Omni Encoder 1.0 Released, A graphical, multi-format front-end and EAC plug-in
Jebus
post Dec 18 2006, 06:59
Omni Encoder is a graphical, multi-format front-end and EAC plug-in.
Supported Formats:
Lame MP3, Ogg Vorbis, Musepack, FLAC, WavPack, Monkey's Audio, Nero and iTunes AAC, Apple Lossless
Features:
  • Graphical interface (no editing config files)
  • Optional EAC integration (like MAREO, REACT or WACK et al.)
  • Automated album art downloading from Amazon.com
  • Album or track ReplayGain analysis, adjustment and/or tagging
  • Tag conversion between formats
  • Directory layout creation based on tag info
  • Extendible, modular design (only install the features you want)
  • Open source license (GPLv2)
A lot of improvements have been made since the early betas last summer - please check it out and give me feedback!
Download it here (requires the .NET 2.0 runtime)
08/30/07: Updated to version 1.4.2.
This post has been edited by Jebus: Jan 4 2008, 21:47
music_man_mpc
post Dec 26 2006, 22:45
Group: Members (Donating)
I just started testing and I noticed that anything encoded with nero is being encoded at ~10kbit/s regardless of selected quality level . . . except if highest quality which yields the expected ~440kbit/s. I'm not sure if all of the other settings produce the same ~10kbit files, but I know for sure that 0.5, 0.75 and 0.9 (tried 0.95 but it kept snapping back to 0.9) all produce this quality level. As well there is a box pops up stating the command line used with only an ok button before each track is encoded; you have to click ok for each track or the process is paused.
A quick test showed that vorbis seems to be functioning perfectly (and it is an absolute pleasure to use), only nero seems to be affected by these bugs.
Another issue is every time I click on Download Modules I get the following message:
Unhandled exception has occurred in your application.  If you click
Countinue, the application will ignore this error and attempt to continue. If
you click Quit, the application will close immediately.
Application not found.
It continues to work fine if I click continue, but obviously the feature is not accessible.
Thanks for your efforts, cool app
-Tyler
- Jebus   Omni Encoder 1.0 Released   Dec 18 2006, 06:59
- - Jebus   The main window: The new "converting" ...   Dec 18 2006, 16:36
- - KarnEvil9   Looks good - thanks!   Dec 18 2006, 21:34
- - audiomars   Looks good, Jeremy. Just downloading it to evaluat...   Dec 20 2006, 07:37
- - Jebus   Please upgrade to version 1.0.2 if you've alre...   Dec 21 2006, 06:49
- - audiomars   @ Jeremy: Just a small thought. The following may ...   Dec 21 2006, 14:02
|- - Jebus   QUOTE (audiomars @ Dec 21 2006, 06:02) @ ...   Dec 21 2006, 17:44
|- - Jebus   Updated to version 1.1: * Musepack (MPC) support...   Dec 23 2006, 00:07
- - Drunk 24/7   Pretty sweet proggy but it doesn't see my FLAC...   Dec 21 2006, 14:26
- - Josiah McGuckin   I've already used v1.1 to run a FLAC-Vorbis co...   Dec 23 2006, 00:26
- - Demonanya   I've just decided to give this a try and so fa...   Dec 23 2006, 17:50
- - =trott=   Will ape support also be coming soon?   Dec 23 2006, 18:37
|- - Jebus   QUOTE (=trott= @ Dec 23 2006, 10:37) Will...   Dec 23 2006, 19:04
|- - bhoar   Just a hint, probably off the mark since the origi...   Dec 23 2006, 19:22
|- - Egor   QUOTE (bhoar @ Dec 24 2006, 00:22) Ah, he...   Dec 23 2006, 20:55
|- - bhoar   QUOTE (Egor @ Dec 23 2006, 14:55) The aut...   Dec 23 2006, 22:19
|- - gordo   I'm playing around with flac -> alac conver...   Dec 26 2006, 19:09
|- - Jebus   QUOTE (gordo @ Dec 26 2006, 11:09) I...   Dec 26 2006, 20:12
|- - gordo   QUOTE (Jebus @ Dec 26 2006, 14:12) QUOTE ...   Dec 26 2006, 21:12
|- - Jebus   QUOTE (gordo @ Dec 26 2006, 13:12) I...   Dec 26 2006, 21:25
- - Demonanya   I've just tried to convert some of my Japanese...   Dec 23 2006, 18:59
- - Jebus   I'm already using random tempfile names, so un...   Dec 23 2006, 20:35
- - music_man_mpc   I just started testing and I noticed that anything...   Dec 26 2006, 22:45
|- - Jebus   QUOTE (music_man_mpc @ Dec 26 2006, 14:45...   Dec 26 2006, 23:03
|- - music_man_mpc   QUOTE (Jebus @ Dec 26 2006, 14:03) Okay, ...   Dec 27 2006, 02:17
- - gordo   I tried itunes aac encoder and have similar proble...   Dec 27 2006, 01:54
- - music_man_mpc   Sorry I forgot to post again last night. It seems...   Dec 27 2006, 17:20
|- - Jebus   QUOTE (music_man_mpc @ Dec 27 2006, 09:20...   Dec 27 2006, 20:20
- - Jebus   Version 1.1.1 is now available. * Bug fixes in th...   Dec 28 2006, 00:51
- - gordo   1.1.1 seems much improved with itunes alac - I jus...   Dec 28 2006, 02:27
- - Preuss   I have just tried Omni Encoder for the first time....   Dec 29 2006, 15:37
|- - Jebus   QUOTE (Preuss @ Dec 29 2006, 07:37) I hav...   Dec 29 2006, 19:04
|- - Preuss   QUOTE (Jebus @ Dec 29 2006, 19:04) Is tha...   Dec 29 2006, 21:22
- - Jebus   Version 1.1.2 released. Okay, it shouldn't th...   Dec 29 2006, 23:51
|- - Preuss   QUOTE (Jebus @ Dec 29 2006, 23:51) Okay, ...   Dec 30 2006, 01:47
|- - Jebus   QUOTE (Preuss @ Dec 29 2006, 17:47) Just ...   Dec 30 2006, 02:20
- - Demonanya   So far apart from my Japanese language music not l...   Dec 30 2006, 00:18
- - samesong   I have a question regarding album art. Your featur...   Dec 31 2006, 13:48
|- - Jebus   QUOTE (samesong @ Dec 31 2006, 05:48) I h...   Dec 31 2006, 20:11
- - kanak   Just downloaded the program. Looks good. I have a ...   Dec 31 2006, 18:38
- - DJED   This proggie is really cool. However, a few thing...   Jan 3 2007, 04:45
|- - Jebus   QUOTE (DJED @ Jan 2 2007, 20:45) When con...   Jan 3 2007, 22:45
- - Jebus   Version 1.2 Released: * WavPack (lossless and hyb...   Jan 3 2007, 07:37
|- - phaedra   QUOTE (Jebus @ Jan 2 2007, 22:37) Version...   Jan 3 2007, 22:56
|- - Jebus   QUOTE (phaedra @ Jan 3 2007, 14:56) Just ...   Jan 3 2007, 23:11
- - Jebus   Since I've added all the "necessary...   Jan 3 2007, 23:00
- - qrwe   Is FAAC encoded files supported?   Jan 4 2007, 09:44
|- - Jebus   QUOTE (qrwe @ Jan 4 2007, 01:44) Is FAAC ...   Jan 4 2007, 17:42
- - krabapple   Just tried this for converting Flac 1.1.0 files (-...   Jan 4 2007, 23:07
- - wraithdu   Exactly what options in EAC are changed when insta...   Jan 5 2007, 00:48
|- - Jebus   QUOTE (wraithdu @ Jan 4 2007, 16:48) Exac...   Jan 5 2007, 01:21
|- - krabapple   QUOTE (Jebus @ Jan 4 2007, 19:21) Omni En...   Jan 5 2007, 03:14
- - DJED   QUOTE (Jebus @ Dec 17 2006, 21:59) Omni E...   Jan 5 2007, 13:29
|- - Jebus   QUOTE (DJED @ Jan 5 2007, 05:29) QUOTE (J...   Jan 5 2007, 19:10
- - Jebus   Back on topic... Omni Encoder 1.2.3 released: * U...   Jan 7 2007, 00:02
- - Moguta   Hey, Omni Encoder is a pretty nice program. I jus...   Jan 8 2007, 09:04
|- - Jebus   QUOTE (Moguta @ Jan 8 2007, 01:04) Hey, O...   Jan 8 2007, 15:10
|- - Moguta   QUOTE (Jebus @ Jan 8 2007, 09:10) * You c...   Jan 9 2007, 02:52
|- - Jebus   QUOTE (Moguta @ Jan 8 2007, 18:52) I reco...   Jan 9 2007, 05:21
- - gottkaiser   @Jebus I have some FLAC files with replay-gain v...   Jan 9 2007, 00:10
|- - Jebus   QUOTE (gottkaiser @ Jan 8 2007, 16:10) @J...   Jan 9 2007, 02:36
- - DJED   Again, so far so good. I don't use many tags,...   Jan 9 2007, 13:24
|- - Jebus   QUOTE (DJED @ Jan 9 2007, 05:24) Again, s...   Jan 9 2007, 16:50
- - gonza   Hi.. First of all , many thanks for doing this fr...   Jan 10 2007, 04:14
|- - Jebus   QUOTE (gonza @ Jan 9 2007, 20:14) Hi.. F...   Jan 11 2007, 18:54
|- - gonza   [quote name='Jebus' date='Jan 11 2007,...   Jan 12 2007, 17:42
- - DJED   I found a critter... Not sure if it's FLAC or...   Jan 12 2007, 00:07
|- - Jebus   QUOTE (DJED @ Jan 11 2007, 16:07) I found...   Jan 12 2007, 20:54
- - DJED   I only had like 5 or so with a '%' so I ju...   Jan 13 2007, 02:06
|- - Jebus   QUOTE (DJED @ Jan 12 2007, 18:06) I only ...   Jan 13 2007, 03:01
|- - Jebus   QUOTE (gonza @ Jan 9 2007, 20:14) Hi.. F...   Jan 13 2007, 22:29
- - Jebus   Version 1.2.4 is out. * Fixed above-mentioned cra...   Jan 14 2007, 20:53
|- - gonza   QUOTE (Jebus @ Jan 14 2007, 16:53) Versio...   Jan 16 2007, 02:36
- - DJED   This program is SO USEFUL... I am ripping my enti...   Jan 15 2007, 03:43
- - Jebus   Released version 1.2.5. * Some trivial bug fixes...   Jan 15 2007, 03:50
- - NappyHead   First, thank you for a great program. I've jus...   Jan 16 2007, 07:30
|- - Jebus   QUOTE (NappyHead @ Jan 15 2007, 23:30) Fi...   Jan 16 2007, 07:45
|- - NappyHead   QUOTE (Jebus @ Jan 15 2007, 22:45) QUOTE ...   Jan 16 2007, 07:54
|- - Jebus   QUOTE (NappyHead @ Jan 15 2007, 23:54) Ve...   Jan 16 2007, 08:04
- - DJED   Hi - Feature request... When transcoding, could...   Jan 17 2007, 03:45
|- - Jebus   QUOTE (DJED @ Jan 16 2007, 19:45) When tr...   Jan 17 2007, 06:08
|- - DJED   QUOTE (Jebus @ Jan 16 2007, 21:08) QUOTE ...   Jan 17 2007, 15:54
|- - Jebus   QUOTE (DJED @ Jan 17 2007, 07:54) Oh, and...   Jan 17 2007, 18:40
|- - DemonCleaner   I've got a small problem, I read through the t...   Jan 17 2007, 21:55
||- - Jebus   QUOTE (DemonCleaner @ Jan 17 2007, 13:55)...   Jan 17 2007, 23:03
||- - DemonCleaner   QUOTE (Jebus @ Jan 17 2007, 17:03) I saw ...   Jan 18 2007, 00:16
||- - Jebus   QUOTE (DemonCleaner @ Jan 17 2007, 16:16)...   Jan 18 2007, 00:58
|- - gonza   QUOTE (Jebus @ Jan 17 2007, 14:40) QUOTE ...   Jan 19 2007, 20:00
|- - Jebus   QUOTE (gonza @ Jan 19 2007, 12:00) Jebus....   Jan 19 2007, 21:10
- - NappyHead   Did some test, and it worked fine. Was able to dra...   Jan 17 2007, 06:38
|- - Jebus   QUOTE (NappyHead @ Jan 16 2007, 22:38) Di...   Jan 17 2007, 06:45
- - NappyHead   Ok, I know I tried that today and it didn't wo...   Jan 17 2007, 07:02
- - NappyHead   Plus, no one who's spent countless hours rippi...   Jan 17 2007, 08:43
- - indybrett   I'm trying this out, but I am having some issu...   Jan 19 2007, 03:52
|- - DemonCleaner   QUOTE (indybrett @ Jan 18 2007, 21:52) I...   Jan 19 2007, 06:40
|- - Jebus   QUOTE (DemonCleaner @ Jan 18 2007, 22:40)...   Jan 19 2007, 09:16
|- - indybrett   QUOTE (Jebus @ Jan 19 2007, 03:16) QUOTE ...   Jan 19 2007, 13:00
- - Jebus   Released version 1.2.7. * Fixed that "%...   Jan 20 2007, 21:15
- - Jebus   There has been some discussion of the huge memory ...   Jan 22 2007, 08:42
- - indybrett   I wouldn't mind if there was an option to igno...   Jan 23 2007, 02:13
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 27th March 2015 - 09:55
