foo_discogs, Tags files with information from Discogs
bubbleguuum
post Nov 26 2006, 22:58
Features:
- tag files using discogs data. Retrieve more info than most taggers. Goes to extra length to make sure retrieve data is correct and well formatted
- flexible tag mapping allows you to write only what you want where you want
- use of meta data in tags to display artist / label / release discogs www page
- able to later update specified tags (useful to update rating)
current version: 1.32
Download foo_discogs 1.32
Documentation (thanks Bachi-Bouzouk)
find release dialog screenshot (v0.90)
screenshot illustrating use of discogs data
GdiPlus.dll is a dependency, however if you use some recent version of Windows you already have it.
If you're using fb2k under wine (Linux) you'll need to copy GdiPlus.dll in fb2k root directory.
This post has been edited by bubbleguuum: Feb 5 2014, 17:13
orchid
post Dec 11 2006, 15:21
Any concrete example of situation you'd like to edit discogs data ?
Main reason would be this new ANV system (good example http://www.discogs.com/release/338567). A variety of names for same artist messes up searches, foo_browse etc. Also Discogs is full of typos but they don't bother me that much, might someone else.
Can you explain more, I did not understand
Sorry never mind. Didn't notice adding discogs menu commands to buttons is already possible wink.gif
bubbleguuum
post Dec 11 2006, 19:56
The parser alerady detects ANV to discard "*" appended to them, although I don't make use of this info for anything else. What I thought some time ago and would be could in the case of the artist being an ANV, let the user choose between the ANV or the Non-ANV name of the artist. Even a configuration settings to automaticcaly use the non-ANV artist name could be done. Anyway there's no harm to make the fields editable (except track names) and i'll think about it.
Now I have a question for you people. If foo_discogs could use foo_custominfo to store tags (customizable per tag) would you use that ? for which use scenario and which tags ?
I see more iconvenient to storing using foo_custominfo, especially because it's usable only with foobar and if you loose the database you loose the tags
QUOTE (mquander @ Dec 11 2006, 17:16) *
Your parser chokes on this, but I don't blame it.
nice find! no wonder the parser goes berserk!
This post has been edited by bubbleguuum: Dec 11 2006, 19:55
mquander
post Dec 11 2006, 21:37
This doesn't seem to get an "Album Artist" tag. Shouldn't it? (Nevermind that the artists are all fake aliases of Bogdan anyway.)
bubbleguuum
post Dec 11 2006, 21:52
QUOTE (mquander @ Dec 11 2006, 21:37) *
Fixed in upcoming version. Actually you have Album Artist written if the main artist is made of several artists, or if Album="Various" or if in the tracklisting there's at least a track with two artists. This is not the case for this release so the last test is more like "has a least a track with *one* artist"
This post has been edited by bubbleguuum: Dec 11 2006, 21:52
- bubbleguuum   foo_discogs   Nov 26 2006, 22:58
- - mquander   May I be the first one to extend my great thanks f...   Nov 26 2006, 23:01
|- - mquander   First impressions: Easy problem: Perhaps add the...   Nov 26 2006, 23:26
|- - bubbleguuum   QUOTE (mquander @ Nov 26 2006, 23:26) Fir...   Nov 26 2006, 23:34
|- - pawls   Woho! Letīs try it out. Iīll report my thought...   Nov 27 2006, 00:05
- - alphaex32   Thank you so much for this. Could you add support ...   Nov 27 2006, 01:40
|- - bubbleguuum   QUOTE (alphaex32 @ Nov 27 2006, 01:40) Th...   Nov 27 2006, 13:20
- - saberrider   Sounds great. But I guess I'll wait for custom...   Nov 27 2006, 01:42
- - eejadx   Thanks, great component. One small bug with files...   Nov 27 2006, 02:05
- - alphaex32   Id like to have genre enabled, if its not too much...   Nov 27 2006, 14:50
|- - eejadx   QUOTE (alphaex32 @ Nov 27 2006, 08:50) Id...   Nov 27 2006, 15:00
- - stampgevaar   this is a very nice idea but is it also possible i...   Nov 27 2006, 15:04
|- - bubbleguuum   QUOTE (stampgevaar @ Nov 27 2006, 15:04) ...   Nov 27 2006, 19:42
|- - stampgevaar   QUOTE (bubbleguuum @ Nov 27 2006, 19:42) ...   Nov 27 2006, 21:08
- - zachastrife   How does this do with releases with multiple discs...   Nov 27 2006, 15:59
|- - bubbleguuum   QUOTE (zachastrife @ Nov 27 2006, 15:59) ...   Nov 27 2006, 19:46
|- - _eclectic_   QUOTE Failed to load DLL: foo_discogs.dll Reason: ...   Nov 27 2006, 23:24
- - _eclectic_   Getting the following message upon startup: Faile...   Nov 27 2006, 17:23
|- - pawls   I think Tracknumber and Vinylnumber should be sepa...   Nov 27 2006, 19:43
- - metal_termite   Yay, you rule. Add support for allmusic.com too...   Nov 27 2006, 19:58
- - pawls   One more thing: please add keyboard shortcuts in s...   Nov 27 2006, 20:01
- - nilsHaus   QUOTE (eejadx @ Nov 27 2006, 09:00) QUOTE...   Nov 27 2006, 21:22
|- - bubbleguuum   QUOTE (nilsHaus @ Nov 27 2006, 21:22) QUO...   Nov 27 2006, 23:48
- - TheTravis   Thanks for this great plugin! I just tagged so...   Nov 27 2006, 22:25
- - nilsHaus   QUOTE (bubbleguuum @ Nov 27 2006, 17:48) ...   Nov 28 2006, 21:09
- - mquander   I'd just like to note this album, on which the...   Nov 29 2006, 03:29
|- - mquander   The plugin errors out when looking up tags for htt...   Nov 29 2006, 10:24
|- - bubbleguuum   QUOTE (mquander @ Nov 29 2006, 10:24) The...   Nov 29 2006, 13:59
- - bubbleguuum   Version 0.2 is OUT. See first post for changelog ...   Dec 3 2006, 03:57
|- - Decuman   Isn't it for v.0.9.4.2? I got this message: F...   Dec 3 2006, 08:17
- - alphaex32   Thank you so much for this I'd still like to ...   Dec 3 2006, 06:08
- - roentgen   2Decuman Check again the first post of this thread...   Dec 3 2006, 08:59
|- - Decuman   Oh, yeah. My bad... I just didn't notice it is...   Dec 3 2006, 11:15
|- - bubbleguuum   0.21 released ! this version add basic album...   Dec 3 2006, 17:56
- - Ronny Pries   wicked!!! ! !! !!...   Dec 3 2006, 18:51
- - stampgevaar   nice work mate really you just saved me a lot of w...   Dec 3 2006, 19:07
- - hiscores   Bubbleguuum: you're my hero. This is AMAZING.   Dec 3 2006, 19:27
- - hiscores   One small suggestion: it'd be really nice to h...   Dec 3 2006, 19:39
|- - bubbleguuum   QUOTE (hiscores @ Dec 3 2006, 19:39) One ...   Dec 3 2006, 19:55
|- - hiscores   QUOTE In a future version it'll be possible to...   Dec 3 2006, 21:29
- - hotzenpl0tz   You probably knew something like this would be req...   Dec 3 2006, 19:47
- - orchid   Hi and thanks for great plugin QUOTE (alphaex32 ...   Dec 5 2006, 17:44
|- - AntiLynd   Thanks for this awesome plugin! I really love ...   Dec 5 2006, 18:10
|- - bubbleguuum   QUOTE (orchid @ Dec 5 2006, 17:44) Hi and...   Dec 5 2006, 20:04
|- - alphaex32   Personally, I would just fill the "style...   Dec 5 2006, 20:22
- - stampgevaar   that's a fact and also make the fields editabl...   Dec 5 2006, 18:44
|- - bubbleguuum   QUOTE (stampgevaar @ Dec 5 2006, 18:44) t...   Dec 5 2006, 19:56
- - stampgevaar   It's not the parser for the typos I'm sure...   Dec 5 2006, 20:00
- - stampgevaar   I was thinking, if you make the album covers downl...   Dec 6 2006, 21:13
|- - bubbleguuum   QUOTE (stampgevaar @ Dec 6 2006, 21:13) I...   Dec 6 2006, 23:35
|- - mquander   Haha, I know you just changed this in the last ver...   Dec 7 2006, 11:56
||- - bubbleguuum   QUOTE (mquander @ Dec 7 2006, 11:56) Haha...   Dec 7 2006, 15:18
|- - stampgevaar   QUOTE (bubbleguuum @ Dec 6 2006, 23:35) Q...   Dec 7 2006, 12:25
- - hiscores   I prefer double digit, please!   Dec 7 2006, 15:20
- - pawls   Single digit for me Two suggestions/wishes: - T...   Dec 7 2006, 17:43
|- - mquander   QUOTE (pawls @ Dec 7 2006, 11:43) Single ...   Dec 7 2006, 17:59
|- - bubbleguuum   QUOTE (pawls @ Dec 7 2006, 17:43) Single ...   Dec 7 2006, 18:12
- - stampgevaar   CODE Illegal operation: Code: C0000005h, flags: 00...   Dec 7 2006, 18:00
|- - bubbleguuum   QUOTE (stampgevaar @ Dec 7 2006, 18:00) I...   Dec 7 2006, 18:37
|- - stampgevaar   QUOTE (bubbleguuum @ Dec 7 2006, 18:37) Q...   Dec 7 2006, 20:08
|- - bubbleguuum   QUOTE (stampgevaar @ Dec 7 2006, 20:08) a...   Dec 7 2006, 20:35
- - 2Pacalypse   I've not actually used this plugin yet but its...   Dec 7 2006, 18:30
|- - 2Pacalypse   QUOTE (2Pacalypse @ Dec 7 2006, 17:30) I...   Dec 7 2006, 19:38
- - pawls   QUOTE (bubbleguuum @ Dec 7 2006, 18:12) T...   Dec 7 2006, 19:36
- - orchid   QUOTE (bubbleguuum @ Dec 5 2006, 21:04) M...   Dec 8 2006, 10:46
|- - bubbleguuum   QUOTE (orchid @ Dec 8 2006, 10:46) QUOTE ...   Dec 8 2006, 13:32
- - Scheisen2000   Hey bubbleguuum, your plug-in sounds very interes...   Dec 8 2006, 13:39
- - Scheisen2000   it's up again tnx alot   Dec 8 2006, 16:48
|- - bubbleguuum   V0.25 IS OUT. See first post for changelog. It wi...   Dec 9 2006, 22:33
- - mquander   Hey, when I tag this release, I get: VINYLTRACK: ...   Dec 10 2006, 00:00
|- - bubbleguuum   QUOTE (mquander @ Dec 10 2006, 00:00) Hey...   Dec 10 2006, 00:35
|- - hiscores   QUOTE (bubbleguuum @ Dec 9 2006, 18:35) M...   Dec 10 2006, 01:06
|- - bubbleguuum   QUOTE (hiscores @ Dec 10 2006, 01:06) QUO...   Dec 10 2006, 01:25
|- - hiscores   QUOTE (bubbleguuum @ Dec 9 2006, 19:25) y...   Dec 10 2006, 01:28
|- - bubbleguuum   QUOTE (hiscores @ Dec 10 2006, 01:28) QUO...   Dec 10 2006, 01:36
|- - hiscores   QUOTE (bubbleguuum @ Dec 9 2006, 19:36) f...   Dec 10 2006, 02:22
- - hiscores   The retrieve album art functionality crashes my Fo...   Dec 10 2006, 00:22
- - bubbleguuum   Just released v0.26 which fixes a few bugs of 0.25   Dec 10 2006, 01:53
- - iOsiris   Shows promise, this database even has some asian s...   Dec 10 2006, 02:18
- - drbeachboy   I'm getting this error message in foobar2000_v...   Dec 10 2006, 03:45
- - c0utta   drbeachboy, As per the first post, make sure that...   Dec 10 2006, 05:25
|- - drbeachboy   QUOTE (c0utta @ Dec 9 2006, 23:25) drbeac...   Dec 10 2006, 16:54
- - mquander   Hah, it still does it! Tagging this release g...   Dec 10 2006, 11:38
- - orchid   Thanks for the fast update Working smoothly exce...   Dec 10 2006, 12:34
|- - mquander   QUOTE (orchid @ Dec 10 2006, 06:34) EDIT:...   Dec 10 2006, 15:19
|- - bubbleguuum   QUOTE (mquander @ Dec 10 2006, 15:19) QUO...   Dec 10 2006, 15:45
- - stampgevaar   Is it safe to start tagging my whole collection wi...   Dec 10 2006, 15:11
- - orchid   QUOTE (bubbleguuum @ Dec 10 2006, 16:39) ...   Dec 10 2006, 15:51
|- - mquander   QUOTE (orchid @ Dec 10 2006, 09:51) QUOTE...   Dec 10 2006, 16:20
|- - bubbleguuum   QUOTE (orchid @ Dec 10 2006, 15:51) Could...   Dec 10 2006, 17:44
- - bubbleguuum   V0.27 is out, see first post as usual for changes....   Dec 10 2006, 21:24
- - orchid   Bugs: - 'album artist' still not written o...   Dec 11 2006, 12:35
|- - mquander   QUOTE (orchid @ Dec 11 2006, 06:35) Bugs:...   Dec 11 2006, 13:19
|- - bubbleguuum   QUOTE (orchid @ Dec 11 2006, 12:35) Bugs:...   Dec 11 2006, 13:33
- - orchid   QUOTE Any concrete example of situation you'd ...   Dec 11 2006, 15:21
|- - bubbleguuum   QUOTE Main reason would be this new ANV system (go...   Dec 11 2006, 19:56
|- - mquander   This doesn't seem to get an "Album Artist...   Dec 11 2006, 21:37
|- - bubbleguuum   QUOTE (mquander @ Dec 11 2006, 21:37) Thi...   Dec 11 2006, 21:52
|- - mquander   QUOTE (bubbleguuum @ Dec 11 2006, 15:52) ...   Dec 11 2006, 22:13
- - mquander   Your parser chokes on this, but I don't blame ...   Dec 11 2006, 17:16
19 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 28th July 2015 - 05:18
