FLAC 1.1.3 released
jcoalson
post Dec 2 2006, 07:20
FLAC Developer
FLAC 1.1.3 has been released. Almost 2 years in the making, FLAC 1.1.3 is a major release with improved compression, improved cover art and multichannel support, better recovery for corrupted files, many new features and options in the command-line tools, and several bug fixes. For developers, the decoder and encoder APIs have also been simplified and there is a new porting guide. See the changelog entry for complete details.
Josh
Martin H
post Jan 17 2007, 13:05
@Josh Coalson
Do you know why the optimized(ICL9.1-SSE2) flac.exe builds gives different filesizes ? There's no problem though, as i have verified that the decoded WAVs are bit-identical to the source files, but i was just currious about the exact reason for this.
PS. Many thank's for this new release which IMHO is just downright awesome and actually made me switch from WavPack to FLAC smile.gif
CU, Martin.
Edit: Of course i have remembered to add -A "tukey(0,5)" to the command-line of the stock compile when i compared the output filesizes of the stock compile VS the ICL9.1-SSE2 optimized compile, as the ICL9.1-SSE2 optimized compile's sources was taken from CVS after the 5th December 2005, so that it would include the comma decimal seperator bug-fix.
This post has been edited by Martin H: Jan 17 2007, 14:20
Jose Hidalgo
post Jan 17 2007, 18:08
Group: Banned
QUOTE (Martin H @ Jan 17 2007, 13:05) *
Just curious : what FLAC features made you switch ? What does FLAC currently have that WavPack doesn't ?
Martin H
post Jan 17 2007, 18:46
QUOTE (Jose Hidalgo @ Jan 17 2007, 18:08) *
FLAC decodes faster and compresses better than WavPack's fastest decoding mode. FLAC has a CUESHEET metadata block which can decode single tracks out from the command line. FLAC has a PICTURE metadata block. FLAC can take FLAC files as input and transcode from FLAC to FLAC and also transfer tags. FLAC has a verify-while-encoding(-V) option. FLAC has better software support. FLAC has better hardware support.
I'm only interested in very fast decoding and not in lossy or hybrid mode or getting better compression in trade of lower decoding speed and then i saw that the new FLAC version both decoded faster while also compressing better than WavPack's fastest decoding mode. Then other features of the new FLAC version really impressed me like with it's added FLAC to FLAC transcoding while transfering all tags and a switch for embedding a cuesheet into a Vorbis comment(like WavPack) + even better than before error correction + giving better compression without decoding penalty.
CU, Martin.
This post has been edited by Martin H: Jan 17 2007, 18:53
- jcoalson   FLAC 1.1.3 released   Dec 2 2006, 07:20
- - jcoalson   note there is one known bug that will affect the c...   Dec 2 2006, 07:49
|- - Triza   This bug is not called out with regards to other v...   Dec 6 2006, 12:20
|- - me7   QUOTE (Triza @ Dec 6 2006, 12:20) This bu...   Dec 6 2006, 12:56
- - Klyith   From the changelog: "Much better recovery for...   Dec 2 2006, 08:33
|- - jcoalson   QUOTE (Klyith @ Dec 2 2006, 02:33) From t...   Dec 2 2006, 18:37
|- - Maurits   QUOTE (jcoalson @ Dec 2 2006, 17:37) QUOT...   Dec 2 2006, 18:58
||- - jcoalson   QUOTE (Maurits @ Dec 2 2006, 12:58) By th...   Dec 2 2006, 20:36
|- - Fandango   QUOTE (jcoalson @ Dec 2 2006, 18:37) I th...   Dec 2 2006, 19:19
|- - hellokeith   QUOTE (jcoalson @ Dec 2 2006, 11:37) I th...   Dec 2 2006, 21:14
|- - Mangix   QUOTE (hellokeith @ Dec 2 2006, 12:14) QU...   Dec 2 2006, 21:27
|- - jcoalson   QUOTE (hellokeith @ Dec 2 2006, 15:14) Jo...   Dec 2 2006, 21:38
- - Fandango   I think many people will never know about the work...   Dec 2 2006, 12:33
- - molnart   I think every country in Europe except the UK use ...   Dec 2 2006, 12:39
|- - goodnews   QUOTE (molnart @ Dec 2 2006, 04:39) I thi...   Dec 2 2006, 14:10
- - Fandango   Oh wow, everyone except the English? That kind of ...   Dec 2 2006, 12:51
- - Emanuel   QUOTE (Fandango @ Dec 2 2006, 12:51) Oh w...   Dec 2 2006, 13:00
- - Fandango   Uhm, to make things clear... is it correct that we...   Dec 2 2006, 14:28
|- - goodnews   QUOTE (Fandango @ Dec 2 2006, 06:28) Uhm,...   Dec 2 2006, 14:36
- - me7   No, it's more than 6 bytes. I tried to encode ...   Dec 2 2006, 14:42
- - dv1989   I am surprised that this major update did not rece...   Dec 2 2006, 14:44
|- - Maurits   QUOTE (dv1989 @ Dec 2 2006, 13:44) I am s...   Dec 2 2006, 16:27
- - me7   What would happen if you put both versions into th...   Dec 2 2006, 15:07
- - dv1989   There is surely a better way to fix the problem?   Dec 2 2006, 15:09
- - Fandango   I found something which I think is a potential pro...   Dec 2 2006, 15:13
|- - Synthetic Soul   QUOTE (Fandango @ Dec 2 2006, 14:13) So t...   Dec 2 2006, 17:24
|- - Egor   QUOTE (Synthetic Soul @ Dec 2 2006, 22:24...   Dec 3 2006, 13:48
- - tev777   Thanks for the update, Josh. Keep up the great wor...   Dec 2 2006, 18:09
- - skelly831   Great news, thanks for the update!   Dec 2 2006, 19:47
- - iGold   Is it possible to show warning if incorrect apodiz...   Dec 2 2006, 20:28
- - DickxLaurent   Will there be a separate P4 specific build like th...   Dec 3 2006, 06:58
- - ozmosis82   Thanks for the great work Josh. Looks like it...   Dec 3 2006, 08:27
- - Sebastian Mares   1.1.2 is not affected by the locale bug, right?   Dec 3 2006, 08:47
|- - goodnews   QUOTE (Sebastian Mares @ Dec 3 2006, 00:4...   Dec 3 2006, 10:16
- - Jose Hidalgo   Considering that a LOT of countries are affected b...   Dec 3 2006, 10:51
- - Sebastian Mares   What does AccurateRip has to do with FLAC? Nothing...   Dec 3 2006, 11:12
|- - Jose Hidalgo   QUOTE (Sebastian Mares @ Dec 3 2006, 11:1...   Dec 3 2006, 11:53
- - ernstblaauw   I will also wait for the version which fixes the l...   Dec 3 2006, 11:19
- - Cartoon   An estimate of a bigfix would be appreciated. Week...   Dec 3 2006, 11:57
- - Synthetic Soul   Thanks for the confirmation, and quotes, Egor. I ...   Dec 3 2006, 13:57
- - Case   I uploaded a hack-fixed version for Windows here. ...   Dec 3 2006, 14:00
|- - WaldoMonster   QUOTE (Case @ Dec 3 2006, 14:00) I upload...   Dec 3 2006, 23:48
- - ernstblaauw   QUOTE (Case @ Dec 3 2006, 05:00) I upload...   Dec 3 2006, 15:56
|- - Synthetic Soul   QUOTE (ernstblaauw @ Dec 3 2006, 14:56) S...   Dec 3 2006, 20:18
|- - Clemech   Is the new version of FLAC OK to use with FLACFron...   Dec 3 2006, 21:08
|- - doubleXP   QUOTE (Clemech @ Dec 3 2006, 21:08) Is th...   Dec 3 2006, 21:20
|- - Clemech   QUOTE (doubleXP @ Dec 3 2006, 15:20) QUOT...   Dec 3 2006, 21:31
- - lextune   Thanks for all your work Josh   Dec 4 2006, 05:06
- - me7   To clear things up: The command line fix completel...   Dec 4 2006, 11:58
- - Synthetic Soul   I believe that is the idea, yes. The easiest way ...   Dec 4 2006, 12:16
- - Synthetic Soul   Discussion regarding decimal separator moved here.   Dec 4 2006, 14:42
- - jcoalson   first, to save time I'll say the answers by sy...   Dec 4 2006, 19:52
|- - Cartoon   QUOTE (jcoalson @ Dec 4 2006, 20:52) , wh...   Dec 6 2006, 12:06
- - dv1989   Can you not update the download on the page and ad...   Dec 4 2006, 21:49
- - Jose Hidalgo   I agree : strict procedures are OK, but a bit of p...   Dec 4 2006, 23:53
- - Maurits   How about a 1.1.3a?   Dec 5 2006, 00:50
- - SoleBastard   I wanted to check out the 'better multichannel...   Dec 5 2006, 06:28
|- - Egor   QUOTE (SoleBastard @ Dec 5 2006, 11:28) W...   Dec 5 2006, 06:54
|- - Mangix   QUOTE (Egor @ Dec 4 2006, 21:54) Besides ...   Dec 5 2006, 07:01
||- - Egor   QUOTE (Mangix @ Dec 5 2006, 12:01) erm, d...   Dec 5 2006, 07:20
||- - SoleBastard   QUOTE (Egor @ Dec 5 2006, 08:20) QUOTE (S...   Dec 5 2006, 07:26
|- - SoleBastard   Thanks Egor, that '--channel-map=none' opt...   Dec 5 2006, 07:07
- - jcoalson   note that if you use --channel-map=none, the incom...   Dec 5 2006, 17:22
- - Tung   What's the simplest way to re-encode FLAC file...   Dec 5 2006, 23:10
- - me7   The simplest way is foobar.   Dec 5 2006, 23:25
|- - ernstblaauw   QUOTE (me7 @ Dec 5 2006, 14:25) The simpl...   Dec 5 2006, 23:47
- - jcoalson   depends on the material but probably 0.5-1.0%   Dec 6 2006, 00:29
- - me7   This depends on the lenght of the album. I got an ...   Dec 6 2006, 00:30
- - Emanuel   QUOTE (Tung @ Dec 5 2006, 23:10) What...   Dec 6 2006, 01:26
|- - esa372   QUOTE (Tung @ Dec 5 2006, 14:10) What...   Dec 6 2006, 01:57
|- - GeSomeone   QUOTE (Emanuel @ Dec 6 2006, 02:26) Cut a...   Dec 6 2006, 12:27
|- - ernstblaauw   QUOTE (Emanuel @ Dec 5 2006, 16:26) QUOTE...   Dec 6 2006, 23:29
|- - MiSP   QUOTE (Emanuel @ Dec 6 2006, 02:26) QUOTE...   Sep 21 2007, 23:33
|- - Egor   QUOTE (MiSP @ Sep 22 2007, 05:33) Tested ...   Sep 22 2007, 08:34
|- - MiSP   QUOTE (Egor @ Sep 22 2007, 09:34) Try the...   Sep 22 2007, 16:04
- - Jose Hidalgo   I'd even say "Many people are currently b...   Dec 6 2006, 12:10
- - Emanuel   QUOTE (GeSomeone @ Dec 6 2006, 12:27) QUO...   Dec 6 2006, 12:46
- - WaldoMonster   (Moved to a new topic)   Dec 7 2006, 13:11
- - Emanuel   John33, does your compile of flac 1.1.3 over at Ra...   Jan 15 2007, 15:39
|- - john33   QUOTE (Emanuel @ Jan 15 2007, 14:39) John...   Jan 15 2007, 16:27
- - Martin H   Hi John33 I had just finished testing your first...   Jan 15 2007, 17:13
|- - john33   QUOTE (Martin H @ Jan 15 2007, 16:13) Hi ...   Jan 15 2007, 17:37
|- - jcoalson   QUOTE (john33 @ Jan 15 2007, 11:37) I inc...   Jan 15 2007, 21:58
- - Emanuel   QUOTE (john33 @ Jan 15 2007, 17:37) I inc...   Jan 15 2007, 20:42
- - hat3k   excuse me? can i make a feature request, i need me...   Jan 15 2007, 22:45
- - Martin H   @John33 I don't think that you have to make ...   Jan 15 2007, 23:07
- - john33   OK, guys, thanks for the feedback. I'll not bo...   Jan 15 2007, 23:24
- - Martin H   @Josh Coalson Do you know why the optimized(ICL9....   Jan 17 2007, 13:05
|- - Egor   QUOTE (Martin H @ Jan 17 2007, 18:05) Do ...   Jan 17 2007, 16:28
|- - Jose Hidalgo   QUOTE (Martin H @ Jan 17 2007, 13:05) Man...   Jan 17 2007, 18:08
|- - Martin H   QUOTE (Jose Hidalgo @ Jan 17 2007, 18:08)...   Jan 17 2007, 18:46
- - Martin H   Yes, i know that this is the explenation for lossy...   Jan 17 2007, 16:57
- - jcoalson   libFLAC still uses floating point for the LPC anal...   Jan 17 2007, 17:10
- - Martin H   @Josh Thank you very much for the explanation A...   Jan 17 2007, 17:19
- - Martin H   Sorry, for repeating my question, but just in case...   Jan 21 2007, 14:42
|- - Heliologue   QUOTE (Martin H @ Jan 21 2007, 07:42) Sor...   Jan 21 2007, 18:55
|- - Triza   QUOTE (Heliologue @ Jan 21 2007, 09:55) Q...   Sep 23 2007, 19:30
- - jcoalson   I feel your pain Martin! this has come up be...   Jan 21 2007, 17:58
|- - Martin H   QUOTE (jcoalson @ Jan 21 2007, 17:58) I f...   Jan 21 2007, 19:11
- - Jose Hidalgo   Wow ! A 20-year old bug ! Amazing ! ...   Jan 21 2007, 18:58
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 4th May 2015 - 01:07
