Sunhillow   QUOTE (kwanbis @ Jan 26 2007, 16:19) free...   Jan 27 2007, 02:00
|- - pepoluan   I also agree with kwanbis and Sunhillow. Kinda of...   Jan 27 2007, 05:27
- - Gow   Do we have a media player that can play Tak? Hope...   Jan 26 2007, 17:04
- - Synthetic Soul   Glad to see that people read my posts. No, no pl...   Jan 26 2007, 17:28
- - spockep   Just like to add my congratulations!! TAK...   Jan 27 2007, 01:03
- - keytotime   Excellent release. I hope the source will be relea...   Jan 27 2007, 02:47
- - Synthetic Soul   I was going to leave this for Thomas to answer, as...   Jan 27 2007, 07:50
|- - TBeck   QUOTE (Synthetic Soul @ Jan 27 2007, 07:5...   Jan 27 2007, 08:51
- - krmathis   Great to see that TAK have reach version 1.0, as t...   Jan 27 2007, 09:13
- - TBeck   QUOTE (TBeck @ Jan 27 2007, 08:51) QUOTE ...   Jan 27 2007, 09:25
|- - krmathis   QUOTE (TBeck @ Jan 27 2007, 09:25) QUOTE ...   Jan 27 2007, 11:09
- - Mr Bungle   Thomas, Congratulations and thanks for your effor...   Jan 27 2007, 11:07
- - fairway   Since TAK is really interesting for all those peop...   Jan 27 2007, 11:23
- - leokennis   Wow great codec...I like FLAC but hates how it tak...   Jan 27 2007, 11:32
- - Gecko   Congratulations Thomas on the final release. I...   Jan 27 2007, 11:53
|- - gib   Upon further reflection it occured to me that, due...   Jan 27 2007, 14:08
- - Mangix   hmmm. i can't use TAK due to its buggy WAV han...   Jan 27 2007, 19:37
- - Synthetic Soul   Strange, all the WAVEs that I have used for testin...   Jan 27 2007, 20:04
- - Mangix   the wav file that i made came from an mp3(wanted t...   Jan 27 2007, 20:26
- - Synthetic Soul   Perhaps you could take a look at the WAVE file in ...   Jan 27 2007, 21:16
- - TBeck   QUOTE (Mangix @ Jan 27 2007, 19:37) hmmm....   Jan 27 2007, 22:44
|- - TBeck   QUOTE (TBeck @ Jan 27 2007, 22:44) I am a...   Jan 27 2007, 22:59
- - guruboolez   foobar2000 did it (optional writing of APEv2 tags ...   Jan 27 2007, 23:36
|- - TBeck   QUOTE (guruboolez @ Jan 27 2007, 23:36) f...   Jan 27 2007, 23:44
- - Mangix   I think i just found a bug in foobar2000 by accide...   Jan 28 2007, 00:02
|- - TBeck   QUOTE (Mangix @ Jan 28 2007, 00:02) I thi...   Jan 28 2007, 00:08
|- - TBeck   QUOTE (TBeck @ Jan 28 2007, 00:08) QUOTE ...   Jan 28 2007, 20:26
- - [JAZ]   As Sintetic Soul suggested, you are creating a 32b...   Jan 28 2007, 00:22
- - Shade[ST]   Rock on Thomas! This is really a revolution i...   Jan 29 2007, 07:29
|- - TBeck   QUOTE ' date='Jan 29 2007, 07:29' post...   Jan 29 2007, 08:07
|- - Synthetic Soul   QUOTE (TBeck @ Jan 29 2007, 07:07) Should...   Jan 29 2007, 08:51
|- - boombaard   QUOTE (TBeck @ Jan 29 2007, 09:07) QUOTE ...   Jan 29 2007, 08:53
- - cabbagerat   QUOTE (Synthetic Soul @ Jan 28 2007, 23:5...   Jan 29 2007, 09:33
|- - MaB_fr   QUOTE (cabbagerat @ Jan 29 2007, 09:33) Q...   Jan 29 2007, 10:17
|- - gib   QUOTE (MaB_fr @ Jan 28 2007, 23:17) At fi...   Jan 29 2007, 12:11
|- - pepoluan   QUOTE (gib @ Jan 29 2007, 18:11) QUOTE (M...   Jan 29 2007, 13:34
||- - ...Just Elliott   QUOTE (pepoluan @ Jan 29 2007, 12:34) QUO...   Jan 31 2007, 19:19
||- - Synthetic Soul   You will be pleased to know that the intention is ...   Jan 31 2007, 19:47
||- - TBeck   QUOTE (...Just Elliott @ Jan 31 2007, 19...   Jan 31 2007, 19:51
||- - rjamorim   QUOTE (TBeck @ Jan 31 2007, 15:51) ...   Jan 31 2007, 20:19
||- - krmathis   QUOTE (rjamorim @ Jan 31 2007, 20:19) QUO...   Jan 31 2007, 21:13
|||- - rjamorim   QUOTE (krmathis @ Jan 31 2007, 17:13) Wha...   Jan 31 2007, 23:43
|||- - krmathis   QUOTE (rjamorim @ Jan 31 2007, 23:43) QUO...   Feb 1 2007, 17:19
|||- - boombaard   QUOTE (krmathis @ Feb 1 2007, 18:19) QUOT...   Feb 1 2007, 17:48
||- - SebastianG   QUOTE (rjamorim @ Jan 31 2007, 20:19) Bes...   Jan 31 2007, 22:44
||- - towolf   QUOTE (SebastianG @ Jan 31 2007, 23:44) Q...   Jan 31 2007, 23:11
|- - boombaard   QUOTE (gib @ Jan 29 2007, 13:11) QUOTE (M...   Jan 29 2007, 13:39
|- - MaB_fr   That's a lot to answer and many misunderstandi...   Jan 29 2007, 14:32
|- - TBeck   QUOTE (MaB_fr @ Jan 29 2007, 14:32) Again...   Jan 29 2007, 14:55
|- - MaB_fr   I'm about to make a volcano of yourself Bu...   Jan 29 2007, 15:25
|- - TBeck   QUOTE (MaB_fr @ Jan 29 2007, 15:25) I...   Jan 29 2007, 15:38
|- - MaB_fr   Then, sorry for your users and the willing develop...   Jan 29 2007, 15:43
|- - Shade[ST]   I'm making a FAQ for you, Thomas. I'll li...   Jan 29 2007, 17:16
|- - TBeck   QUOTE ' date='Jan 29 2007, 17:16' post...   Jan 29 2007, 17:32
|- - Shade[ST]   Yeah, sorry. I edited it again. I do need a descri...   Jan 29 2007, 17:37
- - Enig123   He came from nowhere at the fool's day last ye...   Jan 29 2007, 12:20
- - Squeller   Danke, Anke!   Jan 29 2007, 13:29
- - TBeck   QUOTE (MaB_fr @ Jan 29 2007, 10:17) I...   Jan 29 2007, 13:30
- - PabUK   Congratulations Thomas on the first final release ...   Jan 29 2007, 14:23
- - Synthetic Soul   For someone who wants to look at the source code o...   Jan 29 2007, 15:35
- - Martin H   TBeck has said numerous times that the sources wil...   Jan 29 2007, 15:38
- - Eli   Sounds pretty good. Well will it be added to the l...   Jan 29 2007, 18:14
- - rjamorim   http://www.rarewares.org/ http://www.rarewares.or...   Jan 30 2007, 03:36
- - jido   Glad that version 1.0 is out. Congratulations...   Jan 30 2007, 12:13
- - vhl   Is it possible to make version with multicore supp...   Jan 30 2007, 19:01
|- - jcoalson   QUOTE (vhl @ Jan 30 2007, 13:01) Is it po...   Jan 30 2007, 19:55
|- - Shade[ST]   TAK's actual implementations are generally onl...   Jan 30 2007, 20:09
|- - vhl   QUOTE (jcoalson @ Jan 30 2007, 12:55) QUO...   Jan 30 2007, 20:26
|- - Martin H   QUOTE (vhl @ Jan 30 2007, 20:26) Why i mu...   Jan 31 2007, 00:54
- - Fandango   I'm pretty sure that this has to wait.   Jan 30 2007, 19:14
- - sPeziFisH   Thanks Thomas, the coding/decoding-abilities of th...   Jan 30 2007, 21:35
- - Firon   QUOTE (vhl @ Jan 30 2007, 14:01) Is it po...   Jan 30 2007, 21:59
- - JunkieXL   Just wanted to say Thank You Tbeck! I'm r...   Jan 30 2007, 22:12
- - TBeck   QUOTE (sPeziFisH @ Jan 30 2007, 21:35) Th...   Jan 31 2007, 01:44
|- - spockep   QUOTE (TBeck @ Jan 30 2007, 20:44) My Win...   Jan 31 2007, 04:15
|- - GeSomeone   QUOTE (spockep @ Jan 31 2007, 04:15) To a...   Jan 31 2007, 19:15
- - Funkdude   Wow, I've only recently started following what...   Jan 31 2007, 03:59
- - Fandango   I don't understand all the fuss about this sou...   Jan 31 2007, 21:04
- - Psyphre   This sounds really interesting, however im curious...   Jan 31 2007, 22:55
|- - boombaard   QUOTE (Psyphre @ Jan 31 2007, 23:55) This...   Jan 31 2007, 23:05
||- - Shade[ST]   QUOTE (boombaard @ Jan 31 2007, 17:05) QU...   Jan 31 2007, 23:39
|- - jcoalson   QUOTE (Psyphre @ Jan 31 2007, 16:55) it c...   Jan 31 2007, 23:21
|- - gaekwad2   QUOTE (Psyphre @ Jan 31 2007, 22:55) This...   Jan 31 2007, 23:47
- - Martin H   Fast decoding is not an issue for playback purposs...   Feb 1 2007, 01:56
- - TBeck   QUOTE (jcoalson @ Jan 31 2007, 23:21) QUO...   Feb 1 2007, 02:59
|- - Heliologue   QUOTE (TBeck @ Jan 31 2007, 19:59) Compet...   Feb 1 2007, 06:41
|- - TBeck   QUOTE (Heliologue @ Feb 1 2007, 06:41) QU...   Feb 1 2007, 07:22
- - pest   I've just tested TAK against the best codecs. ...   Feb 2 2007, 11:36
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 26th January 2015 - 06:56
