FLAC 1.1.3 released
jcoalson
post Dec 2 2006, 07:20
FLAC Developer
FLAC 1.1.3 has been released. Almost 2 years in the making, FLAC 1.1.3 is a major release with improved compression, improved cover art and multichannel support, better recovery for corrupted files, many new features and options in the command-line tools, and several bug fixes. For developers, the decoder and encoder APIs have also been simplified and there is a new porting guide. See the changelog entry for complete details.
Josh
Emanuel
post Dec 6 2006, 01:26
QUOTE (Tung @ Dec 5 2006, 23:10) *
What's the simplest way to re-encode FLAC files with 1.1.3? I'm a windows user, and FLAC Frontend will not take FLAC as input to be encoded to FLAC. I want to keep all tags, etc, just encode with newer FLAC. (also, i'm not a command line master, so..)
Cut and paste the following script (author unknown to me) into a text editor and name it something like "convert.cmd". Put in in the root of your flac directory. Doubleclick. And do something great of your day while reencoding.
@echo off
set encoder="C:\Program\Sound\Coding\Flac\flac.exe"
for /r "." %%d in (.) do (cd %%d & for %%f in (*.flac) do %encoder% -8 -V -f -A "tukey(0,5)" "%%f")
Note: Of course you change the directory path of flac.exe to your specific.
Script takes care of the dot/comma bug.
EDIT: And it preserves the old tags.
This post has been edited by Emanuel: Dec 6 2006, 12:48
http://forum.studio.se (in Swedish)
MiSP
post Sep 21 2007, 23:33
QUOTE (Emanuel @ Dec 6 2006, 02:26) *
@echo off
Tested that script, works like a charm. Many thanks. smile.gif Now I only have to run that script once for every new version of FLAC. However, sometimes I get this error:
"ERROR: Input file <insert filename here> has an ID3v2 tag."
What do I do about this? I've tried foobar's "Rewrite file tags", but to no avail.
I'm using FLAC 1.2.1, if it matters.
This post has been edited by MiSP: Sep 21 2007, 23:35
Egor
post Sep 22 2007, 08:34
QUOTE (MiSP @ Sep 22 2007, 05:33) *
Try the Mp3tag program, it may be possible to remove the felonious ID3 tag with it.
MiSP
post Sep 22 2007, 16:04
QUOTE (Egor @ Sep 22 2007, 09:34) *
Thanks, I'll try. smile.gif Is there no other way around this, to make it automatic? Preferably by including something in the script?
- jcoalson   FLAC 1.1.3 released   Dec 2 2006, 07:20
- - jcoalson   note there is one known bug that will affect the c...   Dec 2 2006, 07:49
|- - Triza   This bug is not called out with regards to other v...   Dec 6 2006, 12:20
|- - me7   QUOTE (Triza @ Dec 6 2006, 12:20) This bu...   Dec 6 2006, 12:56
- - Klyith   From the changelog: "Much better recovery for...   Dec 2 2006, 08:33
|- - jcoalson   QUOTE (Klyith @ Dec 2 2006, 02:33) From t...   Dec 2 2006, 18:37
|- - Maurits   QUOTE (jcoalson @ Dec 2 2006, 17:37) QUOT...   Dec 2 2006, 18:58
||- - jcoalson   QUOTE (Maurits @ Dec 2 2006, 12:58) By th...   Dec 2 2006, 20:36
|- - Fandango   QUOTE (jcoalson @ Dec 2 2006, 18:37) I th...   Dec 2 2006, 19:19
|- - hellokeith   QUOTE (jcoalson @ Dec 2 2006, 11:37) I th...   Dec 2 2006, 21:14
|- - Mangix   QUOTE (hellokeith @ Dec 2 2006, 12:14) QU...   Dec 2 2006, 21:27
|- - jcoalson   QUOTE (hellokeith @ Dec 2 2006, 15:14) Jo...   Dec 2 2006, 21:38
- - Fandango   I think many people will never know about the work...   Dec 2 2006, 12:33
- - molnart   I think every country in Europe except the UK use ...   Dec 2 2006, 12:39
|- - goodnews   QUOTE (molnart @ Dec 2 2006, 04:39) I thi...   Dec 2 2006, 14:10
- - Fandango   Oh wow, everyone except the English? That kind of ...   Dec 2 2006, 12:51
- - Emanuel   QUOTE (Fandango @ Dec 2 2006, 12:51) Oh w...   Dec 2 2006, 13:00
- - Fandango   Uhm, to make things clear... is it correct that we...   Dec 2 2006, 14:28
|- - goodnews   QUOTE (Fandango @ Dec 2 2006, 06:28) Uhm,...   Dec 2 2006, 14:36
- - me7   No, it's more than 6 bytes. I tried to encode ...   Dec 2 2006, 14:42
- - dv1989   I am surprised that this major update did not rece...   Dec 2 2006, 14:44
|- - Maurits   QUOTE (dv1989 @ Dec 2 2006, 13:44) I am s...   Dec 2 2006, 16:27
- - me7   What would happen if you put both versions into th...   Dec 2 2006, 15:07
- - dv1989   There is surely a better way to fix the problem?   Dec 2 2006, 15:09
- - Fandango   I found something which I think is a potential pro...   Dec 2 2006, 15:13
|- - Synthetic Soul   QUOTE (Fandango @ Dec 2 2006, 14:13) So t...   Dec 2 2006, 17:24
|- - Egor   QUOTE (Synthetic Soul @ Dec 2 2006, 22:24...   Dec 3 2006, 13:48
- - tev777   Thanks for the update, Josh. Keep up the great wor...   Dec 2 2006, 18:09
- - skelly831   Great news, thanks for the update!   Dec 2 2006, 19:47
- - iGold   Is it possible to show warning if incorrect apodiz...   Dec 2 2006, 20:28
- - DickxLaurent   Will there be a separate P4 specific build like th...   Dec 3 2006, 06:58
- - ozmosis82   Thanks for the great work Josh. Looks like it...   Dec 3 2006, 08:27
- - Sebastian Mares   1.1.2 is not affected by the locale bug, right?   Dec 3 2006, 08:47
|- - goodnews   QUOTE (Sebastian Mares @ Dec 3 2006, 00:4...   Dec 3 2006, 10:16
- - Jose Hidalgo   Considering that a LOT of countries are affected b...   Dec 3 2006, 10:51
- - Sebastian Mares   What does AccurateRip has to do with FLAC? Nothing...   Dec 3 2006, 11:12
|- - Jose Hidalgo   QUOTE (Sebastian Mares @ Dec 3 2006, 11:1...   Dec 3 2006, 11:53
- - ernstblaauw   I will also wait for the version which fixes the l...   Dec 3 2006, 11:19
- - Cartoon   An estimate of a bigfix would be appreciated. Week...   Dec 3 2006, 11:57
- - Synthetic Soul   Thanks for the confirmation, and quotes, Egor. I ...   Dec 3 2006, 13:57
- - Case   I uploaded a hack-fixed version for Windows here. ...   Dec 3 2006, 14:00
|- - WaldoMonster   QUOTE (Case @ Dec 3 2006, 14:00) I upload...   Dec 3 2006, 23:48
- - ernstblaauw   QUOTE (Case @ Dec 3 2006, 05:00) I upload...   Dec 3 2006, 15:56
|- - Synthetic Soul   QUOTE (ernstblaauw @ Dec 3 2006, 14:56) S...   Dec 3 2006, 20:18
|- - Clemech   Is the new version of FLAC OK to use with FLACFron...   Dec 3 2006, 21:08
|- - doubleXP   QUOTE (Clemech @ Dec 3 2006, 21:08) Is th...   Dec 3 2006, 21:20
|- - Clemech   QUOTE (doubleXP @ Dec 3 2006, 15:20) QUOT...   Dec 3 2006, 21:31
- - lextune   Thanks for all your work Josh   Dec 4 2006, 05:06
- - me7   To clear things up: The command line fix completel...   Dec 4 2006, 11:58
- - Synthetic Soul   I believe that is the idea, yes. The easiest way ...   Dec 4 2006, 12:16
- - Synthetic Soul   Discussion regarding decimal separator moved here.   Dec 4 2006, 14:42
- - jcoalson   first, to save time I'll say the answers by sy...   Dec 4 2006, 19:52
|- - Cartoon   QUOTE (jcoalson @ Dec 4 2006, 20:52) , wh...   Dec 6 2006, 12:06
- - dv1989   Can you not update the download on the page and ad...   Dec 4 2006, 21:49
- - Jose Hidalgo   I agree : strict procedures are OK, but a bit of p...   Dec 4 2006, 23:53
- - Maurits   How about a 1.1.3a?   Dec 5 2006, 00:50
- - SoleBastard   I wanted to check out the 'better multichannel...   Dec 5 2006, 06:28
|- - Egor   QUOTE (SoleBastard @ Dec 5 2006, 11:28) W...   Dec 5 2006, 06:54
|- - Mangix   QUOTE (Egor @ Dec 4 2006, 21:54) Besides ...   Dec 5 2006, 07:01
||- - Egor   QUOTE (Mangix @ Dec 5 2006, 12:01) erm, d...   Dec 5 2006, 07:20
||- - SoleBastard   QUOTE (Egor @ Dec 5 2006, 08:20) QUOTE (S...   Dec 5 2006, 07:26
|- - SoleBastard   Thanks Egor, that '--channel-map=none' opt...   Dec 5 2006, 07:07
- - jcoalson   note that if you use --channel-map=none, the incom...   Dec 5 2006, 17:22
- - Tung   What's the simplest way to re-encode FLAC file...   Dec 5 2006, 23:10
- - me7   The simplest way is foobar.   Dec 5 2006, 23:25
|- - ernstblaauw   QUOTE (me7 @ Dec 5 2006, 14:25) The simpl...   Dec 5 2006, 23:47
- - jcoalson   depends on the material but probably 0.5-1.0%   Dec 6 2006, 00:29
- - me7   This depends on the lenght of the album. I got an ...   Dec 6 2006, 00:30
- - Emanuel   QUOTE (Tung @ Dec 5 2006, 23:10) What...   Dec 6 2006, 01:26
|- - esa372   QUOTE (Tung @ Dec 5 2006, 14:10) What...   Dec 6 2006, 01:57
|- - GeSomeone   QUOTE (Emanuel @ Dec 6 2006, 02:26) Cut a...   Dec 6 2006, 12:27
|- - ernstblaauw   QUOTE (Emanuel @ Dec 5 2006, 16:26) QUOTE...   Dec 6 2006, 23:29
|- - MiSP   QUOTE (Emanuel @ Dec 6 2006, 02:26) QUOTE...   Sep 21 2007, 23:33
|- - Egor   QUOTE (MiSP @ Sep 22 2007, 05:33) Tested ...   Sep 22 2007, 08:34
|- - MiSP   QUOTE (Egor @ Sep 22 2007, 09:34) Try the...   Sep 22 2007, 16:04
- - Jose Hidalgo   I'd even say "Many people are currently b...   Dec 6 2006, 12:10
- - Emanuel   QUOTE (GeSomeone @ Dec 6 2006, 12:27) QUO...   Dec 6 2006, 12:46
- - WaldoMonster   (Moved to a new topic)   Dec 7 2006, 13:11
- - Emanuel   John33, does your compile of flac 1.1.3 over at Ra...   Jan 15 2007, 15:39
|- - john33   QUOTE (Emanuel @ Jan 15 2007, 14:39) John...   Jan 15 2007, 16:27
- - Martin H   Hi John33 I had just finished testing your first...   Jan 15 2007, 17:13
|- - john33   QUOTE (Martin H @ Jan 15 2007, 16:13) Hi ...   Jan 15 2007, 17:37
|- - jcoalson   QUOTE (john33 @ Jan 15 2007, 11:37) I inc...   Jan 15 2007, 21:58
- - Emanuel   QUOTE (john33 @ Jan 15 2007, 17:37) I inc...   Jan 15 2007, 20:42
- - hat3k   excuse me? can i make a feature request, i need me...   Jan 15 2007, 22:45
- - Martin H   @John33 I don't think that you have to make ...   Jan 15 2007, 23:07
- - john33   OK, guys, thanks for the feedback. I'll not bo...   Jan 15 2007, 23:24
- - Martin H   @Josh Coalson Do you know why the optimized(ICL9....   Jan 17 2007, 13:05
|- - Egor   QUOTE (Martin H @ Jan 17 2007, 18:05) Do ...   Jan 17 2007, 16:28
|- - Jose Hidalgo   QUOTE (Martin H @ Jan 17 2007, 13:05) Man...   Jan 17 2007, 18:08
|- - Martin H   QUOTE (Jose Hidalgo @ Jan 17 2007, 18:08)...   Jan 17 2007, 18:46
- - Martin H   Yes, i know that this is the explenation for lossy...   Jan 17 2007, 16:57
- - jcoalson   libFLAC still uses floating point for the LPC anal...   Jan 17 2007, 17:10
- - Martin H   @Josh Thank you very much for the explanation A...   Jan 17 2007, 17:19
- - Martin H   Sorry, for repeating my question, but just in case...   Jan 21 2007, 14:42
|- - Heliologue   QUOTE (Martin H @ Jan 21 2007, 07:42) Sor...   Jan 21 2007, 18:55
|- - Triza   QUOTE (Heliologue @ Jan 21 2007, 09:55) Q...   Sep 23 2007, 19:30
- - jcoalson   I feel your pain Martin! this has come up be...   Jan 21 2007, 17:58
|- - Martin H   QUOTE (jcoalson @ Jan 21 2007, 17:58) I f...   Jan 21 2007, 19:11
- - Jose Hidalgo   Wow ! A 20-year old bug ! Amazing ! ...   Jan 21 2007, 18:58
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 30th March 2015 - 03:05
