Free utility to check all Wavpack files in a Directory., New Software Announcement
gl.tter
post Nov 21 2006, 20:09
Updated - latest version: 1.0 (now with shell extension)
I've released a little standalone Windows utility that will check single Wavpack files, or all .wv files contained in a directory tree or drive for errors:
http://wavpack.gl.tter.org
Easy two-click operation. It writes the full paths of any bad files found to a text file for further processing. Useful when eg. like me you ripped 1500+ files with an overheating CPU, and had to track down the few corrupted ones.
Bug reports welcome (here or email).
This post has been edited by gl.tter: Dec 31 2006, 21:38
Author of -Wavpack4Wavelab- and -CheckWavpackFiles-
Maglor
post Mar 23 2007, 14:57
Hi all! smile.gif I've been reading a lot of posts lately about bad blocks or crc errors on wavpack files, and I can't find the solution to my problem, which is: recently I've bought a new external drive where I've passed all my rips still on folders, not rar's, and many of them have now been corrupted when they weren't before that.
So now what I want is to recover those files, because many of those CD's that I've ripped aren't with me anymore. So is there a little something like this that could recover those wavpack files?
photographer
post Apr 2 2007, 21:38
Unfortunately I'm having a little difficulty. When I run CheckWavpackFiles_1.0 I get an error stating "# Couldn't read MD5 hash.". I use Easy CD DA to rip my audio to my hard drive. I've tried it with files that were ripped using both the latest and the previous WavPack .dll's.
gl.tter
post Apr 2 2007, 21:48
QUOTE (photographer @ Apr 2 2007, 20:38) *
Never had that error on any of my files. It could be a bug in the way Easy CD encodes Wavpack files. I don't use EasyCD, anybody else able to test it?
Try ripping to .wav and encoding with the Wavpack utilities. If that works, send an email to the EasyCD guys.
EDIT: also try verifying a bad file with the Wavpack utils (switch -v IIRC).
This post has been edited by gl.tter: Apr 2 2007, 21:49
photographer
post Apr 2 2007, 22:16
QUOTE (gl.tter @ Apr 2 2007, 15:48) *
Thanks for the prompt reply. I just installed WavPack 4.40 and Foobar 2000. Had it rip a single CD to a new directory and your utility verifies that all files are OK. I'll submit a bug report to the author of Easy CD-DA.
Thanks again. Good tool to have.
gl.tter
post Apr 2 2007, 23:35
QUOTE (photographer @ Apr 2 2007, 21:16) *
Cool, he's probably just writing the MD5 hash in slightly the wrong place (or maybe he's forgetting to write it altogether?).
It should be:
<pack all samples>
call WavpackStoreMD5Sum(...)
call WavpackFlushSamples()
(why do my new replies keep getting attached to my last reply??)
QUOTE (Maglor @ Mar 23 2007, 13:57) *
Maglor, it depends why the files are coming back corrupt. If there's a problem with the external drive's interface (USB?), then the files might actually be OK on the disc. If not, then the data really is corrupt and there's no getting it back.
Try connecting the external HD another way, or on another PC.
This post has been edited by gl.tter: Apr 2 2007, 23:34
bryant
post Apr 3 2007, 05:02
WavPack Developer
Group: Developer (Donating)
QUOTE (gl.tter @ Apr 2 2007, 15:35) *
It should be:
<pack all samples>
That will work fine but my documentation says:
  1. get a context and set block output function with WavpackOpenFileOutput()
  2. set the data format and specify modes with WavpackSetConfiguration()
  3. optionally write a RIFF header with WavpackAddWrapper()
  4. allocate buffers and prepare for packing with WavpackPackInit()
  5. actually compress audio and write blocks with WavpackPackSamples()
  6. flush final samples into blocks with WavpackFlushSamples()
  7. optionally write MD5 sum with WavpackStoreMD5Sum()
  8. optionally write RIFF trailer with WavpackAddWrapper()
  9. optionally append metadata tag with functions in next section
  10. optionally update number of samples with WavpackUpdateNumSamples()
  11. close the context with WavpackCloseFile()
which is actually wrong because the MD5 sum will not get written! There should be an additional step at 8.5 to call WavpackFlushSamples() again. Doh! sad.gif
Maybe a registered user should show this post to the author of Easy CD Extractor...
David
gl.tter
post Apr 3 2007, 12:37
QUOTE (bryant @ Apr 3 2007, 04:02) *
<snip>
The function name is confusing - people might easily assume that it's only required after packing the samples.
How about requiring the call only once (as you said it works anyway), and calling it 'FlushStream' or 'FlushData' instead?
Is that sarcasm or true? smile.gif If it's a feature, how do I turn it off?
bryant
post Apr 4 2007, 04:22
WavPack Developer
QUOTE (gl.tter @ Apr 3 2007, 04:37) *
<snip>
Well, there actually is an odd case where the call would be required twice. If the audio only consumes a single WavPack block then the additional flush is required to make sure that the RIFF header and trailer are not in the same block. Not very likely, but possible...
And, of course, you know I'm not going to rename the function, B! smile.gif But I will update the docs.
I haven't tried to turn it off (because I like it), but I think that the button labelled "+ QUOTE" with the tooltip "Toggle multiquote addition" might do it.
QUOTE (photographer @ Apr 3 2007, 10:52) *
The author of the software has made the corrections that you noted and has published a link to the updated .dll's in the thread at : http://www.poikosoft.com/forum/viewtopic.php?p=2573#2573 . Thanks very much for your help and your great softwares.
Thanks for the link, but unfortunately only registered users can access that page. Does it seem to fix the problem?
Thanks,
David
gl.tter
post Apr 5 2007, 13:43
QUOTE (bryant @ Apr 4 2007, 03:22) *
Ah OK, but couldn't all this be automated behind the scenes somehow?
Stubborn to the last smile.gif. Seriously, the guy most likely got it wrong because he went by the function name, not the docs. At least pencil it in when you really have to rename one in the future.
Thanks, I was trying to avoid a situation where people only get notified of the first reply's text, and then not notified of additional chunks (not sure if that actually happens).
- gl.tter   Free utility to check all Wavpack files in a Directory.   Nov 21 2006, 20:09
- - Remedial Sound   Handy little app! I just scanned a few album ...   Nov 21 2006, 20:22
|- - gl.tter   QUOTE (Remedial Sound @ Nov 21 2006, 20:2...   Nov 21 2006, 20:31
|- - guruboolez   That's great. I crossed my fingers and hoped t...   Nov 21 2006, 20:51
|- - jaybeee   QUOTE (guruboolez @ Nov 21 2006, 19:51) T...   Nov 23 2006, 11:30
- - ssjkakaroto   Thanks gl.tter. Synthetic Soul did something simil...   Nov 21 2006, 20:25
- - DARcode   Nice handy little proggy, pretty useful, many than...   Nov 21 2006, 21:47
|- - gl.tter   QUOTE (DARcode @ Nov 21 2006, 21:47) Nice...   Nov 21 2006, 22:59
- - Synthetic Soul   QUOTE (ssjkakaroto @ Nov 21 2006, 19:25) ...   Nov 22 2006, 08:35
|- - gl.tter   QUOTE (Synthetic Soul @ Nov 22 2006, 08:3...   Nov 22 2006, 15:19
- - DrazardX   Wow. This is really nice. I'm obviously not ...   Nov 23 2006, 10:22
- - guruboolez   flactester: http://www.vuplayer.com/other.php   Nov 23 2006, 12:39
|- - jaybeee   QUOTE (guruboolez @ Nov 23 2006, 11:39) f...   Nov 23 2006, 13:31
|- - gl.tter   If the program crashes as soon as you run it, you...   Nov 24 2006, 01:10
|- - gl.tter   New version uploaded. See the site for changes: ...   Nov 25 2006, 20:42
- - DARcode   Thank you. Have you noticed than even when it rea...   Nov 28 2006, 03:10
|- - gl.tter   QUOTE (DARcode @ Nov 28 2006, 03:10) Than...   Nov 28 2006, 15:08
|- - DARcode   QUOTE (gl.tter @ Nov 28 2006, 16:08) QUOT...   Nov 28 2006, 20:29
|- - gl.tter   QUOTE (DARcode @ Nov 28 2006, 20:29) Wow,...   Nov 28 2006, 20:57
- - askoff   Does anyone else have problems with this utility g...   Nov 29 2006, 14:33
|- - DARcode   QUOTE (askoff @ Nov 29 2006, 15:33) Does ...   Nov 29 2006, 15:21
|- - gl.tter   QUOTE (askoff @ Nov 29 2006, 14:33) Does ...   Nov 29 2006, 16:06
|- - askoff   QUOTE (gl.tter @ Nov 29 2006, 17:06) Any ...   Nov 29 2006, 19:32
- - askoff   It took more than couple of days for me to test wi...   Dec 13 2006, 10:39
|- - disintegrated   Hi gl.tter, is Win98 SE supported by CheckWavpac...   Dec 13 2006, 12:08
|- - gl.tter   QUOTE (disintegrated @ Dec 13 2006, 12:08...   Dec 13 2006, 18:02
|- - disintegrated   QUOTE (gl.tter @ Dec 13 2006, 18:02) QUOT...   Dec 13 2006, 19:04
||- - gl.tter   QUOTE (disintegrated @ Dec 13 2006, 19:04...   Dec 13 2006, 21:23
||- - gl.tter   New version uploaded (see 1st post). The files no...   Dec 13 2006, 21:47
|- - collector   QUOTE (gl.tter @ Dec 13 2006, 09:02) QUOT...   Jan 12 2007, 15:37
- - disintegrated   QUOTE (gl.tter @ Dec 13 2006, 21:23) QUOT...   Dec 15 2006, 21:44
|- - gl.tter   QUOTE (disintegrated @ Dec 15 2006, 21:44...   Dec 15 2006, 23:18
|- - gl.tter   0.97b RC1 released. Now includes the new Wavpack ...   Dec 18 2006, 22:41
- - satorippoi   Hey, gl.tter, just wanted to let you know that you...   Dec 23 2006, 01:14
|- - gl.tter   QUOTE (satorippoi @ Dec 23 2006, 01:14) H...   Dec 26 2006, 01:43
- - ssjkakaroto   Hi gl.tter, can you add non-ascii support to your ...   Dec 26 2006, 02:16
|- - gl.tter   QUOTE (ssjkakaroto @ Dec 26 2006, 02:16) ...   Dec 26 2006, 04:10
- - ssjkakaroto   Thanks a lot gl.tter, that'll work for me sinc...   Dec 26 2006, 16:02
- - gl.tter   Managed to squeeze 1.0 in the last few hours of ...   Dec 31 2006, 21:40
- - xequence   Very very usefull program, thanks alot   Feb 24 2007, 02:49
- - Maglor   Hi all! I've been reading a lot of posts...   Mar 23 2007, 14:57
|- - photographer   Unfortunately I'm having a little difficulty. ...   Apr 2 2007, 21:38
|- - gl.tter   QUOTE (photographer @ Apr 2 2007, 20:38) ...   Apr 2 2007, 21:48
|- - photographer   QUOTE (gl.tter @ Apr 2 2007, 15:48) QUOTE...   Apr 2 2007, 22:16
|- - gl.tter   QUOTE (photographer @ Apr 2 2007, 21:16) ...   Apr 2 2007, 23:35
|- - bryant   QUOTE (gl.tter @ Apr 2 2007, 15:35) Cool,...   Apr 3 2007, 05:02
|- - gl.tter   QUOTE (bryant @ Apr 3 2007, 04:02) That w...   Apr 3 2007, 12:37
|- - bryant   QUOTE (gl.tter @ Apr 3 2007, 04:37) QUOTE...   Apr 4 2007, 04:22
|- - gl.tter   QUOTE (bryant @ Apr 4 2007, 03:22) Well, ...   Apr 5 2007, 13:43
|- - photographer   QUOTE (bryant @ Apr 3 2007, 22:22) QUOTE ...   Apr 18 2007, 23:34
- - photographer   Gentlemen, The author of the software has made th...   Apr 3 2007, 18:52
- - sn0wman   hello, i am curious about one thing. it is written...   Apr 5 2007, 11:46
|- - gl.tter   QUOTE (sn0wman @ Apr 5 2007, 10:46) <s...   Jun 5 2007, 19:48
- - SnTholiday   Hi, Is the shell ext meant to work with Vista? I ...   Mar 19 2008, 20:28
- - gl.tter   QUOTE (SnTholiday @ Mar 19 2008, 19:28) I...   Mar 20 2008, 10:32
- - SnTholiday   I've tried several times to get the shell ext ...   Mar 21 2008, 04:29
- - gl.tter   QUOTE (SnTholiday @ Mar 21 2008, 03:29) I...   Mar 21 2008, 08:40
- - SnTholiday   No, it does not work in Vista's Explorer. Sinc...   Mar 22 2008, 00:19
- - gl.tter   QUOTE (SnTholiday @ Mar 21 2008, 23:19) N...   Mar 22 2008, 07:28
- - gl.tter   I've released a new 2.0 version (currently in ...   Aug 9 2008, 11:47
RSS Lo-Fi Version Time is now: 29th January 2015 - 11:26
