foo_discogs, Tags files with information from Discogs
bubbleguuum
post Nov 26 2006, 22:58
Features:
- tag files using discogs data. Retrieve more info than most taggers. Goes to extra length to make sure retrieve data is correct and well formatted
- flexible tag mapping allows you to write only what you want where you want
- use of meta data in tags to display artist / label / release discogs www page
- able to later update specified tags (useful to update rating)
current version: 1.32
Download foo_discogs 1.32
Documentation (thanks Bachi-Bouzouk)
find release dialog screenshot (v0.90)
screenshot illustrating use of discogs data
GdiPlus.dll is a dependency, however if you use some recent version of Windows you already have it.
If you're using fb2k under wine (Linux) you'll need to copy GdiPlus.dll in fb2k root directory.
This post has been edited by bubbleguuum: Feb 5 2014, 17:13
zachastrife
post Nov 27 2006, 15:59
How does this do with releases with multiple discs?
I use the %discnumber% tag...
And when handling many directories (which is how i handle multiple discs) it should sort the files with the full path instead of the filename (making it easier to match files without needing to use the move function over and over again).
This post has been edited by zachastrife: Nov 27 2006, 16:00
bubbleguuum
post Nov 27 2006, 19:46
QUOTE (zachastrife @ Nov 27 2006, 15:59) *
good ideas here, with some work the %discnumber% tag could be autodetected
QUOTE (_eclectic_ @ Nov 27 2006, 17:23) *
Getting the following message upon startup:
Failed to load DLL: foo_discogs.dll
I do have libcurl.dll in the foobar2000 root (didn't get it from your link, already had it), and am running foobar v0.9.4.1. Any idea what is wrong? libcurl.dll is version 7.15.1.
I din't tried it with 0.9.4.1 but it should be compatible...the problem is probably libcurl. Did you tried to replace your existing libcurl with the one linked in the first post to see if it works ?
- bubbleguuum   foo_discogs   Nov 26 2006, 22:58
- - mquander   May I be the first one to extend my great thanks f...   Nov 26 2006, 23:01
|- - mquander   First impressions: Easy problem: Perhaps add the...   Nov 26 2006, 23:26
|- - bubbleguuum   QUOTE (mquander @ Nov 26 2006, 23:26) Fir...   Nov 26 2006, 23:34
|- - pawls   Woho! Letīs try it out. Iīll report my thought...   Nov 27 2006, 00:05
- - alphaex32   Thank you so much for this. Could you add support ...   Nov 27 2006, 01:40
|- - bubbleguuum   QUOTE (alphaex32 @ Nov 27 2006, 01:40) Th...   Nov 27 2006, 13:20
- - saberrider   Sounds great. But I guess I'll wait for custom...   Nov 27 2006, 01:42
- - eejadx   Thanks, great component. One small bug with files...   Nov 27 2006, 02:05
- - alphaex32   Id like to have genre enabled, if its not too much...   Nov 27 2006, 14:50
|- - eejadx   QUOTE (alphaex32 @ Nov 27 2006, 08:50) Id...   Nov 27 2006, 15:00
- - stampgevaar   this is a very nice idea but is it also possible i...   Nov 27 2006, 15:04
|- - bubbleguuum   QUOTE (stampgevaar @ Nov 27 2006, 15:04) ...   Nov 27 2006, 19:42
|- - stampgevaar   QUOTE (bubbleguuum @ Nov 27 2006, 19:42) ...   Nov 27 2006, 21:08
- - zachastrife   How does this do with releases with multiple discs...   Nov 27 2006, 15:59
|- - bubbleguuum   QUOTE (zachastrife @ Nov 27 2006, 15:59) ...   Nov 27 2006, 19:46
|- - _eclectic_   QUOTE Failed to load DLL: foo_discogs.dll Reason: ...   Nov 27 2006, 23:24
- - _eclectic_   Getting the following message upon startup: Faile...   Nov 27 2006, 17:23
|- - pawls   I think Tracknumber and Vinylnumber should be sepa...   Nov 27 2006, 19:43
- - metal_termite   Yay, you rule. Add support for allmusic.com too...   Nov 27 2006, 19:58
- - pawls   One more thing: please add keyboard shortcuts in s...   Nov 27 2006, 20:01
- - nilsHaus   QUOTE (eejadx @ Nov 27 2006, 09:00) QUOTE...   Nov 27 2006, 21:22
|- - bubbleguuum   QUOTE (nilsHaus @ Nov 27 2006, 21:22) QUO...   Nov 27 2006, 23:48
- - TheTravis   Thanks for this great plugin! I just tagged so...   Nov 27 2006, 22:25
- - nilsHaus   QUOTE (bubbleguuum @ Nov 27 2006, 17:48) ...   Nov 28 2006, 21:09
- - mquander   I'd just like to note this album, on which the...   Nov 29 2006, 03:29
|- - mquander   The plugin errors out when looking up tags for htt...   Nov 29 2006, 10:24
|- - bubbleguuum   QUOTE (mquander @ Nov 29 2006, 10:24) The...   Nov 29 2006, 13:59
- - bubbleguuum   Version 0.2 is OUT. See first post for changelog ...   Dec 3 2006, 03:57
|- - Decuman   Isn't it for v.0.9.4.2? I got this message: F...   Dec 3 2006, 08:17
- - alphaex32   Thank you so much for this I'd still like to ...   Dec 3 2006, 06:08
- - roentgen   2Decuman Check again the first post of this thread...   Dec 3 2006, 08:59
|- - Decuman   Oh, yeah. My bad... I just didn't notice it is...   Dec 3 2006, 11:15
|- - bubbleguuum   0.21 released ! this version add basic album...   Dec 3 2006, 17:56
- - Ronny Pries   wicked!!! ! !! !!...   Dec 3 2006, 18:51
- - stampgevaar   nice work mate really you just saved me a lot of w...   Dec 3 2006, 19:07
- - hiscores   Bubbleguuum: you're my hero. This is AMAZING.   Dec 3 2006, 19:27
- - hiscores   One small suggestion: it'd be really nice to h...   Dec 3 2006, 19:39
|- - bubbleguuum   QUOTE (hiscores @ Dec 3 2006, 19:39) One ...   Dec 3 2006, 19:55
|- - hiscores   QUOTE In a future version it'll be possible to...   Dec 3 2006, 21:29
- - hotzenpl0tz   You probably knew something like this would be req...   Dec 3 2006, 19:47
- - orchid   Hi and thanks for great plugin QUOTE (alphaex32 ...   Dec 5 2006, 17:44
|- - AntiLynd   Thanks for this awesome plugin! I really love ...   Dec 5 2006, 18:10
|- - bubbleguuum   QUOTE (orchid @ Dec 5 2006, 17:44) Hi and...   Dec 5 2006, 20:04
|- - alphaex32   Personally, I would just fill the "style...   Dec 5 2006, 20:22
- - stampgevaar   that's a fact and also make the fields editabl...   Dec 5 2006, 18:44
|- - bubbleguuum   QUOTE (stampgevaar @ Dec 5 2006, 18:44) t...   Dec 5 2006, 19:56
- - stampgevaar   It's not the parser for the typos I'm sure...   Dec 5 2006, 20:00
- - stampgevaar   I was thinking, if you make the album covers downl...   Dec 6 2006, 21:13
|- - bubbleguuum   QUOTE (stampgevaar @ Dec 6 2006, 21:13) I...   Dec 6 2006, 23:35
|- - mquander   Haha, I know you just changed this in the last ver...   Dec 7 2006, 11:56
||- - bubbleguuum   QUOTE (mquander @ Dec 7 2006, 11:56) Haha...   Dec 7 2006, 15:18
|- - stampgevaar   QUOTE (bubbleguuum @ Dec 6 2006, 23:35) Q...   Dec 7 2006, 12:25
- - hiscores   I prefer double digit, please!   Dec 7 2006, 15:20
- - pawls   Single digit for me Two suggestions/wishes: - T...   Dec 7 2006, 17:43
|- - mquander   QUOTE (pawls @ Dec 7 2006, 11:43) Single ...   Dec 7 2006, 17:59
|- - bubbleguuum   QUOTE (pawls @ Dec 7 2006, 17:43) Single ...   Dec 7 2006, 18:12
- - stampgevaar   CODE Illegal operation: Code: C0000005h, flags: 00...   Dec 7 2006, 18:00
|- - bubbleguuum   QUOTE (stampgevaar @ Dec 7 2006, 18:00) I...   Dec 7 2006, 18:37
|- - stampgevaar   QUOTE (bubbleguuum @ Dec 7 2006, 18:37) Q...   Dec 7 2006, 20:08
|- - bubbleguuum   QUOTE (stampgevaar @ Dec 7 2006, 20:08) a...   Dec 7 2006, 20:35
- - 2Pacalypse   I've not actually used this plugin yet but its...   Dec 7 2006, 18:30
|- - 2Pacalypse   QUOTE (2Pacalypse @ Dec 7 2006, 17:30) I...   Dec 7 2006, 19:38
- - pawls   QUOTE (bubbleguuum @ Dec 7 2006, 18:12) T...   Dec 7 2006, 19:36
- - orchid   QUOTE (bubbleguuum @ Dec 5 2006, 21:04) M...   Dec 8 2006, 10:46
|- - bubbleguuum   QUOTE (orchid @ Dec 8 2006, 10:46) QUOTE ...   Dec 8 2006, 13:32
- - Scheisen2000   Hey bubbleguuum, your plug-in sounds very interes...   Dec 8 2006, 13:39
- - Scheisen2000   it's up again tnx alot   Dec 8 2006, 16:48
|- - bubbleguuum   V0.25 IS OUT. See first post for changelog. It wi...   Dec 9 2006, 22:33
- - mquander   Hey, when I tag this release, I get: VINYLTRACK: ...   Dec 10 2006, 00:00
|- - bubbleguuum   QUOTE (mquander @ Dec 10 2006, 00:00) Hey...   Dec 10 2006, 00:35
|- - hiscores   QUOTE (bubbleguuum @ Dec 9 2006, 18:35) M...   Dec 10 2006, 01:06
|- - bubbleguuum   QUOTE (hiscores @ Dec 10 2006, 01:06) QUO...   Dec 10 2006, 01:25
|- - hiscores   QUOTE (bubbleguuum @ Dec 9 2006, 19:25) y...   Dec 10 2006, 01:28
|- - bubbleguuum   QUOTE (hiscores @ Dec 10 2006, 01:28) QUO...   Dec 10 2006, 01:36
|- - hiscores   QUOTE (bubbleguuum @ Dec 9 2006, 19:36) f...   Dec 10 2006, 02:22
- - hiscores   The retrieve album art functionality crashes my Fo...   Dec 10 2006, 00:22
- - bubbleguuum   Just released v0.26 which fixes a few bugs of 0.25   Dec 10 2006, 01:53
- - iOsiris   Shows promise, this database even has some asian s...   Dec 10 2006, 02:18
- - drbeachboy   I'm getting this error message in foobar2000_v...   Dec 10 2006, 03:45
- - c0utta   drbeachboy, As per the first post, make sure that...   Dec 10 2006, 05:25
|- - drbeachboy   QUOTE (c0utta @ Dec 9 2006, 23:25) drbeac...   Dec 10 2006, 16:54
- - mquander   Hah, it still does it! Tagging this release g...   Dec 10 2006, 11:38
- - orchid   Thanks for the fast update Working smoothly exce...   Dec 10 2006, 12:34
|- - mquander   QUOTE (orchid @ Dec 10 2006, 06:34) EDIT:...   Dec 10 2006, 15:19
|- - bubbleguuum   QUOTE (mquander @ Dec 10 2006, 15:19) QUO...   Dec 10 2006, 15:45
- - stampgevaar   Is it safe to start tagging my whole collection wi...   Dec 10 2006, 15:11
- - orchid   QUOTE (bubbleguuum @ Dec 10 2006, 16:39) ...   Dec 10 2006, 15:51
|- - mquander   QUOTE (orchid @ Dec 10 2006, 09:51) QUOTE...   Dec 10 2006, 16:20
|- - bubbleguuum   QUOTE (orchid @ Dec 10 2006, 15:51) Could...   Dec 10 2006, 17:44
- - bubbleguuum   V0.27 is out, see first post as usual for changes....   Dec 10 2006, 21:24
- - orchid   Bugs: - 'album artist' still not written o...   Dec 11 2006, 12:35
|- - mquander   QUOTE (orchid @ Dec 11 2006, 06:35) Bugs:...   Dec 11 2006, 13:19
|- - bubbleguuum   QUOTE (orchid @ Dec 11 2006, 12:35) Bugs:...   Dec 11 2006, 13:33
- - orchid   QUOTE Any concrete example of situation you'd ...   Dec 11 2006, 15:21
|- - bubbleguuum   QUOTE Main reason would be this new ANV system (go...   Dec 11 2006, 19:56
|- - mquander   This doesn't seem to get an "Album Artist...   Dec 11 2006, 21:37
|- - bubbleguuum   QUOTE (mquander @ Dec 11 2006, 21:37) Thi...   Dec 11 2006, 21:52
|- - mquander   QUOTE (bubbleguuum @ Dec 11 2006, 15:52) ...   Dec 11 2006, 22:13
- - mquander   Your parser chokes on this, but I don't blame ...   Dec 11 2006, 17:16
17 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 31st March 2015 - 12:46
