foo_default_videoplayer, Plays your video in foobar2k with default external player
Santa Sam
post Jan 20 2007, 12:28
Allows you to play your video clips from foobar playlist with an external player. Foobar2000 v0.9.4.2.
Screenshot:
Download (version 0.1.3)
New version with config form.
This post has been edited by Santa Sam: Mar 10 2007, 19:29
2Pacalypse
post Jan 23 2007, 18:30
well i installed it, added video files and none of them played and i couldnt find any config to help? am i missing something obvious?
Spirit_of_the_oc...
post Jan 23 2007, 20:40
@2Pacalypse: Add Videofiles to your playlist then dubleclick
The standard media Player should open then.
Some Requests:
- Add Videoplayer path
- more Videoextension support: .rm and .mov would be great
Question:
-Every Time I use this plugin Foobar shuts down. Is this the wanted behaviour?
When yes: Request: Only make Foobar pause while playing video
- Why is there no opportunity to configure this plug-in?
Thanks for this plug-in Santa Sam
Santa Sam
post Jan 24 2007, 15:55
QUOTE (Spirit_of_the_ocean @ Jan 23 2007, 13:40) *
Then you dbl-click on your video in playlist, plugin gets it path, stops playback and executes that path - very simple. It works stable for me since first version, so its hard to find bugs.
BTW. I've made new build in full version of Visual Studio with some fixes in code. I should learn SDK more to make the config (will be 'extensions' and 'player path' fields)
This post has been edited by Santa Sam: Jan 24 2007, 15:57
- Santa Sam   foo_default_videoplayer   Jan 20 2007, 12:28
- - foosion   QUOTE (Santa Sam @ Jan 20 2007, 12:28) Pl...   Jan 20 2007, 13:51
- - Bl@ck_warrior   QUOTE Supported extensions: avi, mpg, mpeg, wmv, f...   Jan 20 2007, 14:39
|- - Santa Sam   QUOTE (Bl@ck_warrior @ Jan 20 2007, 07:39...   Jan 20 2007, 19:15
- - Yotsuya   I'd like to request support for .ifo files.. s...   Jan 20 2007, 18:02
|- - Santa Sam   QUOTE (Yotsuya @ Jan 20 2007, 11:02) Also...   Jan 20 2007, 21:20
- - BlueScreenJunky   QUOTE (Bl@ck_warrior @ Jan 20 2007, 05:39...   Jan 20 2007, 22:36
- - mquander   I'm idly curious what situation the poster and...   Jan 21 2007, 02:39
|- - 2Pacalypse   QUOTE (mquander @ Jan 21 2007, 01:39) I...   Jan 21 2007, 15:36
- - pIv   This plugin not work on my PC (XP +SP2, check all ...   Jan 21 2007, 11:44
- - q-stankovic   The only reason i can see to use foobar to start ...   Jan 21 2007, 15:22
|- - Santa Sam   QUOTE (q-stankovic @ Jan 21 2007, 08...   Jan 21 2007, 16:06
- - M   Interesting. Rather than launching the default vid...   Jan 21 2007, 17:27
- - 2Pacalypse   is there any where to configure the plugin? i coul...   Jan 21 2007, 18:46
- - pIv   My foobar don't play avi with version 0.1.1 pl...   Jan 22 2007, 06:35
|- - Keikonium   QUOTE (pIv @ Jan 22 2007, 00:35) My fooba...   Jan 23 2007, 09:06
- - 2Pacalypse   well i installed it, added video files and none of...   Jan 23 2007, 18:30
|- - Spirit_of_the_ocean   @2Pacalypse: Add Videofiles to your playlist then ...   Jan 23 2007, 20:40
|- - Santa Sam   QUOTE (Spirit_of_the_ocean @ Jan 23 2007, 13...   Jan 24 2007, 15:55
|- - Spirit_of_the_ocean   I will try the new version If the same behaviour...   Jan 24 2007, 16:07
|- - Santa Sam   QUOTE (Spirit_of_the_ocean @ Jan 24 2007, 09...   Jan 24 2007, 16:14
- - Keikonium   I just updated to the version 0.1.2 and there is a...   Jan 25 2007, 06:51
- - Psyphre   I dont understand why people are against foobar ma...   Jan 29 2007, 07:49
- - vertigo1980   could you add mkv extension support?   Feb 4 2007, 06:09
- - safemode   If only it can play electric sheep's mpeg file...   Feb 4 2007, 14:08
|- - Spirit_of_the_ocean   Could you post a sheepmpeg? I couldn`t find so...   Feb 4 2007, 14:31
|- - safemode   QUOTE (Spirit_of_the_ocean @ Feb 4 2007, 21...   Feb 4 2007, 17:56
|- - Spirit_of_the_ocean   The "few clips" are working for me An...   Feb 4 2007, 20:07
|- - safemode   QUOTE (Spirit_of_the_ocean @ Feb 5 2007, 03...   Feb 5 2007, 00:29
|- - Spirit_of_the_ocean   The problem is that there seems to be no interest ...   Feb 5 2007, 10:07
- - hoaznod   just wanted to say that i've used foobar2000 f...   Feb 5 2007, 14:53
- - 2Pacalypse   i'm using version 1.2 it shows up in the pref ...   Feb 8 2007, 19:56
- - Santa Sam   Version 0.1.3 with config form released. Now you c...   Mar 10 2007, 19:33
|- - Spirit_of_the_ocean   QUOTE (Santa Sam @ Mar 10 2007, 19:33) Ve...   Mar 10 2007, 20:21
- - Santa Sam   QUOTE Maybe you shouldn't associate WMV with F...   Mar 10 2007, 20:29
|- - Spirit_of_the_ocean   These problems with my player are really annoying....   Mar 10 2007, 21:13
- - Santa Sam   2 Spirit_of_the_ocean I've just tried Gomplay...   Mar 10 2007, 21:30
|- - Spirit_of_the_ocean   I updated my columns ui the last days maybe thats ...   Mar 11 2007, 10:14
- - vertigo1980   works perfect here, thanks santa sam   Mar 11 2007, 13:08
- - Spirit_of_the_ocean   Another thing I recognized using panel ui works al...   Mar 11 2007, 13:53
- - Swoy   Hi guys! This is a plugin with insane possibil...   Mar 13 2007, 12:40
- - Jugdish   I'm unable to get foobar to import all of the ...   Mar 19 2007, 03:05
- - Santa Sam   Jugdish, I have tried foobar with components that ...   Mar 25 2007, 20:04
- - haste   in my case the plugin works well with both mplayer...   May 9 2007, 09:20
- - Santa Sam   2 haste It is exactly that i want to implement - t...   May 23 2007, 19:05
- - TheBlackCat   Monitoring would be difficult to do universally. ...   May 31 2007, 18:10
- - dev   Hi I can`t run this plugin, it says it`s i...   Dec 19 2007, 23:50
- - dev   I needed "vcredist_x86.exe" - now it...   Dec 20 2007, 13:38
|- - lctm   QUOTE (dev @ Dec 20 2007, 06:38) I needed...   Sep 28 2008, 17:59
- - Middy   Sorry for bringing up an old thread, just have a q...   Jan 12 2009, 11:47
- - ivareske   This plug-in works great, except that when the vid...   Jun 2 2009, 21:09
|- - randal1013   QUOTE (ivareske @ Jun 2 2009, 16:09) This...   Jun 2 2009, 22:07
|- - ivareske   QUOTE (randal1013 @ Jun 2 2009, 22:07) QU...   Jun 3 2009, 19:06
|- - Porcus   QUOTE (randal1013 @ Jun 2 2009, 22:07) QU...   Dec 13 2010, 20:12
- - ivareske   Replying myself...: Ok, maybe this is exactly what...   Jun 3 2009, 19:08
- - ThibWay   Hi, I would greatly appreciate using foobar to lis...   Nov 10 2009, 18:33
- - 2E7AH   CODEhttp://www.megaupload.com/?d=XLTGCCNO   Nov 10 2009, 20:18
- - ThibWay   Ty very much but it doesn't work ... It keep...   Nov 10 2009, 20:32
- - 2E7AH   QUOTE Allows you to play your video clips from foo...   Nov 10 2009, 20:37
- - juliaw87   Oh my gosh, this is the best plug-in idea ever. I ...   Jan 8 2010, 06:48
- - dzid_   Hey guys - simple workaround which will make this ...   Nov 11 2012, 17:52
- - xceller8ion   I am also very interested in trying this plugin ho...   Dec 4 2012, 03:41
- - Takaji   Considering that the OP has not been seen on the f...   Dec 4 2012, 07:38
RSS Lo-Fi Version Time is now: 5th August 2015 - 08:56
